120BBS
120BBS
    ANDERSON
    120BBS
120BBS 数据手册
SBE® 320 / SBX® 350 Connectors Up to 550 Amps SBE® and SBX® connectors can integrate up to 8 auxiliary power / signal contacts along with the two primary power circuits. Sequencing within auxiliary positions is possible using the 4 pin lengths available in the 1x4 auxiliary connector. SBE® and SBX® offer touch safe housings. • Silver Plated Wire Contacts up to 350 mcm (185 mm²) Allows low resistance UL rated currents up to 550 amps per pole • Up to 8 Auxiliaries Enables intelligent power switching, CAN and interlock loop circuitry, as well as power up to 20 amps per pole. Auxiliaries are all Last-mate/ First-break relative to power contacts. SBE® 320 / SBX® 350 SBE® 320 / SBX® 350 ORDERING INFORMATION SBE® 320 / SBX® 350 Housings The largest size of SBE®, X, O style housing. SBE® housings are molded from a chemical resistant PBT. SBX® housings are molded from PC. SBE® 320 and SBX® 350 housings of the same Voltage Color-Code cannot be mated. SBX® 350 housings do not meet EN1175-1 requirements for industrial trucks. Description SBE® 320 Part Numbers Minimum Quantity Yellow Orange Red Gray Blue Green Black Brown Purple 100 25 100 2-8171G6 E6362 2-7249G6 2-8171G7 E6339 2-7249G7 2-8171G3 E6352 2-7249G3 2-8171G1 E6350 2-7249G1 2-8171G2 E6351 2-7249G2 2-8171G4 E6353 2-7249G4 2-8171G5 E6361 2-7249G5 2-8171G8 E6336 N/A 2-8171G9 E6349 N/A [ 61.9 ] 2.44 [ 28.6 ] 1.13 Ø [ 6.7 ] 0.27 Top View SBX® 350 Part Numbers 25 6362 6339 6352 6350 6351 6353 6361 N/A N/A [ 83.4 ] 3.28 [ 15.9 ] 0.63 [ 125.4 ] 4.94 [ 200.0 ] 7.88 Mated Length [ 33.3 ] 1.31 SBE® 320 / SBX® 350 Silver Plated Primary Power Wire Contacts Silver plated contacts offer superior electrical performance and durability up to 10,000 mating cycles. See reducing bushings in accessory section for smaller wires. Dimensions - A - - B - - C - -DAWG mm² Loose Piece Part Numbers inches mm inches mm inches mm inches mm D Minimum Quantity 200 150 50 C 300/350 mcm 150 - 6358-BK 6358 * 3.03 76.96 0.88 22.20 0.75 19.05 1.25 31.80 4/0 120 6356-BK - 6356 * 3.10 78.74 0.75 19.05 0.64 16.26 1.25 31.80 B 3/0 95 6355-BK - 6355 * 3.10 78.74 0.70 17.78 0.58 14.73 1.25 31.80 2/0 70 6354-BK - 6354 * 3.10 78.74 0.64 16.26 0.49 12.45 1.25 31.80 2 35 6394-BK - 6394 * 3.10 78.74 0.51 12.95 0.38 9.50 1.25 31.80 * Sold as pairs. 2 parts shipped for every 1 part ordered. SBE® 320 DIN Standard Silver Plated Primary Power Wire Contacts Crimp barrel O.D. are compliant with DIN standard tooling. Will also fit into SBX® 350 housings. Not recommended for cross mating with above typical contacts for SBE® & SBX®. Dimensions Loose Piece - A - - B - - C - -DAWG mm² Part Numbers inches mm inches mm inches mm inches mm Minimum Quantity 200 50 3/0 95 1341G3-BK 1341G3 * 2.89 73.41 0.78 19.81 0.59 14.99 0.94 23.88 2/0 70 1341G2-BK 1341G2 * 2.74 69.60 0.68 17.27 0.51 12.95 0.79 20.07 1341G1-BK 1341G1 * 2.65 67.31 0.57 14.48 0.43 10.92 0.79 20.07 1/0 50 * Sold as pairs. 2 parts shipped for every 1 part ordered. All Data Subject To Change Without Notice D A [ 20.6 ] 0.81 A C B www.andersonpower.com [ 20.6 ] 0.81 - 115 - SBE® 320 / SBX® 350 CONNECTOR TEMPERATURE CHARTS - Temperature rise charts are based on a 25°C ambient temperature. Current - Temperature Derating per IEC 60512-5-2 Test 5B Amperes Applied 50 350 MCM 40 300 MCM 4/0 AWG - 120mm² 30 3/0 AWG 20 2/0 AWG 10 1/0 AWG Ambient Temperature (°C) 125 Amperes Applied 350 MCM 100 300 MCM 4/0 AWG - 120mm² 75 3/0 AWG 2/0 AWG 50 1/0 AWG 0 55 0 45 0 0 35 25 0 15 50 10 0 15 0 20 0 25 0 30 0 35 0 40 0 45 0 50 0 55 0 0 0 25 0 SBE® 320 / SBX® 350 SBE® 320 / SBX® 350 Derating vs. Ambient Temperature 50 Temperature Rise Above Ambient (°C) 60 SBE® 320 / SBX® 350 Temperature Rise at Constant Current SBE® 320 / SBX® 350 CONNECTOR SPECIFICATIONS ELECTRICAL SBX® & SBE® SBE® Only MATERIALS Housings UL CSA EN1175-1 Primary Power (350 MCM) 550 350 320 Powerpole® Auxiliary (12 AWG) 20 20 N/A 1x4 Auxiliary (12 AWG) 20 20 N/A PPMX (20 AWG) 5 5 N/A Current Rating Amperes 1 SBX® and Powerpole® Auxiliary Housings Polycarbonate SBE®, PPMX and 1x4 Auxiliary Housings Polycarbonate / PBT blend Housing Flammability Rating SBX® / SBE® Voltage Rating AC/DC UL IEC (SBE® Only) 94 V-0 960°C (GWFI) 850°C (GWIT) Primary Power (350 MCM) 600 150 4 Contact Materials Powerpole® Auxiliary (12 AWG) 600 150 4 Power Contacts Au Plated Copper 1x4 Auxiliary (12 AWG) 600 N/A Powerpole® Auxiliary Au or Sn - Copper Alloy PPMX (20 AWG) 600 N/A Dielectric Withstanding Voltage Volts AC 2,200 * Average Mated Contact Resistance milliohms 2 1/2 " 350 MCM 0.05 1x4 Auxiliary Contacts Pin Au Over NI - Copper Allow Socket Au Over NI - BeCu Socket Body Sn Over Ni, Copper Alloy Retention Clip Stainless Steel PPMX Contacts Gold Plated Copper Alloy * Not UL rated Contact Terminations 3 - Crimp or Hand Solder - 116 - www.andersonpower.com All Data Subject To Change Without Notice IEC INFORMATION MECHANICAL Wire Size Range AWG mm² Power Contacts 1/0 to 350 MCM 53.5 to 185 Auxiliary Contacts 24 to 10 AWG 0.25 to 5.3 in mm Max Wire Insulation Diameter Power Contact 0.82 * 20.8 * Powerpole® Auxiliary 0.175 4.45 1x4 Auxiliary 0.14 3.6 PPMX Auxiliary 0.09 2.29 °F °C SBX Housing with all Auxiliary -4 to 221 SBE® Housing Connector Series SBE® 320 Creepage / Clearance Material Configurations per IEC Group 60950-1 Unmated 5.6 mm Mated 24.7 mm IIIa SBE® 320 AMP Rating AC/DC 320 Amp Voltage Rating AC/DC (Steady State) 600 V AC/DC (Operational) -20 to -105 -40 to 105 Breaking Capacity AMP Rating / Cycles 275 Amp / 10 Cycles -40 to 221 SBX® Housing with Powerpole® Auxiliary Housings -4 to 221 -20 to -105 Voltage Rating (Breaking Capacity) 220 VDC -40 to 221 -40 to 105 FINGER Safety Mated / Unmated IEC 60529 - IP20 SBE® Housing with 1x4 and PPMX Auxiliaries Wire Size Tested 120 mm² Gold Contact Series Tested 6356 Climatic Testing (Cold, Heat & MFG) IEC 60512 Test -11j, 11i & 11g Cycle Life IEC 60512 Test 9a - 5,000 Cycles Operating Temperature 2 ® Mating Cycles Silver / Tin Power Contacts 10,000 N/A Powerpole® Auxiliary 10,000 / 1500 N/A 1x4 Auxiliary N/A 10,000 PPMX Auxiliary N/A 5,000 Average Mating LBF N Mechanical Strength Impact IEC 60512-5 @ 29.5 Inches Dropped 8 Times Temperature Range -20°C to 105°C Main Connector Housing 37 165 Per Powerpole® Connector 5 22 Per 1x4 Auxiliary Housing 0.7 3 Per PPMX Housing 4.5 20 PROTECTION Min Contact / Spring Retention Force 150 667 Touch Safety Main Connector Housing Powerpole® Housing 25 111 IEC 60950 SBE® 320 Only Pass 1x4 Auxiliary Housing 10 44.5 12 53 IEC 60529 SBE 320 & SBX® 350 IP20 PPMX Housing Min Contact / Spring Retention Force 150 667 Powerpole® Housing 25 111 1x4 Auxiliary Housing 10 44.5 PPMX Housing 12 53 1x4 Auxiliary Housing 10 44.5 PPMX Housing 12 53 SBE® 320 / SBX® 350 ATTRIBUTES -4°F to 221°F ® Note 1: See IEC60664-1 for working voltage Note 2: Amp ratings are stated per position and based on all positions being fully loaded 1 - Based on 195°C rated or better cable of the largest size. Properly calibrated APP® recommended tooling and 25°C ambient temperature 2 - limited by thermal properties of the connector plastic housing 3 - USE APP® recommended tooling only. Alternate tools may adversely affect performance of our connectors along with UL and CSA recognition 4 - Voltage capability of SBE® housings is identical to SBX® but derated to meet EN1175-1 requirements * Refer to assembly instructions for using 300 MCM and 350 MCM wire All Data Subject To Change Without Notice www.andersonpower.com - 117 - SBE® 320 / SBX® 350 ACCESSORIES Cable Clamps Durable metal clamps adapt to a wide range of cable sizes. Cable clamp kit includes clamp top and bottom as well as the hardware bag. Cable Size Min / Max Min / Max Description Inches O.D. mm O.D. Part Number 25 Minimum Quantity Cable Clamp Kit 0.85 to 0.67 21.6 to 17.1 911G2 The given wire O.D. information is an estimate. Cable clamps should be evaluated for performance with the actual wire to be used. Handles * SBE® 320 / SBX® 350 Handles are made out of durable PC plastic. Hardware to attach to connector body included in kits. Description Minimum Quantity Gray Handle Kit Red Handle Kit Handle Only, Gray Handle Only, Red Handle Only, Black Hardware Bag Part Numbers 100 25 995G2-APP 995G2 995G4-APP 995G4 3-5074P1 3-5074P3 3-5074P5 - 106G7 * Torque value 50 (in - lbs) / 5.6 (Nm) NOTE: For assembly of clamps to housing only Powerpole® Auxiliary Powerpole® auxiliary connectors are rated up to 30 amps 600 volts and can be used for auxiliary power, control or sensing. The auxiliary kit includes (1) each black and red standard Powerpole® housing, (2) Contacts, (2) Zip Cable Straps, and (2) Retaining Pins. (1) Retaining Clip can be substituted for (2) Retaining Pins. Description Part Numbers Minimum Quantity 200 25 6305G1 Powerpole® Auxiliary Kit 16 to 12 AWG Contact - 6310G1 Powerpole® Auxiliary Kit 20 to 16 AWG Contact - 1327G6 - Black Powerpole® Housing 1327 Red Powerpole® Housing 16 to 12 AWG Contact 1331 20 to 16 AWG Contact 1332 - NOTE: Finger proof PP15/45 housings should not be used for auxiliary contacts. 1x4 Auxiliary Connector The unique 1x4 auxiliary connector allows up to 4 auxiliary circuits up to 20 amps 150 volts each in SBE®, SBO®, & SBX® housings. The genderless design holds two each of the gold plated pin & socket contacts. This innovation allows the very durable and cost effective design of SBE®,O, X connectors to substitute for DIN 43589-1 applications where 4 auxiliary contacts are required. Multiple pin lengths allow the further benefit of sequencing between circuits. (2) Retaining Pins or (1) Retaining Clip is required to hold the auxiliary housing in place. Auxiliary Kits include (1) Auxiliary Housing, (2) Standard Length Pin Contacts, (2) Socket Contacts, (2) Retaining Pins and (1) Retaining Clip. Description AWG mm² Minimum Quantity 1x4 Auxiliary Kit 12 4 1x4 Auxiliary Kit 16 to 14 1.5 to 2.5 20 to 16 0.75 to 1.5 1x4 Auxiliary Kit 1x4 Auxiliary Housing Contacts Sold Separately - 118 - www.andersonpower.com Part Numbers 1,000 250 - - - - - - 3-5956P1 444G1 25 440G3 440G1 440G2 - Socket Locations [ 8.4 ] 0.33 [ 10.9 ] 0.43 [ 3.8 ] 0.15 [ 41.3 ] 1.62 All Data Subject To Change Without Notice Pin Contacts for 1x4 Auxiliary Connector Gold plated contacts are available in 4 lengths to allow sequencing of circuits. Description AWG mm² Part Numbers 500 50 Minimum Quantity Standard Length 7.7 mm 12 2.5 PM16P12S30 PM16P12S30-50 16 to 14 1.0 to 1.5 PM16P1416S30 PM16P1416S30-50 20 to 16 0.75 to 1.0 PM16P1620S30 PM16P1620S30-50 24 to 20 0.50 to 0.75 PM16P2024S30 PM16P2024S30-50 Pre-Mate 9.3 mm 12 16 to 14 20 to 16 24 to 20 2.5 1.0 to 1.5 0.75 to 1.0 0.50 to 0.75 PM16P12A30 PM16P1416A30 PM16P1620A30 PM16P2024A30 PM16P12A30-50 PM16P1416A30-50 PM16P1620A30-50 PM16P2024A30-50 Post-Mate 6.4 mm 12 16 to 14 20 to 16 24 to 20 2.5 1.0 to 1.5 0.75 to 1.0 0.50 to 0.75 PM16P12C30 PM16P1416C30 PM16P1620C30 PM16P2024C30 PM16P12C30-50 PM16P1416C30-50 PM16P1620C30-50 PM16P2024C30-50 Auxiliary Pin Contact Lengths -L- Retention Clip [ 1.60 ] Ø 0.06 - L1 - mm in. mm Standard Length 7.7 mm 0.77 19.6 0.30 7.7 Pre-Mate 9.3 mm 0.83 21.2 0.37 9.3 Post-Mate 6.4 mm 0.72 18.3 0.25 6.4 L1 L SBE® 320 / SBX® 350 in. Socket Contacts for 1x4 Auxiliary Connector Selectively gold plated contacts offer low resistance and durability up to 10,000 mating cycles. AWG mm² Description Part Numbers Minimum Quantity 500 50 Socket Contact 12 2.5 PM16S12S32 PM16S12S32-50 16 to 14 1.0 to 1.5 PM16S1416S32 PM16S1416S32-50 20 to 16 0.75 to 1.0 PM16S1620S32 PM16S1620S32-50 24 to 20 0.50 to 0.75 PM16S2024S32 PM16S2024S32-50 Auxiliary Socket Contacts Crimp Barrel ID Wire Gauge in. mm. 24 to 20 0.04 1.1 20 to 16 0.07 1.7 16 to 14 0.08 2.1 12 0.10 2.6 [ 19.6 ] 0.77 ID Retention Clip Socket Insert [ 2.6 ] 0.10 SBE® Air Tubes Air tubes fit into SBE® housings to allow electrolyte circulation while charging the battery. Genderless tube design allows the same part to be used on both sides. (2) Retaining Pins or (1) Retaining Clip is required to hold the air tube in place. Retaining Pins are included in Air Tube Kit. Description Part Numbers Minimum Quantity 500 25 Air Tube Kit, Black - 6396G1 Air Tube Only 3-5798P1 - All Data Subject To Change Without Notice www.andersonpower.com - 119 - PPMX Auxiliary Connector The PPMX auxiliary connector allows up to 8 auxiliary circuits to be used in the SBE®, SBO®, & SBX® housings. There are 4 auxiliary circuits per PPMX connector and two PPMX housings fit into the auxiliary port in the main connector housing. Rated up to 7 amps 300 volts per contact, the genderless design holds two each gold plated pin & socket contacts. This innovation allows the very durable and cost effective design of SBE®, O, X connectors to be used for applications requiring up to 8 battery monitoring or equipment vehicle communication circuits. (2) Retaining Pins or (1) Retaining Clip is required to hold the auxiliary housing in place. Auxiliary Kits includes: (1) Auxiliary Housing, (2) Pin Contacts, and (2) Socket Contacts. Description AWG mm² Minimum Quantity PPMX Auxiliary Kit 24 to 20 0.50 to 0.25 1x4 Auxiliary Housing Contacts Sold Separately 4803G3 Part Numbers 1,000 100 25 - 4850G6 4827G6-BK - 4827G6 4827G6 * No extraction tool required for contact removal. 4802G3 Socket Locations SBE® 320 / SBX® 350 Pin & Socket Contacts for PPMX Auxiliary Connector Gold plated contacts are ideal for signal or low power use with durability up to 5,000 mating cycles. Description AWG mm² Minimum Quantity Pin Contacts 24 to 20 0.50 to 0.25 Socket Contacts 24 to 20 0.50 to 0.25 Part Numbers 2,000 50 4803G3-BK 4803G3 4802G3-BK 4802G3 Retaining Clip Retaining clips can be used in place of two retaining pins to hold auxiliary connectors or air tubes. Allows easier removal of auxiliary modules. Description Part Number Minimum Quantity 100 For SBE® 320 & SBX® 350 2-8675P1 Retaining Pins Retaining pins are used to hold accessories in the auxiliary port in SBE®, SBO®, & SBX® housings. Dimension “B” is +/- 0.015 in or 0.38 mm. Dimensions - A - -BDescription Part Number inches mm inches mm Minimum Quantity 1,000 For SBE® 320 & SBX® 350 110G59-BK 0.093 / 0.103 2.36 / 2.62 1.000 25.40 B A - 120 - www.andersonpower.com All Data Subject To Change Without Notice Zip Cable Straps Zip cable straps are used to secure auxiliary wires to the side of the main power cables. Description Minimum Quantity White Use cable ties to secure auxiliary contact leads to one of the main cables. Part Number 1,000 H1835P3 Manual Release - Battery Side * Works with the Charger / Truck side to ease mating and unmating connectors. Description Part Numbers 72 25 Minimum Quantity Bracket and Hardware Kit - 993G1 Battery Bracket Only 111961P1 - 106G6 Hardware Bag * Torque value 50 (in - lbs) / 5.6 (Nm) NOTE: For assembly of bracket to housing only 993G1 111961P1 SBE® 320 / SBX® 350 Manual Release - Charger/ Truck Side * Works with the Battery side to ease mating and unmating connectors. Description Part Numbers Minimum Quantity 25 Bracket and Hardware Kit 994G1 Bracket / Lever Only B00511G4 Hardware Bag 106G6 * Torque value 50 (in lbs) / 5.6 (Nm) 994G1 B00511G4 NOTE: For assembly of bracket to housing only All Data Subject To Change Without Notice www.andersonpower.com - 121 - Reducing Bushings: for Use with Contact Part Number 6354 and Bushing Part Number 5918 Use with contact part number 6354-BK and bushing part number 5918-BK to allow a smaller wire to be used with the connector. Electrical capability is derated with smaller wire. Bushing Part Number 5918 Wire Size Barrel Size AWG mm² AWG mm² Part Numbers Minimum Quantity 1,500 1,000 500 100 1 42.4 - - 5687-BK 5687 1/0 53.5 1/0 53.5 2 33.6 5690-BK - - 5690 1/0 53.5 4 21.2 - 5693-BK - 5693 1/0 53.5 6 13.3 - 5663-BK - 5663 1/0 53.5 10 to 8 5.3 to 8.4 5648-BK - - 5648 Dimensions - ID inches mm 0.39 0.34 0.27 0.22 0.19 9.91 8.64 6.86 5.59 4.83 [ 25.4 ] 1.00 ID Wire Entrance Reducing Bushings: for Use with Contact Part Number 6354 Use with contact part number 6354-BK to allow a smaller wire to be used with the connector. Electrical capability is derated with smaller wire. SBE® 320 / SBX® 350 Contact Barrel Size / Wire Size Minimum Quantity 2/0 AWG (67.4 mm²) 1/0 AWG (53.5 mm²) [ 28.4 ] 1.12 Part Number 500 100 5918-BK 5918 [ 11.1 ] 0.44 Wire Entrance Reducing Bushings: for Use with Contact Part Number 6394 Use with contact part number 6394-BK to allow a smaller wire to be used with the connector. Electrical capability is derated with smaller wire. Contact Barrel Size / Wire Size Part Numbers Minimum Quantity 1,000 100 35 mm² 16 mm² 5920-BK 5920 - 122 - www.andersonpower.com Dimensions - ID inches mm 0.23 5.8 [ 21.4 ] 0.84 ID Wire Entrance All Data Subject To Change Without Notice SBO® / SBE® / SBX® - Tooling Information Wire Size AWG mm² Loose Piece Part Number Contacts Loose Piece Contact Crimp Tools Pneumatic Bench Tool + Locator Number of Crimps N/A N/A N/A 1303G12 1303G28 1303G2 1304G28 Die + + Hand Tools SBE® 320 / SBX® 350 300 MCM 152 6358 4/0 AWG 107.2 6356 N/A 3/0 AWG 85 6355 2/0 AWG 67.4 6354 2 N/A 6394 N/A 95 mm² 1341G3 1303G17 1304G35 N/A 70 mm² 1341G2 1303G12 1304G34 N/A 50 mm² 1341G1 1303G8 1304G36 1387G2 Double 1368 Series SBE® 160 / SBX® 175 53.5 6384G1 1387G2 1303G13 1304G32 Double 2 25 mm² 6384G2 1387G2 1303G13 1304G32 Double 1/0 & #2 53.5 to 5mm2 6384G1 & 6384G2 1387G1 1388G3 1389G3 Single 4 25 1339G4 6 16 1339G1 1389G9 Single 16 to 20 1.3 to .52 1332 12 to 16 3.3 to 1.3 1331 1368 series SBO® 60 / SBE® 80 1387G1 1388G7 1388G6 N/A 1309G4 Powerpole® 15/45 Auxiliary Contacts ** N/A N/A N/A Single 1309G2 or 1309G8 PowerMod® 1x4 Auxiliary Contacts 12 to 24 2.5 to 0.25 All Crimp Pins All Crimp Sockets TP0001* N/A TL0001 TL0002 Single TM0001* PM1000G1 PPMX Auxiliary Contacts 20 to 24 0.50 to 0.25 4803G3 4802G3 TP0001* N/A TL0005 Single TM0001* or PM1000G1 Tools PM1002G1 - 1 x 4 Auxiliary Contact Insertion Tool - For use with PM contacts and 1x4 auxiliary housing (444G1 housings and 441G kits) PM1003G1 - 1 x 4 Auxiliary Contact Insertion Tool - For use with PM contacts and 1x4 auxiliary housing (444G1 housings and 441G kits) PM1003GX - 1x4 Auxiliary contacts Inspection Tool - For use with PM contacts and 1x4 auxiliary housing (444G1 housings and 441G kits) 969P1 - SBE® 160 / SBX® 175 Power Contact Extraction Tool 970P1 - SBE® 320 / SBX® 350 Power Contact Extraction Tool * TP0001 and TM0001 tools require locators to properly position contacts. ** See Powerpole® family tooling chart for other Powerpole® contacts The auxiliary contacts used with wire sizes 16 to 24 AWG cannot be properly inserted without the insertion tool. Properly installed auxiliary contact of all wire gauges cannot be removed from the housing without the extraction tool. Your Best Connection™ 2020-0055 DS-SBEX320-350 REV C7 Anderson™ will use reasonable efforts to include accurate and up-to-date content in the data sheet. All product information contained in the data sheet including ordering information, illustrations, specifications, and dimensions, are believed to be reliable as of the date of publishing, but is subject to change without notice. Anderson™ makes no warranty or representation as to its accuracy. Content in the data sheet may contain technical inaccuracies, typographical errors and may be changed or updated without notice. Anderson™ may also make improvements and/or changes to the products and/or to the programs described in the content at any time without notice. Current sales drawings and specifications are available upon request. ©2020 Anderson Power Products, Inc. All rights reserved. APP®, A®, Anderson Power Products®, SBE®, SBO®, SBX®, PowerMod®, Powerpole® and the APP Logo are registered trademarks of Anderson Power Products, Inc. Anderson™ and Your Best Connection™ are trademarks of Anderson Power Products, Inc. All Data Subject To Change Without Notice www.andersonpower.com - 123 - SBO® / SBE® / SBX® TOOLING 1/0 AWG
120BBS 价格&库存
很抱歉,暂时无法提供与“120BBS”相匹配的价格&库存,您可以联系我们找货
