AOM-5024L-HD-R
AOM-5024L-HD-R
    PUIAUDIO
    AOM-5024L-HD-R
AOM-5024L-HD-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Data Sheet AOM-5024L-HD-R PUI Audio’s all-new HD Series microphones use premium-grade FETs and diaphragms for high sensitivity and superior signal-to-noise ratio. Each microphone features GSM buzz-blocking capacitors. Upgrade the ECM microphone that you use today with a PUI Audio HD Series microphone. The 9.7mm diameter AOM-5024L-HD-R is designed for extreme fidelity in even the quietest settings from 20 Hz to 20 kHz. Features: • 9.7mm diameter • 5mm height • -24 dB sensitivity • 80 dB signal-to-noise ratio • True 20 Hz to 20 kHz performance Specifications Parameters Sensitivity (1 kHz @ 50cm) 0 dB=1V/Pa Rated Voltage Output Impedance (@ 1 kHz) Current consumption (3VS with 2.2 kΩ RL) Signal-to-Noise Ratio (1kHz, 94 dB input, A-weighted) Decreasing Voltage (3VS to 2VS) Frequency Range Operating Voltage Range Maximum SPL Input (THD
AOM-5024L-HD-R 价格&库存
很抱歉,暂时无法提供与“AOM-5024L-HD-R”相匹配的价格&库存,您可以联系我们找货
