USB3106-30-0230-A
USB3106-30-0230-A
    GCT
    插件
USB3106-30-0230-A 数据手册
H 0.25±0.05 S Designed to comply with physical, electrical and environmental requirements of Micro USB Standard (USB2.0) A/B types support USB On-The-GO (OTG) interface. 5.00 7.15 If you seek shorter shell stakes for use with PCB thickness 1.00mm (.039”), see USB3105. G F 0.60 Ref. 4.75 7.96 0.35 3 5 R0 .17 4 2.60 Plating Underplating: Nickel 50µ" min. Plating: Contact Area: 30µ" Gold plating Solder Tails: Gold Flash Metallic Shell: Nickel 1.35 0.65 0.28 1.00 Pin 5 3.50 0.78 2 5 1.00 1.85 1 Pin 1 Materials Plastic Housing: LCP, UL 94V-0, Black, Contact Terminal: Copper Alloy Metallic Shell: Stainless Steel SUS304-1/2H T=0.25mm Ø 0. 40 0.22 min. 0.80 6.20 E Specifications 7.15 6.90 5.30 Recommended PCB Layout D As viewed from component side General Tolerance: ±0.05 Electrical Voltage Rating: 30V Current Rating: Signal (Pins 2,3,4): 1.0 A. Power (Pins 1,5): 1.8A. Operating Temperature: -55°C to +85°C. Contact Resistance: 30 mΩ max. Insulating Resistance: 1000 MΩ min. Dielectric Withstand Voltage: 100V AC for 1 minute Ordering Grid USB3106 30 0230 A Contact Plating 30 = 30µ" Gold C Request Samples and Quotation Packing Options A = Tape & Reel (1,500 Pieces per Reel) Shell Stake Length "S" 0230 = 2.30mm (recommended for 1.6mm PCB thickness) Mechanical & Environmental Mating Force: 35N max. Unmating Force: Initial 10N min. Final 8N min after durability test. Durability: 10,000 Cycles 0.25 0.65 1.30 B 0.80 1.00 0.15 0.78 0.65 2.60 A 2.35 1.95 2.90 2.60 Part Number Product Description USB3106 Micro USB Receptacle, Type A/B, Vertical, Through Hole with 2.30mm (Standard) Shell Stakes Drawing Date 28th October 2013 By Detail 1 2 3 4 Revision Date 5 CC USB3106 B PCN B4 25/08/17 Tolerances (Except as Noted) Length Angle X.X ± 0.35 X.XX ± 0.25 Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/2 18036 12.00±0.10 4.00±0.10 2.00±0.10 First approximately 10pcs empty carrier 0 .1 +0 .00 -0 264 100 First approximately 22pcs empty carrier Cover tape is empty 0 .5 Ø1 Round Sprocket Hole 13.3 G F 16.0 120 1.75±0.10 7.50±0.10 H Ø2 3 16.5mm ° 12 0 I/O Direction Cover Tape Ø13.5 Products P/N ø330 Carrier Tape Ø330mm E 120° PCS/Reel Reels/Carton PCS/Carton USB3106 1,500 10 15,000 Detail F 6 PS D Detail F Reel Waterproof bag Carton Triangle Liner Protection Tape Label 230mm C Label GP Label B 1,500 Pieces/Reel 35 10 Reels Product Description Micro USB Receptacle, Type A/B, Vertical, Through Hole with 2.30mm (Standard) Shell Stakes By Detail Revision Date 2 3 4 m 0m USB3106 28th October 2013 1 35 Part Number Drawing Date A 0m m 5 CC USB3106 B PCN B4 25/08/17 Tolerances (Except as Noted) Length Angle Units: Metric (mm) X.X ± 0.35 X.XX ± 0.25 C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 2/2
USB3106-30-0230-A 价格&库存
很抱歉,暂时无法提供与“USB3106-30-0230-A”相匹配的价格&库存,您可以联系我们找货
USB3106-30-0230-A
  • 1500+4.150761500+0.53728
  • 3000+3.952663000+0.51163
  • 4500+3.841214500+0.49721
  • 7500+3.705317500+0.47962
  • 10500+3.6184310500+0.46837
  • 15000+3.5286115000+0.45674
USB3106-30-0230-A
    库存:40500
    USB3106-30-0230-A
