1.5KE SERIES
Technical Data
Data Sheet N0209, Rev. E
1.5KE SERIES
TRANSIENT VOLTAGE SUPPRESSOR
Features
Glass Passivated Die Construction
1500W Peak Pulse Power Dissipation
6.8V- 550V Standoff Voltage
Uni- and Bi-Directional Versions Available
Excellent Clamping Capability
Fast Response Time
Plastic Case Material has UL Flammability Classification
Rating 94V-O
This is a Pb − Free Device
All SMC Parts are Traceable to the Wafer Lot
Additional testing can be offered upon request
DO-201AD
Circuit Diagram
Mechanical Data
Unipolar
Case: JEDEC DO-201AD Low Profile Molded Plastic
Terminals: Axial Leads, Solderable per MIL-STD-202,
Method 208
Polarity: Cathode Band or Cathode Notch
Weight: 1.10 grams(approx.)
Bipolar
Maximum Ratings and Thermal Characteristics@TA=25°C unless otherwise specified
Symbol
Value
Unit
Peak Pulse Power Dissipation at
TA=25°C (Fig.1)(Note 1, 2, 5)
Parameter
PPPM
1500
W
Peak Forward Surge Current (Note 3)
IFSM
200
A
PM(AV)
5.0
W
Typical Thermal Resistance Junction to Lead
RθJL
15
°C/W
Typical Thermal Resistance Junction to Ambient
RθJA
75
°C/W
TJ,TSTG
-65 to 175
°C
Steady State Power Dissipation(Note 2, 4)
Operating Junction and Storage
Temperature Range
Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2.
2. Mounted on 20mm² copper pad.
3. Measured on 8.3ms single half sine wave or equivalent square wavefor unidirectional device only.
4. Lead temperature at 75°C=TL.
5. Peak pulse power waveform is 10x1000μs.
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
1.5KE SERIES
Technical Data
Electrical Characteristics @TA=25°C unless otherwise specified
BREAKDOWN
VOLTAGE
VBR (V) MIN.
@IT
BREAKDOWN
VOLTAGE VBR
(V) MAX.
@IT
TEST
CURRE
NT
IT(MA)
MAXMUM
CLAMPING
VOLTAGE
@IPP
VC(V)
PEAK
PULSE
CURRENT
IPP(A)
REVERSE
LEAKAGE
@VRWM
IR(uA)
UNI-POLAR
BI-POLAR
REVERSE
STAND-OFF
VOLTAGE
VRWM (V)
1.5KE6.8A
1.5KE6.8CA
5.8
6.45
7.14
10
10.5
144.8
1000
1.5KE7.5A
1.5KE7.5CA
6.4
7.13
7.88
10
11.3
134.5
500
1.5KE8.2A
1.5KE8.2CA
7.02
7.79
8.61
10
12.1
125.6
200
1.5KE9.1A
1.5KE9.1CA
7.78
8.65
9.5
10
13.4
113.4
50
1.5KE10A
1.5KE10CA
8.55
9.5
10.5
1
14.5
104.8
10
1.5KE11A
1.5KE11CA
9.4
10.5
11.6
1
15.6
97.4
5
1.5KE12A
1.5KE12CA
10.2
11.4
12.6
1
16.7
91
5
1.5KE13A
1.5KE13CA
11.1
12.4
13.7
1
18.2
83.5
5
1.5KE15A
1.5KE15CA
12.8
14.3
15.8
1
21.2
71.7
5
1.5KE16A
1.5KE18A
1.5KE20A
1.5KE16CA
1.5KE18CA
1.5KE20CA
13.6
15.3
17.1
15.2
17.1
19
16.8
18.9
21
1
1
1
22.5
25.2
27.7
67.6
60.3
54.9
5
5
5
1.5KE22A
1.5KE22CA
18.8
20.9
23.1
1
30.6
49.7
5
1.5KE24A
1.5KE24CA
20.5
22.8
25.2
1
33.2
45.8
5
1.5KE27A
1.5KE27CA
23.1
25.7
28.4
1
37.5
40.5
5
1.5KE30A
1.5KE33A
1.5KE36A
1.5KE30CA
1.5KE33CA
1.5KE36CA
25.6
28.2
30.8
28.5
31.4
34.2
31.5
34.7
37.8
1
1
1
41.4
45.7
49.9
36.7
33.3
30.5
5
5
5
1.5KE39A
1.5KE39CA
33.3
37.1
41
1
53.9
28.2
5
1.5KE43A
1.5KE43CA
36.8
40.9
45.2
1
59.3
25.6
5
1.5KE47A
1.5KE51A
1.5KE56A
1.5KE47CA
1.5KE51CA
1.5KE56CA
40.2
43.6
47.8
44.7
48.5
53.2
49.4
53.6
58.8
1
1
1
64.8
70.1
77
23.5
21.7
19.7
5
5
5
1.5KE62A
1.5KE62CA
53
58.9
65.1
1
85
17.9
5
1.5KE68A
1.5KE68CA
58.1
64.6
71.4
1
92
16.5
5
1.5KE75A
1.5KE75CA
64.1
71.3
78.8
1
103
14.8
5
1.5KE82A
1.5KE82CA
70.1
77.9
86.1
1
113
13.5
5
1.5KE91A
1.5KE91CA
77.8
86.5
95.5
1
125
12.2
5
1.5KE100A
1.5KE100CA
85.5
95
105
1
137
11.1
5
1.5KE110A
1.5KE120A
1.5KE130A
1.5KE150A
1.5KE110CA
1.5KE120CA
1.5KE130CA
1.5KE150CA
94
102
111
128
105
114
124
143
116
126
137
158
1
1
1
1
152
165
179
207
10
9.2
8.5
7.3
5
5
5
5
1.5KE160A
1.5KE160CA
136
152
168
1
219
6.9
5
1.5KE170A
1.5KE170CA
145
162
179
1
234
6.5
5
1.5KE180A
1.5KE180CA
154
171
189
1
246
6.2
5
1.5KE200A
1.5KE200CA
171
190
210
1
274
5.5
5
1.5KE220A
1.5KE220CA
185
209
231
1
328
4.6
5
1.5KE250A
1.5KE250CA
214
237
263
1
344
4.4
5
1.5KE300A
1.5KE300CA
256
285
315
1
414
3.7
5
1.5KE350A
1.5KE350CA
300
332
368
1
482
3.2
5
1.5KE400A
1.5KE400CA
342
380
420
1
548
2.8
5
1.5KE440A
1.5KE440CA
376
418
462
1
602
2.5
5
1.5KE480A
1.5KE480CA
408
456
504
1
658
2.3
5
1.5KE510A
1.5KE510CA
434
485
535
1
698
2.1
5
1.5KE530A
1.5KE530CA
450
503.5
556.5
1
725
2.1
5
1.5KE540A
1.5KE540CA
459
513
567
1
740
2
5
1.5KE550A
1.5KE550CA
467
522.5
577.5
1
760
2
5
1.5KE SERIES
Technical Data
For bidirectional type having Vrwm of 10 volts and less, the IR limit is double.
For parts without A , the VBR is ±10%.
Ratings and Characteristics Curves
1.5KE SERIES
Technical Data
Mechanical Dimensions DO-201AD
SYMBOL
Ordering Information
Device
1.5KE SERIES
1.5KE SERIES
Package
DO-201AD
(Pb-Free)
DO-201AD
(Pb-Free)
Millimeters
Inches
Min.
Max.
Min.
Max.
A
24.0
0.945
B
7.20
9.50
0.265
0.374
C
0.96
1.07
0.038
0.042
D
4.80
5.30
0.190
0.210
Marking Diagram
Shipping
1250pcs / tape
1250pcs / tape
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
1.5KE6.8A/1.5KE6.8CA
= Part Name
Note: Starting from the 16XXX will not mark date code.
Carrier Tape Specification DO-201AD
SYMBOL
Millimeters
Min.
Max.
A
9.50
10.50
B
50.9
53.9
Z
1.20
T
5.60
6.40
E
0.80
IL1-L2I
1.0
1.5KE SERIES
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of
the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during
operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property
claims or any other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“1.5KE18CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.11780
- 10+0.60480
- 30+0.26676
- 100+0.23220
