471-034-1
471-034-1
    DIGILENT(迪芝伦)
471-034-1 数据手册
      ZedBoard Advanced Image Processing Kit  SKU:  471‐034‐1  Product Description    The ZedBoard Advanced Image Processing Kit was built to use the video processing capabilities  of the Zynq‐7000 AP SoC's tightly coupled ARM processing system and 7‐series programmable  logic. Included in the bundle is a ZedBoard, an FMC Pcam Adapter, and up to four Pcams to  create the ultimate video streaming setup. This bundle has everything you'll need for setup,  including the ribbon cables for connection to the Pcams and Pcam Adapter.     Users can take advantage of our project demonstrations to get started:    ZedBoard FMC Pcam Adapter: One to Four Camera Demo   ZedBoard FMC Pcam Adapter: Two Camera Demo  ZedBoard Features:              Xilinx Zynq‐7000 AP SoC XC7Z020‐CLG484  Dual‐core ARM Cortex™‐A9   512 MB DDR3   256 MB Quad‐SPI Flash   On‐board USB‐JTAG Programming  10/100/1000 Ethernet   USB OTG 2.0 and USB‐UART   Analog Devices ADAU1761 SigmaDSP® Stereo, Low Power, 96 kHz, 24‐Bit Audio Codec  Analog Devices ADV7511 High Performance 225 MHz HDMI Transmitter (1080p HDMI, 8‐bit VGA,  128x32 OLED)  PS & PL I/O expansion (FMC, Pmod, XADC)     FMC Pcam Adapter Features:        Two/Four Pcam system‐side connectors  Level translators from MIPI D‐PHY to LVDS and LVCMOS  Male FMC LPC connector for digital signals  Compatible with a wide range of VADJ voltages (1.8V – 3.3V)    Pcam 5C Features:              5MP color system‐on‐chip image sensor  15‐pin FFC connector for image data  Dual lane MIPI CSI‐2 image sensor interface  Supports QSXGA@15Hz, 1080p@30Hz, 720p@60Hz, VGA@90Hz and QVGA@120Hz  Output formats include RAW10, RGB565, CCIR656, YUV422/420, YCbCr422, and JPEG compression*  Standard M12 lens mount for lens interchangeability  Ships with 10 cm cable and factory installed fixed‐focus lens  Small PCB size for flexible designs (4.0 cm x 2.5 cm)  1×7 straight 100‐mil header for access to auxiliary camera signals  Works with Pcam compatible Digilent development boards    *JPEG compressed output is a feature of the OV5640, but is currently untested on this module       What's  Included:        ZedBoard Zynq‐7000 ARM/FPGA  SoC Development Board Choose between bundling with two or four Pcam 5C fixed focus color camera  modules, which also come with:   10 cm ribbon cable   Factory installed fixed focus‐lens  One Pcam Adapter  12 V AC/DC power supply (US & EU adapters ‐ UK plug adapter not included)  4 GB SD Card  USB A to micro‐B cable  USB Adapter: Male Micro‐B to Female Standard‐A  Custom Digilent cardboard packaging with protective foam                  https://store.digilentinc.com/zedboard‐advanced‐image‐processing‐kit//10‐15‐19
471-034-1 价格&库存
很抱歉,暂时无法提供与“471-034-1”相匹配的价格&库存,您可以联系我们找货
