FN7563-63-M6
FN7563-63-M6
    SCHAFFNER(夏弗纳)
    AXIAL
FN7563-63-M6 数据手册
DATA SHEET Feedthrough Capacitors FN756X DC Feedthrough Capacitor EN/IEC 60384-14 approval Approvals & Compliances Rated currents from 10 to 200 A 2.5 kV pulse test capability Class Y4 capacitor Feedthrough capacitors offer a high insertion loss across a broad band of frequencies from a few tens of kHz up to the GHz region. The construction of feedthrough capacitors cause a better suppression performance over a much wider frequency range than a conventional two-wire capacitor of equivalent value. Different versions are available offering a wide selection on operating currents and performance levels. DC feedthrough capacitors are designed and approved for 130 VDC/130 VAC 50/60 Hz operation. Technical Specifications Features and Benefits Maximum continuous operating voltage 130 DC (UL, ENEC) 130 VAC, 50/60 Hz (UL, ENEC) 650 VDC max Rated currents 10 to 200 A @ 60°C max. Very high self-resonant frequency Capacitor class Y4 Self-healing dielectric High potential test voltage 1700 VDC for 2 sec High quality and reliability Insulation resistance (100VDC after 60 sec) 1500 MΩ >0.33 μF, τ >5000 s Anti-twist protection Temperature range (operation and storage) -40°C to +100°C (40/100/21) Flammability corresponding to UL 94 V-2 or better MTBF @ 60°C/130 V (Mil-HB-217F) 1,400,000 hours ≥200 A: >450,000 hours Very low internal series inductance Through-bulkhead mounting Custom-specific or dual-versions on request Typical Applications Power line filter for 48 VDC battery power Increasing system and information security Telecom base stations Switching and cellular equipment Computer servers UPS power supplies Medical equipment Typical electrical schematic 2 Feedthrough Capacitors Schaffner Group DATA SHEET 15. Jun 2022 Feedthrough Selector Table Feedthrough Rated current @ 60°C Leakage current* @ 130 VAC/50 Hz Capacitance** C DC resistance*** R @ 25°C Weight [A] [mA] [nF] [mΩ] [g] FN 7560-10-M3 10 0.49 10 0.8 15 FN 7562-16-M4 16 4.9 100 0.62 34 FN 7563-16-M4 16 23 470 0.63 78 FN 7562-32-M4 32 4.9 100 0.62 34 FN 7563-32-M4 32 23 470 0.63 79 FN 7560-63-M6 63 0.49 10 0.3 70 FN 7561-63-M6 63 2.3 47 0.3 70 FN 7562-63-M6 63 4.9 100 0.3 70 FN 7563-63-M6 63 23 470 0.43 103 FN 7560-100-M8 100 2.3 47 0.23 145 FN 7561-100-M8 100 4.9 100 0.23 145 FN 7562-100-M8 100 23 470 0.23 145 FN 7563-100-M8 100 49 1000 0.25 192 FN 7560-200-M10 200 4.9 100 0.16 160 FN 7561-200-M10 200 23 470 0.16 160 FN 7562-200-M10 200 49 1000 0.18 268 FN 7563-200-M10 200 230 4700 0.14 490 *** Tolerance +20% *** Tolerance ±20% *** Tolerance +15% Typical Filter Attenuation Full load, 50 Ω system 10 A types 16 A types 100 A types 200 A types 32 A types 63 A types 3 Feedthrough Capacitors Schaffner Group DATA SHEET 15. Jun 2022 Mechanical Data Mechanical drawing Panel cut out 10 A types Panel cut out other types Dimensions A B C D E L FN 7560-10-M3 57 10 15 13 16 19 FN 7562-16-M4 75 12 20 17 18 30 10.3 FN 7563-16-M4 82 16 32 27 18 33 FN 7562-32-M4 75 12 20 17 18 FN 7563-32-M4 82 16 32 27 18 FN 7560-63-M6 96 14 25 22 FN 7561-63-M6 96 14 25 22 FN 7562-63-M6 96 14 25 FN 7563-63-M6 M N S T Ø10.3 M3 M10x1 Ø12.3 M4 M12x1 18.3 Ø20.3 M4 M20x1 30 10.3 Ø12.3 M4 M12x1 33 18.3 Ø20.3 M4 M20x1 26 30 14.3 Ø16.3 M6 M16x1 26 30 14.3 Ø16.3 M6 M16x1 22 26 30 14.3 Ø16.3 M6 M16x1 99 16 32 27 26 33 18.3 Ø20.3 M8 M20x1 FN 7560-100-M8 113 16 32 27 32 33 18.3 Ø20.3 M8 M20x1 FN 7561-100-M8 113 16 32 27 32 33 18.3 Ø20.3 M8 M20x1 FN 7562-100-M8 113 16 32 27 32 33 18.3 Ø20.3 M8 M20x1 FN 7563-100-M8 133 19 38 27 32 50 22.3 Ø24.3 M8 M24x1 FN 7560-200-M10 130 19 32 27 40 33 22.3 Ø24.3 M10 M24x1 FN 7561-200-M10 130 19 32 27 40 33 22.3 Ø24.3 M10 M24x1 FN 7562-200-M10 147 19 38 27 40 50 22.3 Ø24.3 M10 M24x1 FN 7563-200-M10 165 19 54 41 40 68 24.3 Ø27.3 M10 M27x1.5 Tolerances ±2 ±0.2 All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Recommended Torque Terminal thread Mounting thread M3 M4 M6 M8 M10 0.5 Nm 1.2 Nm 2.5 Nm 5 Nm 8 Nm M10x1 M12x1 M16x1 M20x1 M24x1 M27x1.5 2 Nm 3 Nm 4 Nm 7 Nm 8 Nm 12 Nm 4 Feedthrough Capacitors Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road,Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 15. Jun 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN7563-63-M6 价格&库存
很抱歉,暂时无法提供与“FN7563-63-M6”相匹配的价格&库存,您可以联系我们找货
