REVISION F
DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
HDBNC-P-C-XX-ST-CA8X
DO NOT
SCALE FROM
THIS PRINT
CRIMP OPTION
(LEAVE BLANK FOR SOLDERED CENTER CONTACT)
-C: CRIMPABLE CENTER CONTACT
(USE HDBNC-P-C-X-ST-CA8-PIN-C)
GENDER
-P: PLUG
TERMINATION
-CA8: CCA-1855A
CCA-4855R
TYPE
-C: CABLE
ORIENTATION
-ST: STRAIGHT
1
PLATING SPECIFICATION
-HF: 30µ" GOLD CENTER CONTACT,
3µ" GOLD OUTER CONTACT
100µ" NICKEL ON OTHER COMPONENTS
-HN: 30µ" GOLD CENTER CONTACT,
100µ" NICKEL OUTER CONTACT
-GF: 10µ" GOLD CENTER CONTACT,
-GN: 10µ" GOLD CENTER CONTACT,
(SEE TABLE 1)
3
2
1.40 .055
REF
7.75 .305
REF
5.80 .228 REF
13.50 .531 REF
10.00 .394
REF
24.05 .947 REF
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
ANGLES
X.X: 0.3 [.01]
5
X.XX: 0.13 [.005]
X.XXX: 0.051 [.0020]
NOTES:
1. NOTE DELETED.
2. PRODUCT TO BE PACKAGED PER PACKING STANDARD CO-RF-WI-3040-M.
3. THE TEST RESULT OF THE CABLE PULL-OUT FORCE EXCEEDS 40 POUNDS.
c:\enterprisevault\DWG\MISC\MKTG\HDBNC-P-C-XX-ST-CA8X-MKT.SLDDRW
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
COUPLING NUT, SHELL, BODY, PIN, FERRULE : BRASS
GASKET: SILICONE
C-RING, FLAT WASHER: BRASS
SPRING: STAINLESS STEEL
DIELECTRIC: PTFE
SHEET SCALE: 3:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
75 OHM, HIGH DENSITY BNC STRAIGHT PLUG, RG59
DWG. NO.
BY: ALVIN W
02/16/2011 SHEET 1 OF 2
REVISION F
11.2 .44
CCA-1855A/CCA-4855R CABLE
4.4 .17
2.6 .10
IN-PROCESS 1
STRIP CABLE & TIN INNER CONDUCTOR
PIN SHOULD BE FLUSH TO CABLE INSULATOR
IN-PROCESS 2
INDUCTION SOLDER SIGNAL CONTACT
OR CRIMP (CA8C OPTION) USING .042" SQ. DIE
2
3
HEAT SHRINK
IN-PROCESS 3
ADD FERRULE & HEAT SHRINK TUBING
20.0 .79
IN-PROCESS 4
ADD SUB ASSEMBLY
1
FERRULE SHOULD BE FLUSH TO SUB ASSEMBLY
5.25±0.23 .207±.009 (HEX CRIMP)
(ACROSS 2 FACES)
IN-PROCESS 5
CRIMP FERRULE
(USE RF CRIMP HAND TOOL #CAT-RF-FER-001
AND .207" DIE SIZE)
HEAT SHRINK SHOULD BE FLUSH TO SUB ASSEMBLY
IN-PROCESS 6
ACTIVATE HEAT SHRINK TUBING
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: ALVIN W
02/16/2011
SHEET 2 OF 2
HDBNC-P-C-GN-ST-CA8 价格&库存
很抱歉,暂时无法提供与“HDBNC-P-C-GN-ST-CA8”相匹配的价格&库存,您可以联系我们找货
