SR1206FR-7T1KL
SR1206FR-7T1KL
    YAGEO(国巨)
    1KΩ ±1% 750MW
SR1206FR-7T1KL 数据手册
DATA SHEET AUTOMOTIVE GRADE SURGE CHIP RESISTORS SR series 20%, 10%, 5% 1%, 0.5% sizes 0201/0402/0603/0805/1206/1210/1218/2010/2512 Product specification – February 14, 2025 V.14 RoHS compliant & Halogen free 2 Product specification Chip Resistor Surface Mount SR 0201/0402/0603/0805/1206/1210/1218/2010/2512 SERIES 12 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes SR0201 to SR2512 chip resistors with lead-free terminations made by thick film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. APPLICATIONS ⚫ Telecommunications ⚫ Power supplies ⚫ Car electronics GLOBAL PART NUMBER SR XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201 / 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE D = ± 0.5% FEATURES ⚫ AEC-Q200 qualified ⚫ Superior to RC series in pulse withstanding voltage and surge withstanding voltage. ⚫ MSL class: MSL 1 ⚫ Halogen free epoxy ⚫ RoHS compliant - - Products with lead-free terminations meet RoHS requirements Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS ⚫ Reduce environmentally hazardous waste ⚫ High component and equipment reliability F = ± 1% J = ± 5% K = ± 10% M = ± 20% (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Based on spec. (5) TAPING REEL & POWER 07 = 7 inch dia. Reel & Standard power 7W = 7 inch dia. Reel & 2 x standard power 13 = 13 inch dia. Reel 7T = 7 inch dia. Reel & 3 x standard power 47 = 7 inch dia. Reel & 4xstandard power (6) RESISTANCE VALUE 1 Ω ≤ R ≤ 1M Ω There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XXKX (10 to 97.6 KΩ) 10K = 10,000 Ω 97K6= 97,600 Ω XXXK (100 KΩ) O RDERING EXAMPLE The ordering code for an SR0805 chip resistor, value 10 KΩ with ± 5% tolerance, supplied in 7-inch tape reel is: SR0805JR-0710KL. 100K = 100,000 Ω www.yageo.com Feb. 14, 2025 V.14 Product specification Chip Resistor Surface Mount SR SERIES 0201/0402/0603/0805/1206/1210/1218/2010/2512 3 12 MARKING SR0201 / SR0402 No Marking ynsc007 Fig. 1 SR1218 YNSC099-1 Fig. 2 E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros Value=10 KΩ SR0603 / SR0805 / SR1206 / SR1210 / SR2010 / SR2512 E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros YNSC001 Fig. 3 Value=10 KΩ NOTE For further marking information, please refer to data sheet “Chip resistors marking”. TAPING REEL & POWER Table 1 POWER, W (P70) TYPE CODING 07 0201 1/20 7W 7T 47 1/10 - 1/5 0402 1/16 1/8 1/5 - 0603 1/10 1/5 1/4 1/3 0805 1/8 1/4 1/3 1/2 1206 1/4 1/2 3/4 1 1210 1/2 1 - - 1218 1 2010 3/4 1.5 - - 1.25 - - 2512 1 2 - - www.yageo.com Feb. 14, 2025 V.14 Product specification Chip Resistor Surface Mount SR SERIES 4 12 0201/0402/0603/0805/1206/1210/1218/2010/2512 CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a lead -free glass. The composition of the glaze is adjusted to give the approximately required resistance value. The whole element is covered by a protective overcoat. The top of overcoat is marked with the resistance value. Finally, the two external terminations (Ni/matte tin) are added, as shown in Fig.4. OUTLINES For 2512 1%, 0.5% marking layer marking layer overcoat overcoat protective glass protective glass resistive layer resistive layer inner electrode termination (Ni/matte tin) inner electrode inner electrode termination (Ni/matte tin) inner electrode YNSC095-1 ceramic substrate YNSC095 resistive layer protective glass overcoat Fig. 4-1 Fig. 4-2 Chip resistor outlines Chip resistor outlines DIMENSIONS Table 2 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) SR0201 0.60± 0.03 0.30± 0.03 0.23± 0.03 0.12± 0.05 0.15± 0.05 SR0402 1.00± 0.05 0.50± 0.05 0.35± 0.05 0.20± 0.10 0.25± 0.10 SR0603 1.60± 0.10 0.80± 0.10 0.45± 0.10 0.25± 0.15 0.25± 0.15 SR0805 2.00± 0.10 1.25± 0.10 0.50± 0.10 0.35± 0.20 0.35± 0.20 SR1206 3.10± 0.10 1.60± 0.10 0.55± 0.10 0.45± 0.20 0.45± 0.20 SR1210 3.10± 0.10 2.60± 0.15 0.55± 0.10 0.45± 0.15 0.50± 0.20 SR1218 3.10± 0.10 4.60± 0.10 0.55± 0.10 0.45± 0.20 0.40± 0.20 SR2010 5.00± 0.10 2.50± 0.15 0.55± 0.10 0.55± 0.15 0.55± 0.20 SR2512 6.35± 0.10 3.10± 0.15 0.55± 0.10 0.60± 0.20 0.60± 0.20 SR0201/0402 For dimension, please refer to Table 1 SR0603/0805/1206/ 1210/2010/2512 I1 SR1218 Side view for all type I1 I1 W W Fig. 5 Chip resistor dimensions H W I2 L L L YNSC096_1 www.yageo.com Feb. 14, 2025 V.14 Product specification Chip Resistor Surface Mount SR SERIES 0201/0402/0603/0805/1206/1210/1218/2010/2512 5 12 ELECTRICAL CHARACTERISTICS Table 3 TYPE POWER CHARACTERISTICS Max. Max. Dielectric RESISTANCE Operating Temperature RANGE Range Working Overload Withstanding Voltage Voltage Voltage 1/20W SR0201 1/10W 1Ω ≤ R < 10Ω -100~+350 ppm°C 50 V 10Ω ≤ R ≤ 1MΩ ± 200 ppm°C 25 V 50 V 75 V 100 V 100 V 150V 300V 300V 500V 1000V 1000V 1/5W Temperature Coefficient of Resistance 1/16W SR0402 1/8W 1/5W 1/10W SR0603 1/5W 1/4W 1/3W SR0805 1/8 W E24/E96 0.5%, 1% E24 5%, 10%, 20% 1/4W 1Ω ≤ R ≤ 10MΩ 1/3W for 0402, 0603, 0805, 1206, 2010 1/2W 1/4 W SR1206 1/2W 3/4W 1Ω ≤ R ≤ 1MΩ for 0201, 1210, 1218, 2512 –55 °C to +155 °C 10Ω ≤ R ≤ 10MΩ ± 100 ppm/ °C 500V 1000V 1000V 1Ω ≤ R < 10Ω ± 200 ppm/ °C 500V 1000V 1000V 200 V 400 V 500 V 200 V 400 V 500 V 500 V 1000 V 1000 V 1W SR1210 SR1218 SR2010 SR2512 1/2W 1W 1W 1.5W 3/4W 1.25W 1W 2W www.yageo.com Feb. 14, 2025 V.14 Product specification Chip Resistor Surface Mount SR SERIES 0201/0402/0603/0805/1206/1210/1218/2010/2512 6 12 FOOTPRINT AND SOLDERING PROFILES Recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 4 Packing style and packaging quantity PACKING STYLE Paper taping reel (R) Embossed taping reel (K) REEL DIMENSION SR0201/0402 SR0603/0805/1206 SR1210 SR1218/2010/2512 7" (178 mm) 10,000 5,000 5,000 --- 13" (330 mm) 50,000 20,000 20,000 --- 7" (178 mm) --- --- --- 4,000 NOTE 1. For paper/embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”. TEMPERATURE COEFFICIENT OF RESISTANCE RESISTANCE FUNCTIONAL DESCRIPTION RANGE OPERATING TEMPERATURE RANGE MRA632 Pmax PT040–55 °C to +155 °C 100 m to 910 m Range: (%Prated) 2 ± 200 ppm/°C POWER RATING 100 PT060 Each type rated power at 70 ±°C: 200 ppm/°C 3 SR0201: 1/20W, 1/10W, 1/5W SR0402: PT080 1/16W, 1/8W, 1/5W 50 200 ppm/°C SR0603: 1/10W, 1/5W, 1/4W,±1/3W 5 SR0805: 1/8W, 1/4W, 1/3W, 100 MΩ TO 910 MΩ 1/2W PT120 1/4W, 1/2W, 3/4W, 1W SR1206: 100 mΩ 0 > 100 mΩ 6 SR1210: 1/2W, 1W 55 0 50 70 100 155 SR1218: 1W, 1.5W Tamb ( C) PT201 ± 100 ppm/°C ± 75 ppm/°C SR2010: 3/4W, 1.25W 0 Fig. 6 Maximum dissipation (P max ) in percentage of rated power SR2512: 1W, 2W as a function of the operating ambient temperature (T amb) PT251 ± 100 ppm/°C ± 75 ppm/°C R ATED VOLTAGE 2 The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= (P X R) or max. working voltage whichever is less Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) www.yageo.com Feb. 14, 2025 V.14 Product specification Chip Resistor Surface Mount SR SERIES 0201/0402/0603/0805/1206/1210/1218/2010/2512 7 12 Pulse load Behavior Fig. 7-1 Pulse-Load behavior Fig. 7-2 Pulse-Load behavior www.yageo.com Feb. 14, 2025 V.14 Product specification Chip Resistor Surface Mount SR SERIES 0201/0402/0603/0805/1206/1210/1218/2010/2512 8 12 Pulse load Behavior Fig. 7-3 Pulse-Load behavior Peak Continuous Pulse Power (SR series J/K/M tol) 10,000.0 Permissible electric power (W) 1,000.0 100.0 10.0 2512 1218 2010 1210 1.0 1206 0805 0603 0.1 0402 0201 0.0 0.000001 0.00001 0.0001 0.001 0.01 0.1 1 Pulse duration(Sec) Maximum permissible peak continuous pulse power as a function of pulse duration Follow EN140401-802 Paverage ≤ P( amb) Pulse-SR002 Fig. 7-4 Pulse-Load behavior www.yageo.com Feb. 14, 2025 V.14 Product specification Chip Resistor Surface Mount SR SERIES 0201/0402/0603/0805/1206/1210/1218/2010/2512 9 12 TESTS AND REQUIREMENTS Table 5 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS High Temperature Exposure AEC-Q200 Test 3 1,000 hours at TA = 155 °C, unpowered ± (2.0%+0.05Ω) for D/F tol Moisture Resistance MIL-STD-202 Method 106 Biased Humidity MIL-STD-202 Method 108 AEC-Q200 Test 7 MIL-STD-202 Method 103 ± (3.0%+0.05Ω) for others Each temperature / humidity cycle is defined at 8 hours, 3 cycles / 24 hours for 10d. with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered ± (0.5%+0.05Ω) for D/F tol 1,000 hours; 85 °C / 85% RH 10% of operating power ± (1.0%+0.05Ω) for D/F tol ± (2.0%+0.05Ω) for others ± (3.0%+0.05Ω) for others Measurement at 24± 4 hours after test conclusion. Operational Life Resistance to Soldering Heat AEC-Q200 Test 8 ± (2.0%+0.05Ω) for D/F tol MIL-STD-202 Method 108 1,000 hours at 125 °C, derated voltage applied for 1.5 hours on, 0.5 hour off, still-air required AEC-Q200 Test 15 Condition B, no pre-heat of samples ± (1.0%+0.05Ω) MIL-STD-202 Method 210 Lead-free solder, 260± 5 °C, 10± 1 seconds immersion time No visible damage ± (3.0%+0.05Ω) for others Procedure 2 for SMD: devices fluxed and cleaned with isopropanol Thermal Shock MIL-STD-202 Method 107 -55/+125 °C ± (0.5%+0.05Ω) for D/F tol Number of cycles is 300. Devices mounted ± (1.0%+0.05Ω) for others Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air ESD AEC-Q200 Test 17 Human Body Model, AEC-Q200-002 1 pos. + 1 neg. discharges ± (3.0%+0.05Ω) 0201: 500V 0402/0603: 1KV 0805 and above: 2KV Solderability - Wetting AEC-Q200 Test 18 Electrical Test not required Magnification 50X J-STD-002 SMD conditions: Well tinned (≥95% covered) No visible damage (a) Method B, aging 4 hours at 155 °C dry heat, dipping at 235± 3 °C for 5± 0.5 seconds. (b) Method B, steam aging 8 hours, dipping at 215± 3 °C for 5± 0.5 seconds. (c) Method D, steam aging 8 hours, dipping at 260± 3 °C for 30± 0.5 seconds. www.yageo.com Feb. 14, 2025 V.14 Product specification Chip Resistor Surface Mount TEST Board Flex SR SERIES 0201/0402/0603/0805/1206/1210/1218/2010/2512 TEST METHOD PROCEDURE REQUIREMENTS AEC-Q200 Test 21 Chips mounted on a 100mm x 40mm glass epoxy resin PCB (FR4) ± (1.0%+0.05Ω) AEC-Q200-005 10 12 Bending for 0201/0402: 5 mm 0603/0805: 3 mm 1206 and above: 2 mm Holding time: minimum 60 seconds Temperature Coefficient of Resistance (T.C.R.) MIL-STD-202 Method 304 At +25/–55 °C and +25/+125 °C Refer to table 2 Formula: R2–R1 T.C.R= ------------------------- × 106 (ppm/°C) R1(t2S–t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Short Time Overload IEC60115-1 8.1 2.5 times of rated voltage or maximum overload voltage whichever is less for 5 sec at room temperature ± (2.0%+0.05Ω) www.yageo.com Feb. 14, 2025 V.14 Product specification Chip Resistor Surface Mount SR SERIES 0201/0402/0603/0805/1206/1210/1218/2010/2512 11 12 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 14 Feb. 14, 2025 - - Extend resistance range of 0402,0603,0805,1206,2010 to 10Mohm. Version 13 Jul. 23, 2024 - - Upgrade the working voltage of 1206 and 1210 to 500V Version 12 Apr. 23, 2024 - - Add continuous pulse curve Aug. 31, 2023 - - Upgrade the working voltage of 2512 to 500V Version 11 - Merge F/D tol Add size 0201 Version 10 Upgrade the working voltage of 0402 to 75V Aug. 02, 2022 - Upgrade the working voltage of 0603 to 150V Upgrade the working voltage of 0805 to 500V I2 dimension updated, for size 1206, size 2010, size 2512 Version 9 Aug. 04, 2021 - - Upgrade to Automotive Grade Version 8 Jul. 22, 2019 - - Update power rating - Extend resistance range of 0402 ~ 2512 to 1Mohm, Version 7 Sep. 27, 2018 - - Tighten TCR of all sizes for 10Ω < R ≤ 1MΩ from ± 200 ppm/°C to ± 100 ppm/°C - Add SR1210, SR1218, SR2010 7W (double power) Version 6 Oct. 02, 2017 - Version 5 Nov.11, 2016 - Version 4 Sep. 01, 2015 - Version 3 Jul. 31, 2015 - Version 2 Jan. 06, 2014 - Version 1 Mar 18, 2011 - Version 0 Oct 19, 2004 - - Add SR0402 7T (triple power), SR0805 47 (quadruple power), SR2512 7W (double power) - Update 7T power for 1206 - Update SR0603 Dielectric Withstanding Voltage to 150V - Update 7T power for 0603/0805 & 7W for 1210 - Comply with AEC-Q200 standard - Add SR0402/0603/1210 - Update electrical characteristic - Change to dual brand datasheet that describes SR0805 to SR2512 with RoHS compliant - Define global part number - www.yageo.com Feb. 14, 2025 V.14 Product specification Chip Resistor Surface Mount SR SERIES 0201/0402/0603/0805/1206/1210/1218/2010/2512 12 12 LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. Particularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Feb. 14, 2025 V.14
SR1206FR-7T1KL
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。 3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出晶体管的集电极,4脚输出晶体管的发射极,5脚输出晶体管的基极,6脚为隔离电源。 4. 参数特性:EL817的主要参数包括最大正向电流100mA,最小正向电压1.2V,最大反向电压5V,最大隔离电压5000V,最小传播延迟时间250ns。 5. 功能详解:EL817通过光电效应实现电信号的隔离传输,常用于开关电源、测量设备等需要电气隔离的场合。 6. 应用信息:EL817适用于需要电气隔离的各种应用,如开关电源、测量设备、通信设备等。 7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 4.9mm。
SR1206FR-7T1KL 价格&库存
很抱歉,暂时无法提供与“SR1206FR-7T1KL”相匹配的价格&库存,您可以联系我们找货
SR1206FR-7T1KL
  • 1+1.69470
  • 100+1.10970
  • 1000+0.79010
  • 2500+0.53570
  • 5000+0.38150
库存:916
SR1206FR-7T1KL
    库存:170000
    SR1206FR-7T1KL
    • 1+4.143471+0.53708
    • 10+2.3252410+0.30140
    • 25+1.9270925+0.24979
    • 50+1.7000050+0.22036
    • 100+1.51945100+0.19695
    • 250+1.33712250+0.17332
    • 500+1.23177500+0.15966
    • 1000+1.148181000+0.14883
    库存:6921
    SR1206FR-7T1KL
      SR1206FR-7T1KL
      • 1+1.282801+0.16340
      • 10+0.9224010+0.11750
      • 50+0.7172050+0.09130
      • 100+0.64020100+0.08150
      • 500+0.49560500+0.06310
      • 1000+0.435001000+0.05540
      • 5000+0.332405000+0.04230
      • 10000+0.3160010000+0.04030
      库存:422
