COM-16346
COM-16346
    SPARKFUNELECTRONICS
    COM-16346
COM-16346 数据手册
WS2812B Intelligent control LED integrated light source Features and Benefits            Intelligent reverse connect protection, the power supply reverse connection does not damage the IC. The control circuit and the LED share the only power source. Control circuit and RGB chip are integrated in a package of 5050 components, form a complete control of pixel point. Built-in signal reshaping circuit, after wave reshaping to the next driver, ensure wave-form distortion not accumulate. Built-in electric reset circuit and power lost reset circuit. Each pixel of the three primary color can achieve 256 brightness display, completed 16777216 color full color display, and scan frequency not less than 400Hz/s. Cascading port transmission signal by single line. Any two point the distance more than 5m transmission signal without any increase circuit. When the refresh rate is 30fps, cascade number are not less than1024 points. Send data at speeds of 800Kbps. The color of the light were highly consistent, cost-effective.. Applications   Full-color module, Full color soft lights a lamp strip. LED decorative lighting, Indoor/outdoor LED video irregular screen. General description WS2812B is a intelligent control LED light source that the control circuit and RGB chip are integrated in a package of 5050 components. It internal include intelligent digital port data latch and signal reshaping ampli fication drive circuit. Also include a precision internal oscillator and a 12V voltage programmable constant curr e-nt control part, effectively ensuring the pixel point light color height consistent. The data transfer protocol use single NZR communication mode. After the pixel power-on reset, the DIN port receive data from controller, the first pixel collect initial 24bit data then sent to the internal data latch, the other data which reshaping by the internal signal reshaping amplification circuit sent to the next cascade pixel through the DO port. After transmission for each pixel,the signal to reduce 24bit. pixel adopt auto resha -ping transmit technology, making the pixel cascade number is not limited the signal transmission, only depend on the speed of signal transmission. LED with low driving voltage, environmental protection and energy saving, high brightness, scattering angl e is large, good consistency, low power, long life and other advantages. The control chip integrated in LED above becoming more simple circuit, small volume, convenient installation. WS2812B Intelligent control LED integrated light source Mechanical Dimensions PIN configuration PIN function NO. Symbol Function description 1 VDD 2 DOUT 3 VSS Ground 4 DIN Control data signal input Power supply LED Control data signal output Absolute Maximum Ratings Prameter Symbol Ratings Unit Power supply voltage VDD +3.5~+5.3 V Input voltage VI -0.5~VDD+0.5 V Operation junction temperature Topt -25~+80 ℃ Storage temperature range Tstg -40~+105 ℃ Electrical Characteristics(TA=-20~+70℃,VDD=4.5~5.5V,VSS=0V,unless otherwise specified) WS2812B Intelligent control LED integrated light source Prameter Smybol conditions Min Tpy Max Unit Input current II VI=VDD/VSS —— —— ±1 µA VIH DIN,SET 0.7VDD —— —— V VIL DIN,SET —— —— 0.3 VDD V VH DIN,SET —— 0.35 —— V Input voltage level Hysteresis voltage Switching characteristics(TA=-20~+70℃,VDD=4.5~5.5V,VSS=0V,unless otherwise specified) Prameter Symbol Condition Min Tpy Max Unit Transmission delay time tPLZ CL=15pF,DIN→ DOUT,RL=10KΩ —— —— 300 ns Fall time tTHZ CL=300pF,OUTR/OU TG/OUTB —— —— 120 µs Input capcity CI —— —— —— 15 pF RGB IC characteristic parameter Emitting color Model Wavelength(nm) Luminous intensity(mcd) Voltage(V) Red 13CBAUP 620-625 390-420 2.0-2.2 Green 13CGAUP 522-525 660-720 3.0-3.4 Blue 10R1MUX 465-467 180-200 3.0-3.4 Data transfer time( TH+TL=1.25µs±600ns) T0H 0 code ,high voltage time 0.4us ±150ns T1H 1 code ,high voltage time 0.8us ±150ns T0L 0 code , low voltage time 0.85us ±150ns T1L 1 code ,low voltage time 0.45us ±150ns RES low voltage time Above 50µs Sequence chart: WS2812B Intelligent control LED integrated light source T0L 0 code T0H T1L 1 code T1H Treset RET code Cascade method: D1 DIN DO D2 PIX1 DIN DO PIX2 D3 D4 DIN DO PIX3 Data transmission method: reset code >=50us Data refresh cycle 1 D1 D2 D3 D4 first 2 4 b it seco n d th ird 2 4 b it 2 4 b it seco n d 2 4 b it th ird 2 4 b it th ird 2 4 b it reset code Data refresh cycle 2 first 2 4 b it seco n d 2 4 b it th ird 2 4 b it seco n d 2 4 b it th ird 2 4 b it th ird 2 4 b it WS2812B Intelligent control LED integrated light source Note: The data of D1 is send by MCU,and D2, D3, D4 through pixel internal reshaping amplification to transmit. Composition of 24bit data: G7 G6 G5 G4 G3 G2 G1 G0 R7 R6 R5 R4 R3 R2 R1 R0 Note: Follow the order of GRB to sent data and the high bit sent at first. Typical application circuit: U1 5V 1 C1 104 2 VDD DIN DOUT VSS 4 DIN 3 WS2812B U2 5V 1 C2 104 2 VDD DIN DOUT VSS 4 3 WS2812B U1 5V 1 C1 104 DOUT2 VDD DIN DOUT VSS WS2812B 4 3 B7 B6 B5 B4 B3 B2 B1 B0
COM-16346 价格&库存
很抱歉,暂时无法提供与“COM-16346”相匹配的价格&库存,您可以联系我们找货
