Mongoose OS & Google IoT Core Pack w/ Adafruit
Feather HUZZAH32
PRODUCT ID: 3606
Description
In collaboration with Google and Mongoose OS, Adafruit's releasing an IoT Core Pack based
around our Feather HUZZAH32! This kit includes a pre‐soldered Adafruit Feather HUZZAH
with ESP32 WiFi and some sensors and components to get you started on your IoT journey.
Feather is a development board from Adafruit that, like its namesake, is thin, light and lets you
fly. We designed Feather to be a new standard for portable microcontroller cores.
This starter kit contains the Adafruit HUZZAH32 – ESP32 Feather Board ‐ our take on an 'all‐in‐
one' ESP32 WiFi development board with built‐in USB and battery charging. It's an ESP32 WiFi
module with all the extras you need, ready to rock!
At the Feather HUZZAH's heart is an ESP32 WiFi microcontroller clocked at 240 MHz and at 3.3V
logic. The ESP32 is a perfect upgrade from the ESP8266 that has been so popular. In
comparison, the ESP32 has way more GPIO, plenty of analog inputs, two analog outputs,
multiple extra peripherals (like a spare UART), two cores so you don't have to yield to the WiFi
manager, much higher‐speed processor, etc. etc! We think that as the ESP32 gets traction, we'll
see more people move to this chip exclusively, as it is so full‐featured.
Mongoose is providing all documentation and setup support for this pack. For more
information on how to get started with Mongoose, follow the link below:
https://mongoose-os.com/gcp/
And for more information on how to set up your Feather HUZZAH32, check out our learn guide.
This kit includes:
o
o
o
o
o
o
o
o
1x pre‐soldered Adafruit HUZZAH32 – ESP32 Feather Board
1x Micro Servo
1x PIR (motion) Sensor
1x USB Cable ‐ A/Micro B
1x Fast Vibration Switch
1x Magnetic Contact Switch (door sensor)
1x Half‐sized Breadboard
1x Premium Male/Male Jumper Wires ‐ 40 x 6"
o
o
1x DHT22 Temperature‐humidity Sensor + Extras
Component bag containing:
o
o
o
o
o
o
o
o
o
o
3x 12mm Tactile Switches
1x Breadboard Trim Potentiometer 10K
1x Diffused 10mm Green LED
1x Diffused 10mm Red LED
5x 10K 5% 1/4W Resistor
5x 560 Ohm 5% 1/4W Resistor
1x Piezo Buzzer
1x Photo Cell Light Sensor
1x Diffused RGB (tri‐color) LED
1x Breadboard‐friendly SPDT Slide Switch
很抱歉,暂时无法提供与“3606”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+525.365661+67.38871
