SDU850A
SDU850A
    SOLAHD
    SDU850A
SDU850A 数据手册
Uninterruptible Power Supplies SDU AC -A Series, DIN Rail UPS The SolaHD SDU AC - A Series DIN Rail UPS combines an industry leading compact design with a wide operation temperature range, enhanced communication and unique installation options. The SDU Series provides economical protection from damaging impulses and power interruptions. These units include easy to wire screw terminations for critical devices needing battery back up such as computer based control systems. Applications • Programmable Logic Controllers • Factory Automation • Robotics • Conveying Equipment • Computer based Control Systems E179213 E491259 • Features • Lightweight, compact industrial design • Communications port for optional Industrial Ethernet protocols or discrete communication card • Wide operation temperature range (0°C to 50°C) • Cold start capability • Software and cable included for easy installation • Simulated sinewave output • USB communication port • Remote turn-on and shutdown capabilities • Two year limited warranty • Panel/wall mounting brackets (optional) Certifications and Compliances UL Recognized Component, UPS Equipment, UL 60950 E1729213 E137632 CUL/CSA-C22.2 No. 234-M90 - UL 1778 5th Ed., CSA C22.2 No. 107.3 - Suitable for UL 508 at full load output (no derating) and Ind. Control Equipment Applications Overvoltage Cat III, Pollution Degree III • UL Recognized Component, Hazardous UL 60950 Locations E491259 E137632 CUL/CSA-C22.2 No. 234-M90 - ANSI ISA 12.12.01/CSA 213 - Class I, Division 2, Groups A, B, C, D, T3 • ODVA Compliant - EtherNet/IP™ SDUENETIPCARD has been tested and approved for conformance by the ODVA. More information about EtherNet/IP™ and the ODVA can be obtained from the following website: www.odva.org. • RoHS Compliant Related Products • • Portable MCR Power Conditioners • STV Surge Protective Devices • SDN DIN Rail Power Supplies • STFV Plus Active Tracking® Filters - Low Voltage Directive: EN62040-1 - EMC Directive: EN62040-2 Selection Table Catalog Number Capacity (VA/W) SDU 500A 500/300 SDU 850A 850/510 SDU 500A-5 500/300 SDU 850A-5 850/510 Volts, Frequency In/Out 120 Vac, 50/60 Hz 230 Vac, 50/60 Hz Typical Back-Up Time (minutes) At full load/half load. Input/Output Connections 4/18 2/10 4/18 2/10 Approx. Ship Weight - lbs (kg) 10.6 (4.8) IP20 touch proof, screw terminals. Wire range: 10 ~ 18 AWG. 11.5 (5.2) 10.6 (4.8) 11.5 (5.2) Note: Run times in this table are approximate. They are based upon new, fully charged standard battery modules at a temperature of 25°C (77°F) with 100% resistive UPS loading. Run times listed above can vary by +/-5% due to manufacturing variances of the individual batteries Visit our website at www.emerson.com or contact Technical Services at (800) 377-4384 with any questions. © December 2018 65 Uninterruptible Power Supplies Specifications Catalog Number Capacity (VA/Watts) SDU 500A SDU 850A SDU 500A-5 SDU 850A-5 500/300 850/510 500/300 850/510 0.6 Load Power Factor Dimensions - inches (mm) 4.87 x 11.1 x 4.81 (123.7 x 281.9 x 122.3) Unit (H x W x D) - in. (mm) Weight - lbs (kg) 10.6 (4.8) 11.5 (5.2) 10.6 (4.8) 11.5 (5.2) Input Parameters 120 V (+10%, -20%) Voltage 230 V (+/- 15%) 50 +/- 5 Hz or 60 Hz +/- 6 Hz (auto sensing) Frequency Output AC Parameters Simulated sinewave Voltage (Battery Mode) +/- 5% 50 or 60 Hz +/- 0.3 Hz Frequency (On Battery) UPS automatic shutdown if overload exceeds: 105% of nominal at 20 seconds, 120% of nominal at 10 seconds, 130% of nominal at 3 seconds Overload Protection UPS shutdown, auto-recovery Short Circuit Battery Parameters Battery Type Sealed, non-spillable, maintenance-free lead acid batteries Transfer Time Typical
SDU850A 价格&库存
很抱歉,暂时无法提供与“SDU850A”相匹配的价格&库存,您可以联系我们找货
