LEA75F-15-RV
LEA75F-15-RV
    COSEL
    模块
    LEA75F-15-RV
LEA75F-15-RV 数据手册
Ordering information AC-DC Power Supplies Open Frame/Enclosed type LEA50F LEA 1 50 2 F 3 -5 4 Recommended EMI/EMC Filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series *The EMI/EMC Filter is recommended *to connect with several devices. -O 5 1Series name 2Output wattage 3Universal input 4Output voltage 5Optional *6 C :with Coating G :Low leakage current J2:Mini terminal block R :with Remote ON/OFF S :with Chassis SN :with Chassis & cover Y :with Potentiometer LEA MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT *5 LEA50F-3R3-Y LEA50F-5 33 50 3.3V 10A 5V 10A LEA50F-9 50.4 9V 5.6A LEA50F-12 LEA50F-15 LEA50F-18 LEA50F-24 LEA50F-24-H LEA50F-30 LEA50F-48 51.6 52.5 50.4 50.4 50.4 51 52.8 12V 4.3A 15V 3.5A 18V 2.8A 24V 2.1A 24V 2.1(2.6)A 30V 1.7A 48V 1.1A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] *1 LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *2 RIPPLE[mVp-p] -10 - 0C *2 0 to +50C *2 RIPPLE NOISE[mVp-p] -10 - 0C *2 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *3 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT -RC *4 INPUT-FG OUTPUT-RC-FG *4 OUTPUT-RC *4 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LEA50F-3R3-Y LEA50F-5 LEA50F-9 LEA50F-12 LEA50F-15 LEA50F-18 LEA50F-24 LEA50F-24-H AC85 - 264 1f or DC120 - 370 0.6 0.7typ 0.3 0.35typ 50/60 (47 - 63) or DC 70typ 75typ 78typ 78typ 79typ 80typ 81typ 81typ 71typ 77typ 80typ 80typ 81typ 82typ 83typ 83typ 0.98typ 0.99typ 0.91typ 0.93typ 15typ (Io=100%) (At cold start) (Ta=25 C) 30typ (Io=100%) (At cold start) (Ta=25 C) 0.75max (60Hz, According to IEC62368-1 and DEN-AN) 3.3 5 9 12 15 18 24 24 10 10 5.6 4.3 3.5 2.8 2.1 2.1 (Peak 2.6) 20max 20max 36max 48max 60max 72max 96max 96max 40max 40max 100max 100max 120max 120max 150max 150max 80max 80max 120max 120max 120max 120max 120max 120max 140max 140max 160max 160max 160max 160max 160max 160max 120max 120max 150max 150max 150max 150max 150max 150max 160max 160max 180max 180max 180max 180max 180max 180max 50max 50max 90max 120max 150max 180max 240max 240max 60max 60max 120max 150max 180max 200max 290max 290max 20max 20max 36max 48max 60max 72max 96max 96max 500max (ACIN 100V, Io=100%) 20typ (Io=100%) 2.85 - 3.6 Fixed ("Y"which can be adjusted the output is available as optional:t10%) 3.25 - 3.35 4.9 - 5.3 8.6 - 9.4 11.5 - 12.5 14.4 - 15.6 17.3 - 18.7 23.0 - 25.0 23.0 - 25.0 Works over 105% of rating (works over 105% of peak current at option -H) and recovers automatically 4.00 - 5.25V Works at 115 - 140% of rating Not provided Not provided Option (Refer to Instruction Manual) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) AC100V 1minute, Cutoff current = 100mA, DC100V 10MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL, EN62368-1 Complies with DEN-AN and IEC62368-1 (At only AC input) Complies with FCC-B, CISPR22-B, EN55022-B, VCCI-B Complies with IEC61000-3-2 55X26X195mm (WXHXD) /210g max (without chassis and cover) Convection *1 Peak load for 10sec. or less is acceptable if the total wattage is less than the rated wattage. *2 This is the value that measured on measuring board with capacitor of 22mF within 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM101). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, LEA-2 *4 *5 *6 * * LEA50F-30 LEA50F-48 82typ 84typ 83typ 85typ 30 1.7 120max 180max 120max 160max 150max 180max 300max 360max 120max 48 1.1 192max 300max 150max 200max 350max 400max 480max 600max 192max 28.5 - 31.5 46.0 - 50.0 with the input voltage held constant at the rated input/output. Applicable when remote control (optional) is added. ( ):peak current. Please contact us about safety approvals for the model with option. Parallel operation with other model is not possible. Derating is required when operated with chassis and cover. January 20, 2022 LEA50F External view 55 RC(-) RC(+) FG AC(N) AC(L) 45-+0.5 17.5 CN3 CN1 Output(-) Output(+) C119 2-º3.5 4-º3.5 Mounting Hole Connector for Remote ON/OFF (optional) CN3 CN2 4-M3 Mounting Hole CN1 5 CN2 7 210-+0.5 3.5 32 65 23 Name plate 40 -+0.5 12 20 -+0.5 22 Voltage adjust (optional) 185-+0.5 195 5 225 210-+0.5 7 3.5 LEA 15 10 36 2-M3 Mounting Hole (Lead) 3max 23 º3.5 PCB t=1.6 PIN CONNECTION I / O Connector Mating Connector VHR-5N CN1 B3P5-VH CN2 B4P-VH VHR-4N CN3 B2B-XH-A XHP-2 Terminal Chain : SVH-21T-P1.1 Loose: BVH-21T-P1.1 Chain : SVH-21T-P1.1 Loose: BVH-21T-P1.1 Chain : SXH-001T-P0.6 Loose: BXH-001T-P0.6 (Mfr: J.S.T.) ¶Weight: 210g or less (Without chassis and cover) ¶Tolerance: t1 ¶Dimensions in mm. ¶PCB Material: Glass composite (CEM3) ¶Chassis and cover is optional. ¶Mounting torque: 0.6N · m(6.3kg f · cm)max Optional Pin No. Input 1 AC(L) 2 CN1 3 AC(N) 4 5 FG Pin No. Output CN2 1 -V 2 -V 3 +V 4 +V Pin No. Remote ON/OFF 1 RC(+) 2 RC(-) CN3 ¶Keep drawing current per pin below 5A for CN2 Performance data ¡RISE TIME & FALL TIME (LEA50F-5) ¡EFFICIENCY (LEA50F-5) 80 78 EFFICIENCY 76 DC Output ACIN 100V Io=100% AC Input 74 72 Load factor100% Load factor 50% 70 68 60 50ms/DIV ¡INPUT HARMONIC CURRENT (LEA50F-5) 180 220 260 300 V ¡INPUT HARMONIC CURRENT (LEA50F-5) 10 HARMONIC CURRENT Load factor 100% Input voltage AC 100V 1 0.1 0.01 0 10 20 30 Harmonic current standard class A (at odd number) A Harmonic current standard class A (at odd number) A HARMONIC CURRENT 140 INPUT VOLTAGE 10 0.001 100 40 HARMONIC ORDER 1 100% Load factor Input voltage AC 230V 0.1 0.01 0.001 0 10 20 30 40 HARMONIC ORDER January 20, 2022 LEA-3 Ordering information AC-DC Power Supplies Open Frame/Enclosed type LEA75F LEA 1 75 2 F 3 -5 4 Recommended EMI/EMC Filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series *The EMI/EMC Filter is recommended *to connect with several devices. -O 5 1Series name 2Output wattage 3Universal input 4Output voltage 5Optional *6 C :with Coating G :Low leakage current J2:Mini terminal block R :with Remote ON/OFF S :with Chassis SN :with Chassis & cover Y :with Potentiometer LEA MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT *5 LEA75F-3R3-Y LEA75F-5 49.5 75 3.3V 15A 5V 15A LEA75F-9 76.5 9V 8.5A LEA75F-12 LEA75F-15 LEA75F-18 LEA75F-24 LEA75F-24-H LEA75F-30 LEA75F-48 75.6 75 75.6 76.8 76.8 75 76.8 12V 6.3A 15V 5A 18V 4.2A 24V 3.2A 24V 3.2(3.8)A 30V 2.5A 48V 1.6A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] *1 LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *2 RIPPLE[mVp-p] -10 - 0C *2 0 to +50C *2 RIPPLE NOISE[mVp-p] -10 - 0C *2 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *3 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT -RC *4 INPUT-FG OUTPUT-RC-FG *4 OUTPUT-RC *4 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LEA75F-3R3-Y LEA75F-5 LEA75F-9 LEA75F-12 LEA75F-15 LEA75F-18 LEA75F-24 LEA75F-24-H AC85 - 264 1f or DC120 - 370 0.8 1.1typ 0.4 0.55typ 50/60 (47 - 63) or DC 70typ 75typ 78typ 78typ 79typ 81typ 82typ 82typ 71typ 77typ 80typ 80typ 81typ 83typ 84typ 84typ 0.98typ 0.99typ 0.92typ 0.94typ 15typ (Io=100%) (At cold start) (Ta=25 C) 30typ (Io=100%) (At cold start) (Ta=25 C) 0.75max (60Hz, According to IEC62368-1 and DEN-AN) 3.3 5 9 12 15 18 24 24 15 15 8.5 6.3 5 4.2 3.2 3.2 (Peak 3.8) 20max 20max 36max 48max 60max 72max 96max 96max 40max 40max 100max 100max 120max 120max 150max 150max 80max 80max 120max 120max 120max 120max 120max 120max 140max 140max 160max 160max 160max 160max 160max 160max 120max 120max 150max 150max 150max 150max 150max 150max 160max 160max 180max 180max 180max 180max 180max 180max 50max 50max 90max 120max 150max 180max 240max 240max 60max 60max 120max 150max 180max 200max 290max 290max 20max 20max 36max 48max 60max 72max 96max 96max 500max (ACIN 100V, Io=100%) 20typ (Io=100%) 2.85 - 3.6 Fixed ("Y"which can be adjusted the output is available as optional:t10%) 3.25 - 3.35 4.9 - 5.3 8.6 - 9.4 11.5 - 12.5 14.4 - 15.6 17.3 - 18.7 23.0 - 25.0 23.0 - 25.0 Works over 105% of rating (works over 105% of peak current at option -H) and recovers automatically 4.00 - 5.25V Works at 115 - 140% of rating Not provided Not provided Option (Refer to Instruction Manual) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) AC100V 1minute, Cutoff current = 100mA, DC100V 10MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL, EN62368-1 Complies with DEN-AN and IEC62368-1 (At only AC input) Complies with FCC-B, CISPR22-B, EN55022-B, VCCI-B Complies with IEC61000-3-2 55X32X222mm (WXHXD) /290g max (without chassis and cover) Convection *1 Peak load for 10 sec. or less is acceptable if the total wattage is less than the rated wattage. *2 This is the value that measured on measuring board with capacitor of 22mF within 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM101). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, LEA-4 *4 *5 *6 * * LEA75F-30 LEA75F-48 82typ 84typ 84typ 86typ 30 2.5 120max 180max 120max 160max 150max 180max 300max 360max 120max 48 1.6 192max 300max 150max 200max 350max 400max 480max 600max 192max 28.5 - 31.5 46.0 - 50.0 with the input voltage held constant at the rated input/output. Applicable when remote control (optional) is added. ( ):peak current. Please contact us about safety approvals for the model with option. Parallel operation with other model is not possible. Derating is required when operated with chassis and cover. January 20, 2022 LEA75F External view CN3 C119 CN2 4.5 32 65 Output(-) Output(+) 4-M4 Mounting Hole CN2 CN1 5 55 FG AC(N) AC(L) 8 235-+0.5 2-º4.5 12.5 RC(-) RC(+) CN1 45-+0.5 4-º3.5 Mounting Hole 35.5 Name plate 40-+0.5 12 20-+0.5 22 Voltage adjust (optional) Connector for Remote ON/OFF (optional) 212-+0.5 222 5 252 235-+0.5 8 LEA 4.5 2-M4 Mounting Hole PCB t=1.6 PIN CONNECTION I / O Connector Mating Connector CN1 B3P5-VH VHR-5N CN2 B6P-VH VHR-6N CN3 B2B-XH-A XHP-2 Terminal Chain : SVH-21T-P1.1 Loose: BVH-21T-P1.1 Chain : SVH-21T-P1.1 Loose: BVH-21T-P1.1 Chain : SXH-001T-P0.6 Loose: BXH-001T-P0.6 (Mfr: J.S.T.) 15 15 42 (Lead) 3max 29 º4.5 ¶Weight: 290g or less (Without chassis and cover) ¶Tolerance: t1 ¶Dimensions in mm. ¶PCB Material: Glass composite (CEM3) ¶Chassis and cover is optional. ¶Chassis and cover is not available to remote ON/OFF unit. ¶Mounting torque: 1.5N · m(16kgf · cm)max Optional Pin No. Input 1 AC(L) 2 CN1 3 AC(N) 4 5 FG Pin No. Output 1~3 Pin No. Remote ON/OFF -V 1 RC(+) 2 RC(-) CN3 CN2 4~6 +V ¶Keep drawing current per pin below 5A for CN2 Performance data ¡RISE TIME & FALL TIME (LEA75F-5) ¡EFFICIENCY (LEA75F-5) 80 EFFICIENCY 78 DC Output ACIN 100V Io=100% AC Input 76 74 Load factor100% Load factor 50% 72 60 50ms/DIV ¡INPUT HARMONIC CURRENT (LEA75F-5) 180 220 260 300 V ¡INPUT HARMONIC CURRENT (LEA75F-5) 10 HARMONIC CURRENT Load factor 100% Input voltage AC 100V 1 0.1 0.01 0 10 20 30 Harmonic current standard class A (at odd number) A Harmonic current standard class A (at odd number) A HARMONIC CURRENT 140 INPUT VOLTAGE 10 0.001 100 40 HARMONIC ORDER 1 Load factor 100% Input voltage AC 230V 0.1 0.01 0.001 0 10 20 30 40 HARMONIC ORDER January 20, 2022 LEA-5 Ordering information AC-DC Power Supplies Open Frame/Enclosed type LEA100F LEA 100 1 2 F 3 -5 4 Recommended EMI/EMC Filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series *The EMI/EMC Filter is recommended *to connect with several devices. -O 5 1Series name 2Output wattage 3Universal input 4Output voltage 5Optional *6 C :with Coating G :Low leakage current J2:Mini terminal block R :with Remote ON/OFF S :with Chassis SN :with Chassis & cover Y :with Potentiometer LEA MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT *5 LEA100F-3R3-Y LEA100F-5 LEA100F-9 LEA100F-12 LEA100F-15 LEA100F-18 LEA100F-24 LEA100F-24-H LEA100F-30 LEA100F-48 66 100 103.5 102 100.5 100.8 103.2 103.2 105 105.6 3.3V 20A 5V 20A 9V 11.5A 12V 8.5A 15V 6.7A 18V 5.6A 24V 4.3A 24V 4.3(5.0)A 30V 3.5A 48V 2.2A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] *1 LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *2 RIPPLE[mVp-p] -10 - 0C *2 0 to +50C *2 RIPPLE NOISE[mVp-p] -10 - 0C *2 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *3 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT -RC *4 INPUT-FG OUTPUT-RC-FG *4 OUTPUT-RC *4 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LEA100F-3R3-Y LEA100F-5 LEA100F-9 LEA100F-12 LEA100F-15 LEA100F-18 LEA100F-24 LEA100F-24-H AC85 - 264 1f or DC120 - 370 1.0 1.4typ 0.5 0.7typ 50/60 (47 - 63) or DC 71typ 75typ 79typ 79typ 79typ 81typ 81typ 81typ 73typ 78typ 81typ 81typ 82typ 83typ 84typ 84typ 0.98typ 0.99typ 0.92typ 0.94typ 15typ (Io=100%) (At cold start) (Ta=25 C) 30typ (Io=100%) (At cold start) (Ta=25 C) 0.75max (60Hz, According to IEC62368-1 and DEN-AN) 3.3 5 9 12 15 18 24 24 20 20 11.5 8.5 6.7 5.6 4.3 4.3 (Peak 5.0) 20max 20max 36max 48max 60max 72max 96max 96max 40max 40max 100max 100max 120max 120max 150max 150max 80max 80max 120max 120max 120max 120max 120max 120max 140max 140max 160max 160max 160max 160max 160max 160max 120max 120max 150max 150max 150max 150max 150max 150max 160max 160max 180max 180max 180max 180max 180max 180max 50max 50max 90max 120max 150max 180max 240max 240max 60max 60max 120max 150max 180max 200max 290max 290max 20max 20max 36max 48max 60max 72max 96max 96max 500max (ACIN 100V, Io=100%) 20typ (Io=100%) 2.85 - 3.6 Fixed ("Y"which can be adjusted the output is available as optional:t10%) 3.25 - 3.35 4.9 - 5.3 8.6 - 9.4 11.5 - 12.5 14.4 - 15.6 17.3 - 18.7 23.0 - 25.0 23.0 - 25.0 Works over 105% of rating (works over 105% of peak current at option -H) and recovers automatically 4.00 - 5.25V Works at 115 - 140% of rating Not provided Not provided Option (Refer to Instruction Manual) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) AC100V 1minute, Cutoff current = 100mA, DC100V 10MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL, EN62368-1 Complies with DEN-AN and IEC62368-1 (At only AC input) Complies with FCC-B, CISPR22-B, EN55022-B, VCCI-B Complies with IEC61000-3-2 62X35X222mm (WXHXD) /380g max (without chassis and cover) Convection *1 Peak load for 10 sec. or less is acceptable if the total wattage is less than the rated wattage. *2 This is the value that measured on measuring board with capacitor of 22mF within 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM101). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, LEA-6 *4 *5 *6 * * LEA100F-30 LEA100F-48 82typ 85typ 83typ 85typ 30 3.5 120max 180max 120max 160max 150max 180max 300max 360max 120max 48 2.2 192max 300max 150max 200max 350max 400max 480max 600max 192max 28.5 - 31.5 46.0 - 50.0 with the input voltage held constant at the rated input/output. Applicable when remote control (optional) is added. ( ):peak current. Please contact us about safety approvals for the model with option. Parallel operation with other model is not possible. Derating is required when operated with chassis and cover. January 20, 2022 LEA100F External view CN3 Connector for Remote Voltage adjust (optional) CN2 72 CN1 4.5 13 Output(+) 4-M4 Mounting Hole 23 11 45-+0.5 CN2 C119 Output(-) 25-+0.5 FG AC(N) AC(L) 8 235-+0.5 2-º4.5 5 62 Mounting Hole RC(-) RC(+) CN1 52-+0.5 4-º3.5 34.5 Name plate 36 ON/OFF (optional) 212-+0.5 222 252 235-+0.5 º4.5 (Lead) 4.5 45 LEA 2-M4 Mounting Hole 32 3max 8 20 15 5 PCB t=1.6 PIN CONNECTION I / O Connector Mating Connector CN1 B3P5-VH VHR-5N CN2 B8P-VH VHR-8N CN3 B2B-XH-A XHP-2 Terminal Chain : SVH-21T-P1.1 Loose: BVH-21T-P1.1 Chain : SVH-21T-P1.1 Loose: BVH-21T-P1.1 Chain : SXH-001T-P0.6 Loose: BXH-001T-P0.6 (Mfr: J.S.T.) ¶Weight: 380g or less (Without chassis and cover) ¶Tolerance: t1 ¶Dimensions in mm. ¶PCB Material: Glass composite (CEM3) ¶Chassis and cover is optional. ¶Chassis and cover is not available to remote ON/OFF unit. ¶Mounting torque: 1.5N · m(16kgf · cm)max Optional Pin No. Input 1 AC(L) 2 CN1 3 AC(N) 4 5 FG Pin No. Output 1~4 Pin No. Remote ON/OFF -V 1 RC(+) 2 RC(-) CN3 CN2 5~8 +V ¶Keep drawing current per pin below 5A for CN2 Performance data ¡RISE TIME & FALL TIME (LEA100F-5) ¡EFFICIENCY (LEA100F-5) 80 78 EFFICIENCY 76 DC Output ACIN 100V Io=100% AC Input 74 72 Load factor100% Load factor 50% 70 68 60 50ms/DIV ¡INPUT HARMONIC CURRENT (LEA100F-5) 180 220 260 300 V ¡INPUT HARMONIC CURRENT (LEA100F-5) 10 HARMONIC CURRENT Load factor 100% Input voltage AC 100V 1 0.1 0.01 0 10 20 30 Harmonic current standard class A (at odd number) A Harmonic current standard class A (at odd number) A HARMONIC CURRENT 140 INPUT VOLTAGE 10 0.001 100 40 HARMONIC ORDER 1 Load factor 100% Input voltage AC 230V 0.1 0.01 0.001 0 10 20 30 40 HARMONIC ORDER January 20, 2022 LEA-7 Ordering information AC-DC Power Supplies Open Frame/Enclosed type LEA150F LEA 150 1 2 F 3 -5 4 Recommended EMI/EMC Filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series *The EMI/EMC Filter is recommended *to connect with several devices. -O 5 1Series name 2Output wattage 3Universal input 4Output voltage 5Optional *6 C :with Coating G :Low leakage current J2:Mini terminal block R :with Remote ON/OFF S :with Chassis SN :with Chassis & cover Y :with Potentiometer LEA MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT *5 LEA150F-3R3-Y LEA150F-5 LEA150F-9 LEA150F-12 LEA150F-15 LEA150F-18 LEA150F-24 LEA150F-24-H LEA150F-30 LEA150F-48 99 150 153 150 150 153 151.2 151.2 150 153.6 3.3V 30A 5V 30A 9V 17A 12V 12.5A 15V 10A 18V 8.5A 24V 6.3A 24V 6.3(7.5)A 30V 5A 48V 3.2A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] *1 LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *2 RIPPLE[mVp-p] -10 - 0C *2 0 to +50C *2 RIPPLE NOISE[mVp-p] -10 - 0C *2 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *3 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT -RC *4 INPUT-FG OUTPUT-RC-FG *4 OUTPUT-RC *4 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LEA150F-3R3-Y LEA150F-5 LEA150F-9 LEA150F-12 LEA150F-15 LEA150F-18 LEA150F-24 LEA150F-24-H AC85 - 264 1f or DC120 - 370 1.4 2.0typ 0.7 1.0typ 50/60 (47 - 63) or DC 71typ 76typ 79typ 78typ 80typ 81typ 81typ 81typ 74typ 79typ 82typ 81typ 83typ 84typ 84typ 84typ 0.98typ 0.99typ 0.91typ 0.94typ 15typ (Io=100%) (At cold start) (Ta=25 C) 30typ (Io=100%) (At cold start) (Ta=25 C) 0.75max (60Hz, According to IEC62368-1 and DEN-AN) 3.3 5 9 12 15 18 24 24 30 30 17 12.5 10 8.5 6.3 6.3 (Peak 7.5) 20max 20max 36max 48max 60max 72max 96max 96max 40max 40max 100max 100max 120max 120max 150max 150max 80max 80max 120max 120max 120max 120max 120max 120max 140max 140max 160max 160max 160max 160max 160max 160max 120max 120max 150max 150max 150max 150max 150max 150max 160max 160max 180max 180max 180max 180max 180max 180max 50max 50max 90max 120max 150max 180max 240max 240max 60max 60max 120max 150max 180max 200max 290max 290max 20max 20max 36max 48max 60max 72max 96max 96max 500max (ACIN 100V, Io=100%) 20typ (Io=100%) 2.85 - 3.6 Fixed ("Y"which can be adjusted the output is available as optional:t10%) 3.25 - 3.35 4.9 - 5.3 8.6 - 9.4 11.5 - 12.5 14.4 - 15.6 17.3 - 18.7 23.0 - 25.0 23.0 - 25.0 Works over 105% of rating (works over 105% of peak current at option -H) and recovers automatically 4.00 - 5.25V Works at 115 - 140% of rating Not provided Not provided Option (Refer to Instruction Manual) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) AC100V 1minute, Cutoff current = 100mA, DC100V 10MW min (At Room Temperature) -10 to +60C, 20 - 90%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL, EN62368-1 Complies with DEN-AN and IEC62368-1 (At only AC input) Complies with FCC-B, CISPR22-B, EN55022-B, VCCI-B Complies with IEC61000-3-2 75X40X222mm (WXHXD) /500g max (without chassis and cover) Convection *1 Peak load for 10 sec. or less is acceptable if the total wattage is less than the rated wattage. *2 This is the value that measured on measuring board with capacitor of 22mF within 150mm from output terminal. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM101). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, LEA-8 *4 *5 *6 * * LEA150F-30 LEA150F-48 84typ 87typ 84typ 87typ 30 5 120max 180max 120max 160max 150max 180max 300max 360max 120max 48 3.2 192max 300max 150max 200max 350max 400max 480max 600max 192max 28.5 - 31.5 46.0 - 50.0 with the input voltage held constant at the rated input/output. Applicable when remote control (optional) is added. ( ): peak current. Please contact us about safety approvals for the model with option. Parallel operation with other model is not possible. Derating is required when operated with chassis and cover. January 20, 2022 LEA150F External view 8 235-+0.5 4-M4 Mounting Hole 42 15 25 CN3 CN3 Output(-) Output(+) CN2 CN2 5 RC(-)RC(+) CN1 85 C119 4.5 FG AC(N) AC(L) 65-+0.5 75 CN1 2-º4.5 55-+0.5 4-º3.5 Mounting Hole 35-+0.5 Name plate Connector for Remote CN4 ON/OFF (Optional) 29.5 Voltage adjust (Optional) 212-+0.5 222 5 252 235-+0.5 8 (Lead) 3max 2-M4 Mounting Hole PCB t=1.6 PIN CONNECTION I / O Connector Mating Connector CN1 B3P5-VH VHR-5N CN2 B6P-VH VHR-6N CN3 B7P-VH VHR-7N CN4 B2B-XH-A XHP-2 Terminal Chain : SVH-21T-P1.1 Loose: BVH-21T-P1.1 Chain : SVH-21T-P1.1 Loose: BVH-21T-P1.1 Chain : SVH-21T-P1.1 Loose: BVH-21T-P1.1 Chain : SXH-001T-P0.6 Loose: BXH-001T-P0.6 (Mfr: J.S.T.) LEA 20 15 51 37 4.5 º4.5 Optional Pin No. Input 1 AC(L) 2 CN1 AC(N) 3 4 FG 5 Pin No. Output CN2 1~6 ¶Weight: 500g or less (Without chassis and cover) ¶Tolerance: t1 ¶Dimensions in mm. ¶PCB Material: Glass composite (CEM3) ¶Chassis and cover is optional. ¶Chassis and cover is not available to remote ON/OFF unit. ¶Mounting torque: 1.5N · m(16kgf · cm)max Pin No. Remote ON/OFF +V 1 RC(+) 2 RC(-) CN4 CN3 1~7 -V ¶Keep drawing current per pin below 5A for CN2, CN3 Performance data ¡RISE TIME & FALL TIME (LEA150F-5) ¡EFFICIENCY (LEA150F-5) 82 EFFICIENCY 80 DC Output ACIN 100V Io=100% AC Input 78 76 Load factor100% Load factor 50% 74 60 50ms/DIV ¡INPUT HARMONIC CURRENT (LEA150F-5) 220 260 300 V 10 HARMONIC CURRENT Load factor 100% Input voltage AC 100V 1 0.1 0.01 0 10 20 30 Harmonic current standard class A (at odd number) A Harmonic current standard class A (at odd number) A HARMONIC CURRENT 180 ¡INPUT HARMONIC CURRENT (LEA150F-5) 40 HARMONIC ORDER 1 Load factor 100% Input voltage AC 230V 0.1 0.01 0.001 0 10 20 30 40 HARMONIC ORDER January 20, 2022 Powered by TCPDF (www.tcpdf.org) 140 INPUT VOLTAGE 10 0.001 100 LEA-9
LEA75F-15-RV 价格&库存
很抱歉,暂时无法提供与“LEA75F-15-RV”相匹配的价格&库存,您可以联系我们找货
