RTV162-85ML
RTV162-85ML
    MGCHEMICALS
    SIL
    RTV162-85ML
RTV162-85ML 数据手册
RTV Silicones >> Electronics grade >> White, 1 Part Paste, RTV Silicone Adhesive Sealant RTV Silicones by Technical Support for RTV Silicones 1-Part Adhesive Sealant RTV162 RTV Number... Jump to Product Number Product Number... Accessories Adhesives 1-800-255-8886 Primary Characteristics White Paste Non-corrosive Alkoxy neutral cure UL File. no. E-36952 MIL-A-46146, group 1, type 1 Non-corrosive. Bond capacitors, resistors and integrated circuits to PCBs' seals exposed wires, faying surfaces, connectors. Meets MIL-A-46146B. UL HB recognition. M.G. Chemicals Disclaimer for RTV Silicones > Locate Distributor > Quick Links Brushes Cleaners / Degreasers Contact Cleaners Desoldering Braid Dusters & Circuit Coolers EMI / RFI Shielding Epoxies Available Sizes Catalog Number Sizes Available Description RTV162-85ML 85 mL (2.8 oz) Tube RTV162-300ML 300mL (10 oz) Cartridge RTV167 Gray Specifications TSE397C Clear Isopropyl Alcohol TSE399C Clear Lead Free Solder Lubricants Use Adhesive Sealant Potting & Encapsulating Standards MIL-A-46146, group 1, type 1 UL File no. E-36952 Protective Coatings Pens Cross Reference Prototyping Materials Uncured Properties RTV Silicones Consistency Paste Soldering/desoldering Color White Specific Gravity 1.09 Tack Free Time 4 hours Cure through time 48 hours Useful Temp. Range -60°C to 205°C (-75°F to 400°F) Specialized Cleaners Swabs Thermal Management Thermally Conductive Adhesives Wipes Related products: RTV160 White Flux and Flux Remover Glass & Screen Cleaners MSDS Specifications Available Sizes RTV162 Selection Guide One Part Chart Two Part Chart Cured Properties - MECHANICAL General Purpose Aerospace Marine High Performance Assembly Electronics Hardness 35 (Shore A) Tensile Strength 3.73 MPa (550 psi) Elongation 400% Peel Strength 7.2 kg/cm (40 lb/in) Thermal Conductivity High Temperature Low Temperature Cured Properties - ELECTRICAL Volume Resistivity 3 x 1015 ohm · cm Dielectric Strength 19.7 kV/mm (450 V/mil) Dielectric Constant 2.8 @ 60 Hz Cured Properties - THERMAL Thermal Conductivity Google Search MG 0.21 W/m · °K Other Viscosity (@ 25°C) Return to top ^ http://www.mgchemicals.com/products/162.html (1 of 2)11/24/2008 8:00:42 AM 350 g/min RTV Silicones >> Electronics grade >> White, 1 Part Paste, RTV Silicone Adhesive Sealant © 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us web site design by offbeat studio http://www.mgchemicals.com/products/162.html (2 of 2)11/24/2008 8:00:42 AM
RTV162-85ML 价格&库存
很抱歉,暂时无法提供与“RTV162-85ML”相匹配的价格&库存,您可以联系我们找货
