LEB150F-0512
LEB150F-0512
    COSEL
    LEB150F系列是一款150W的AC-DC电源模块,支持双输出。输入电压范围为85-264V AC或120-370V DC,具有多种保护功能和符合多项安全标准。
LEB150F-0512 数据手册
AC-DC Power Supplies Open Frame/ Enclosed Type Power Factor Correction World wide Safety Approvals EMI Inrush current limiting OCP OVP Remote ON/OFF Rugged PCB type LEB-series Feature Rugged PCB type (CEM) Harmonic attenuator (Complies with IEC61000-3-2) Universal input voltage (AC85 - 264V) Remote ON/OFF (Option) Safety agency approvals UL60950-1, C-UL recognized, TuV approved Complies with DEN-AN EMI Complies with FCC-B, CISPR22-B, EN55022-B, VCCI-B 2-year warranty Optional parts Optional parts Model Chassis and cover LEB100F, LEB150F, LEB225F Harness for-J type LEB100F, LEB150F, LEB225F Remarks Refer to page of optional parts CE marking Low Voltage Directive RoHS Directive EMS Compliance : EN61204-3, EN61000-6-2 EN55022-B EN61000-3-2 EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-5 EN61000-4-6 EN61000-4-8 EN61000-4-11 January 31, 2022 LEB-1 AC-DC Power Supplies Open Frame/ Enclosed Type Ordering information LEB100F LEB 100 1 2 F 3 -05 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. 24 5 -O 6 1 Series name 2 Output wattage 3 Universal input 4 V1 Output voltage 5 V2 Output voltage 6 Optional *1 *8 G : Low leakage current R : with Remote ON/OFF S : with Chassis SN : with Chassis & cover T : Vertical terminal block Y : with Potentiometer Z : with ZT *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL V1 V2 DC OUTPUT LEB100F-0512 +5V 5A +12V 5(Peak 10)A LEB100F-0324 +3.3V 5A +24V 4(Peak 7)A LEB100F-0524 +5V 5A +24V 4(Peak 7)A LEB100F-0530 +5V 5A +30V 3.2(Peak 5.6)A LEB100F-0536 +5V 5A +36V 2.7(Peak 4.7)A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] *2 TOTAL OUTPUT WATTAGE[W] *3 LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *4 RIPPLE[mVp-p] -10 - 0C *4 0 to +50C *4 RIPPLE NOISE[mVp-p] -10 - 0C *4 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *5 START-UP TIME[ms] *6 HOLD-UP TIME[ms] *6 OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] V1 OVERCURRENT PROTECTION V2 V1 OVERVOLTAGE PROTECTION V2 REMOTE ON/OFF INPUT-OUTPUT -RC *7 INPUT-FG OUTPUT-RC-FG *7 OUTPUT-OUTPUT(V1 -RC-V2) *7 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LEB100F-0512 LEB100F-0324 LEB100F-0524 LEB100F-0530 AC85 - 264 1f or DC 120 - 370 1.2typ (Io=100%) 1.4typ (Io=100%) 0.6typ (Io=100%) 0.7typ (Io=100%) 50/60 (47 - 63) or DC 74typ (Io=100%) 78typ (Io=100%) 78typ (Io=100%) 78typ (Io=100%) 76typ (Io=100%) 80typ (Io=100%) 80typ (Io=100%) 80typ (Io=100%) 0.98typ 0.99typ 0.93typ 15typ (Io=100%) (At cold start) (Ta=25 C) 30typ (Io=100%) (At cold start) (Ta=25 C) 0.75max (60Hz, According to IEC62368-1 and DEN-AN) +5 +12 +3.3 +24 +5 +24 +5 +30 0-5 0 - 5 (Peak 10) 0 - 5 0 - 4 (Peak 7) 0 - 5 0 - 4 (Peak 7) 0 - 5 0 - 3.2 (Peak 5.6) 85 (Peak 145) 100 (Peak 172) 100 (Peak 172) 100 (Peak 172) 20max 48max 20max 96max 20max 96max 20max 120max 40max 100max 40max 150max 40max 150max 40max 180max 80max 120max 80max 120max 80max 120max 80max 200max 140max 160max 140max 160max 140max 160max 140max 240max 120max 150max 120max 150max 120max 150max 120max 300max 160max 180max 160max 180max 160max 180max 160max 360max 50max 120max 50max 240max 50max 240max 50max 300max 60max 150max 60max 290max 60max 290max 60max 350max 20max 48max 20max 96max 20max 96max 20max 120max 250max 500max 250max 500max 250max 500max 250max 500max 40typ 20typ 40typ 20typ 40typ 20typ 40typ 20typ 4.5 - 5.5 Fixed 2.85 - 3.60 Fixed 4.5 - 5.5 Fixed 4.5 - 5.5 Fixed 11.5 - 12.5 xx 23.0 - 25.0 xx 23.0 - 25.0 xx 28.7 - 31.5 xx Works over 105% of rating current and recovers automatically Works over 101% of peak current and recovers automatically Works over 115% of rating, by zener diode clamping Works at 115 - 140% of rating Option (Refer to Instruction Manual) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) AC100V 1minute, Cutoff current = 100mA, DC100V 10MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL, EN62368-1 Complies with DEN-AN and IEC60950-1 (At only AC input) Complies with FCC-B, CISPR22-B, EN55022-B, VCCI-B Complies with IEC61000-3-2 *9 75X35X222mm [2.95X1.38X8.74 inches] (WXHXD) /420g max (with chassis & cover : 690g max) Convection *1 Specification is changed at option, refer to Instruction Manual 5. *2 Peak loading for 10sec. And Duty 35% max, refer to Instruction Manual 4. In detail. *3 Refer to Instruction Manual 2.2 in detail. *4 This is the value that measured on measuring board with capacitor of 22mF within 150mm from output terminal.Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM101). *5 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. LEB-2 LEB100F-0536 78typ (Io=100%) 80typ (Io=100%) +5 +36 0-5 0 - 2.7 (Peak 4.7) 100 (Peak 172) 20max 144max 40max 180max 80max 200max 140max 240max 120max 300max 160max 360max 50max 300max 60max 350max 20max 144max 250max 500max 40typ 20typ 4.5 - 5.5 Fixed 34.5 - 37.5 xx *6 ACIN 100V,lo=100% *7 Applicable when remote control (optional) is added. *8 Please contact us about safety approvals for the model with option. *9 Please contact us about class C. * Series/Parallel operation is not possible. * Derating is required when operated with chassis and cover. * A sound may occur from power supply at peak loading. January 31, 2022 LEB100F External view [7.76] 212 + 0.5 [8.35] 222 Connector for -Z (option) 32 (Lead) CN4 CN4 [9.92] 235-+0.5 8 [0.31] [9.25] 2-M4 Mounting Hole CN3 [0.12] RC(-) PCB t=1.6 I / O Connector Mating Connector Terminal Chain : SVH-21T-P1.1 CN1 VHR-5N B3P5-VH Loose: BVH-21T-P1.1 Chain : SVH-21T-P1.1 CN2 VHR-8N B8P-VH Loose: BVH-21T-P1.1 Chain : SXH-001T-P0.6 CN3 XHP-2 (Option) B2B-XH-A Loose: BXH-001T-P0.6 Chain : SXH-001T-P0.6 CN4 XHP-3 (Option) B3B-XH-A Loose: BXH-001T-P0.6 (Mfr: J.S.T.) RC(+) + COM - [0.06] CN1 Pin No. Input 1 AC(L) 2 3 AC(N) 4 5 FG CN3 252 º4.5 [0.18] [1.26] [8.74] 3max 4.5 [0.18] 45-+0.5 [1.77] 25-+0.5 [0.98] (17) Connector for Remote ON/OFF (option) º3.5-4.0 [0.14-0.16] Mounting Hole 4.5 20 [0.18] [0.79] 15 [0.59] 46 [1.81] 5 [0.2] Voltage adjust(V1) (197) 5 CN2 CN3 4-M4 Mounting Hole 42 [1.65] CN1 4 5 8 CN4 [0.2] 20 [0.79] 30 [1.18] 1 G2 +V2 G1 +V1 C119 FG AC(N) AC(L) 8 [0.31] [9.25] [0.67] 65-+0.5 [2.56] [2.95] PIN CONNECTION CN2 Pin No. Output G2 1, 2 V2 3, 4 G1 5, 6 V1 7, 8 CN3 (Option) Pin No. Remote ON/OFF 1 RC(+) 2 RC(-) ¶Weight: 420g max (with chassis & cover : 690g max) ¶Tolerance: t1 [t0.04] ¶Dimensions in mm, [ ]= inches ¶PCB Material : CEM3 ¶Chassis and cover is optional. ¶Mounting torque: 1.5N · m(16kgf · cm)max CN4 (Option) Pin No. -Z 1 + COM 2 3 ¶Keep drawing current per pin below 5A for CN2 Performance data ¡RISE TIME & FALL TIME (LEB100F-0524) ¡EFFICIENCY (LEB100F-0524) 82 +24V 80 ACIN 100V Io=100% DC Output EFFICIENCY 78 +5V 76 74 AC Input 72 100ms/DIV 70 60 20ms/DIV ¡INPUT HARMONIC CURRENT (LEB100F-0524) 100 140 180 220 260 300 V ¡INPUT HARMONIC CURRENT (LEB100F-0524) 10 0.1 0.01 10 20 30 1 HARMONIC CURRENT Load factor 100% Input voltage AC 100V 1 Harmonic current standard class A (at odd number) A A Harmonic current standard class A (at odd number) 0.001 0 Load factor100% Load factor 50% INPUT VOLTAGE 10 HARMONIC CURRENT 75 CN2 CN1 5 3 1 2-º4.5 [0.18] 3-º3.5 [0.14] Mounting Hole 85 [3.35] 235-+0.5 Name plate 40 Load factor 100% Input voltage AC 230V 0.1 0.01 0.001 0 HARMONIC ORDER 10 20 30 40 HARMONIC ORDER January 31, 2022 LEB-3 AC-DC Power Supplies Open Frame/ Enclosed Type Ordering information LEB150F LEB 150 1 2 F 3 -05 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. 24 5 -O 6 1 Series name 2 Output wattage 3 Universal input 4 V1 Output voltage 5 V2 Output voltage 6 Optional *1 *8 G : Low leakage current R : with Remote ON/OFF S : with Chassis SN : with Chassis & cover T : Vertical terminal block Y : with Potentiometer Z : with ZT *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL V1 V2 DC OUTPUT LEB150F-0512 +5V 5A +12V 7.5(Peak 14)A LEB150F-0324 +3.3V 5A +24V 6(Peak 10)A LEB150F-0524 +5V 5A +24V 6(Peak 10)A LEB150F-0530 +5V 5A +30V 4.8(Peak 8)A LEB150F-0536 +5V 5A +36V 4(Peak 6.7)A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] *2 TOTAL OUTPUT WATTAGE[W] *3 LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +45C *4 RIPPLE[mVp-p] -10 - 0C *4 0 to +45C *4 RIPPLE NOISE[mVp-p] -10 - 0C *4 0 to +45C TEMPERATURE REGULATION[mV] -10 to +45C DRIFT[mV] *5 START-UP TIME[ms] *6 HOLD-UP TIME[ms] *6 OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] V1 OVERCURRENT PROTECTION V2 V1 OVERVOLTAGE PROTECTION V2 REMOTE ON/OFF INPUT-OUTPUT -RC *7 INPUT-FG OUTPUT-RC-FG *7 OUTPUT-OUTPUT(V1 -RC-V2) *7 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LEB150F-0512 LEB150F-0324 LEB150F-0524 LEB150F-0530 AC85 - 264 1f or DC 120 - 370 1.6typ (Io=100%) 2.0typ (Io=100%) 0.8typ (Io=100%) 1.0typ (Io=100%) 50/60 (47 - 63) or DC 76typ (Io=100%) 79typ (Io=100%) 79typ (Io=100%) 79typ (Io=100%) 79typ (Io=100%) 82typ (Io=100%) 82typ (Io=100%) 82typ (Io=100%) 0.98typ 0.99typ 0.93typ 15typ (Io=100%) (At cold start) (Ta=25 C) 30typ (Io=100%) (At cold start) (Ta=25 C) 0.75max (60Hz, According to IEC62368-1 and DEN-AN) +5 +12 +3.3 +24 +5 +24 +5 +30 0-5 0 - 7.5 (Peak 14) 0 - 5 0 - 6 (Peak 10) 0 - 5 0 - 6 (Peak 10) 0 - 5 0 - 4.8 (Peak 8) 115 (Peak 193) 150 (Peak 246) 150 (Peak 246) 150 (Peak 246) 20max 48max 20max 96max 20max 96max 20max 120max 40max 100max 40max 150max 40max 150max 40max 180max 80max 120max 80max 120max 80max 120max 80max 200max 140max 160max 140max 160max 140max 160max 140max 240max 120max 150max 120max 150max 120max 150max 120max 300max 160max 180max 160max 180max 160max 180max 160max 360max 50max 120max 50max 240max 50max 240max 50max 300max 60max 150max 60max 290max 60max 290max 60max 350max 20max 48max 20max 96max 20max 96max 20max 120max 250max 500max 250max 500max 250max 500max 250max 500max 40typ 20typ 40typ 20typ 40typ 20typ 40typ 20typ 4.5 - 5.5 Fixed 2.85 - 3.60 Fixed 4.5 - 5.5 Fixed 4.5 - 5.5 Fixed 11.5 - 12.5 xx 23.0 - 25.0 xx 23.0 - 25.0 xx 28.7 - 31.5 xx Works over 105% of rating current and recovers automatically Works over 101% of peak current and recovers automatically Works over 115% of rating, by zener diode clamping Works at 115 - 140% of rating Option (Refer to Instruction Manual) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) AC100V 1minute, Cutoff current = 100mA, DC100V 10MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL, EN62368-1 Complies with DEN-AN and IEC60950-1 (At only AC input) Complies with FCC-B, CISPR22-B, EN55022-B, VCCI-B Complies with IEC61000-3-2 *9 85X40X222mm [3.35X1.57X8.74 inches] (WXHXD) /530g max (with chassis & cover : 870g max) Convection *1 Specification is changed at option, refer to Instruction Manual 5. *2 Peak loading for 10sec. And Duty 35% max, refer to Instruction Manual 4. In detail. *3 Refer to Instruction Manual 2.2 in detail. *4 This is the value that measured on measuring board with capacitor of 22mF within 150mm from output terminal.Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM101). *5 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. LEB-4 LEB150F-0536 79typ (Io=100%) 82typ (Io=100%) +5 +36 0-5 0 - 4 (Peak 6.7) 150 (Peak 246) 20max 144max 40max 180max 80max 200max 140max 240max 120max 300max 160max 360max 50max 300max 60max 350max 20max 144max 250max 500max 40typ 20typ 4.5 - 5.5 Fixed 34.5 - 37.5 xx *6 ACIN 100V,lo=100% *7 Applicable when remote control (optional) is added. *8 Please contact us about safety approvals for the model with option. *9 Please contact us about class C. * Series/Parallel operation is not possible. * Derating is required when operated with chassis and cover. * A sound may occur from power supply at peak loading. January 31, 2022 LEB150F External view [0.2] 5 (24) Voltage adjust(V1) Connector for Remote ON/OFF (option) 105 -+ 0.5 [4.13] [0.2] CN4 º3.5-4.0 [0.14-0.16] Mounting Hole Connector for -Z (option) (204) [8.03] 47 CN3 CN4 5 CN1 4.5 4 5 8 212 -+ 0.5 [8.35] 222 [9.92] 235-+0.5 [9.25] 8 [0.31] 4.5 [0.18] 25 15 [0.98] [0.59] 51 [2.01] 37 [1.46] Mounting Hole CN4 CN3 3max [0.12] (Lead) RC(-) I / O Connector Mating Connector Terminal Chain : SVH-21T-P1.1 CN1 VHR-5N B3P5-VH Loose: BVH-21T-P1.1 Chain : SVH-21T-P1.1 CN2 VHR-8N B8P-VH Loose: BVH-21T-P1.1 Chain : SXH-001T-P0.6 CN3 XHP-2 B2B-XH-A (Option) Loose: BXH-001T-P0.6 Chain : SXH-001T-P0.6 CN4 XHP-3 B3B-XH-A (Option) Loose: BXH-001T-P0.6 (Mfr: J.S.T.) RC(+) + COM - PIN CONNECTION CN1 Pin No. Input 1 AC(L) 2 3 AC(N) 4 5 FG CN3 252 º4.5 [0.18] 2-M4 [8.74] PCB t=1.6 [0.06] [1.85] 20 [0.79] 30 [1.18] CN2 1 4-M4 Mounting Hole [0.18] CN2 G2 +V2 G1 +V1 C119 55-+0.5 [2.17] 35-+0.5 [1.38] FG AC(N) AC(L) 8 [0.31] [0.94] [2.95] 75-+0.5 [3.35] 85 CN1 5 3 1 235-+0.5 [9.25] 2-º4.5 [0.18] 95 [3.74] 4-º3.5 [0.14] Mounting Hole Name plate CN2 Pin No. Output G2 1, 2 V2 3, 4 G1 5, 6 V1 7, 8 CN3 (Option) Pin No. Remote ON/OFF 1 RC(+) 2 RC(-) ¶Weight: 530g max (with chassis & cover : 870g max) ¶Tolerance: t1 [t0.04] ¶Dimensions in mm, [ ]= inches ¶PCB Material : CEM3 ¶Chassis and cover is optional. ¶Mounting torque: 1.5N · m(16kgf · cm)max CN4 (Option) Pin No. -Z 1 + COM 2 3 ¶Keep drawing current per pin below 5A(7A at peak load)for CN2 Performance data ¡RISE TIME & FALL TIME (LEB150F-0524) ¡EFFICIENCY (LEB150F-0524) 84 +24V 82 ACIN 100V Io=100% DC Output EFFICIENCY 80 +5V 78 76 AC Input 74 100ms/DIV 72 60 20ms/DIV ¡INPUT HARMONIC CURRENT (LEB150F-0524) 140 180 220 260 300 V ¡INPUT HARMONIC CURRENT (LEB150F-0524) 10 0.1 0.01 10 20 30 1 HARMONIC CURRENT Load factor 100% Input voltage AC 100V 1 Harmonic current standard class A (at odd number) A Harmonic current standard class A (at odd number) A HARMONIC CURRENT 100 INPUT VOLTAGE 10 0.001 0 Load factor100% Load factor 50% 40 Load factor 100% Input voltage AC 230V 0.1 0.01 0.001 0 HARMONIC ORDER 10 20 30 40 HARMONIC ORDER January 31, 2022 LEB-5 AC-DC Power Supplies Open Frame/ Enclosed Type Ordering information LEB225F LEB 225 1 2 F 3 -05 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. 24 5 -O 6 1 Series name 2 Output wattage 3 Universal input 4 V1 Output voltage 5 V2 Output voltage 6 Optional *1 *8 G : Low leakage current R : with Remote ON/OFF S : with Chassis SN : with Chassis & cover T : Vertical terminal block Y : with Potentiometer Z : with ZT *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL V1 V2 DC OUTPUT LEB225F-0512 +5V 5A +12V 10(Peak 20)A LEB225F-0324 +3.3V 5A +24V 9(Peak 14)A LEB225F-0524 +5V 5A +24V 9(Peak 14)A LEB225F-0530 +5V 5A +30V 7.2(Peak 11)A LEB225F-0536 +5V 5A +36V 6(Peak 9.3)A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] *2 TOTAL OUTPUT WATTAGE[W] *3 LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +40C *4 RIPPLE[mVp-p] -10 - 0C *4 0 to +40C *4 RIPPLE NOISE[mVp-p] -10 - 0C *4 0 to +40C TEMPERATURE REGULATION[mV] -10 to +40C DRIFT[mV] *5 START-UP TIME[ms] *6 HOLD-UP TIME[ms] *6 OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] V1 OVERCURRENT PROTECTION V2 V1 OVERVOLTAGE PROTECTION V2 REMOTE ON/OFF INPUT-OUTPUT -RC *7 INPUT-FG OUTPUT-RC-FG *7 OUTPUT-OUTPUT(V1 -RC-V2) *7 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] LEB225F-0512 LEB225F-0524 LEB225F-0530 =LEB225F-0324 AC85 - 264 1f or DC 120 - 370 1.9typ (Io=100%) 3.0typ (Io=100%) 1.0typ (Io=100%) 1.5typ (Io=100%) 50/60 (47 - 63) or DC 77typ (Io=100%) 81typ (Io=100%) 81typ (Io=100%) 81typ (Io=100%) 79typ (Io=100%) 83typ (Io=100%) 83typ (Io=100%) 83typ (Io=100%) 0.98typ 0.99typ 0.93typ 15typ (Io=100%) (More than 3sec.to re-start) 30typ (Io=100%) (More than 3sec.to re-start) 0.75max (60Hz, According to IEC62368-1 and DEN-AN) +5 +12 +3.3 +24 +5 +24 +5 +30 0-5 0 - 10 (Peak 20) 0 - 5 0 - 9 (Peak 14) 0 - 5 0 - 9 (Peak 14) 0 - 5 0 - 7.2 (Peak 11) 145 (Peak 265) 225 (Peak 345) 225 (Peak 345) 225 (Peak 345) 20max 48max 20max 96max 20max 96max 20max 120max 40max 100max 40max 150max 40max 150max 40max 180max 80max 120max 80max 120max 80max 120max 80max 200max 140max 160max 140max 160max 140max 160max 140max 240max 120max 150max 120max 150max 120max 150max 120max 300max 160max 180max 160max 180max 160max 180max 160max 360max 50max 120max 50max 240max 50max 240max 50max 300max 60max 150max 60max 290max 60max 290max 60max 350max 20max 48max 20max 96max 20max 96max 20max 120max 250max 500max 250max 500max 250max 500max 250max 500max 40typ 20typ 40typ 20typ 40typ 20typ 40typ 20typ 4.5 - 5.5 Fixed 2.85 - 3.60 Fixed 4.5 - 5.5 Fixed 4.5 - 5.5 Fixed 11.5 - 12.5 xx 23.0 - 25.0 xx 23.0 - 25.0 xx 28.7 - 31.5 xx Works over 105% of rating current and recovers automatically Works over 101% of peak current and recovers automatically Works over 115% of rating, by zener diode clamping Works at 115 - 140% of rating Option (Refer to Instruction Manual) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) AC100V 1minute, Cutoff current = 100mA, DC100V 10MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL, EN62368-1 Complies with DEN-AN and IEC60950-1 (At only AC input) Complies with FCC-B, CISPR22-B, EN55022-B, VCCI-B Complies with IEC61000-3-2 *9 95X45X222mm [3.74X1.77X8.74 inches] (WXHXD) /700g max (with chassis & cover : 1,080g max) Convection *1 Specification is changed at option, refer to Instruction Manual 5. *2 Peak loading for 10sec. And Duty 35% max, refer to Instruction Manual 4. In detail. *3 Refer to Instruction Manual 2.2 in detail. *4 This is the value that measured on measuring board with capacitor of 22mF within 150mm from output terminal.Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM101). *5 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. LEB-6 =LEB225F-0536 81typ (Io=100%) 83typ (Io=100%) +5 +36 0-5 0 - 6 (Peak 9.3) 225 (Peak 345) 20max 144max 40max 180max 80max 200max 140max 240max 120max 300max 160max 360max 50max 300max 60max 350max 20max 144max 250max 500max 40typ 20typ 4.5 - 5.5 Fixed 34.5 - 37.5 xx *6 ACIN 100V,lo=100% *7 Applicable when remote control (optional) is added. *8 Please contact us about safety approvals for the model with option. *9 Please contact us about class C. * Series/Parallel operation is not possible. * Derating is required when operated with chassis and cover. * A sound may occur from power supply at peak loading. =marked models are pending for safety approvals. Consult with us for delivery. January 31, 2022 LEB225F External view 235-+0.5 [9.25] [0.18] Connector for Remote ON/OFF (option) 5 [0.2] Voltage adjust(V1) 124 -+ 0.5 [4.88] (200) CN4 º3.5-4.0 [0.14-0.16] Mounting Hole [7.87] 212 + 0.5 [8.35] 222 [8.74] Connector for -Z (option) [9.92] 235+0.5 [9.25] 52 8 [0.31] 4.5 [0.18] Mounting Hole CN3 30 [1.18] 42 [1.65] CN3 252 º4.5 [0.18] 2-M4 CN4 (Lead) RC(-) PCB t=1.6 3max [0.12] 108 [4.25] CN3 CN4 5 [0.2] CN1 4.5 6 7 10 [0.18] G1 +V1 RC(+) + COM - 15 [0.59] 58 [2.28] +V2 CN2 1 65-+0.5 [2.56] 45-+0.5 [1.77] G2 (15.5) CN2 C119 4-M4 Mounting Hole [0.61] 85-+0.5 [3.35] 95 [3.74] 5 FG 3 AC(N) 1 AC(L) 23 [0.91] 33 [1.3] 4-º3.5 [0.14] Mounting Hole CN1 8 [0.31] [2.05] 2-º4.5 Name plate [0.06] I / O Connector Mating Connector Terminal Chain : SVH-21T-P1.1 CN1 VHR-5N B3P5-VH Loose: BVH-21T-P1.1 Chain : SVH-21T-P1.1 CN2 B10P-VH VHR-10N Loose: BVH-21T-P1.1 Chain : SXH-001T-P0.6 CN3 XHP-2 B2B-XH-A (Option) Loose: BXH-001T-P0.6 Chain : SXH-001T-P0.6 CN4 XHP-3 B3B-XH-A (Option) Loose: BXH-001T-P0.6 (Mfr: J.S.T.) CN1 Pin No. Input 1 AC(L) 2 3 AC(N) 4 5 FG PIN CONNECTION CN2 Pin No. Output G2 1, 2, 3 V2 4, 5, 6 G1 7, 8 V1 9, 10 CN3 (Option) Pin No. Remote ON/OFF 1 RC(+) 2 RC(-) ¶Weight: 700g max (with chassis & cover : 1,080g max) ¶Tolerance:t1 [t0.04] ¶Dimensions in mm, [ ]= inches ¶PCB Material : CEM3 ¶Chassis and cover is optional. ¶Mounting torque: 1.5N · m(16kgf · cm)max CN4 (Option) Pin No. -Z 1 + COM 2 3 ¶Keep drawing current per pin below 5A (7A at peak load) for CN2 Performance data ¡RISE TIME & FALL TIME (LEB225F-0524) ¡EFFICIENCY (LEB225F-0524) 86 +24V ACIN 100V Io=100% 82 EFFICIENCY DC Output 84 +5V 80 AC Input 78 100ms/DIV 76 60 20ms/DIV ¡INPUT HARMONIC CURRENT (LEB225F-0524) 140 180 220 260 300 V ¡INPUT HARMONIC CURRENT (LEB225F-0524) 10 0.1 0.01 10 20 30 1 HARMONIC CURRENT Load factor 100% Input voltage AC 100V 1 Harmonic current standard class A (at odd number) A Harmonic current standard class A (at odd number) A HARMONIC CURRENT 100 INPUT VOLTAGE 10 0.001 0 Load factor100% Load factor 50% 40 Load factor 100% Input voltage AC 230V 0.1 0.01 0.001 0 HARMONIC ORDER 10 20 30 40 HARMONIC ORDER January 31, 2022 LEB-7
LEB150F-0512 价格&库存
很抱歉,暂时无法提供与“LEB150F-0512”相匹配的价格&库存,您可以联系我们找货
LEB150F-0512
  • 1+1333.660761+168.26468
