7.15
H
PCB Mount Orientation
Designed to comply with physical,
electrical and environmental
requirements of Micro USB
Standard (USB2.0).
G
2.6
Pin 1
0.65
7.4
1.45
4.75
0.4
1.15
PCB Edge
Specifications 规格
Materials 材料
Plastic Housing 塑胶外壳: LCP, UL94V-0, Black
Contact Terminal 接触端子: Copper Alloy
Metallic Shell 金属外壳: Stainless Steel,
SUS304, T= 0.25mm
Plating电镀
Underplating 底层电镀: 50µ" Nickel
Contact Area 接触面积: 30µ" Gold
Solder Tails 焊接末端: Gold Flash
Metallic Shell 金属外壳: Matte Tin
1.45
0.8
1.9
4.69
5.55
0.59
2.23
F
3.35
1.4
0.25
Pin 5
1.02
0.5
E
0.45
4
6.20
1.05
7.15
7.8 REF.
Recommended PCB Layout
As viewed from component side
Solder Area
General Tolerance: ±0.05
Component Outline
0.31
Electrical 电气规格
Voltage Rating电压额定值: 30 V AC
Current Rating电流额定值: Signal(Pins 2,3,4)信号:1.0 A.
Power (Pins1,5)电源:1.8A.
Operating Temperature 工作温度: -30°C to +85°C
Contact Resistance接触电阻值: 30 mΩ max.
Insulating Resistance绝缘电阻值: 1000 MΩ min.
Dielectric Withstand Voltage耐电压: 500V AC/minute
1
2.7
1.85
2.35
6.9
D
C
Pin 1
Pin 5
0.90
2.80
2.15
Mechanical & Environmental 机械 & 环境
Mating Force插入力: 35N max.
Unmating Force拨出力: Initial 10N min.
Final 8N min after durability test.
Durability耐久性: 10,000 Cycles 次插拨
0.48
B
0.77
Ordering Grid
USB3075
30
A
Request Samples
and Quotation
Packing Options
A = Tape & Reel
Contact Plating
30 = 30u" Gold
(1.5K per Reel)
1.30
Product Description
USB3075
Micro USB Receptacle, Type B, SMT, Horizontal, Bottom
Mount (Standard), without Peg, with Outer Shell Stakes
Drawing Date
0.02
2.6
A
Part Number
4th February 2011
By
Detail
1
2
3
4
Revision
Date
5
CC
USB3075
D PCN
D3
14/02/17
Tolerances (Except as Noted)
Length
Angle
X.X ± 0.2
X.XX ± 0.10
X.XXX ± 0.05
X.X° ± 2°
X.XX° ± 1°
X.XXX° ± 0.5°
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
SA
8
Sheet No.
1/2
H
FIRST APPROXIMATELY
15PCS EMPTY CARRIER
4.0
FIRST APPROXIMATELY
15PCS EMPTY CARRIER
12.0
16.0
4.0
G
PCS/Reel Reels/Carton PCS/Carton
Products P/N
I/O Direction
卷盘绕逆时针方向转动
F
USB3075
10°
Cover Tape
盖带
4
6000
Carrier Tape
载带
Notes注意:
1. Peeling off force of top tape: 0.1-1.3N
2. Part Conforms to EIA-481-C Standards产品符合EIA-481-C标准
3. All dimensions in millimeters 所有尺寸均是毫米
4. 10 sprocket hole pitch cumulative tolerance±0.2mm
120
Ø2
3
ø330
1500
Peel off Angle
剥离角度
Ø13.5
E
120°
Detail F
6
PS
D
Cardboard
纸板
Detail F
Reel 卷筒
Waterproof bag
防水袋
Label
标签
Carton
纸箱
Triangle Liner
三角形班轮
Protection Tape
保护胶带
160mm
C
4 Reels
4 卷轴
1500 pieces/reel
1500 件/卷
35
0m
m
700x600x0.08
B
Part Number
Product Description
USB3075
Drawing Date
A
4th February 2011
By
Detail
1
2
3
4
m
0m
35
Revision
Date
5
CC
USB3075
D PCN
D3
14/02/17
Length
Angle
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
SA
8
Sheet No.
2/2
很抱歉,暂时无法提供与“USB3075-30-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.61550
- 10+3.31420
- 30+3.01290
