DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
REVISION P
UPS-XX-XX.X-XX-X-XX-XX-XX
No. OF POSITIONS
-02: 2 POSITIONS
-04: 4 POSITIONS
-06: 6 POSITIONS
-08: 8 POSITIONS
"B" REF
DO NOT
SCALE FROM
THIS PRINT
3.81 .150
REF (TYP)
CL
01
5.00 .197
REF
FIG 1
+.005
CL
1.25 .049
TAIL OPTION
-V: VERTICAL
-PV: PRESS-FIT VERTICAL
(ONLY AVAILABLE ON -03
TAIL LENGTH)
PLATING
-03: PRESS-FIT FOR 1.57(.062) THICK PCB AND UP
(USE SUB-C-341-XX.X-X)(SEE FIG. 3)
(ONLY AVAILABLE WITH -PV)
(SEE NOTE 7)
(UPS-04-04.0-01-X-V SHOWN)
+0.13
(ONLY AVAILABLE WITH -V)
TAIL LENGTH
-01: FOR 1.57[.062] THICK PCB (SEE FIG. 1)
(USE SUB-C-258-XX.XX-01-X)
-02: FOR 2.36[.093] THICK PCB (SEE FIG. 2)
(USE SUB-C-258-XX.XX-02-X)
"C" REF
C
OPTION
-LC: LOCKING CLIP
HEIGHT
-04.0: (USE SUB-C-258-04.0-XX-X)
(SEE FIG. 1)
-07.0: (USE SUB-C-258-07.0-XX-X)
(SEE FIG. 2)
7.00 .276
REF
"D"
1.69 - 0.05 .067 - .002
PACKAGING
BLANK: TUBES (SEE NOTE 6 & 8)
-TR: TAPE & REEL (SEE NOTES 8 & 9)
-FR: FULL REEL QTY TAPE & REEL
(SEE NOTES 8 & 9)
3.75 .148
"A"
REF
UPS-XX-XX.X-V
6.75 REF
REF
-L: 10 µ" SELECTIVE GOLD IN
CONTACT AREA, MATTE TIN ON TAIL
-T: MATTE TIN CONTACT AND TAIL
3.75 REF
"A"
"A" REF
0.30 .012
REF (TYP)
C
C
2.00 .079
"F"±0.20
SUB-C-258-XX.X-XX-X
1.00 .039
REF
0.40 .016
REF (TYP)
2.00±0.20 .079±.008
1.50 .059
REF (TYP)
"E"
SECTION "A"-"A"
(TYP)
NOTES:
1.
2.
3.
4.
5.
6.
7.
C
REPRESENTS A CRITICAL DIMENSION.
NOTE DELETED.
MINIMUM PUSHOUT FORCE: 4.45N[1.0 LB].
MAXIMUM BOW: 0.15[.006].
MINIMUM -LC PULL OUT FORCE: 2.23 N [0.5 LB]
TUBES ARE STANDARD PACKAGING.
APPLICATION TOOLING REQUIRED FOR PV TAIL LENGTH.
CONTACT IPG. FLAT BAR TOOLING FOR THE UPPER TOOL
MAY BE USED. REFERENCE DIMENSION "C" MINUS 1.25MM
FOR LENGTH, 7.00MM FOR WIDTH, AND 3.5MM FOR HEIGHT.
8. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC
PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM.
9. ATTACH LABEL TO EACH REEL.
2.00 .079
REF
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
PROPRIETARY NOTE
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
ANGLES
X.X: 0.3 [.01]
2
X.XX: 0.13 [.005]
X.XXX: 0.051 [.0020]
MATERIAL:
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, COLOR: BLACK
CONTACT: BeCu
LOCKING CLIP: PHOS BRONZE
SHEET SCALE: 2.5:1
DESCRIPTION:
UPS-V, ASSEMBLY
DWG. NO.
F:\DWG\MISC\MKTG\UPS-XX-XX.X-XX-X-XX-XX-XX-MKT.SLDDRW
BY:
B RAY
07-12-2010
SHEET 1 OF 2
REVISION P
FIG 2
(UPS-04-07.0-02-X-V-LC SHOWN)
(SAME AS FIG. 1 EXCEPT AS SHOWN)
PACKAGING VIEW
(ASSEMBLIES TO HAVE POSITION #1 LOADED IN
THE SAME DIRECTION AS ARROW ON TUBE)
9.75 .384
REF
6.75 .266
REF
1.38 .054
C
PT-1-24-01-123
LC-07-TM
0.25 .010
REF
2 MAX SWAY
(TYP)
"A"
(SEE TABLE 1, SHT 1)
1.42 .056
REF
2.00 .079
C
FIG 3
(UPS-04-04.0-03-X-PV SHOWN)
PT-1-24-15-29
UPS-XX-XX.X-V-LC
C-341-XX.X-X
0.78 .031
REF (TYP)
PACKAGING TABLE
HEIGHT
PACKAGING TUBE
PLUG
-04
PT-1-24-01-123
TP-07
-07
PT-1-24-15-29
TP-07
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
SHEET SCALE: 3:1
DESCRIPTION:
UPS-V, ASSEMBLY
DWG. NO.
BY:
B RAY
07-12-2010
SHEET 2 OF 2
很抱歉,暂时无法提供与“UPS-04-07.0-01-L-V”相匹配的价格&库存,您可以联系我们找货
