471-028
471-028
    DIGILENT(迪芝伦)
471-028 数据手册
    OpenLogger: High Resolution Portable Data Logger    SKU: 471‐028  OpenLogger and Acrylic Case  SKU: 471‐029  OpenLogger with Accessory Bundle    OpenLogger is a high‐resolution data logger designed to provide quality measurements without  the limits of traditional data logging or data acquisition solutions.   Engineers, scientists, and data enthusiasts can take advantage of eight analog channels, two  power supplies, a function generator, eight digital I/O, and a wireless connection to deploy a  data logging system compatible with a wide range of sensors.   Data can be streamed to the user interface, WaveForms Live, or logged to an SD card providing  the ability to save large amounts of data and check the status of systems in real time.  WaveForms Live open source and browser based and can be accessed at WaveFormsLive.com.  We believe that engineers shouldn't be limited by the tools available to them, so we equipped  OpenLogger with features that enable operation in a wide range of conditions. OpenLogger can  be powered via a USB battery pack or barrel jack power supply, so it can be connected and  powered by a computer or externally and set up for long‐term testing. OpenLogger can connect  to WaveForms Live over WiFi or USB, which allows it to be used when electrical isolation or  freedom from a wired connection is necessary.      OpenLogger with the optional Screw Terminal  Adapter  OpenLogger with the included Flywires     The OpenLogger comes with a protective acrylic case, flywires for connection via female‐ terminated wires, and a sheet of labels for the flywires. We also offer an option to bundle the  OpenLogger with an Accessory Kit, which includes a clear project box, a micro USB cable, and  8G microSD card, and the Screw Terminal Adapter.  Features:          Eight analog data logging channels with 16 bits @ 500kS/s and 50kHz bandwidth  One‐channel function generator with 10‐bit resolution and 2MS/s  Two‐channel power supply at ± 4V and 50mA per channel  Eight digital I/O channels  USB or wireless connection  Data streamed via USB/WiFI or logged to SD  USB or externally powered  Browser‐based Open Source WaveForms Live software  OpenLogger and Acrylic Case option includes the following:   What's  Included:    OpenLogger  Protective acrylic  case(assembly required)  OpenLogger Flywires  OpenLogger Flywire Labels  sheet  OpenLogger with Accessory Bundle option includes the following:        OpenLogger  Protective acrylic  case(assembly required)  OpenLogger Flywires  OpenLogger Flywires  Label sheet  8GB microSD card  USB A to Micro B cable  OpenLogger Screw  Terminal Adapter                   https://reference.digilentinc.com/reference/instrumentation/openlogger/reference‐manual?_ga=2.187979880.113684049.1563310986‐341180776.1529427923/7‐17‐19
471-028 价格&库存
很抱歉,暂时无法提供与“471-028”相匹配的价格&库存,您可以联系我们找货
