C4D10120D
VRRM = 1200 V
Silicon Carbide Schottky Diode
IF (TC=135˚C) = 18 A**
Z-Rec Rectifier
Q c
Features
Package
1.2kV Schottky Rectifier
Zero Reverse Recovery Current
High-Frequency Operation
Temperature-Independent Switching
Extremely Fast Switching
Benefits
TO-247-3
Replace Bipolar with Unipolar Rectifiers
Essentially No Switching Losses
Higher Efficiency
Reduction of Heat Sink Requirements
Parallel Devices Without Thermal Runaway
Applications
= 54 nC**
Switch Mode Power Supplies (SMPS)
Boost diodes in PFC or DC/DC stages
Free Wheeling Diodes in Inverter stages
AC/DC converters
Part Number
Package
Marking
C4D10120D
TO-247-3
C4D10120
Maximum Ratings (TC=25°C unless otherwise specified)
Symbol
Parameter
Unit
Test Conditions
VRRM
Repetitive Peak Reverse Voltage
1200
V
VRSM
Surge Peak Reverse Voltage
1300
V
VR
DC Peak Reverse Voltage
1200
V
IF
Continuous Forward Current
(Per Leg/Device)
19/38
9/18
5/10
A
TC=25˚C
TC=135˚C
TC=160˚C
Note
Fig. 3
IFRM
Repetitive Peak Forward Surge Current
26*
18*
A
TC=25˚C, tP=10 ms, Half Sine Pulse
TC=110˚C, tP=10 ms, Half Sine Pulse
IFSM
Non-Repetitive Forward Surge Current
46*
36*
A
Fig. 8
IF,Max
Non-Repetitive Peak Forward Current
400*
320*
A
TC=25˚C, tP=10 ms, Pulse
TC=110˚C, tP=10 ms, Pulse
Fig. 8
93/187
40/81
W
TC=25˚C
TC=110˚C
Fig. 4
200
V/ns
VR=0-650V
Ptot
Power Dissipation(Per Leg/Device)
dV/dt
Diode dV/dt ruggedness
∫i2dt
i2t value
10.6*
6.5*
A2s
TJ
Operating Junction Range
-55 to
+175
˚C
Tstg
Storage Temperature Range
-55 to
+135
˚C
1
8.8
Nm
lbf-in
TO-247 Mounting Torque
* Per Leg, ** Per Device
1
Value
C4D10120D Rev. H, 09-2016
TC=25˚C, tP=10 ms
TC=110˚C, tP=10 ms
M3 Screw
6-32 Screw
Electrical Characteristics (Per Leg)
Symbol
Parameter
Typ.
Max.
Unit
VF
Forward Voltage
1.4
1.9
1.8
3
V
IR
Reverse Current
150
300
QC
Total Capacitive Charge
C
EC
Test Conditions
Note
IF = 5 A TJ=25°C
IF = 5 A TJ=175°C
Fig. 1
μA
VR = 1200 V TJ=25°C
VR = 1200 V TJ=175°C
Fig. 2
27
nC
VR = 800 V, IF = 5A
di/dt = 200 A/μs
TJ = 25°C
Fig. 5
Total Capacitance
390
27
pF
VR = 0 V, TJ = 25°C, f = 1 MHz
VR = 400 V, TJ = 25˚C, f = 1 MHz
VR = 800 V, TJ = 25˚C, f = 1 MHz
Fig. 6
Capacitance Stored Energy
8.0
μJ
VR = 800 V
Fig. 7
Note:This is a majority carrier diode, so there is no reverse recovery charge.
Thermal Characteristics
Symbol
RθJC
Parameter
Thermal Resistance from Junction to Case
Per Leg,
Typ.
Unit
Note
1.6*
0.8**
°C/W
Fig. 9
Per Device
Typical Performance (Per Leg)
10
1000
TJ=-55°C
TJ= 25°C
T = 75°C
J
T =125°C
TJ =175°C
J
9
8
900
800
700
Current
I (μA)(µA)
6
5
4
500
400
3
300
2
200
1
100
TJ=-55°C
TJ= 25°C
T = 75°C
J
T =125°C
TJ =175°C
J
1
1.5
2
VF (V)
Voltage
(V)
2.5
Figure 1. Forward Characteristics
2
600
R
F
Current
I (A) (A)
7
3
3.5
1000
1500
VR (V)
Voltage (V)
Figure 2. Reverse Characteristics
2000
C4D10120D Per Leg Current Derating
100.0
60
55
10%
20%
30%
50%
70%
DC
45
40
90.0
Duty
Duty
Duty
Duty
Duty
80.0
70.0
35
60.0
30
50.0
PTot (W)
I
(A)
F(peak)
IF(PEAK) Peak Forward Current (A)
50
25
40.0
30.0
20.0
10
10.0
5
0.0
50
75
100
125
150
175
25
Tc Case Temperature (C)
50
75
TC ˚C
100
125
150
175
TC ˚C
Figure 4. Power Derating
Figure 3. Current Derating
35
450
400
30
350
25
300
C (pF)
Qc (nC)
250
200
150
10
100
5
50
400
600
VR (V)
800
Figure 5. Recovery Charge vs. Reverse Voltage
3
1000
0.1
1
10
VR (V)
100
Figure 6. Capacitance vs. Reverse Voltage
1000
Typical Performance
14
14.0
1000
1000
10.0
10
8.08
(A)
IFSMIFSM
(A)
E (mJ)
C
EC Capacitive Energy (uJ)
12
12.0
6.06
100
100
TJ_initial = 25°C
T
= 110°C
J_initial
4.04
2.02
0.00
0 200 400 600 800 1000
400
600
800
1000
10
10
1E-05 1E-04 1E-03 1E-02
1.E-05
1.E-04
1.E-03
1.E-02
VR Reverse
Voltage (V)
V (V)
tptp(s)
(s)
R
Figure 7. Typical Capacitance Stored Energy, per leg
Figure 8. Non-repetitive peak forward surge current
versus pulse duration (sinusoidal waveform), per leg
Junction
To Case
Impedance,(˚C/W)
ZthJC (oC/W)
Thermal
Resistance
1
0.5
0.3
100E-3
0.1
0.05
10E-3
0.02
SinglePulse
0.01
1E-3
1E-6
10E-6
100E-6
1E-3
Time,
tp (s)
T (Sec)
10E-3
Figure 9. Device Transient Thermal Impedance
4
100E-3
1
Package Dimensions
ASE
Advanced
Package TO-247-3
Semiconductor
Engineering Weihai, Inc.
PACKAGE
OUTLINE
DWG NO.
98WHP03165A
ISSUE
O
DATE
Sep.05, 2016
POS
e
Inches
Millimeters
Min
Max
Min
A
.190
.205
4.83
5.21
A1
.090
.100
2.29
2.54
A2
.075
.085
1.91
2.16
b
.042
.052
1.07
1.33
b1
.075
.095
1.91
2.41
b3
.113
.133
2.87
3.38
c
.022
.027
0.55
0.68
D
.819
.831
20.80
21.10
D1
.640
.695
16.25
17.65
D2
.037
.049
0.95
1.25
E
.620
.635
15.75
16.13
E1
.516
.557
13.10
14.15
E2
.145
.201
3.68
5.10
E3
.039
.075
1.00
1.90
E4
.487
.529
12.38
13.43
e
.214 BSC
5.44 BSC
L
.780
.800
19.81
20.32
L1
.161
.173
4.10
4.40
ØP
.138
.144
3.51
3.65
Q
.216
.236
5.49
6.00
S
.238
.248
6.04
6.30
N
NOTE ;
1. ALL METAL SURFACES: TIN PLATED,EXCEPT AREA OF CUT
2. DIMENSIONING & TOLERANCEING CONFIRM TO
ASME Y14.5M-1994.
3. ALL DIMENSIONS ARE IN MILLIMETERS.
ANGLES ARE IN DEGREES.
4. THIS DRAWING WILL MEET ALL DIMENSIONS REQUIREMENT
OF JEDEC outlines TO-247 AD.
1 - GATE
2 - DRAIN (COLLECTOR)
3 - SOURCE (EMITTER)
4 - DRAIN (COLLECTOR)
TITLE:
TO-247 3LD, Only For Cree
COMPANY
ASE Weihai
SHEET
1 OF 3
Recommended Solder Pad Layout
3
T
17.5° REF
W
3.5° REF
X
4° REF
Part Number
Package
Marking
C4D10120D
TO-247-3
C4D10120
all units are in inches
TO-247-3
Note: Recommended soldering profiles can be found in the applications note here:
http://www.wolfspeed.com/power_app_notes/soldering
5
Max
Diode Model
VfT = VT + If * RT
VT = 0.96 + (Tj * -1.22*10-3)
RT = 0.08 + (Tj * 8.5*10-4)
Note:
Junction
Temperature
In Degrees Celsius,
Note: TTj j =
is Diode
diode junction
temperature
in degrees
Celsius
valid from 25°C to 175°C
Notes
• RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred
to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance
with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can
be obtained from your Wolfspeed representative or from the Product Ecology section of our website at http://
www.wolfspeed.com/power/tools-and-support/product-ecology.
• REACh Compliance
REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable
future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration.
REACh banned substance information (REACh Article 67) is also available upon request.
This product has not been designed or tested for use in, and is not intended for use in, applications implanted into
the human body nor in applications in which failure of the product could lead to death, personal injury or property
damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines,
cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control
systems, or air traffic control systems.
Related Links
Cree SiC Schottky diode portfolio: http://www.wolfspeed.com/Power/Products#SiCSchottkyDiodes
Schottky diode Spice models: http://www.wolfspeed.com/power/tools-and-support/DIODE-model-request2
SiC MOSFET and diode reference designs: http://go.pardot.com/l/101562/2015-07-31/349i
Copyright © 2016 Cree, Inc. All rights reserved.
The information in this document is subject to change without notice.
Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc.
6
C4D10120A Rev. H, 09-2016
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
Fax: +1.919.313.5451
www.cree.com/power
