IN-S42AT series
Top View SMD LED 0402 PCB Type
Features
0402 0.45mm SMD LED
High Brightness
AlInGaP / InGaN Technology
Small package
High reliability
Clear Lens
Description
The IN-S42AT series is a popular low profile 0402
package with versatile design capabilities. It is a PCB
type molding style LED which can be used in various
applications.
Recommended Solder Pattern
Applications
Consumer Electronics
Wearables
Automobile After Market
Industrial Equipment
Figure 1. IN-S42AT Solder Pattern
Package Dimensions in mm
Figure 2. IN-S42AT Package Dimensions
Inolux Corporation
Proprietary & Confidential
Page 1
April 25, 2017
www.inolux-corp.com
IN-S42AT series
Absolute Maximum Rating at 25oC (Note 1)
Product
Emission
Color
Pd (mW)
IF (mA)
IFP* (mA)
VR (V)
TOP (oC)
IN-S42ATYG
Yellow Green
78
25
100
5
-30 C~+80 C
IN-S42ATY
Yellow
78
25
100
5
-30 C~+80 C
IN-S42ATA
Amber
78
25
100
5
-30 C~+80 C
IN-S42ATR
Red
78
25
100
5
-30 C~+80 C
IN-S42ATB
Blue
100
25
100
5
-30 C~+80 C
IN-S42ATG
Green
100
25
100
5
-30 C~+80 C
IN-S42ATUW
White
100
25
100
5
-30 C~+80 C
TST (oC)
o
o
-40 C~+85 C
o
o
o
o
-40 C~+85 C
o
o
o
o
-40 C~+85 C
o
o
o
o
-40 C~+85 C
o
o
o
o
-40 C~+85 C
o
o
o
o
-40 C~+85 C
o
o
o
o
-40 C~+85 C
o
o
Notes
1. Condition for IFP is pulse of 1/10 duty and 0.1msec width
ESD Precaution
ATTENTION: Electrostatic Discharge (ESD) protection
The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even
though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based
chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly.
If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process.
Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which
may be induced by electrostatic discharge (ESD).
Inolux Corporation
Page 2
April 25, 2017
www.inolux-corp.com
IN-S42AT series
Electrical Characteristics T
A
= 25°C (Note 1)
VF(V)
Product
Emission
Color
IN-S42ATYG Yellow Green
λ(nm)
IF(mA)
Viewing
Angle
I*V(mcd)
typ.
max
λD
λP
△λ
2θ1/2
typ.
2.6
572
575
130
28.5
IN-S42ATY
Yellow
2.6
592
593
130
145
IN-S42ATA
Amber
2.6
605
610
130
145
IN-S42ATR
Red
2.6
631
645
130
90
IN-S42ATB
Blue
4.0
470
468
120
100
IN-S42ATG
Green
4.0
525
523
130
450
IN-S42ATUW
White
4.0
X=0.295
Y=0.30
130
600
Notes
1. Performance guaranteed only under conditions listed in above tables.
Inolux Corporation
Page 3
April 25, 2017
www.inolux-corp.com
IN-S42AT series
Chromaticity Bin (for White only)
BIN
R27
R29
R31
CIE
X
Y
X
Y
X
Y
Top
0.275
0.27
0.285
0.29
0.295
0.31
Inolux Corporation
Right
0.285
0.28
0.295
0.3
0.305
0.32
Bottom
0.305
0.28
0.315
0.3
0.325
0.32
Left
0.295
0.27
0.305
0.29
0.315
0.31
BIN
R28
R30
Page 4
CIE
X
Y
X
Y
Top
0.28
0.28
0.29
0.3
Right
0.29
0.29
0.3
0.31
Bottom
0.31
0.29
0.32
0.31
Left
0.3
0.28
0.31
0.3
April 25, 2017
www.inolux-corp.com
IN-S42AT series
Typical Characteristic Curves – YG, Y, A, R
Inolux Corporation
Page 5
April 25, 2017
www.inolux-corp.com
IN-S42AT series
Typical Characteristic Curves – B, G, W
Inolux Corporation
Page 6
April 25, 2017
www.inolux-corp.com
IN-S42AT series
Typical Characteristic Curves – Radiation Pattern
Ordering Information
Product
Technolog Test Current
Emission Color
y
IF (mA)
Forward
Luminous Intensity
Voltage
IV (mcd)
VF (V)
(Typ.)
(Typ.)
Orderable
Part Number
IN-S42ATYG
Yellow Green
AllnGaP
1.9
IN-S42ATYG
IN-S42ATY
Yellow
AllnGaP
2.0
IN-S42ATY
IN-S42ATA
Amber
AllnGaP
2.1
IN-S42ATA
IN-S42ATR
Red
AllnGaP
2.1
IN-S42ATR
IN-S42ATB
Blue
InGaN
3.1
IN-S42ATB
IN-S42ATG
Green
InGaN
3.3
IN-S42ATG
IN-S42ATUW
White
InGaN
3.1
IN-S42ATUW
Inolux Corporation
Page 7
April 25, 2017
www.inolux-corp.com
IN-S42AT series
Label Specifications
Inolux P/N:
I
N
S
Material
Inolux
SMD
4
2
Package
S = PCB
Type
A
T
Variation
Orientation
42A = 1.0 x 0.5 x
0.45mm
T = Top Mount
X
Lens
Color
Customized
Stamp-off
(Blank) =
20mA
5=5mA
(Blank) = Clear
U = Diffused
R=645m
A=610nm
Y=593nm
YG=575nm
G=523nm
B=468nm
W=White
7
01
24
001
Month
Date
Serial
Current
X
X X X
Lot No.:
Z
Internal
Tracker
Inolux Corporation
2
Year (2017, 2018, …..)
Page 8
April 25, 2017
www.inolux-corp.com
IN-S42AT series
Packaging Information: 5000pcs Per Reel
Tape Dimension
Reel Dimension
Inolux Corporation
Page 9
April 25, 2017
www.inolux-corp.com
IN-S42AT series
Packing Dimension
Inolux Corporation
Page 10
April 25, 2017
www.inolux-corp.com
IN-S42AT series
Dry Pack
All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during
transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly
sealed prior to shipment.
Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment.
The packaging sequence is as follows:
Reflow Soldering
• Recommended tin glue specifications: melting temperature in the range of 178~192 OC
• The recommended reflow soldering profile is as follows (temperatures indicated are as measured on
the surface of the LED resin):
Lead-free Solder Profile
Inolux Corporation
Page 11
April 25, 2017
www.inolux-corp.com
IN-S42AT series
Precautions
Avoid exposure to moisture at all times during transportation or storage.
Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products.
It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a
reverse voltage.
Avoid operation beyond the limits as specified by the absolute maximum ratings.
Avoid direct contact with the surface through which the LED emits light.
If possible, assemble the unit in a clean room or dust-free environment.
Reworking
Rework should be completed within 5 seconds under 260 OC.
The iron tip must not come in contact with the copper foil.
Twin-head type is preferred.
Cleaning
Following are cleaning procedures after soldering:
• An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended.
• Temperature x Time should be 50oC x 30sec. or
很抱歉,暂时无法提供与“IN-S42ATUW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+0.920305000+0.11941
- 10000+0.8677310000+0.11259
- 15000+0.8407515000+0.10909
- 25000+0.8103025000+0.10514
- 35000+0.7921835000+0.10279
- 50000+0.7745050000+0.10049
- 国内价格
- 1+2.57647
- 10+1.78233
- 25+1.54995
- 100+1.26368
- 500+1.02053
- 1000+0.94027
- 2000+0.86721
- 2500+0.85044
- 5000+0.79414
- 10000+0.73784
- 国内价格 香港价格
- 1+2.994501+0.38854
- 10+2.0450010+0.26534
- 100+1.44344100+0.18729
- 500+1.17118500+0.15196
- 1000+1.081111000+0.14028
- 2000+1.004372000+0.13032
- 国内价格
- 5+1.38435
- 50+1.23056
- 150+1.16468
- 500+1.08249
- 2500+1.04588
- 5000+1.02384
- 国内价格
- 50+0.77000
- 1000+0.73500
