210-156
210-156
    DIGILENT(迪芝伦)
210-156 数据手册
      VRM: Voltage Regulator Module (Rev. B)  SKU:  210‐156       Product Description  The Digilent VRM (Voltage Regulator Module) is a battery‐friendly, switching voltage regulator capable  of providing 6A of current at 5V or 3.3V. The input voltage can be stepped down from sources as high as  15V. It is ideal for use in Mechatronics or Robotics applications to efficiently regulate battery voltage, or  in any application where a clean step down is required.  Capable of providing 6A of power at multiple voltage levels, the VRM can provide power to multiple 5V  servos, 12V motors, and a system board, allowing your robotics application a simple 1 battery power  system.     Features:         Texas Instruments TPS54620 switching regulator  6A synchronous step down switcher  Selectable 5V or 3.3V output voltage  Input voltage range of 5‐15V  479kHz internal switching frequency  Switching synchronization to an external clock  Screw terminals and pin headers for power input/output                                      http://store.digilentinc.com/vrm‐voltage‐regulator‐module‐rev‐b/ 11‐10‐17
210-156 价格&库存
很抱歉,暂时无法提供与“210-156”相匹配的价格&库存,您可以联系我们找货
  • 2+154.289092+19.95965
库存:2
210-156
  • 2+151.644132+19.61749
库存:2
