LCDA03
THRU
LCDA24
Technical Data
Data Sheet N0284, Rev. A
LCDA03 THRU LCDA24 TVS ARRAY SERIES
Description
The LCDAXX series of TVS array are designed to
protect sensitive electronics from damage or latchup due to ESD and other voltage-induced transient
events. Each device will protect two high-speed
lines. They are bi-directed devices and may be used
on lines where the signal polarities are above and
below ground
SO-8
Features
Schematic & Pin Configuration
Mechanical Characteristics
Protects 3.3, 5, 12, 15, 24 V Components
Bidirectional
Low capacitance for high-speed date lines
300 W @ 8/20 us
Protect 2 I/O Lines
SO-8 Packaging
Solid-state silicon avalanche technology
“-A” is an AEC-Q101 qualified device
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Application
SO-8 Surface Mount Package
Approximate Weight: 0.1 grams
PIN #1 Indicator: DOT on top of package
Packaging: Tubes or Tape & Reel per EIA
Standard 481
High-Speed Data Lines
Microprocessor Based Equipment
Universal Serial Bus(USB) Port Protection
Notebooks, Desktops, & Servers
Instrumentation
LAN/WAN Equipment
Peripherals
Absolute Maximum Ratings:
Parameter
Symbol
Value
Units
Peak Pulse Power, 8/20 μs Wave shape
P
300
W
Operating Temperature
TJ
-55 to +125
C
Storage Temperature
Tstg
-55 to +150
C
Lead Soldering Temperature
TL
260 (10 Sec.)
C
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
LCDA03
THRU
LCDA24
Technical Data
Electrical Characteristics@25°C
Stand-off
Voltage
Vwm
(V)
Max
Breakdown
Voltage
VBR
@1mA
(V)
Min
Clamping
Voltage
Vc
@1A
(V)
Max
Leakage
Current
IR
@ Vwm
(uA)
Max
Capacitance
(f = 1MHz)
C
@ 0V
(pF)
Max
Temperature
Coefficient of
VBR
a(VBR)
mv/°C
Max
LCDA03
3.3
4
7
200
5
-5
LCDA05
5.0
6
9.8
1
LCDA12
12.0
13.3
19
1
5
8
LCDA15
15.0
16.7
24
1
5
11
LCDA24
24.0
26.7
43
1
5
28
Part Number
Ratings and Characteristics Curves
Ordering Information
Device
LCDA03
THRU
LCDA24
LCDA03TR
THRU
LCDA24TR
Marking Diagram
Package
Shipping
SO-8 (Pb-Free)
2500pcs / reel
SO-8 (Pb-Free)
2500pcs / reel
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
Where XXXXX is YYWWL
LCDA03 = Part Name
-A
S
YY
WW
L
= AEC-Q101
=S
= Year
= Weak
= Lot Number
LCDA03
THRU
LCDA24
Technical Data
Circuit Diagram
The devices are connected as follows:
✔ Pins 1 and 2 are tied together and pins 7 and 8 are tied together providing the protection circuit for one I/O line. Pins 3
and 4 are tied together and pins 5 and 6 are tied together providing the protection circuit for the second I/O line. Since the
device is electrically symmetrical, either side of the connected pairs may be used to protect the lines. The other side of
the pair is used to make the ground connection. The ground connections should be made directly to the ground plane for
best results. The path length is kept as short as possible to reduce the effects of parasitic inductance in the board traces.
Mechanical Dimensions SO-8
SYMBOL
Millimeters
Inches
MIN.
MAX.
MIN.
MAX.
A
A1
A2
b
1.350
0.100
1.350
0.306
1.800
0.250
1.750
0.510
0.053
0.004
0.053
0.012
0.071
0.010
0.069
0.020
c
0.150
0.300
0.006
0.012
D
e
E
E1
L
4.720
1.140
5.700
3.750
0.300
5.120
1.400
6.300
4.150
1.270
0.186
0.045
0.224
0.148
0.012
0.202
0.055
0.248
0.163
0.050
θ
0°
8°
0°
8°
Carrier Tape Specification SO-8
LCDA03
THRU
LCDA24
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of
the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during
operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property
claims or any other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“LCDA12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.17273
- 50+1.76252
- 150+1.58675
- 500+1.36739
- 2500+1.23070
- 5000+1.17204
- 国内价格 香港价格
- 2500+1.779022500+0.22248
- 5000+1.688545000+0.21117
- 12500+1.5679412500+0.19609
- 25000+1.5317525000+0.19156
- 国内价格 香港价格
- 1+5.292571+0.66188
- 10+4.5095210+0.56395
- 100+3.13572100+0.39215
- 500+2.44845500+0.30620
- 1000+1.990101000+0.24888
