SIM8051-6-0-14-01-A
SIM8051-6-0-14-01-A
    GCT
    SMD
    自弹式 NANOSIM卡 卡座
SIM8051-6-0-14-01-A 数据手册
9.00 C5 6x 1.20 8.30 1.45 4.85 0.70 12.20 10.70 -Y- 1.4 Pick/Place area G C7 C6 C5 2x 3.00 C6 4.15 A C7 Ø0.70+0.10 -0.00 1.65 0.10 (3.50) 6x 1.00 2.54 4.60 6x 1.00 6x 1.10 H Specification -X- Material Plastic Housing: LCP 30%GF, UL94V-0, Black Contact Terminal: Phosphor Bronze,T=0.12mm Cover: SUS301-H, T=0.15mm 2x 1.00 F 5.08 8.94+0.15 -0 Section A-A Recommended PCB Layout 2.54 2.54 Solder Area Keep Out Area Ø0.60 0.12 0.30 4.60 0.70 1.95 8.30±0.10 Electrical Voltage Rating: 30V max. Current Rating: 0.5A max. Dielectric Withstanding Voltage: 100V AC (60 Sec min.) Insulation Resistance: 1000 MΩ min. Contact Resistance: 100 mΩ max. Component Outline Mechanical & Environmental Operating Temperature: -40°C to +85°C Durability: 1500 cycles 9.00±0.10 10.8 Ordering Grid -Y- C 0.75 For NanoSIM 1.10 D Plating: Contact Terminal: Contact Area: 3µ” Gold Solder area: Gold Flash Underplating: Ni overall 50µ" min. Cover: Ni overall 50µ" min. C1 As viewed from component side General Tolerance ±0.05 Locating peg holes only applicable to locating peg version 1.35 0.28 0.65 (9.54) C2 5.08 7.15 10.60 1.25 0.10 C3 Ø0.90+0.10 -0.00 A 0.37±0.05 E C1 C2 C3 0.40 0.35 SIM8051 6 0 14 XX No. of Contacts 6=6 Switch 0 = Without B A Request Samples and Quotation Packing Options A = Tape & Reel (1500 per Reel) Locating Peg 01 = With (Standard) 00 = Without Profile Height (H) 14 = 1.35mm -XPart Number Product Description SIM8051 Nano SIM Card Connector Push-Pull Type, 6 Pin, SMT, Profile 1.35mm Drawing Date A 28th April 2015 1 2 3 4 By CC Detail SIM8051 D PCN Revision Date 5 D5 22/01/21 Tolerances (Except as Noted) Length Angle X. ± 0.35 X.X ± 0.25 X.XX ± 0.15 X.XXX ± 0.10 All ± 2° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/3 H 25.00mm Mini G 15.00mm Micro 12.30mm Nano D 8.80mm Nano E 12.00mm Micro 15.00mm Mini F C1----->VCC C2----->RST Nano SIM C3----->CLK C5----->GND C6----->Vpp C7----->I/O Micro SIM C Mini SIM Reference B Part Number Product Description SIM8051 Nano SIM Card Connector Push-Pull Type, 6 Pin, SMT, Profile 1.35mm Drawing Date 28th April 2015 A By CC Detail SIM8051 D PCN Revision Date 1 2 3 4 5 D5 22/01/21 Tolerances (Except as Noted) Length X. ± 0.35 X.X ± 0.25 X.XX ± 0.15 X.XXX ± 0.10 Angle Units: Metric (mm) All ± 2° C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 2/3 H 400 Peeling Angle Min. 165°~18 0° Reel Label RoHS Label Ø330 1500Pcs/Reel G 160mm Product Loading Section F Desiccant Vacuum Bag 44cmX45cm Unloaded Section 128mm Unloaded Section 24.5 28.5 Inner Carton Label Direction of Unreeling RoHS Label 1.75 11.50±0.15 E 2.00 13500Pcs/carton 4.00 1 Ø 0 .5 Inner Carton:340mmX340mmX285mm 2.60 24.00±0.3 D Box label C RoHS Label 16.00 Box: 355mmX355mmX305mm Notes: Peeling off force of top tape: 0.1-1.3N (Peeling direction as shown) B Products P/N Pcs / Reel Reels/Carton 1500 SIM8051 Materials: Carrier Tape: Polystyrene (PS) Top Tape: PE Reel Tape: Polystyrene (PS) Vacuum Bag: PE A Part Number Product Description SIM8051 Nano SIM Card Connector Push-Pull Type, 6 Pin, SMT, Profile 1.35mm Drawing Date 28th April 2015 By CC Detail SIM8051 D PCN Revision Date 1 2 3 4 9 5 Tolerances (Except as Noted) Length Angle D5 22/01/21 Units: Metric (mm) C 3rd Angle Projection 6 7 Reels/Carton 13500 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 3/3
SIM8051-6-0-14-01-A 价格&库存
很抱歉,暂时无法提供与“SIM8051-6-0-14-01-A”相匹配的价格&库存,您可以联系我们找货
SIM8051-6-0-14-01-A
    库存:1500
    SIM8051-6-0-14-01-A
      库存:3000
