01KR1P9-K0AS3
01KR1P9-K0AS3
    ROSENBERGER
    01KR1P9-K0AS3
01KR1P9-K0AS3 数据手册
Robust Precision Interface up to 90 GHz RPC-1.35 Connectors TEST & MEASUREMENT Company Profile About Rosenberger Rosenberger, a family owned company, is one of the world’s leading manufacturers of impedance-controlled connectivity solutions in high-frequency, high-voltage and fiberoptic technology. Renowned companies in high-tech industries trust the precision and quality of Rosenberger products, e.g. mobile communication networks, data centers, test & measurement industries, automotive electronics, industrial and medical ­electronics, or aerospace engineering. Worldwide, the Rosenberger group operates a global network of R&D, manufacturing and assembly ­locations as well as Rosenberger sales offices in Europe, Asia and North and South America where more than 10,000 employees develop, produce and sell our products. Test & Measurement Rosenberger is a dependable and renowned development partner in industrial measurement technology. The fact that we work with leading global companies from the electronic measurement technology field ­reflects the way that others trust our research and development, our high-quality manufacturing, and not least our customer-orientated “Made in Germany” service. Rosenberger provides customized solutions – cost-optimized and timely – from the initial idea right through to volume production. Rosenberger develops and produces a comprehensive range of cost-effective, high-quality and high-­ precision test & measurement products and services – microwave measurements & VNA calibrations, lab and factory testing, semiconductor test applications, PCB connections or network testing. 2 RPC-1.35 - Precision Coaxial 1.35 mm Connectors Due to the expanding market for 5G, industrial sensors in the E-Band, millimeter wave sensors for self-driving vehicles and WLAN IEEE 802.11ax and 802.11ay, there is a growing demand for proper R ­ F-connections up to 90 GHz. For achieving good RF performance, especially for applications in the range of 60 to 90 GHz (E-Band) a re­ liable coaxial interface connection is crucial. The unwanted unlocking of 1.00 mm coaxial thread which results in time-consuming calibrations are a common frustration in RF laboratories. The idea of a 1.35 mm connector, the E Connector, with a precise metric thread like the 1.85 mm connector and an integrated time-saving push-pull capability arise from these issues. The 1.35 mm connector is perfect to carry out high-performance RF measurements in the E-Band without delays through fragile 1.00 mm coaxial connectors or reassembling WR 10 waveguide. A working group consisting of: ■■ ■■ ■■ ■■ Physikalisch-Technische-Bundesanstalt PTB (Germany's national metrology institute) Rosenberger Hochfrequenztechnik GmbH & Co. KG Rohde & Schwarz GmbH & Co. KG Spinner GmbH has designed the new 1.35 mm E Connector to close the gap between 1.85 mm and 1.00 mm connectors. The standardization of the 1.35 mm interface is in progress for IEC (IEC 61169-65) and for IEEE (IEEE Std 287), therefore a manufacturer-independent supply of the new 1.35 E Connector is ensured. Rosenberger Hochfrequenztechnik GmbH & Co. KG | www.rosenberger.com 3 RPC-1.85 RPC-1.35 RPC-1.00 70 GHz 90 GHz 110 GHz IEC 61169-32 IEC 61169-65 (in progress) IEC 61169-31 V Connectors E Connectors W Connectors ■■ ■■ Single-mode operation up to 65 GHz (70 GHz) Robust, reliable design ■■ Single-mode operation up to 90 GHz ■■ Single-mode operation up to 110 GHz ■■ Robust, reliable design ■■ Drawbacks – Unintended unlocking caused by coarse coupling thread M4 x 0.7 – Possible connector damage due to eccentricities – Unnecessarily small/fragile for a ­ pplications in the range of 70 to 90 GHz – Pin diameter different from inner conductor diameter of any standard semi-rigid cable RPC-1.35 Characteristics Target Specifications ■■ ■■ ■■ ■■ ■■ Operating frequency DC up to 90 GHz, E-Band Highly robust mechanics – minimum 3000 mating cycles – locking by threaded coupling nut that sufficiently secures against unintended opening Precision interface – well-defined reference plane – maximized return loss – high connector repeatability – suitable for precision S-parameter measurement – design similar to 1.85 mm connector "thru male" capability, i.e. pin diameter must coincide with inner conductor of standard 0.047-inch ­semi-rigid cable (largest cable covering the E-Band) Push-pull coupling as an option Special Design Features ■■ ■■ ■■ ■■ ■■ 4 Only precision connector which ensures a pin gap in mated condition to avoid near field effects from ­impairing connector repeatability Only precision connector which uses a common reference for all eccentricity tolerances to prevent for a tolerance chain Only precision connector for higher frequencies with a provision for push-pull locking High-quality low budget jumper cables possible, because pin diameter is equal to center conductor of 0.047-inch semi-rigid cables. Can be used with the same torque wrench as most precision connectors (3.50 mm, 2.92 mm, 2.40 mm, 1.85 mm) Comparison of Technical Data Technical Data 1.85 mm/V Connector 1.35 mm/E Connector 1.00 mm/W Connector Upper operating frequency 65 (70) GHz 90 GHz 110 GHz Cut-off frequency 72 GHz 98 GHz 133 GHz Outer conductor diameter 1.85 mm 1.35 mm 1.00 mm Inner conductor diameter 0.8036 mm 0.586 mm 0.434 mm Pin diameter 511 µm 290 µm 250 µm Thread M7 x 0.75 M5.5 x 0.5 M4 x 0.7 Coupling torque 0.9 Nm 0.9 Nm 0.45 Nm Flat wrench size 8 mm 8 mm 6 mm Optional push-pull locking No Yes No Mating Cycles > 500 (IEC) > 3000 > 500 (IEC) Advantages 1.35 mm Connector Series ■■ ■■ ■■ Optimized for frequently used bands Allows "thru male" design with multiple cables Thread and coupling torque prevents unintended opening Rosenberger Hochfrequenztechnik GmbH & Co. KG | www.rosenberger.com 5 Typical Reflection of L70-324-140 dB Sample 1 Guaranteed Performance 0 -10 -20 -30 -40 -50 -60 0 10 20 30 40 50 60 70 80 90 GHz Product Portfolio Semi-Rigid Cable Assemblies Rosenberger No. 1) Connector 1 Connector 2 Return Loss L70-324-XXX RPC-1.35 male RPC-1.35 male ≥ 17 dB, DC to 26.5 GHz ≥ 14 dB, 26.5 GHz to 50 GHz ≥ 12 dB, 50 GHz to 90 GHz Flexible Cable Assemblies Rosenberger No. 1) Connector 1 Connector 2 Return Loss L70-345-XXX RPC-1.35 male RPC-1.35 male ≥ 17 dB, DC to 50 GHz ≥ 14 dB, 50 GHz to 90 GHz L70-346-XXX RPC-1.35 male RPC-1.85 male ≥ 17 dB, DC to 50 GHz ≥ 14 dB, 50 GHz to 70 GHz L70-347-XXX RPC-1.00 male RPC-1.35 male ≥ 17 dB, DC to 50 GHz ≥ 14 dB, 50 GHz to 90 GHz 1) XXX: Please fill in the requested length. Standard = 140 mm PCB Connectors Rosenberger No. Version Remarks Return Loss P9K80A-40ML5 30° Angle Solderless PCB connector, female ≥ 21 dB, DC to 26.5 GHz ≥ 19 dB, 26.5 GHz to 40 GHz ≥ 17 dB, 40 GHz to 60 GHz ≥ 14 dB, 60 GHz to 70 GHz ≥ 12 dB, 70 GHz to 90 GHz Can be screwed anywhere on the board ­without soldering P9K241-40ML5 Right Angle Soldered PCB connector, female Edge mount For specific details refer to the technical data sheets in our online catalog. www.rosenberger.com/ok 6 ≥ 20 dB, DC to 40 GHz ≥ 14 dB, 40 GHz to 70 GHz ≥ 12 dB, 70 GHz to 90 GHz Product Portfolio Test PCBs Rosenberger No. Connector Return Loss PCB-K2702D-SB 2 x P9K80A-40ML5 PCB-S2402-SB 2 x P9K241-40ML5 ≥ 12 dB, DC to 70 GHz ≥ 10 dB, 70 GHz to 90 GHz Cable Connectors Rosenberger No. Version Remarks Return Loss P9S101-270E Straight Cable inner contact is connector pin ≥ 23 dB, DC to 26.5 GHz ≥ 20 dB, 26.5 GHz to 50 GHz ≥ 18 dB, 50 GHz to 90 GHz Pin diameter matches semi rigid cable 0.047" Tools Rosenberger No. Remarks P9W001-000 Soldering fixture for outer conductor of P9S101-270E P9W002-000 Cutting bit to sharp the center conductor 0.047-inch semi-rigid cable 03W008-000 Combi Wrench with 5 mm, 6 mm, 7 mm and 8 mm across flats 03W021-000 Torque Wrench with 8 mm across flats, 0.90 Nm Rosenberger Hochfrequenztechnik GmbH & Co. KG | www.rosenberger.com 7 Product Portfolio In-Series Adaptors Rosenberger No. Version Interface Return Loss P9K121-K00D3 Straight RPC-1.35 female – RPC-1.35 female P9S121-K00D3 Straight RPC-1.35 male – RPC-1.35 female P9S121-S00D3 Straight RPC-1.35 male – RPC-1.35 male ≥ 28 dB, DC to 20 GHz ≥ 19 dB, 20 GHz to 40 GHz ≥ 17 dB, 40 GHz to 90 GHz Inter-Series Adaptors 8 Rosenberger No. Version Interface Return Loss P9K101-K00D3 Straight RPC-1.35 female – RPC-1.00 female P9S101-S00D3 Straight RPC-1.35 male – RPC-1.00 male ≥ 28 dB, DC to 20 GHz ≥ 20 dB, 20 GHz to 40 GHz ≥ 17 dB, 40 GHz to 90 GHz P9K108-K00D3 Straight RPC-1.35 female – RPC-1.85 female P9S108-S00D3 Straight RPC-1.35 male – RPC-1.85 male ≥ 28 dB, DC to 20 GHz ≥ 20 dB, 20 GHz to 50 GHz ≥ 17 dB, 50 GHz to 70 GHz Floating Adaptor Rosenberger No. P9K721-S23S3 DUT Device Under Test RPC-1.35 female Adaptor Connector Floating – Side Connector Fixed – Port Side RPC-1.35 male RPC-1.35 female Return Loss ≥ 16 dB, DC to 40 GHz ≥ 14 dB, 40 GHz to 90 GHz Test-Port Adaptor Rosenberger No. Interface Return Loss 01KR1P9-K0AS3 RPC-1.00 female, ruggedized – RPC-1.35 female ≥ 28 dB, DC to 20 GHz ≥ 19 dB, 20 GHz to 40 GHz ≥ 17 dB, 40 GHz to 90 GHz Waveguide-to-Coaxial Adaptors Rosenberger No. Version Interface Frequency Range Return Loss P9K620-385 Straight RPC-1.35 female – WR-15 50 GHz to 75 GHz ≥ 16 dB P9S620-385 Straight RPC-1.35 male – WR-15 P9K740-387 Straight RPC-1.35 female – WR-12 P9S740-387 Straight RPC-1.35 male - WR-12 60 GHz to 90 GHz Rosenberger Hochfrequenztechnik GmbH & Co. KG | www.rosenberger.com 9 Product Portfolio Gauge Kit The mechanical gauging of connectors is essential to ensure correct fit and to achieve the best performance. This means that all coaxial connectors fitted on all equipment, cables and terminations etc. should be gauged on a regular basis in order to detect any out of tolerance conditions that may impair the electrical performance. Inner conductor protrusion can damage the equipment and recession can influence the electrical measurement. For details please see the operating manual. Rosenberger No. Remarks P9GK0KS-010 Rosenberger gauge kits are delivered in a stable wooden box with gauge male/female incl. gauge block male/female Calibration Kits Rosenberger calibration kits are delivered in stable wooden boxes including factory calibration certificate. Rosenberger No. Remarks P9CK001-150 Full version with open, short, load in male and female, in-series adaptors male/male and female/female, torque wrench, combi wrench and gauges male/female incl. gauge block male/female P9CK010-150 Industrial version with open, short, load as male and female, in-series adaptors male/male and female/female, torque wrench and combi wrench All parts from the calibration kits and gauge kits (calibration standards, calibration adaptors, gauges) are also available as separate parts. 10 Product Portfolio Status January 2019 – Technical modifications and errors excepted. Similar images. 11 Website For more information refer to our website: www.rosenberger.com/t&m Rosenberger Hochfrequenztechnik GmbH & Co. KG Hauptstraße 1 | 83413 Fridolfing P.O. Box 1260 | 84526 Tittmoning Germany Phone  +49 8684 18-0 info@rosenberger.com www.rosenberger.com Certified by IATF 16949 · DIN EN 9100 · ISO 9001 · ISO 14001 Order No. pA 405951 · Info356RPC1.35FlyEN 2000/2019 Rosenberger® is a registered trademark of Rosenberger Hochfrequenztechnik GmbH & Co. KG. All rights reserved. © Rosenberger 2019
01KR1P9-K0AS3 价格&库存
很抱歉,暂时无法提供与“01KR1P9-K0AS3”相匹配的价格&库存,您可以联系我们找货
01KR1P9-K0AS3
    • 1+37746.567071+4881.15464
