DATA SHEET
Thick Film Chip Resistor
RC 01005
(RoHS Compliant & Halogen Free)
YAGEO CORPORATION
350, Zhongzheng Rd., Dashe Shiang, Kaohsiung 815, Taiwan
Tel: 886-7-351-4117
Fax: 886-7-351-2075
Headquarters: 3F., 233-1, Baoqiao Rd., Xindian, Taipei 231, Taiwan
Tel: 886-2-2917-7555
Fax: 886-2-2917-4286
www.yageo.com
1
Chip Resistor Surface Mount
RC
SERIES
01005(RoHS Compliant & Halogen Free)
6
SCOPE
This specification describes size of RC01005 series chip resistors with lead-free terminations
made by thick film process.
FEATURES
● Products with lead free terminations meet RoHS requirements.
● Small size and lightweight
● Saving of PCB space
● Halogen Free Epoxy
ORDERING INFORMATION
Part number is identified by the series name, size code, tolerance, packing style, temperature
coefficient of resistance, taping reel and resistance value.
YAGEO ORDERING CODE
MARKING
GLOBAL PART NUMBER (PREFERRED)
RC 0100
(1)
X R
— 07
(2) (3) (4)
(5)
XXXX
(6)
RC01005
L
No marking
(7)
Fig.1
(1) Size Code
0100= size 01005
(2) TOLERANCE
CONSTRUCTION
The resistors are constructed on top of a high-grade ceramic body. Internal
metal electrodes are added at each end and connected by the resistive
F = ±1%
glaze. The resistive glaze is covered by a leadfree glass. The composition
J = ±5%
of the glaze is adjusted to give the approximate required resistance value
(3) PACKING STYLE
and laser trimming of this resistive glaze achieves the value inside
tolerance. The whole element is covered by a protective Epoxycoat. Finally,
R = Press Pocket Paper
the two external terminations (Ni / matte tin) are added. See fig. 2.
(4) TEMPERATURE COEFFICIENT OF
RESISTANCE
— = base on spec.
(5) TAPING REEL
07 = 7 inch dia. Reel
Fig.2
ORDERING EXAMPLE
(6) RESISTANCE VALUE
The ordering code of a RC0100 chip resistor, value 10 Ω with ±5%
tolerance, supplied in 7-inch tape reel is: RC0100JR-0710RL.
10R to 1M
(7) Default code
Letter L is system default code for
order only (NOTE)
NOTE
1. All our RSMD products meet RoHS compliant and Halogen Free.
"LFP" of the internal 2D reel label mentions "Lead Free Process".
2. On customized label, "LFP" or specific symbol can be printed.
www.yageo.com
2
RC
SERIES
6
DIMENSION
For dimension see Table 1
Table 1
TYPE
RC01005
L (mm)
0.40±0.02
W (mm)
0.20±0.02
H (mm)
0.13±0.02
I1 (mm)
0.10±0.03
I2 (mm)
0.10±0.03
Fig.3 Chip resistor outlines
POWER RATING
ELECTRICAL CHARACTERISTICS
RC01005 rated power at 70°C is 1/32W
Table 2
CHARACTERISTICS
Operating Temperature
RC01005
1/32 W
–55°C to +125°C
Range
Maximum Working Voltage
15V
Maximum Overload Voltage
30V
Dielectric Withstanding
30V
Voltage
Resistance Range
±5% (E24) 10Ω to 1MΩ
±1% (E24) 10Ω to 1MΩ
Zero Ohm Jumper
很抱歉,暂时无法提供与“RC0100FR-07150RL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.27980
- 100+0.17130
- 1000+0.11000
- 10000+0.07050
- 20000+0.05020
- 国内价格 香港价格
- 20000+0.3194720000+0.04152
- 40000+0.3064040000+0.03982
- 60000+0.3000260000+0.03899
- 100000+0.29311100000+0.03809
- 140000+0.28915140000+0.03758
- 200000+0.28540200000+0.03709
- 国内价格 香港价格
- 1+1.140301+0.14810
- 10+0.7894010+0.10250
- 50+0.7187050+0.09340
- 100+0.52580100+0.06830
- 500+0.44680500+0.05810
- 1000+0.394101000+0.05120
- 2500+0.359302500+0.04670
- 10000+0.2719010000+0.03530
- 20000+0.2719020000+0.03530
- 国内价格 香港价格
- 1+2.024931+0.26315
- 10+1.0572310+0.13739
- 25+0.8423725+0.10947
- 50+0.7208850+0.09368
- 100+0.62485100+0.08120
- 250+0.52772250+0.06858
- 500+0.47188500+0.06132
- 1000+0.427441000+0.05555
- 5000+0.356555000+0.04634
