XB8X-DMUS-001
XB8X-DMUS-001
    DIGIINTERNATIONAL
    SMD-37P
    XB8X-DMUS-001
XB8X-DMUS-001 数据手册
LOW-POWER RF MODULE FOR EUROPE DIGI XBEE® SX 868 RF module family operates in the 863-870 MHz range delivering superior performance and interference immunity at 868 MHz The Digi XBee SX 868 is an 868 MHz RF module for Europe. The module can run either a proprietary DigiMesh® or point-tomultipoint networking protocol utilizing a low-power Silicon Labs microcontroller and an Analog Devices ADF7023 transceiver, along with an integrated SAW filter which offers industry-leading interference blocking. The Digi XBee SX 868 operates between 863 MHz and 870 MHz, making it deployable in several regions throughout the world including approved European countries. the radio environment before any transmission starts, and automatically shifting to a new channel when interference is detected. This patented frequency scan occurs automatically and in a matter of microseconds so as not to impact performance. The Digi XBee SX 868 RF module is a complete hardware and software solution that works directly out of the box. X-CTU, Digi’s easy-to-use RF configuration tool, reduces development time from months to weeks, ensuring your product gets to market fast. The Digi XBee SX 868 also leverages 868 MHz and surrounding frequencies for LBT + AFA (Listen Before Talk and Adaptive Frequency Agility). This significantly reduces interference by listening to BENEFITS APPLICATION EXAMPLE – Low-power CE/RED certified 868MHz RF module based on Silabs EFM32 and ADI7023 – Design includes SAW filter for optimal performance in noisy RF environments – OTA and pin compatible with legacy XBee 868LP – Listen-Before-Talk and Frequency Agility for optimal interference immunity Ethernet UTILITY ENERGY MANAGEMENT SYSTEMS DIGI XBEE® 868 MHZ WIRELESS METER NETWORK – DigiMesh networking topology for redundancy and reliability – Simple configuration using X-CTU accelerates time to market DIGI XBEE® SX 868 MODULE Utility Meter Utility Meter Utility Meter Development Kits Gateways XCTU Digi Remote Manager® Cellular/VPN CONCENTRATOR GATEWAY RELATED PRODUCTS Modules DIGI REMOTE MANAGER® SPECIFICATIONS Digi XBee® SX 868 HARDWARE PROCESSOR ADF7023 transceiver, Cortex™-M3 EFM32LG230F256 @ 48 MHz FREQUENCY BAND 863 MHz to 870 MHz ANTENNA OPTIONS U.FL, RF pad PERFORMANCE RF DATA RATE 10 Kbps or 80 Kbps, software selectable UART DATA RATE Up to 921 Kbps SPI DATA RATE Up to 6 Mbps THEORETICAL LINE-OF-SIGHT RANGE Up to 14.5 km w/ 2.1 dBi antenna TRANSMIT POWER Up to 13 dBm ERP RECEIVER SENSITIVITY -106 dBm @ 80 Kbps, -113 dBm @ 10 Kbps FEATURES I/O 13 Digital I/O ANALOG INPUTS 4 channels 10-bit OPERATING TEMPERATURE -40° C to +85° C NETWORKING TOPOLOGIES DigiMesh®, Repeater, Point-to-point, Point-to-multipoint, Peer-to-peer SECURITY 128-bit AES Encryption POWER SUPPLY VOLTAGE 2.4 - 3.6 VDC TRANSMIT CURRENT 55 mA RECEIVE CURRENT 40 mA SLEEP CURRENT 1.8 uA REGULATORY APPROVALS ETSI (EUROPE) CE/RED ROHS Compliant PART NUMBERS DESCRIPTION XB8X-DMUS-001 XBee SX 868, 25 mW, DigiMesh/P2MP, U.FL, Europe XB8X-DMRS-001 XBee SX 868, 25 mW, DigiMesh/P2MP, RF Pad, Europe XK8X-DMS-0 Digi XBee SX 868 Development Kit Top View Point-to-Multipoint / Star Side View Bottom View DigiMesh DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2017 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91003946 A1/617 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL FRANCE +33-1-55-61-98-98 / www.digi.fr DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
XB8X-DMUS-001 价格&库存
很抱歉,暂时无法提供与“XB8X-DMUS-001”相匹配的价格&库存,您可以联系我们找货
