PDB-C142
PDB-C142
    AMSOSRAM(艾迈斯半导体)
    Radial
    PDB-C142
PDB-C142 数据手册
Plastic Photodiode Package with Leads PDB-C142 Precision – Control – Results WWW.LUNAINC.COM DESCRIPTION FEATURES The PDB-C142 is a blue enhanced PIN silicon photodiode in a photoconductive mode packaged in a water clear T1 ¾ plastic package. • • • • RELIABILITY APPLICATIONS Contact Luna for recommendations on specific test conditions and procedures. • • • • Large active area Photoconductive High Speed Low cost Smoke detectors Light pen detectors TV & VCR remotes Bar code detectors ABSOLUTE MAXIMUM RATINGS SYMBOL Reverse Voltage MIN MAX UNITS - - 100 V Ta = 23°C UNLESS OTHERWISE NOTED Storage Temperature -40 - +100 °C - Operating Temperature -40 to +80 °C - Soldering Temperature* - - +260 °C - * 1/16 inch from case for 3 seconds max. Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. REV 01-04-16 Page 1/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 Plastic Photodiode Package with Leads PDB-C142 Precision – Control – Results WWW.LUNAINC.COM Ta = 23°C UNLESS NOTED OTHERWISE OPTO-ELECTRICAL PARAMETERS TEST CONDITIONS PARAMETER MIN TYP MAX UNITS 100 150 - µA - 5 30 nA 100 500 - MΩ - 18 25 pF Spot Scan 400 - 1100 nm Breakdown Voltage I=10 µA 15 25 - V Noise Equivalent Power VR =10V@λ= Peak - 2x10 - W/ √ Hz Response Time** RL = 1KΩ,VR = 10 V - 50 - nS Short Circuit Current H=100 fc, 2850 K Dark Current VR = 10 V Shunt Resistance VR = 10 mV Junction Capacitance VR =10V; f = 1 MHz Spectral Application Range -14 **Response time of 10% to 90% is specified at 660nm wavelength light. TYPICAL PERFORMANCE SPECTRAL RESPONSE Responsivity (A/W) 0.60 0.50 0.40 0.30 0.20 0.10 Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. 1150 1100 1050 950 900 1000 Wavelength (nm) 850 800 750 700 650 600 550 500 450 400 350 300 250 0.00 REV 01-04-16 Page 2/2 © 2016 Luna Optoelectronics. All rights reserved. Luna Optoelectronics, 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935
PDB-C142 价格&库存
很抱歉,暂时无法提供与“PDB-C142”相匹配的价格&库存,您可以联系我们找货
