BT840F
BT840F
    FANSTEL
    BT840F
BT840F 数据手册
BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 BluNor BT840F is a powerful, highly flexible, ultra low power Bluetooth Low Energy (BLE) using Nordic nRF52840 SoC. With an ARM CortexTM M4F MCU, available 1MB flash, 256KB RAM, embedded 2.4GHz multiprotocol transceiver, and an integrated PCB trace antenna or u.FL connector for an external antenna. A power amplifier is integrated in BT840X and BT840XE to increase Bluetooth range. It allows faster time to market with reduced development cost. Bluetooth ranges are measured in environments with Low Multiple Path Interference (LMPI) and antenna at 5 feet (1.52 meters), typical height of thermostat in the USA. Ranges for LMPI, correlating to actual link budget, indicates the Bluetooth signal strength for penetrating walls in buildings. Specifications:
 nRF52840 QIAA, ARM Cortex M4F, 64 MHz ARM® TrustZone® Cryptocell-310 co-processor Complete RF solution with integrated antenna BLE 5 data rate: 2Mbps, 1Mbps, 500kbps, 125kbps. IEEE 802.15.4 Thread and Zigbee data rate: 250 Kbps 2.4 GHz proprietary data rate: 2 Mbps, 1 Mbps Integrated DC-DC converter, inductors on board. Direct powered by Lithium batteries or USB supply (up to 5.5V) Serial Wire Debug (SWD) Nordic SoftDevice Ready Over-the-Air (OTA) firmware update Flash/RAM: 1MB/256KB. 48 General purpose I/O pins USB 2.0 full speed (12 Mbps) controller QSPI 32 MHz interface High speed 32 MHz SPI Type 2 NFC-A tag with wake-on field, Touch-topair support Programmable peripheral interconnect (PPI) 12 bit/200 Ksps ADC, 8 configurable channels with programmable gain 64 level comparator 15 level comparator with wake-up from OFF mode Temperature sensor 4x4-channel pulse width modulator (PWM) Audio peripherals: I2S, digital microphone interface (PDM) 5 x 32 bit timers with counter mode Up to 4x SPI masters/3x SPI slaves Up to 2x I2C compatible 2-wire masters/slaves 2x UART (CTS/RTS) Quadrature Demodulator (QDEC) 3x real time counters (RTC) 128-bit AES HW encryption SoC Receiver Sensitivity: -96 dBm at 1Mbps SoC TX power: programmable +8dBm to -20dBm. Up to +6 dBi antenna gain. Hybrid pins: 16 castellated and 45 LGA. Integrated PCB trace antenna or u.FL connector Operation voltage: 1.7V to 5.5V Operation temperature: - 4 0 ° C t o + 8 5 ° C QDID: 108621
 Applications
 Secure IoT Beacons/Proximity Connected appliances Lighting products Sensors Home and building automation
 Model Summaries module SoC Size BT Antenna 32.768 sleep crystal BT range,1 Mbps, LMPI BT range, 1Mbps, 1.52m BT range, 125 Kbps, LMPI. BT range, 125 kBps, 1.52m FCC ID IC ID CE Availability BT840F nRF52840-QIAA 15x20.8x1.9mm PCB trace External 1000 meters 390 meters 2300 meters 640 meters X8WBT840 4100A-BT840 Certified Production BT840 nRF52840-QIAA 14x16x1.9mm PCB trace External 150 meters 120 meters 320 meters 210 meters X8WBT840 4100A-BT840 Certified Production !1 BT840E nRF52840-QIAA 14x16x1.9mm u.FL External BT840X nRF52840-QIAA 15x20.8x1.9mm PCB trace + PA Integrated BT840XE nRF52840-QIAA 15x20.8x1.9mm PA + u.FL Integrated X8WBT840 4100A-BT840 Certified Production Pending Pending Pending Pending Sample Sample 10/2018 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 Table Of Contents 1. Introduction ........................................................................................................................................................3 BT840F Block Diagram ..................................................................................................................................... 3 BT840F ..............................................................................................................................................................3 BT840 4 BT840E..............................................................................................................................................................4 BT840X..............................................................................................................................................................4 BT840XE ........................................................................................................................................................... 4 2. Codes Development Using Nordic Tools ........................................................................................................... 5 Easy, fast and safe code development.............................................................................................................. 5 Over-The-Air DFU .............................................................................................................................................5 SoftDevices ....................................................................................................................................................... 5 Development Tools ............................................................................................................................................5 3. Product Descriptions .........................................................................................................................................6 Block Diagram of nRF52840 .............................................................................................................................6 ARM Trustzone CryptoCell 310 .........................................................................................................................7 Mechanical Drawings ........................................................................................................................................ 9 Pin Assignments of BT840 .............................................................................................................................. 12 Pin Function..................................................................................................................................................... 14 Mounting BT840F on the Host PCB ................................................................................................................ 16 Host Board Design for Low Cost or Long Range ............................................................................................ 17 Control Skyworks Power Amplifier................................................................................................................... 18 4. Bluetooth Range Measurements .....................................................................................................................21 5. AT Commands .................................................................................................................................................22 6. BT840F Evaluation Board ...............................................................................................................................22 Nordic Development Tools .............................................................................................................................. 23 Android OS Apps ............................................................................................................................................23 iOS Apps .........................................................................................................................................................23 BT840F V4 EvaluationBoard Schematics .......................................................................................................23 Suggestion for Battery Power Application .......................................................................................................24 7. Miscellaneous..................................................................................................................................................25 Soldering Temperature-Time Profile for Re-Flow Soldering ............................................................................ 25 Cautions, Design Notes, and Installation Notes .............................................................................................. 25 Packaging ........................................................................................................................................................ 28 FCC Label ....................................................................................................................................................... 28 Revision History .................................................................................................................................................. 29 8. Contact Us .......................................................................................................................................................30 !2 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 1. Introduction BluNor BT840F Series are powerful, highly flexible, ultra low power wireless modules using Nordic nRF52840 SoCs. With an ARM CortexTM M4F MCU, 1MB flash, 256KB RAM, embedded 2.4GHz multi-protocol transceiver, and an integrated antenna, it allows faster time to market with reduced development cost. The following is a block diagram of BT840F. Antenna circuit and main clock are integrated. All 48 GPIOs of nRF52840 can be accessed from main board. For lower power consumption at idle state, a 32.768 kHz crystal can be added on the host board. Connection to an external NFC (Near Field Communication) antenna is provided. BT840F Block Diagram BlurNor BT840F is a sister module of BT832F. The physical size is the same. There are 21 additional LGA pins for additional GPIOs provided by nRF52840. There are 3 modules in the BT840F Series. BT840F • Uses an nRF52840 QIAA with Cortex M4F MCU • 1MB flash, 256 KB RAM • Supports NFC • Integrated PCB trace range antenna. Bluetooth range is 1000 meters at 1Mbps and 2300 meters at 125 Kbps measured in environments with low RF and multiple path !3 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE interferences. • Size: 15x20.8x1.9mm. BT840 • Uses an nRF52840 QIAA with Cortex M4F MCU • 1MB flash, 256 KB RAM • Supports NFC • Integrated PCB trace range antenna. • Size: 14x16x1.9mm. BT840E • Uses an nRF52840 QIAA with Cortex M4F MCU • 1MB flash, 256 KB RAM • Supports NFC • An u.FL connector for external antenna. Certified with Fanstel ANT020 antenna.. • Size: 14x16x1.9mm. BT840X • Uses an nRF52840 QIAA with Cortex M4F MCU • 1MB flash, 256 KB RAM • Supports NFC • Integrated SKY66112 power amplifier • Integrated 32.768 KHz sleep crystal • Integrated PCB trace antenna • Size: 15x28x1.9mm. BT840XE • Uses an nRF52840 QIAA with Cortex M4F MCU • 1MB flash, 256 KB RAM • Supports NFC • Integrated SKY66112 power amplifier. • Integrated 32.768 KHz sleep crystal. • An u.FL connector for external antenna. • Size: 15x28x1.9mm.
 !4 Ver 1.10 Aug. 2018 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 2. Codes Development Using Nordic Tools Development tools by Nordic and other third party development tools recommended by Nordic should be used . Easy, fast and safe code development Nordic development environment for nRF52840 offers a clean separation between application code development and embedded protocol stacks. This means compile, link and run time dependencies with the embedded stack and associated debugging challenges are removed. The Bluetooth low energy and ANT stack is a pre-compiled binary, leaving application code to be compiled stand-alone. The embedded stack interface uses an asynchronous and event driven model removing the need for RTOS frameworks. Over-The-Air DFU The nRF52840 is supported by an Over-The-Air Device Firmware Upgrade (OTA DFU) feature. This allows for in the field updates of application software and SoftDevice. SoftDevices The Nordic protocol stacks are known as SoftDevices and complement the nRF52 Series SoCs. All nRF52 Series are programmable with software stacks from Nordic. This bring maximum flexibility to application development and allows the latest stack version to be programmed into the SoC. SoftDevices available from Nordic: S140: Bluetooth low energy concurrent central/peripheral/observer/broadcaster stack. Development Tools Nordic Semiconductor provides a complete range of hardware and software development tools for the nRF52 Series devices. nRF52 DK board is recommended for firmware development. Nordic software development tools can be downloaded from the following webpage. http://infocenter.nordicsemi.com/index.jsp?topic=/com.nordic.infocenter.nrf52/dita/nrf52/development/ nrf52_dev_kit.html&cp=1_1 !5 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 3. Product Descriptions Brief description of nRF52840 SoC is provided. For full description of the SoC, please download from Nordic Semiconductor website. https://www.nordicsemi.com/eng/Products/Bluetooth-low-energy Block Diagram of nRF52840 The following is a block diagram of Nordic nRF52840 Bluetooth Low Energy (BLE) SoC. Arrows with white heads indicate signals that share physical pins with other signals. !6 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 The 32 bit ARM Cortex M4F MCU with hardware supports for DSP instructions and floating point operations, code density and execution speed are higher than other Cortex M MCU. The Programmable Peripheral Interconnect (PPI) system provides a 20-channel bus for direct and autonomous system peripheral communication without CPU intervention. This brings predictable latency times for peripheral to peripheral interaction and power saving benefits associated with leaving CPU idle. The device has 2 global power modes ON/OFF, but all system blocks and peripherals have individual power management control which allows for an automatic switching RUN/IDLE for system blocks based only on those required/not required to achieve particular tasks. The radio supports Bluetooth low energy and ANT. Output power is scalable from a maximum of +8dBm down to -20 dBm in 4dB steps. Sensitivity is increased to -96 dBm to -89 dBm, depending on data rate. Sensitivity for BLE is -96 dBm, and -92.5 dBm for ANT. The NFC block supports NFC-A tags with proximity detection and Wake-on-field from low power mode. The NFC enables Out-Of-Band (OOB) Bluetooth pairing of devices and thus greatly simplifying deployment. ARM Trustzone CryptoCell 310 ARM® TrustZone® CryptoCell-310 co-processor is a security subsystem which provides Root of Trust (RoT) and cryptographic services for a device. CryptoCell services are available to the application through a software library API, not a hardware register interface. !7 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 The following cryptographic features are provided. • FIPS-140-2 certified True Random Number Generator (TRNG) • RSA asymmetric encryption Up to 2048 bit key size PKCS#1 v2.1/v1.5 Optional CRT support • Elliptic curve cryptography (ECC) NIST FIPS 186-4 recommended curves using pseudo-random parameters, up to 521 bits: ➢ Prime field: P-192, P-224, P-256, P-384, P-521 SEC 2 recommended curves using pseudo-random parameters, up to 521 bits: ➢ Prime field: P-160, P-192, P-224, P-256, P-384, P-521 Koblitz curves using fixed parameters, up to 256 bits: ➢ Prime field: P-160, P-192, P-224, P-256 Edwards/Montgomery curves: ➢ Ed25519, Curve 25519 ECDH/ECDSA support • Secure remote password protocol (SRP) Up to 3072 bit operations • Hashing functions SHA-1, SHA-2 up to 256 bit size keyed-hash message authentication code (HMAC) • AES symmetric encryption General purpose AES engine (encrypt/decrypt, sign/verify) 128 bit key size Supported encryption modes: ECB, CBC, CMAC/CBC-MAC, CTR, CCM/CCM*. • ChaCha20/Poly1305 symmetric encryption Supported keyed size: 128 and 256 bits Authenticated encryption with associated data (AEAD) mode !8 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 Mechanical Drawings The followings are mechanical drawings of BT840F and BT832F. The physical sizes of both are the same, 15x20.8x1.9mm. Except the 19 pins in solid black dots, BT840F and BT832F is hardware pin to pin compatible. Firmware configuration is required to perform the same function. Two types of pins are available to meet different application requirements. • 16 castellated pins for application needing limited number of IOs. SMT equipment is not required for soldering castellated pins. • 45 LGA (Land Grid Array) pins to access all 48 GPIOs of nRF52840 when needed. BT840F and BT832F Mechanical drawings, top view !9 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE BT840 and BT840E mechanical drawings, top view. !10 Ver 1.10 Aug. 2018 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE BT840X and BT840XE mechanical drawings !11 Ver 1.10 Aug. 2018 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 Pin Assignments of BT840 The followings are BT840 pin assignment. Pin functions are in a table in next section. Please refer to Nordic nRF52840 Product Specifications for detailed descriptions and features supported. https://www.nordicsemi.com/eng/Products/nRF52840 BT840F pins is a super set of that of BT832F. A PCB developed for BT832 Series can be used for BT840 Series and vice versa. BT832F pin assignments. !12 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE BT840F pin assignments !13 Ver 1.10 Aug. 2018 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 Pin Function BT840 52840 pin# pin# pin name G1 P0.26/SDA 1 1 BT832 52832 pin# pin# pin name Descriptions 38 P0.26 GPIO, configured as I2C SDA on EV-BT840 39 2 H2 P0.27/SCL 2 P0.27 GPIO, configured as I2C SCL on EV-BT840 3 D2 P0.00/XL1 3 2 P0.00/XL1 GPIO, connection for 32.768kHz crystal 4 F2 P0.01/XL2 4 3 P0.01/XL2 GPIO, connection for 32.768kHz crystal 5 A12 P0.02/AIN0 5 4 P0.02/AIN0 GPIO, Analog input 5 P0.03/AIN1 GPIO, Analog input 6 B13 P0.03/AIN1 6 7 L24 P0.09/NFC1 7 11 P0.09/NFC1 GPIO, NFC antenna connection 8 J24 P0.10/NFC2 8 12 P0.10/NFC2 GPIO, NFC antenna connection 13 9 B1 VDD 9 VDD DC supply 1.7V to 3.6V 10 B7 GND 10 45 VSS Ground 11 T2 P0.11 11 16 P0.13 GPIO 12 AD22 P1.00 12 21 P0.18 GPIO 23 13 AD8 P0.13 13 P0.20 GPIO 14 AC13 P0.18/RESET 14 24 P0.21/RESET GPIO, configurable as RESET pin 15 AA24 SWDCLK 15 25 SWDCLK Serial Wire Debug clock input 16 AC24 SWDIO 16 26 SWDIO Serial Wire Debug I/O Z0 B19 P1.11 GPIO Z1 B17 P1.12 GPIO Z2 A16 P1.13 GPIO Z3 B15 P1.14 GPIO Z4 A14 P1.15 GPIO Z5 A20 P1.10 GPIO Z6 R24 P1.06 GPIO A0 GND A0 45 VSS Ground A1 B11 P0.28/AIN4 A1 40 P0.28/AIN4 GPIO, Analog input A2 A10 P0.29/AIN5 A2 41 P0.29/AIN5 GPIO, Analog input A3 J1 P0.04/AIN2 A3 6 P0.04/AIN2 GPIO, Analog input A4 K2 P0.05/AIN3 A4 7 P0.05/AIN3 GPIO, Analog input A5 M2 P0.07 A5 9 P0.07 GPIO A6 P2 P1.08 B0 GPIO GND B0 45 VSS Ground B1 AC21 P0.25 B1 37 P0.25 GPIO B2 B9 P0.30/AIN6 B2 42 P0.30 GPIO B3 A8 P0.31/AIN7 B3 43 P0.31 GPIO B4 L1 P0.06 B4 8 P0.06 GPIO, NC for BT840X, BT840XE, PA control B5 N1 P0.08 B5 10 P0.08 GPIO B6 V23 P1.03 C0 GPIO GND C0 45 VSS Ground C1 AD20 P0.24 C1 29 P0.24 GPIO C2 AD18 P0.22 C2 27 P0.22 GPIO C3 AD12 P0.17 C3 20 P0.17 GPIO, NC for BT840X,BT840XE, PA control !14 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE C4 AD10 P0.15 C4 18 P0.15 GPIO C5 W24 P1.02 C5 15 P0.12 GPIO C6 U24 P1.04 GND D0 45 VSS Ground D0 Ver 1.10 Aug. 2018 GPIO D1 AC19 P0.23 D1 28 P0.23 GPIO D2 AC15 P0.19 D2 22 P0.19 GPIO, NC for BT840 X,BT840XE, PA control D3 AC11 P0.16 D3 19 P0.16 GPIO D4 AC9 P0.14 D4 17 P0.14 GPIO D5 Y23 P1.01 D5 14 P0.11 GPIO D6 T23 P1.05 GPIO E0 P23 P1.07 GPIO E1 AD16 P0.20 GPIO E2 AC17 P0.21 GPIO E3 R1 P1.09 GPIO E4 AD6 D+ USB D+ E5 AD4 D- USB D- E6 U1 P0.12 GPIO F0 Ground pad F1 Ground pad F2 Ground pad F3 Ground pad F4 Y2 VDDH High Voltage Power Supply F5 AB2 DCCH DC to DC converter output F6 AD2 VBUS 5V DC power for USB 3.3V regulator !15 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 Mounting BT840F on the Host PCB The following figure shows recommended mounting of BT840F module on the host PCB. • For the best Bluetooth range performance, the antenna area of module shall extend 9.8 mm outside the edge of host PCB board, or 9.8 mm outside the edge of a ground plane. • The next choice is to place a module on a corner of host PCB, the antenna area shall extend 9.8 mm from the edge of ground plane. Ground plane shall be at least 5 mm from the edge of the antenna area of module. • We don’t recommend mounting BT840F module in the middle of a host PCB. For the best Bluetooth range performance, keep all external metal at least 30mm from the antenna area. !16 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 Host Board Design for Low Cost or Long Range On nRF52 series SoCs, Nordic offers various memory options and protocol supports. Fanstel offers various antenna and power amplifier options. A host board can be designed to accommodate these nRF52 modules. Our suggestions for host PCB design: If your main goal is minimum PCB cost, • use a 2-sided PCB. • Use library component from EV BT832 Gerber files, can be downloaded from http://www.fanstel.com/ download-document/. It has 16 castellated pins plus 24 LGA pins. BT840F library component can be used. However, signal routing can be difficult on a 2-sided PCB. • Be sure of no metal contact in the area of 21 additional BT840F pins. • BT840F can be mounted on a BT832 pad. If you main goal is maximum wireless range, • use a 4 or more layers PCB. • Use library component from EV BT840F V4 or newer Gerber files, can be downloaded from http:// www.fanstel.com/download-document/. It has 16 castellated pins plus 45 LGA pins. • As much ground plane under BT840F, on top side of host PCB as possible. Use EV BT840F V4 Gerber files as an example. • If your products may need wireless range of 1350 meters or more, allocate physical space for a 15x28x1.9mm module. This larger module size is required to accommodate Skyworks SKY66112 power amplifier. • Don’t use P0.06 (BT840F pin B4), P0.17 (BT840F pin C3), and P0.19 (BT840F pin D2) on the host board. These pins are used to control SKY66112 power amplifier in BT832X, BT832XE, BT840X and BT840XE. !17 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.10 Aug. 2018 Control Skyworks Power Amplifier BT840X uses SKYWORKS SKY66112-11 power amplifier. The connection diagram with control signal pins is below. 5 4 3 2 1 D D VDD UART Filter nRF52840 C I2C GPIO P17 CTX P19 CRX P06 CPS C BT840 PCB ANT: 2.34dBi BT840 SMA-J ANT: 6dBi PA SKY66112 ANT1 PCB ANT 1 B B X'TAL RESET 32MHz Frequency Band from 2402 MHz to 2480 MHz. FANSTEL Corporation. A A Title BT840 Module 5 4 3 Size A Document Number Date: Friday, August 10, 2018 Rev 1.0 BLOCK Sheet 2 1 of 1 1 A firmware configuration example to contol Skyworks SKY66112 power amplifier is below. This firmware file, SKY66112_PAconfig.txt can be downloaded from http://www.fanstel.com/download-document/. //PCA10040.h //set the clock #define NRF_CLOCK_LFCLKSRC .rc_ctiv {.source = 0, = NRF_CLOCK_LF_SRC_SYNTH, \ .rc_temp_ctiv = 0, \ .xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM} !18 \ BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE //main.c //config the PA/LNA #ifdef APP_PA_LAN #define APP_PA_PIN 17 #define APP_LNA_PIN 19 #define APP_CPS_PIN 6 #define APP_AMP_PPI_CH_ID_SET 0 #define APP_AMP_PPI_CH_ID_CLR 1 #define APP_AMP_GPIOTE_CH_ID 0 static void pa_lna_setup(void) { uint32_t err_code; nrf_gpio_cfg_output(APP_CPS_PIN); nrf_gpio_pin_clear(APP_CPS_PIN); //enable nrf_gpio_cfg_output(APP_PA_PIN); nrf_gpio_pin_clear(APP_PA_PIN); // nrf_gpio_cfg_output(APP_LNA_PIN); nrf_gpio_pin_clear(APP_LNA_PIN); // static ble_opt_t pa_lna_opts = { .common_opt = { .pa_lna = { .pa_cfg = { .enable = 1, !19 Ver 1.10 Aug. 2018 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE .active_high = 1, .gpio_pin = APP_PA_PIN }, .lna_cfg = { .enable = 1, .active_high = 1, .gpio_pin = APP_LNA_PIN }, .ppi_ch_id_set = APP_AMP_PPI_CH_ID_SET, .ppi_ch_id_clr = APP_AMP_PPI_CH_ID_CLR, .gpiote_ch_id = APP_AMP_GPIOTE_CH_ID } } }; NRF_GPIO->DIRSET |= (1
BT840F 价格&库存
很抱歉,暂时无法提供与“BT840F”相匹配的价格&库存,您可以联系我们找货
BT840F
  • 1+115.647601+14.96740
  • 10+101.1782010+13.09480
  • 25+95.3089025+12.33520
  • 100+88.12210100+11.40500
  • 250+83.03150250+10.74620
  • 500+80.75570500+10.45160
  • 1000+77.940801000+10.08730
库存:3714
