IN-P55TATRGB
IN-P55TATRGB
    INOLUX(英诺斯)
    PLCC-6
    是一款受欢迎的低矮型 RGB 5050 封装产品,具有多种设计能力。它是 PLCC 类型的 LED,可用于各种应用。
IN-P55TATRGB 数据手册
IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Features • 5050 top view SMD LED • High Brightness • AlInGaP / InGaN Technology • Small package • High reliability • Clear Lens Description The IN-P55TATRGB is a popular low profile RGB 5050 package with versatile design capabilities. It is a PLCC type LED which can be used in various applications. Recommended Solder Pattern Applications • Consumer Electronics • Light pipe application • Automobile After Market • Industrial Equipment Figure 1. IN-P55TATRGB Solder Pattern Package Dimensions in mm Figure 2. IN-P55TATRGB Package Dimensions Inolux Corporation Proprietary & Confidential April 26, 2017 Page 1 www.inolux-corp.com IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Absolute Maximum Rating at 25oC (Note 1) Product Emission Color Pd (mW) IF (mA) IFP* (mA) VR (V) TOP (oC) IN-P55TATRGB Red 60 25 100 5 -40 C~+80 C IN-P55TATRGB Green 95 25 100 5 -40 C~+80 C IN-P55TATRGB Blue 95 25 100 5 -40 C~+80 C TST (oC) o o -40 C~+85 C o o o o -40 C~+85 C o o o o -40 C~+85 C o o Notes 1. Condition for IFP is pulse of 1/10 duty and 0.1msec width Electrical Characteristics T A = 25°C (Note 1) VF(V) Emission Color IF(mA) IN-P55TATRGB Red IN-P55TATRGB IN-P55TATRGB Product λ(nm) Viewing Angle I*V(mcd) min max λD λP △λ 2θ1/2 typ. 20 1.6 2.4 624 632 20 120 900 Green 20 2.8 3.4 520 525 35 120 1800 Blue 20 2.8 3.4 468 470 25 120 600 Notes 1. Performance guaranteed only under conditions listed in above tables. ESD Precaution ATTENTION: Electrostatic Discharge (ESD) protection The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which may be induced by electrostatic discharge (ESD). Inolux Corporation Proprietary & Confidential April 26, 2017 Page 2 www.inolux-corp.com IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Luminous Intensity (Iv) Bin: Color Red Green Blue Bin Code B1 B2 B3 B4 B5 B6 E1 E2 E3 E4 E5 E6 H1 H2 H3 H4 H5 H6 Spec. Range 600-700 mcd 700-800 mcd 800-900 mcd 900-1000 mcd 1000-1100 mcd 1100-1200 mcd 1500-1600 mcd 1600-1700 mcd 1700-1800 mcd 1800-1900 mcd 1900-2000 mcd 2000-2100 mcd 300-400 mcd 400-500 mcd 500-600 mcd 600-700 mcd 700-800 mcd 800-900 mcd O @20mA / Ta=25 C, Tolerance: ± 10% Dominant Wavelength (λD) Bin: Color Red Green Blue Bin Code A1 A2 A3 D1 D2 D3 G1 G2 G3 Spec. Range 620-625 nm 625-630 nm 630-635 nm 520-525 nm 525-530 nm 530-535 nm 460-465 nm 465-470 nm 470-475 nm Forward Color Red Green Blue Voltage (Vf) Bin: Bin Code C0 C1 C2 F1 F2 F3 V1 V2 V3 Spec. Range 1.80-2.00 V 2.00-2.20 V 2.20-2.40 V 2.80-3.00 V 3.00-3.20 V 3.20-3.40 V 2.80-3.00 V 3.00-3.20 V 3.20-3.40 V Inolux Corporation Proprietary & Confidential April 26, 2017 Page 3 www.inolux-corp.com IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Typical Characteristic Curves-Red Inolux Corporation Proprietary & Confidential April 26, 2017 Page 4 www.inolux-corp.com IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Typical Characteristic Curves-Green Inolux Corporation Proprietary & Confidential April 26, 2017 Page 5 www.inolux-corp.com IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Typical Characteristic Curves-Blue Inolux Corporation Proprietary & Confidential April 26, 2017 Page 6 www.inolux-corp.com IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Ordering Information Product Test Current Emission Color Technology IF (mA) IN-P55TATRGB • Luminous Intensity IV (mcd) (Typ.) Forward Voltage VF (V) (Typ.) Red AlInGaP 20 900 2.0 Green InGaN 20 1800 3.2 Blue InGaN 20 600 3.2 Orderable Part Number IN-P55TATRGB Bin Range specified on page 3. Inolux Corporation Proprietary & Confidential April 26, 2017 Page 7 www.inolux-corp.com IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Label Specifications Inolux P/N: I N - P 5 Material Inolux SMD P = PLCC Type 5 Package TA T Variation Orientation 55TA = 5.0 x 5.5 x 1.5 mm T = Top Mount Current Lens (Blank) = 20mA (Blank) = Clear per Chip R G B Color R=632nm G=520nm B=470nm - X X X X Customized Stamp-off Lot No.: Z Internal Tracker 2 0 1 7 Year (2017, 2018, …..) Inolux Corporation Proprietary & Confidential 01 24 001 Month Date Serial April 26, 2017 Page 8 www.inolux-corp.com IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Packaging Information: 1000pcs Per Reel Tape Dimension Reel Dimension Inolux Corporation Proprietary & Confidential April 26, 2017 Page 9 www.inolux-corp.com IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Packing Dimension 5 boxes per carton are available depending on shipment quantity. Specification Per EIA 481-1A specs Per EIA 481-1A specs IN standard 220x240mm IN standard Material Conductive black tape Conductive black Paper Aluminum laminated bag/ no-zipper Paper Quantity Carrier tape 1000pcs per reel Reel Label Packing bag One reel per bag Carton Non-specified Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Inolux Corporation Proprietary & Confidential April 26, 2017 Page 10 www.inolux-corp.com IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Reflow Soldering • Recommended tin glue specifications: melting temperature in the range of 178~192 OC • The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Lead-free Solder Profile Inolux Corporation Proprietary & Confidential April 26, 2017 Page 11 www.inolux-corp.com IN-P55TATRGB 1.5mm 5050 PLCC-6 Top View Precautions • • • • • • Avoid exposure to moisture at all times during transportation or storage. Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products. It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a reverse voltage. Avoid operation beyond the limits as specified by the absolute maximum ratings. Avoid direct contact with the surface through which the LED emits light. If possible, assemble the unit in a clean room or dust-free environment. Reworking • • • Rework should be completed within 5 seconds under 260 OC. The iron tip must not come in contact with the copper foil. Twin-head type is preferred. Cleaning Following are cleaning procedures after soldering: • An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended. • Temperature x Time should be 50oC x 30sec. or
IN-P55TATRGB 价格&库存
很抱歉,暂时无法提供与“IN-P55TATRGB”相匹配的价格&库存,您可以联系我们找货
IN-P55TATRGB
    IN-P55TATRGB
      IN-P55TATRGB
        库存:3000
