102991009
102991009
    SEEED(矽递科技)
102991009 数据手册
    GeeekNET ESP32 Development Board SKU 102991009 GeeekNET ESP32 Development Board is made with the official WROOM32 module. There is built in USB‐to‐Serial converter, automatic bootloader reset, Lithium Ion/Polymer charger. And just about all of the GPIOs brought out so you can use it with any sensor. That module contains a dual‐core ESP32 chip, 4 MB of SPI Flash, tuned antenna. And all the passives you need to take advantage of this powerful new processor. The ESP32 has both Wi‐Fi and Bluetooth Classic/LE support. That means it's perfect for just about any wireless or Internet‐connected project. The ESP32 is a perfect upgrade from the ESP8266 that has been so popular. In comparison, the ESP32 has way more GPIO, plenty of analog inputs, two analog outputs, multiple extra peripherals (like a spare UART), two cores so you don't have to yield to the Wi‐Fi manager, much higher‐speed processor. Please note: The ESP32 is still targeted to developers. Not all of the peripherals are fully documented with example code, and there are some bugs still being found and fixed. We got it working under Arduino IDE, so you can expect things like I2C and SPI and analog reads to work. And also we got it working under MicroPython, so you can test it with the command line console, it will be nice to programmer. But other elements are still under development. For that reason, we recommend this module for makers who have some experience with microcontroller programming, and not as a first dev board. Mechanical Drawing GeeeKNET ESP32 Development Board Pin Layout Product Details Voltage: 5V Current: 80mA Battery: 3.7V Dimension: 59.76mmx28.05mmx12.60mm Wi‐Fi •802.11 b/g/n/e/i •802.11 n (2.4 GHz), up to 150 Mbps •802.11 e: QoS for wireless multimedia technology •WMM‐PS, UAPSD •A‐MPDU and A‐MSDU aggregation •Block ACK •Fragmentation and defragmentation •Automatic Beacon monitoring/scanning •802.11 i security features: pre‐authentication and TSN •Wi‐Fi Protected Access (WPA)/WPA2/WPA2‐Enterprise/Wi‐Fi Protected Setup (WPS) •Infrastructure BSS Station mode/Soft AP mode •Wi‐Fi Direct (P2P), P2P Discovery, P2P Group Owner mode and P2P Power Management •UMA compliant and certified •Antenna diversity and selection Bluetooth •Compliant with Bluetooth v4.2 BR/EDR and BLE specification •Class‐1, class‐2 and class‐3 transmitter without external power amplifier •Enhanced power control •+12 dBm transmitting power •NZIF receiver with ‐97 dBm sensitivity •Adaptive Frequency Hopping (AFH) •Standard HCI based on SDIO/SPI/UART •High speed UART HCI, up to 4 Mbps •BT 4.2 controller and host stack •Service Discover Protocol (SDP) •General Access Profile (GAP) •Security Manage Protocol (SMP) •Bluetooth Low Energy (BLE) •ATT/GATT •HID •All GATT‐based profile supported •SPP‐Like GATT‐based profile •BLE Beacon •A2DP/AVRCP/SPP, HSP/HFP, RFCOMM •CVSD and SBC for audio codec •Bluetooth Piconet and Scatternet CPU and Memory •Xtensa® Single‐/Dual‐core 32‐bit LX6 microprocessor(s), up to 600 DMIPS •448 KB ROM •520 KB SRAM •16 KB SRAM in RTC •QSPI flash/SRAM, up to 4 x 16 MB • Power supply: 2.3V to 3.6V Clocks and Timers •Internal 8 MHz oscillator with calibration •Internal RC oscillator with calibration •External 2 MHz to 60 MHz crystal oscillator (40 MHz only for Wi‐Fi/BT functionality) •External 32 kHz crystal oscillator for RTC with calibration •Two timer groups, including 2 x 64‐bit timers and 1 x main watchdog in each group •RTC timer with sub‐second accuracy •RTC watchdog Advanced Peripheral Interfaces •12‐bit SAR ADC up to 18 channels •2 × 8‐bit D/A converters •10 × touch sensors •Temperature sensor •4 × SPI •2 × I2S •2 × I2C •3×UART •1 host (SD/eMMC/SDIO) • 1 slave (SDIO/SPI) •Ethernet MAC interface with dedicated DMA and IEEE 1588 support • CAN 2.0 •IR (TX/RX) •Motor PWM •LED PWM up to 16 channels •Hall sensor •Ultra‐low‐noise analog pre‐amplifier Security •IEEE 802.11 standard security features all supported, including WFA, WPA/WPA2 and WAPI •Secure boot •Flash encryption •1024‐bit OTP, up to 768‐bit for customers Cryptographic hardware acceleration •AES •HASH (SHA‐2) library •RSA •ECC •Random Number Generator (RNG) Development Support •SDK firmware for fast on‐line programming •Open source toolchains based on GCC Technical Details Dimensions 60mm x 28mm x 12.6mm  Weight  G.W 9.75g      Battery  Exclude  Part List GeeekNET ESP32 Development Board 1              https://www.seeedstudio.com/GeeekNET‐ESP32‐Development‐Board‐p‐2945.html 12‐14‐17
102991009
物料型号:GeeekNET ESP32 Development Board SKU 102991009
器件简介:开发板基于官方WROOM32模块,内置USB转串口转换器、自动引导程序重置、锂离子/聚合物充电器,几乎所有的GPIO都引出,适用于任何传感器。模块包含双核ESP32芯片、4MB SPI Flash和调谐天线。
引脚分配:文档提供了详细的引脚布局图,包括3.3V、GND、EN、TXD/RXD等引脚。
参数特性:包括电压5V、电流80mA、电池3.7V、尺寸59.76mmx28.05mmx12.60mm。
功能详解:ESP32支持Wi-Fi(802.11 b/g/n/e/i)和蓝牙(v4.2 BR/EDR和BLE),具有多种安全特性和加密硬件加速。
应用信息:适合任何无线或互联网连接项目,是ESP8266的升级版,具有更多的GPIO、模拟输入、两个模拟输出等。
封装信息:提供了开发板的尺寸、重量和电池信息。
102991009 价格&库存
很抱歉,暂时无法提供与“102991009”相匹配的价格&库存,您可以联系我们找货
