ABX00023
ABX00023
    ARDUINO
    MKR WIFI 1010:配备ESP32模块的WIFI接口设备
ABX00023 数据手册
MKR WIFI 1010 Want to add a WiFi interface to your devices? Get the MKR WIFI 1010. It connects easily to other Arduino products and is configurable using Arduino software — and you don’t need to be a network expert. This is the newest version of the MKR 1000 WIFI, but with an ESP32 module on board made by U-BLOX. STORE.ARDUINO.CC/ARDUINO-MKR-WIFI-1010 MKR WIFI 1010 ARDUINO MICROCONTROLLER The MKR WIFI 1010 is a significant improvement on the MKR 1000 WIFI. It's equipped with an ESP32 module made by U-BLOX. This board aims to speed up and simplify the prototyping of WiFi based IoT applications thanks to the flexibility of the ESP32 module and its low power consumption. Microcontroller SAMD21 Architecture ARM Cortex-M0+ 32bit Operating Voltage 3.3V Flash Memory 256 KB SRAM 32 KB Clock Speed 32.768 kHz (RTC), 48 MHz DC Current per I/O Pin 3 mA (I/O Pins) GENERAL The MKR WIFI 1010 includes 32-bit computational power, the usual rich set of I/O interfaces, and low power Wi-Fi with a Cryptochip for secure communication using SHA-256 encryption. Plus, it offers ease of use Arduino Software (IDE) for code development and programming. All of these features make this board the preferred choice for the emerging IoT battery-powered projects in a compact form. Its USB port can be used to supply power (5V) to the board. It has a Li-Po charging circuit that allows the Arduino MKR WIFI 1010 to run on battery power or an external 5 volt source, charging the Li-Po battery while running on external power. Input Voltage 5 V Digital I/O Pins 22 Interfaces I2C, I2S, SPI, UART PWM Output 12 Analog I/O Pins 7/1 Power Consumption 93 mA, Weight 15.3 g Product Code ABX00023 30mA (low power)
ABX00023 价格&库存
很抱歉,暂时无法提供与“ABX00023”相匹配的价格&库存,您可以联系我们找货
ABX00023
  • 2+333.12400
库存:2
ABX00023
    • 1+308.65572
    • 10+298.98127
    • 25+289.93164
    库存:391
    ABX00023
    • 1+351.822681+45.51766
    • 10+344.7464610+44.60216
    • 25+338.8238125+43.83591
    • 50+329.8092350+42.66963
    • 100+314.87028100+40.73688
    • 250+300.81452250+38.91839
    库存:371
