RC0100FR-072K2L
RC0100FR-072K2L
    YAGEO(国巨)
    2.2KΩ ±1% 31.25MW
RC0100FR-072K2L 数据手册
DATA SHEET Thick Film Chip Resistor RC 01005 (RoHS Compliant & Halogen Free) YAGEO CORPORATION 350, Zhongzheng Rd., Dashe Shiang, Kaohsiung 815, Taiwan Tel: 886-7-351-4117 Fax: 886-7-351-2075 Headquarters: 3F., 233-1, Baoqiao Rd., Xindian, Taipei 231, Taiwan Tel: 886-2-2917-7555 Fax: 886-2-2917-4286 www.yageo.com 1 Chip Resistor Surface Mount RC SERIES 01005(RoHS Compliant & Halogen Free) 6 SCOPE This specification describes size of RC01005 series chip resistors with lead-free terminations made by thick film process. FEATURES ● Products with lead free terminations meet RoHS requirements. ● Small size and lightweight ● Saving of PCB space ● Halogen Free Epoxy ORDERING INFORMATION Part number is identified by the series name, size code, tolerance, packing style, temperature coefficient of resistance, taping reel and resistance value. YAGEO ORDERING CODE MARKING GLOBAL PART NUMBER (PREFERRED) RC 0100 (1) X R — 07 (2) (3) (4) (5) XXXX (6) RC01005 L No marking (7) Fig.1 (1) Size Code 0100= size 01005 (2) TOLERANCE CONSTRUCTION The resistors are constructed on top of a high-grade ceramic body. Internal metal electrodes are added at each end and connected by the resistive F = ±1% glaze. The resistive glaze is covered by a leadfree glass. The composition J = ±5% of the glaze is adjusted to give the approximate required resistance value (3) PACKING STYLE and laser trimming of this resistive glaze achieves the value inside tolerance. The whole element is covered by a protective Epoxycoat. Finally, R = Press Pocket Paper the two external terminations (Ni / matte tin) are added. See fig. 2. (4) TEMPERATURE COEFFICIENT OF RESISTANCE — = base on spec. (5) TAPING REEL 07 = 7 inch dia. Reel Fig.2 ORDERING EXAMPLE (6) RESISTANCE VALUE The ordering code of a RC0100 chip resistor, value 10 Ω with ±5% tolerance, supplied in 7-inch tape reel is: RC0100JR-0710RL. 10R to 1M (7) Default code Letter L is system default code for order only (NOTE) NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com 2 Chip Resistor Surface Mount RC SERIES 01005(RoHS Compliant & Halogen Free) 6 DIMENSION For dimension see Table 1 Table 1 TYPE RC01005 L (mm) 0.40±0.02 W (mm) 0.20±0.02 H (mm) 0.13±0.02 I1 (mm) 0.10±0.03 I2 (mm) 0.10±0.03 Fig.3 Chip resistor outlines POWER RATING ELECTRICAL CHARACTERISTICS RC01005 rated power at 70°C is 1/32W Table 2 CHARACTERISTICS Operating Temperature RC01005 1/32 W –55°C to +125°C Range Maximum Working Voltage 15V Maximum Overload Voltage 30V Dielectric Withstanding 30V Voltage Resistance Range ±5% (E24) 10Ω to 1MΩ ±1% (E24) 10Ω to 1MΩ Zero Ohm Jumper
RC0100FR-072K2L 价格&库存
很抱歉,暂时无法提供与“RC0100FR-072K2L”相匹配的价格&库存,您可以联系我们找货
RC0100FR-072K2L
    • 1+0.27980
    • 100+0.17130
    • 1000+0.11000
    • 10000+0.07050
    • 20000+0.05020
    库存:4979
    RC0100FR-072K2L
      RC0100FR-072K2L
        • 1+0.024781+0.00322
        • 10000+0.0247810000+0.00322
        • 20000+0.0165220000+0.00215
        • 30000+0.0165230000+0.00215
        • 40000+0.0165240000+0.00215
        库存:20000
        RC0100FR-072K2L
          • 1000+0.01570
          • 5000+0.01420
          库存:1060
          RC0100FR-072K2L
          • 20000+0.08222
          库存:2340000
          RC0100FR-072K2L
          • 20000+0.3018120000+0.03923
          • 40000+0.2894540000+0.03762
          • 60000+0.2834360000+0.03684
          • 100000+0.27690100000+0.03599
          • 140000+0.27316140000+0.03551
          • 200000+0.26962200000+0.03505
          RC0100FR-072K2L
          • 1+2.027741+0.26356
          • 10+1.0587010+0.13761
          • 25+0.8435425+0.10964
          • 50+0.7218850+0.09383
          • 100+0.62572100+0.08133
          • 250+0.52845250+0.06869
          • 500+0.47253500+0.06142
          • 1000+0.428041000+0.05564
          • 5000+0.357055000+0.04641
