H
4x 0.60
8x 0.30
B8
A5
B7
A6
A7
B6
A8
B5
B4 A9
2x 2.60
2x 3.68
12x 4.18
G
2x Ø0.65
GCT
7.35
Pin
Signal
Mating
Sequence
Pin
Signal
Mating
Sequence
First
A1
GND
First
B12
GND
A4
VBUS
First
B9
VBUS
First
A5
CC1
Second
B8
SBU2
Second
A6
Dp1
Second
B7
Dn2
Second
A7
Dn1
Second
B6
Dp2
Second
A8
SBU1
Second
B5
CC2
Second
A9
VBUS
First
B4
VBUS
First
A12
GND
First
B1
GND
B1 A12
2x 2.10
2x 1.70
A1 B12 A4 B9
12x 1.15
8.64
6.40
4.80
3.50
0.50
F
8.94
2x 1.40
2x 1.80
SHELL
4x 0.60
4x 1.00
5.78
PCB Edge
Solder Area
8.34+0.06
-0.02
0.10
B1
4.18
C
5.00A collectively for VBUS pins
6.25A collectively for GND pins
1.25A for B5 pin
0.25A per pin for all other pins
Voltage Rating: 20V DC
Contact Resistance: 40mΩ max initial.
50mΩ max after test
Dielectric Withstanding Voltage: 100V AC
Insulation Resistance 100MΩ min
1.85 Min
Plug
1.30
2.60
3.68
Electrical
Current Rating:
1.10
6.5 Max.
0.80
S±0.15
5.78
8.64
2x Ø0.50
0.38
B
Plating
Contact: See Ordering Grid
Solder Tails: Gold Flash Over Nickel
Shell: Nickel
0.60
3.31
B12
(0.95mm stake shown)
D
Component Outline
A12
2.56±0.04
A1
Mechanical & Environmental
Operating Temperature: -40°C to +85°C
Mating Force: 5 to 20 N.
Unmated Force: 6 to 20 N after test
Durability: 10,000 cycles
Plug and Receptacle Mating View
Ordering Grid
A1 B12 A4 B9
B8
A5
B7
A6
A7
B6
A8
B5
B4 A9
B1 A12
16x 0.20
4x 0.45
2x 0.25
2x 0.75
2x 1.25
2x 1.75
2x 2.40
A
USB4105
XX
A
XXX
Contact Plating
GF = Gold Flash (standard)
15 = 15µ" Gold
Request Samples
and Quotation
Shell Stake Length "S"
Blank = 0.95mm
060 = 0.60mm
120 = 1.20mm
Packing Options
A = Tape & Reel
Part Number
Product Description
USB4105
USB Type C Receptacle for USB 2.0
SMT Type, PCB Top Mount
Drawing Date
4th October 2019
By
Detail
6.40
1
2
3
4
GND
Material
Insulator: LCP, UL 94V-0, Black
Contact: Copper Alloy
Shell: Stainless steel
Mid Plate:Stainless Steel
Tolerance:±0.05mm
1.73
E
First
SHELL
Specifications
Recommended PCB Layout
As viewed from component side
GND
Revision
Date
5
CC
USB4105
B PCN
B
29/04/21
Tolerances (Except as Noted)
Length
Angle
X. ± 0.38
X.X ± 0.30
X.XX ± 0.15
X.XXX ± 0.10
X.±2°
X.X±1°
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/2
H
Unloaded Section
800 PCS
Folder Paper Board
Unloaded Section
(20 Pockets)
(20 Pockets)
Paper Board
G
Direction of Unreeling
Peeling
Angle
F
165°~180°
Vacuum Bag
Reel and Tape
Ø330
E
Carton
Ø1
D
3
Label
320
W+0.5
Paper Board
C
34
B
1.75
24.0
4.00
2.00
Pcs /
Reel
800
Product Description
By
Detail
Revision
Date
3
4
Total
Quantity
8000 pcs
USB4105
4th October 2019
2
Reels /
Carton
10
Part Number
Drawing Date
A
1
5
CC
USB4105
B PCN
B
29/04/21
Length
Angle
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
2/2
很抱歉,暂时无法提供与“USB4105-GF-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.94450
- 100+3.60640
- 800+3.49370
- 国内价格
- 1+8.34204
- 10+6.75922
- 160+4.40372
- 320+4.35968
- 800+4.27249
- 型号:USB4105-GF-A
- 品牌:GCT
- 封装:SMD
- 描述:GCT - USB4105-GF-A - 连接器, USB, 5A, 48V, 240W, USB C, USB 2.0, 插座, 16 路, 表面安装, 通孔安装, 水平
- 国内价格
- 1+7.09527
- 20+5.99183
- 60+5.35112
- 160+5.10195
- 400+4.41378
- 国内价格
- 1+6.01230
- 10+5.58980
- 100+5.27830
- 500+4.82380
- 1000+4.53340
- 5000+4.46540
