USB3130-30-A
USB3130-30-A
    GCT
    插件
    USB连接器 Micro-B 5P 直插 端口数:1 额定电流:1A,1.8A 额定电压:30V 工作温度:-55℃~+85℃
USB3130-30-A 数据手册
H 7.15 0.25±0.05 5 1.50 1 Designed to comply with physical, electrical and environmental requirements of Micro USB Standard (USB2.0), A/B types support USB On-The-GO (OTG) interface. 5.00 G If you seek longer shell stakes for a thicker PCB (for example 1.60mm (.062”)) Please see USB3140 (SMT with cap) or USB3131 / USB3145 (Through-hole) F 2 0.78 3.50 .18 5 4 0.65 Plating: Underplating: Nickel 100µ" min. Contact Area: 30µ" Gold plating Solder Tails: Gold Flash Metallic Shell: Nickel 80µ" min. 1.35 5 3 1.00 1 Materials: Plastic Housing: LCP, UL94V-0, Black Contact Terminal: Copper Alloy Metallic Shell: Stainless Steel,SUS304 T=0.25mm R0 0.35 1 1.85 E Specifications: 7.15 R0 .2 7 5 0.22.MIN 6.90 0.60 0.60 4.75 2.60 7.96 Recommended PCB Layout D As viewed from component side General Tolerance: ±0.05 Component Outline Electrical: Voltage Rating: 30 V Current Rating: Signal (Pins 2,3,4): 1.0 A Power (Pins 1,5): 1.8 A Operating Temperature: -55°C to +85°C Contact Resistance: 30 mΩ max. Insulating Resistance: 1000 MΩ min. Dielectric Withstand Voltage: 100 V AC/minute Ordering Grid USB3130 C 30 Contact Plating 30 = 30µ" Gold 1 Request Samples and Quotation A Packing Options A = Tape & Reel (1.5K per Reel) 5 0.25±0.05 Mechanical & Environmental Mating Force: 35N max. Unmating Force: Initial 10N min. Final 8N min after durability test. Durability: 10,000 Cycles 0.65 Part Number Product Description USB3130 Micro USB Receptacle, Type B, Through-Hole, Vertical, With 1.5mm Through-Hole Shell Stakes Drawing Date 0.80 0.65 A 2.35 1.95 2.90 0.78 0.15±0.05 B 1.00 2.60 2.60 21st October 2011 By Detail 1 2 3 4 Revision Date 5 CC USB3130 D PCN D4 01/06/18 Tolerances (Except as Noted) Length Angle X.X ± 0.35 X.XX ± 0.25 Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By ASE 8 Sheet No. 1/2 18036 12.00±0.10 4.00 2.00±0.10 First approximately 10pcs empty carrier 100 First approximately 22pcs empty carrier Cover tape is empty 0 .5 Ø1 Round Sprocket Hole 13.3 G 0 .1 +0 .00 -0 264 16.0 120 1.75±0.10 7.50±0.10 H F 16.5mm Products P/N I/O Direction USB3130 Cover Tape 1,500 10 15,000 Carries Tape Carrier Tape ø330 Ø330mm E PCS/Reel Reels/Carton PCS/Carton 6 PS D GP Cover Tape GP Label Reel PE Bag Triangle Liner Protection Tape Carton Label Tape 230mm C Label GP Label B 1,500 Pieces/Reel 35 10 Reels Part Number Product Description USB3130 Micro USB Receptacle, Type B, Through-Hole, Vertical, With 1.5mm Through-Hole Shell Stakes Drawing Date A 21st October 2011 By Detail Revision Date 1 2 3 4 0m m 5 CC USB3130 D PCN D4 01/06/18 Tolerances (Except as Noted) Length Angle Units: Metric (mm) C 3rd Angle Projection 6 7 35 m 0m This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By ASE 8 Sheet No. 2/2
USB3130-30-A 价格&库存
很抱歉,暂时无法提供与“USB3130-30-A”相匹配的价格&库存,您可以联系我们找货
USB3130-30-A
  • 1500+4.391591500+0.56845
  • 3000+4.181983000+0.54132
  • 4500+4.064074500+0.52606
  • 7500+3.920297500+0.50744
  • 10500+3.8283910500+0.49555
  • 15000+3.7333415000+0.48325
库存:12682
USB3130-30-A
  • 1+7.329201+0.94869
  • 10+6.2554610+0.80971
  • 25+5.8667825+0.75940
  • 50+5.5838750+0.72278
  • 100+5.31709100+0.68825
  • 250+4.98386250+0.64511
  • 500+4.74565500+0.61428
库存:12682
USB3130-30-A
    • 1+6.00480
    • 10+4.87080
    • 30+4.30920
    库存:1
