HDMR-19-02-S-SM-TR
HDMR-19-02-S-SM-TR
    SAMTEC(申泰)
    SMD,P=0.5mm,卧贴
    HDMI连接器 19Pin SMD,P=0.5mm,卧贴
HDMR-19-02-S-SM-TR 数据手册
F-217 SUPPLEMENT HDMR–19–01–S–SM–PF HDMR–29–01–S–SM HDMR–19–02–S–SM HDMR SERIES HIGH-SPEED I/O RECEPTACLES Meets Digital Display Working Group Single Monitor Interface Specifications SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?HDMR Insulator Material: High Temperature Thermoplastic Contact Material: Copper Alloy Shell Material: Steel Operating Temp Range: -25 °C to +85 °C Plating: Gold on Contacts, Nickel on Shell and Tin on Tails Current Rating: 1.3 A per pin (6 adjacent pins powered) Voltage Rating: 40 VAC Contact Resistance: 30 mW Minimum Cycles: 100 Lead-Free Solderable: Yes RoHS Compliant: Yes Hot Pluggable Selectively Plated • Panel flange option NO. OF POSITIONS HDMR –29 = Surface Mount Ground Tails (-19 only) A (2.20) .087 (4.55) .179 –01 –19 –29 A (4.60) .181 –19–01–PF TAIL OPTION –S = Surface Mount (Signal Leads) (1.20) .047 (2.00) .079 OPTIONS –SM = 30 µ" (0.76 µm) Gold on Mating Area, Tin on Tails 01 (6.18) .243 (15.00) .591 (22.30) .878 (9.98) .393 (0.50) .020 –02 Through-hole or Surface Mount (19 only) Ground tails Surface Mount or Through-hole Signal Leads PLATING –01 = Through-hole Ground Tails = 29 Positions / Mates with HPXXX 8 Pairs NO. OF POSITIONS LEAD STYLE –19 = 19 Positions / Mates with HPXXX 5 Pairs Note: Some lengths, styles and options are non-standard, non-returnable. 19 or 29 Positions • Locking option OTHER SOLUTIONS HDMP is an Edge Mount plug that mates to HDMR receptacles. Call Samtec for HDMP Series specifications. Optional Panel Flange (19 position only) (4.55) .179 (8.00) 02 .315 (17.20) .677 –TH = Through-hole (Only available on HDMR–19–01–X– TH–PF–L) (1.60) .062 –02 (Leave Blank for no Panel Flange) –PF = Panel Flange –L = Locking Option (Only available on HDMR–19–01–X– TH–PF–L) (6.18) .243 (1.20) .047 (0.76) .030 (7.50) .295 (16.05) .632 (5.96) .235 (0.35) .014 (7.20) .283 (0.50) .020 (2.80) .110 (4.60) .181 (9.00) .354 –19–01–PF–L WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –19–02–PF (5.96) .235
HDMR-19-02-S-SM-TR 价格&库存
很抱歉,暂时无法提供与“HDMR-19-02-S-SM-TR”相匹配的价格&库存,您可以联系我们找货
HDMR-19-02-S-SM-TR
  • 275+36.63779275+4.75373
库存:783
HDMR-19-02-S-SM-TR
  • 1+65.655181+8.51871
  • 10+55.7744010+7.23669
  • 25+52.2756425+6.78272
  • 50+49.7798650+6.45890
  • 100+47.40323100+6.15053
库存:783
HDMR-19-02-S-SM-TR
    • 1+42.55200
    • 10+41.31000
    • 30+40.47840
    库存:10
