IN-S85DATRG
IN-S85DATRG
    INOLUX(英诺斯)
    发光二极管/LED 红色,翠绿色 0805 522nm,622nm 140mcd,450mcd
IN-S85DATRG 数据手册
IN-S85DATRG Top View SMD LED 0805 PCB Type Features Description • 0805 1.1mm SMD LED • High Brightness • AlInGaP / InGaN Technology • Small package • High reliability • Clear Lens The IN-S85DATRG is a dual color 0805 package with versatile design capabilities. It is a PCB type LED which can be used in various applications. Recommended Solder Pattern Applications • Consumer Electronics • Wearables • Automobile After Market • Industrial Equipment Figure 1. IN-S85DATRG Solder Pattern Package Dimensions in mm Figure 2. IN-S85DATRG Package Dimensions Inolux Corporation Proprietary & Confidential May 12, 2017 Page 1 www.inolux-corp.com IN-S85DATRG Top View SMD LED 0805 PCB Type Absolute Maximum Rating at 25oC (Note 1) Product Emission Color Pd (mW) IF (mA) IFP* (mA) Red 75 25 70 VR (V) TOP (oC) 5 -30 C~+85 C IN-S85DATRG 75 Green o TST (oC) o o o -40 C~+90 C 100 25 Notes 1. Condition for IFP is pulse of 1/10 duty and 0.1msec width ESD Precaution ATTENTION: Electrostatic Discharge (ESD) protection The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which may be induced by electrostatic discharge (ESD). Electrical Characteristics T A = 25°C (Note 1) VF(V) Product Emission Color IF(mA) Red Green Viewing λ(nm) Angel I*V(mcd) typ. max λD λP △λ 2θ1/2 typ. 20 2.2 2.6 622 630 17 120 140 20 3.2 3.6 522 530 30 120 450 IN-S85DATRG Notes 1. Performance guaranteed only under conditions listed in above tables. Inolux Corporation Proprietary & Confidential May 12, 2017 Page 2 www.inolux-corp.com IN-S85DATRG Top View SMD LED 0805 PCB Type Typical Characteristic Curves – YG, Y, A, R Inolux Corporation Proprietary & Confidential May 12, 2017 Page 3 www.inolux-corp.com IN-S85DATRG Top View SMD LED 0805 PCB Type Typical Characteristic Curves – B, G, W Inolux Corporation Proprietary & Confidential May 12, 2017 Page 4 www.inolux-corp.com IN-S85DATRG Top View SMD LED 0805 PCB Type Typical Characteristic Curves – Radiation Pattern Ordering Information Product Emission Color Test Current IF (mA) IN-S85DATRG Red Green 20 20 Inolux Corporation Proprietary & Confidential Luminous Intensity IV (mcd) (Typ.) Forward Voltage VF (V) (Typ.) Orderable Part Number 140 450 2.2 3.2 IN-S85DATRG May 12, 2017 Page 5 www.inolux-corp.com IN-S85DATRG Top View SMD LED 0805 PCB Type Label Specifications Inolux P/N: I N - S 8 Material Inolux SMD S = PCB Type 5 Package D A Variation 85DA = 2.0 x 1.25 x 1.1mm T R G - Orientation Current Lens Color Chip Type T = Top Mount (Blank) = 20mA (Blank) = Clear R=630nm G=530nm (blank) = Standard X X Inolux Corporation Proprietary & Confidential 2 0 1 7 Year (2017, 2018, …..) 01 24 001 Month Date Serial May 12, 2017 Page 6 X Customized Stamp-off Lot No.: Z Internal Tracker X www.inolux-corp.com IN-S85DATRG Top View SMD LED 0805 PCB Type Packaging Information: 3000pcs Per Reel Tape Dimension Reel Dimension Inolux Corporation Proprietary & Confidential May 12, 2017 Page 7 www.inolux-corp.com IN-S85DATRG Top View SMD LED 0805 PCB Type Packing Dimension 5 boxes per carton are available depending on shipment quantity. Specification Material Quantity Carrier tape Per EIA 481-1A specs Conductive black tape 3000pcs per reel Reel Per EIA 481-1A specs Conductive black Label IN standard Paper Packing bag 220x240mm Aluminum laminated bag/ no-zipper One reel per bag Carton IN standard Paper Non-specified Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Inolux Corporation Proprietary & Confidential May 12, 2017 Page 8 www.inolux-corp.com IN-S85DATRG Top View SMD LED 0805 PCB Type Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Reflow Soldering • Recommended tin glue specifications: melting temperature in the range of 178~192 OC • The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Lead-free Solder Profile Inolux Corporation Proprietary & Confidential May 12, 2017 Page 9 www.inolux-corp.com IN-S85DATRG Top View SMD LED 0805 PCB Type Precautions • • • • • • Avoid exposure to moisture at all times during transportation or storage. Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products. It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a reverse voltage. Avoid operation beyond the limits as specified by the absolute maximum ratings. Avoid direct contact with the surface through which the LED emits light. If possible, assemble the unit in a clean room or dust-free environment. Reworking • • • Rework should be completed within 5 seconds under 260 OC. The iron tip must not come in contact with the copper foil. Twin-head type is preferred. Cleaning Following are cleaning procedures after soldering: • An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended. • Temperature x Time should be 50oC x 30sec. or
IN-S85DATRG 价格&库存
很抱歉,暂时无法提供与“IN-S85DATRG”相匹配的价格&库存,您可以联系我们找货
IN-S85DATRG
  • 1+2.826501+0.36613
  • 10+1.8964210+0.24566
  • 100+1.33806100+0.17333
  • 500+1.08297500+0.14029
  • 1000+0.998741000+0.12938
库存:17073
IN-S85DATRG
  • 3000+0.889813000+0.11526
  • 6000+0.834206000+0.10806
  • 9000+0.805659000+0.10436
  • 15000+0.7733915000+0.10018
  • 21000+0.7541821000+0.09770
  • 30000+0.7354430000+0.09527
库存:17073
IN-S85DATRG
    IN-S85DATRG
