IQS263B-0-DNR
IQS263B-0-DNR
    AZOTEQ
    IQS263B-0-DNR
IQS263B-0-DNR 数据手册
IQ Switch® ProxSense® Series ProxSense® IQS263B Datasheet 3 Channel Capacitive Touch and Proximity Controller with 8-bit Resolution Slider or Scroll Wheel The IQS263B ProxSense® IC is a 3-channel projected (or self) capacitive proximity and touch controller with best in class sensitivity, signal to noise ratio and power consumption. Other features include automatic tuning for sense electrodes, internal reference capacitor and internal regulator to reduce total system cost. Main Features                  3 Self or Mutual Channel Capacitive Controller Configurable 8-bit 2/3 channel slider or 3 channel scroll wheel Up to 80Hz report rate On chip Movement Detection algorithm SAR compliance in mobile devices according to the IEC 62209-2 ed1.0 standard and the FCC standard (KDB 616217 – D04 SAR for laptop and tablets v01) RoHS2 Left and right flick gesture recognition Automatic adjustment for optimal performance (ATI) Compliant User selectable Proximity and Touch thresholds Long proximity range Automatic drift compensation Fast I2C Interface Event mode or Streaming modes IQS263B MSOP10 / DFN 10 Hibernation mode Low Power, suitable for battery applications Representations only, not actual markings Supply voltage: 1.8V to 3.6V LTA + Threshold Threshold can be either a Proximity or Touch threshold, depending on the current channel being processed. Note that a proximity condition will be forced enabled if there is a touch condition on any channel. Please refer to Section 6.7 and 6.8 for proximity and touch threshold selections. 8.6 ATI The Automatic Tuning Implementation (ATI) is a sophisticated technology implemented on the new ProxSense® series devices. It allows for optimal performance of the devices for a wide range of sense electrode capacitances, without modification or addition of external components. The ATI allows the tuning of two parameters, an ATI Multiplier and an ATI Compensation, to adjust the Count values for an attached sense electrode. ATI allows the designer to optimize a specific design by adjusting the sensitivity IQS263B Datasheet V1.05 Page 24 of 53 January 2021 IQ Switch® ProxSense® Series and stability of each channel through the adjustment of the ATI parameters. The IQS263B has a full ATI function. The full-ATI function is default enabled, but can be disabled by setting the ATI_OFF bit, or changed to partial or alternative ATI by setting the ATI_Partial and ATI_ALT. The ATI_Busy bit will be set while an ATI event is busy. For more information regarding the ATI algorithm, please contact Azoteq at: ProxSenseSupport@azoteq.com 8.6.1 ATI Sensitivity 8.6.3 ATI Base (Multiplier) The following parameters will influence the base value:  Cs_SIZE1: Size of sampling capacitor.  PROJ_BIAS bits: Adjusts the biasing of some analogue parameters in the mutual capacitive operated IC. (Only applicable in mutual capacitance mode.)  Charge Transfer Frequency  MULTIPLIER bits. The base value used for the ATI function can be implemented in 2 ways: On the IQS263B device, the user can specify the BASE value (Section 6.13) and the TARGET value (Section 6.14) for the proximity channel (CH0) and touch channels (CH1-CH3). 1. ATI_PARTIAL = 0. ATI automatically adjusts MULTIPLIER bits to reach a selected base value2. Please refer to Section 6.13 for available base values. A rough estimation of sensitivity can be calculated as: 2. ATI_PARTIAL = 1. The designer can specify the multiplier settings. These settings will give a custom base value from where the compensation bits will be automatically implemented to reach the required target value. The base value is determined by two sets of multiplier bits. Sensitivity Multipliers which will also scale the compensation to normalise the sensitivity and Compensation Multipliers to adjust the gain. ܵ݁݊‫ ן ݕݐ݅ݒ݅ݐ݅ݏ‬ ܶ‫ܶܧܩܴܣ‬ ‫ܧܵܣܤ‬ As can be seen from this equation, the sensitivity can be increased by either increasing the Target value or decreasing the Base value. It should, however, be noted that a higher sensitivity will yield a higher noise susceptibility. 8.6.2 ATI Target The target value is reached by adjusting the COMPENSATION bits for each channel (ATI target limited to 2048 counts). The target value is written into the respective channel’s TARGET registers. The value written into these registers multiplied by 8 will yield the new target value. (Please refer to Section 6.14) 1 Changing CS_SIZE if ATI_OFF = 0 will change CS Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 8.6.4 Re-ATI An automatic re-ATI event will occur if the counts are outside its re-ATI limits. The reATI limit or ATI boundary is calculated as the target value divided by 8. For example: - Target = 512, Re-ATI will occur if CS is outside 512±64. 2 ATI function will use user selected CS_SIZE and PROJ_BIAS (if applicable) and will only adjust the MULTIPLIER bits to reach the base values. IQS263B Datasheet V1.05 Page 25 of 53 January 2021 IQ Switch® ProxSense® Series A re-ATI event can also be issued by the host MCU by setting the REDO_ATI bit. The REDO_ATI bit will clear automatically after the ATI event was started. Note: Re-ATI will automatically clear all proximity, touch and halt status bits. Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 8.6.5 ATI ERROR The ATI error bit (read only) indicates to the user that the ATI targets where not reached. Adjustments of the base values or ATI BANDs are required. IQS263B Datasheet V1.05 Page 26 of 53 January 2021 IQ Switch® ProxSense® Series 9 Communication The IQS263B device interfaces to a master controller via a 3-wire (SDA, SCL and RDY) serial interface bus that is I2CTM compatible, with a maximum communication speed of 400kbit/s. 9.1 Control Byte The Control byte indicates the 7-bit device address (44H default) and the Read/Write indicator bit. The structure of the control byte is shown in Figure 9.1. 7 bit address MSB 1 0 0 0 I2C Group Figure 9.1 1 0 0 R/W LSB Sub- addresses IQS263B Control Byte. The I2C device has a 7 bit Slave Address (default 0x44H) in the control byte as shown in Figure 9.1. To confirm the address, the software compares the received address with the device address. Sub-address values can be set by OTP programming options. 9.2 I2C Read To read from the device a current address read can be performed. This assumes that the address-command is already setup as desired. Current Address Read Start Control Byte S Figure 9.2 Data n ACK Data n+1 Stop NACK ACK S Current Address Read. If the address-command must first be specified, then a random read must be performed. In this case a WRITE is initially performed to setup the address-command, and then a repeated start is used to initiate the READ section. Start Control Byte S Adr + WRITE Figure 9.3 Random Read Addresscommand ACK ACK Start Control Byte S Adr + READ Data n Stop NACK ACK S Random Read. 9.3 I2C Write To write settings to the device a Data Write is performed. Here the Address-Command is always required, followed by the relevant data bytes to write to the device. DATA WRITE Start Control Byte S Adr + WRITE Figure 9.4 AddressCommand ACK Data n ACK Data n+1 ACK Stop ACK S I2C Write. Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. IQS263B Datasheet V1.05 Page 27 of 53 January 2021 IQ Switch® ProxSense® Series 9.4 End of Communication Session / Window Similar to other Azoteq I2C devices, to end the I2C communication session, a STOP command is given. When sending numerous read and write commands in one communication cycle, a repeated start command must be used to stack them together (since a STOP will jump out of the communication window, which is not desired). The STOP will then end the communication, and the IQS263B will return to process a new set of data. Once this is obtained, the communication window will again become available (RDY set LOW). 9.5 I2C Sub-address The IQS263B has four available sub addresses, 44H (default) to 47H, which allows up to four devices on a single I2C bus. 9.5.1 Internal sub-address selection Selecting the sub-address via OTP bits allows the user 4 different options: Table 9.1 I2C sub-address selection FG25 FG26 Device Address 0 0 1 1 0 1 0 1 0x44 0x45 0x46 0x47 9.6 RDY Hand-Shake Routine The master or host MCU has the capability to request a communication window at any time, by pulling the RDY line low. The communication window will open directly following the current conversion cycle. For more details please refer to the communication interface guide. 9.7 I2C Specific Commands bit. A reset will typically take place if a timeout during communication occurs. 9.7.2 I2C Timeout If no communication is initiated from the master/host MCU within the first tCOMMS (tCOMMS = 5.12ms default) of the RDY line indicating that data is available (i.e. RDY = low), the device will resume with the next cycle of charge transfers and the data from the previous conversions will be lost. The timeout time is adjustable in steps of 1.28ms in the Thresholds register (0x0A; byte 7). There is also a timeout (tI2C) that cannot be disabled, for when communication has started but not been completed, for example when the bus is being held by another device. tI2C = 150ms. 9.8 I2C I/O Characteristics The IQS263B requires the input voltages given in Table 9.2, for detecting high (“1”) and low (“0”) input conditions on the I2C communication lines (SDA, SCL and RDY). Table 9.2 IQS263B I2C Input voltage 9.7.1 Show Reset After start-up, and after every reset event, the “Show Reset” flag will be set in the System Flags register (0x01H; byte 0). The “Show Reset” bit can be read to determine whether a reset has occurred on the device (it is recommended to be continuously monitored). This bit will be set ’1’ after a reset. Input Voltage (V) VinLOW VinHIGH 0.3*VDDHI 0.7*VDDHI Table 9.3 provides the output voltage levels of the IQS263B device during I2C communication. The SHOW_RESET bit will be cleared (set to ’0’) by writing a ’0’ into the “Show Reset” Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. IQS263B Datasheet V1.05 Page 28 of 53 January 2021 IQ Switch® ProxSense® Series Table 9.3 IQS263B I2C Output voltage between bits 8 and 9 when any device on the bus is addressed in order to determine whether the clocked address matches its own. This will only occur during times when the IQS263B is monitoring the I2C bus, this is whenever the ready line is low in both streaming and event mode. In event mode, there are also times during the operating cycle where the IQS263B will monitor the I2C bus, regardless of whether an event has occurred, said clock stretching will also take place during these times. It is recommended to place any slave devices which cannot tolerate such behavior on a separate bus. Output Voltage (V) VoutLOW VoutHIGH GND +0.2 (max.) VDDHI – 0.2 (min.) 9.9 Multi -Slave Bus Operation The IQS263B can operate on an I2C bus with other slave devices. However, it should be noted that the IQS263B will clock stretch 10 Communication Command/Address Structure 10.1 Registers & Memory map Table 10.1 IQS263B Registers Address Description 0x00H Device Information R 10.2.1 0x01H System Flags R/W 10.2.2 0x02H Coordinates R 10.2.3 0x03H Touch Bytes R 10.2.4 0x04H Counts R 10.2.5 0x05H LTA R 10.2.6 0x06H Deltas R 10.2.7 0x07H Multipliers R/W 10.2.8 0x08H Compensation R/W 10.2.9 0x09H ProxSettings R/W 10.2.10 0x0AH Thresholds R/W 10.2.11 0x0BH Timings & Targets R/W 10.2.12 Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. IQS263B Datasheet V1.05 Access Section Page 29 of 53 January 2021 IQ Switch® ProxSense® Series 0x0CH Gesture Timers R/W 10.2.13 0x0DH Active Channels R/W 10.2.14 10.2 Registers Descriptions 10.2.1 Device Information 0x00H Information regarding the device type and version is recorded here. Any other information specific to the device version can be stored here. Each Azoteq ROM has a unique Product- and Version number. Product Number (PROD_NUM) Access Bit R Value 7 6 5 4 3 2 1 0 1 0 0x3C Version Number (VERSION_NUM) Access Bit R Value 7 6 5 4 3 2 0x01 10.2.2 System Flags 0x01H System Flags (SYSFLAGS0) Access Bit R/W Name 7 Show Reset 6 5 Move ment ATI Error 4 Proj Filter Mode Halt Bit 7: 0 = Reset has NOT occurred. 1 = Reset has occurred. Write to 0 to clear. Bit 6: 0 = No movement detected. 1 = Movement detected. Bit 5: 0 = ATI Error has NOT occurred. 1 = ATI Error has occurred. Bit 4: 0 = Self capacitive mode selected. Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 3 IQS263B Datasheet V1.05 2 ATI Busy 1 0 Ind LP Halt Active Page 30 of 53 January 2021 IQ Switch® ProxSense® Series 1 = Projected capacitive mode selected. Bit 3: Will show only if “Ind Halt” bit is set to 0. 0 = A global filter halt is not active. 1 = A global filter halt is active. Bit 2: 0 = Device is not busy with ATI. 1 = Device is busy with ATI. Bit 1: 0 = Global Filter Halt enabled. 1 = Global Filter Halt disabled. Bit 0: 0 = Low Power mode is not active. 1 = Low Power mode is active. Events Access Bit R Name 7 6 Flick Flick Left Right 5 Tap 4 Move ment 3 ATI Event 2 1 Slide Touch Prox Event Event Event 0 10.2.3 Wheel Coordinates 0x02H Wheel 1 Low Access Bit R Name 7 6 5 4 3 2 1 0 1 0 1 0 Wheel 1 Coordinate Low byte first Relative Coordinate Low Access Bit R Name 7 6 5 4 3 2 Relative Coordinate Low byte first Relative Coordinate High Access Bit R Name Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 7 6 5 4 3 2 Relative coordinate High byte IQS263B Datasheet V1.05 Page 31 of 53 January 2021 IQ Switch® ProxSense® Series 10.2.4 Touch Bytes 0x03H Touch Byte 0 Access Bit R Name 7 6 5 4 3 2 1 0 CH3 CH2 CH1 CH01 3 2 1 0 CH3 CH2 CH1 CH02 Halt Byte 1 Access Bit R Name 7 6 5 4 Bit 0 of the first byte (CH0) will indicate proximity events; the rest of the bits indicate touches as shown. The second byte shows the halt status bits. 10.2.5 Counts 0x04H This register has 10 bytes to store the count values of the low power channel and then CH0 up to CH3 the low byte will always read out first, followed by the high byte, before the moving to the next channel. Low Power Channel Low Access Bit R Name 7 6 5 4 3 2 1 0 1 0 Low Power Channel CS (Counts) Low byte first Byte 0 CH 3 Counts High byte Access Bit R Name 7 6 5 4 3 2 Channel 3 Count value (High byte last) Byte 9 10.2.6 LTA 0x05H This register has 10 bytes to store the LTA values of the low power channel and then CH0 up to CH3 the low byte will always read out first, followed by the high byte, before the moving to the next channel. Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 1 CH0 indicates Proximity, not Touch. 2 CH0 indicates Proximity, not Touch. IQS263B Datasheet V1.05 Page 32 of 53 January 2021 IQ Switch® ProxSense® Series Low Power Channel LTA Low byte Access Bit R Name 7 6 5 4 3 2 1 0 1 0 Low Power Channel LTA value (Low byte first) Byte 0 CH 3 LTA High byte Access Bit R Name 7 6 5 4 3 2 Channel 3, LTA value (High byte last) Byte 9 10.2.7 Deltas 0x06H This register has 8 bytes to store the Delta (the difference between Count and LTA) values of CH0 up to CH3. The low byte will always read out first, followed by the high byte, before the moving to the next channel. Deltas are not available when using the wheel setting. Delta Counts for CH0 Low Access Bit R Name 7 6 5 4 3 2 1 0 1 0 1 0 Delta for CH0 – Low Byte first Byte 0 Delta Counts for CH3 High Access Bit R Name 7 6 5 4 3 2 Delta for CH3 – High Byte last Byte 7 10.2.8 Multipliers 0x07H CH0 Multipliers Access Bit R/W Name Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 7 6 5 4 Sensitivity Multipliers IQS263B Datasheet V1.05 3 2 Comp Multipliers Page 33 of 53 January 2021 IQ Switch® ProxSense® Series Byte 0 CH1 Multipliers Access Bit R/W Name 7 6 5 4 3 Sensitivity Multipliers 2 1 0 Comp Multipliers Byte 1 CH2 Multipliers Access Bit R/W Name 7 6 5 4 3 Sensitivity Multipliers 2 1 0 Comp Multipliers Byte 2 CH3 Multipliers Access Bit R/W Name 7 6 5 4 3 Sensitivity Multipliers 2 1 0 Comp Multipliers Byte 3 CH1/CH0 Base Values Access Bit R/W Name Byte 4 Default 7 6 5 4 3 Channel 1 2 1 0 Channel 0 0x44 CH3/CH2 Base Values Access Bit R/W Name Byte 5 Default 7 6 5 4 3 Channel 3 2 1 0 Channel 2 0x44 Base Value Options: Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. IQS263B Datasheet V1.05 Page 34 of 53 January 2021 IQ Switch® ProxSense® Series 0000 - 74 1000 - 202 0001 - 90 1001 - 218 0010 - 106 1010 - 234 0011 - 122 1011 - 250 0100 - 138 (default) 1100 - 266 0101 - 154 1101 - 282 0110 - 170 1110 - 298 0111 - 186 1111 - 314 10.2.9 Compensation 0x08H CH0 Compensation value Access Bit R/W Name 7 6 5 4 3 2 1 0 1 0 Channel 0 Compensation Byte 0 CH 3 Compensation Value Access Bit R/W Name 7 6 5 4 3 2 Last active channel Compensation Byte 3 10.2.10 ProxSettings 0x09H ProxSettings0 Access Bit R/W Name 7 6 5 4 3 2 Reseed Stream ATI ATI ATI Redo OFF Partial Band ATI Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. IQS263B Datasheet V1.05 ATI 1 0 4MHz Force Halt Page 35 of 53 January 2021 IQ Switch® ProxSense® Series Byte 0 0x00H Default Bit 7: 0 = ATI Enable 1 = ATI Disabled Bit 6: 0 = Full ATI 1 = Partial ATI Bit 5: 0 = 1/8 * LTA 1 = 1/4 *LTA Bit 4: 0 = No Action 1 = Redo ATI Bit 3: 0 = No Action 1 = Send Reseed Bit 2: 0 = No communication widows during ATI routine 1 = Communication windows after each charge cycle regardless of ATI busy. Bit 1: 0 = 2MHz Oscillator 1 = 4MHz Oscillator Bit 0: 0 = No Action 1 = Forcing all LTAs to stop calculating ProxSettings1 Access Bit R/W Name Byte 1 Default 7 6 WDT Event OFF Mode 5 4 LTA Beta 3 2 Slider 0 CF 0x11H Bit 7: 0 = WDT Enable 1 = WDT Disabled Bit 6: 0 = Streaming Mode 1 = Event Mode Bit 5:4: 00 = 29 01 = 28 (default) 10 = 27 11 = 26 (fastest following) Bit 3:2: 00 = Slider Disabled 01 = 2CH Slider 10 = Wheel (Also used for 3CH wrap around slider) 11 = 3CH Slider Bit 1:0: 00 = Counts Filtering OFF 01 = Beta - 01 10 = Beta - 02 11 = Beta – 03 (largest filter for noise suppression, slowest response) Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 1 IQS263B Datasheet V1.05 Page 36 of 53 January 2021 IQ Switch® ProxSense® Series ProxSettings2 Access Bit R/W Name Byte 2 Default 7 6 5 4 Sleep Force Wake Halt Sleep Release Wheel Filter 3 2 1 Movement 0 OUT 0x00H Bit 7: 0 = Reseed upon Halt timer expiration 1 = Return to LP upon Halt timer expiration Bit 6: 0 = No Action 1 = Send Force Sleep Bit 5: 0 = Wake from LP only in the normal direction (Counts below LTA for Self) 1 = Wake from LP for counts in both direction Bit 4: 0 = Coordinate Filter Enabled 1 = Coordinate Filter Disabled Bit 3:2: 00 = Movement Disabled 01 = Movement on CH0 10 = Movement on CH3 Bit 1:0: 00 = Prox 01 = Sync (ZC input) 10 = Touch on CH1 11 = Movement output ProxSettings3 Access Bit R/W Name Byte 3 Default 7 6 5 4 3 2 Touch Off Proj Float Halt Debounc e Mode Bias Cx Charge Mode Bit 7: 0 = 2 consecutive samples 1 = 4 Sample Bit 6: 0 = off mode disabled 1 = off mode enabled Bit 5: 0 = 10uA 1 = 20uA Bit 4: 0 = Grounded 1 = Floating Bit 3: 0 = Normal Charging Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. Turbo 1 0 Filtered Xfer Touches 0x00H IQS263B Datasheet V1.05 Page 37 of 53 January 2021 IQ Switch® ProxSense® Series 1 = Halt All Channels’ Charging Bit 2: 0 = Turbo Mode Enabled 1 = Turbo Mode Disabled Bit 1: 0 = Touch detection on unfiltered counts 1 = Touch detection on filtered counts Bit 0: 0 = Fast Charging 1 = Slower Charging Event Mask Access Bit 7 6 5 4 3 2 1 0 R/W Name Flick Left Flick Right Tap Move ment ATI Slide Touch Prox Byte 4 Default 10.2.11 0xFFH Thresholds 0x0A Proximity Threshold Access Bit 7 6 5 4 3 R/W Name Value Byte 0 Default 4D 2 1 0 2 1 0 2 1 0 Touch Threshold CH1 Access Bit 7 6 5 4 3 R/W Name 1-255 Byte 1 Default 16D Touch Threshold CH3 Access Bit R/W Name 1-255 Byte 3 Default 16D Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 7 6 5 4 3 IQS263B Datasheet V1.05 Page 38 of 53 January 2021 IQ Switch® ProxSense® Series Movement Threshold Access Bit 7 6 5 4 3 R/W Name 1-255 Byte 4 Default 3D 2 1 0 3 2 1 0 CH3 CH2 CH1 Halt timeout Reseed Block Access Bit 7 R/W Name Byte 5 Default 6 5 4 0 Halt Time in Number of Samples Access Bit 7 6 5 4 3 2 R/W Name Value times 50 (FF = Always; 00 = Never) Byte 6 Default 20D 1 0 1 0 I2C Timeout Access Bit R/W Name Value times 1.28ms Byte 7 Default 4D 10.2.12 7 6 5 4 3 2 Timings 0x0BH Low Power Time Access Bit R/W Name Steps of 16ms (Value times 16ms) Byte 0 Default 0x00H Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 7 6 5 4 3 IQS263B Datasheet V1.05 2 1 0 Page 39 of 53 January 2021 IQ Switch® ProxSense® Series ATI Target for Touch Channels Access Bit 7 6 5 4 3 R/W Name Steps of 8 (Value times 8) Byte 1 Default 48D 2 1 0 2 1 0 2 1 0 2 1 0 2 1 0 ATI Target for Proximity Access Bit R/W Name Steps of 8 (Value times 8) Byte 2 Default 64D 10.2.13 7 6 5 4 3 Gesture Timers 0x0CH Tap Timer Access Bit 7 6 5 4 3 R/W Name Tap Timer Limit Byte 0 Default 5D Flick Timer Access Bit 7 6 5 4 3 R/W Name Flick Timer Limit Byte 1 Default 20D Flick Threshold Access Bit R/W Name Flick Threshold Value Byte 2 Default 50D Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 7 6 5 4 3 IQS263B Datasheet V1.05 Page 40 of 53 January 2021 IQ Switch® ProxSense® Series 10.2.14 Active Channels 0x0DH Active Chan 0 Access Bit R/W Name Byte 0 Default Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 7 6 5 4 3 2 1 0 CH3 CH2 CH1 CH0 0x0FH IQS263B Datasheet V1.05 Page 41 of 53 January 2021 IQ Switch® ProxSense® Series 11 Specifications 11.1 Absolute Maximum Specifications The following absolute maximum parameters are specified for the device: Exceeding these maximum specifications may cause damage to the device.  Operating temperature -20°C to 85°C  Supply Voltage (VDDHI – GND) 3.6V  Maximum pin voltage  Maximum continuous current (for specific Pins) VDDHI + 0.5V (may not exceed VDDHI max) 10mA  Minimum pin voltage GND - 0.5V  Minimum power-on slope 100V/s  ESD protection ±4kV (Human body model) Table 11.1 IQS263B Self Capacitive General Operating Conditions1 DESCRIPTION Conditions Supply voltage MIN TYP MAX UNIT VDDHI 1.8 3.3V 3.6 V 1.62 1.7 1.79 V Internal regulator output 1.8 ≤ VDDHI≤ 3.6 VREG Streaming mode* 3.3V 80Hz 180 Event Mode 80Hz 90 150 μA Low Power Setting 8** 128ms 4 6.5 μA Low Power Setting 16** 256ms 3 4 μA Table 11.2 μA IQS263B Projected Capacitive General Operating Conditions DESCRIPTION Conditions Supply voltage * PARAMETER PARAMETER MIN TYP MAX UNIT VDDHI 1.8 3.3V 3.6 V 1.79 V Internal regulator output 1.8 ≤ VDDHI≤ 3.6 VREG 1.62 1.7 Streaming mode 3.3V 80Hz - 305 μA Event Mode 80Hz - 230 μA Low Power Setting 8** 128ms - 5 11 μA Low Power Setting 16** 256ms - 4 6 μA Current consumption for streaming mode will differ with number of bytes read, speed and pull up resistor values Current values shown in this datasheet, does not include dissipation through I2C pull up resistors unless streaming mode is indicated. 1 Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. IQS263B Datasheet V1.05 Page 42 of 53 January 2021 IQ Switch® ProxSense® Series ** LP interval period = Low power value x 16ms Table 11.3 Start-up and shut-down slope Characteristics DESCRIPTION Power On Reset Brown Out Detect Table 11.4 Conditions PARAMETER VDDHI Slope ≥ 100V/s POR @25°C VDDHI Slope ≥ 100V/s BOD @25°C MAX UNIT 1.6 V 1.05 V Electrode Specifications – Self Capacitance DESCRIPTION Conditions PARAMETER MAX UNIT CP 120 pF RS 10 kΩ Parasitic Capacitance CX to GND Series Resistor Table 11.5 MIN CP = 120pF Electrode Specifications – Mutual Capacitance DESCRIPTION Conditions PARAMETER MIN MAX UNIT Parasitic Capacitance Tx to GND CT 100 pF Parasitic Capacitance Rx to GND CR 100 pF Mutual Capacitance CM 10 pF Series Resistor RTX 10 kΩ RRX 1 kΩ Series Resistor Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. CM = 1pF IQS263B Datasheet V1.05 0.1 Page 43 of 53 January 2021 IQ Switch® ProxSense® Series Table 11.6 ATI Times Turbo Mode Off Oscillator 2MHZ Target value 4MHZ Low High Low High Channels active 1 3 1 3 1 3 1 3 Typical time [ms] 625 625 630 630 310 300 313 305 850 (34 cycles @25ms per cycle) Worst case Turbo Mode On Oscillator 2MHZ Target value 4MHZ Low High Low High Channels active 1 3 1 3 1 3 1 3 Typical time [ms] 200 350 240 420 105 175 120 205 Worst case 500 - 600 (34 cycles estimate) ATI Error / Failure Worst case Including re-tries Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. 4.7 seconds (189 cycles @25ms per cycle) Something is wrong with settings or electrode(s) IQS263B Datasheet V1.05 Page 44 of 53 January 2021 IQ Switch® ProxSense® Series 12 Packaging Information 12.1 MSOP-10 Figure 12.1 Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. MSOP-10 Package Dimensions. IQS263B Datasheet V1.05 Page 45 of 53 January 2021 IQ Switch® ProxSense® Series Figure 12.2 Table 12.1 Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. MSOP-10 Footprint. MSOP-10 Footprint Dimensions from Figure 12.2. Dimension [mm] Pitch 0.50 C 4.40 Y 1.45 X 0.30 IQS263B Datasheet V1.05 Page 46 of 53 January 2021 IQ Switch® ProxSense® Series 12.2 DFN10 Table 12.2 DFN-10 Package dimensions (bottom) 3 ±0.1 B 0.5 C 0.25 D n/a F 3 ±0.1 L 0.4 P 2.4 Q 1.65 Table 12.3 DFN-10 Package dimensions (side) Dimension [mm] G 0.05 H 0.65 I 0.7-0.8 Table 12.4 F A L [mm] D B Q Dimension A C P Figure 12.3 DFN-10 Package dimensions (bottom). Note that the saddle need to be connected to GND on the PCB. Figure 12.4 DFN-10 Package dimensions (side) DFN-10 Landing dimensions Dimension [mm] A 2.4 B 1.65 C 0.8 D 0.5 E 0.3 F 3.2 Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. Figure 12.5 DFN-10 Landing dimensions IQS263B Datasheet V1.05 Page 47 of 53 January 2021 IQ Switch® ProxSense® Series 12.3 Tape and Reel Specification 12.3.1 MSOP10 Figure 12.6 MSOP-10 Tape Specification. Bulk orientation LT. Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. IQS263B Datasheet V1.05 Page 48 of 53 January 2021 IQ Switch® ProxSense® Series 12.3.2 DFN10 (3x3) Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. IQS263B Datasheet V1.05 Page 49 of 53 January 2021 IQ Switch® ProxSense® Series 12.4 Package MSL Moisture Sensitivity Level (MSL) relates to the packaging and handling precautions for some semiconductors. The MSL is an electronic standard for the time period in which a moisture sensitive device can be exposed to ambient room conditions (approximately 30°C/85%RH see J-STD033C for more info) before reflow occur. Table 12.5 MSL Package Level (duration) MSL 1 (Unlimited at ≤30 °C/85% RH) MSOP-10 Reflow profile peak temperature < 260 °C for < 25 seconds Number of Reflow ≤ 3 MSL 1 (Unlimited at ≤30 °C/85% RH) DFN10 (3x3) Reflow profile peak temperature < 260 °C for < 25 seconds Number of Reflow ≤ 3 Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. IQS263B Datasheet V1.05 Page 50 of 53 January 2021 IQ Switch® ProxSense® Series 13 Device Marking 13.1 Top Marking REVISION x = IC Revision Number TEMPERATURE RANGE t = = i c IC CONFIGURATION z = Configuration (Hexadecimal) -20°C to 85°C (Industrial) 0°C to 70°C (Commercial) Marking not present for a configuration of 0. DATE CODE Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. P = Package House WW = Week YY = Year IQS263B Datasheet V1.05 Page 51 of 53 January 2021 IQ Switch® ProxSense® Series 14 Ordering Information Order quantities will be subject to multiples of a full reel. Contact the official distributor for sample quantities. A list of the distributors can be found under the “Distributors” section of www.azoteq.com. 14.1 MSOP-10 Package IC NAME IQS263B = IQS263B CONFIGURATION z = Sub Address Configuration (hexadecimal) 0 = 44H 1 = 45H 2 = 46H 3 = 47H PACKAGE TYPE MS = MSOP-10 BULK PACKAGING R = Reel MSOP - 4000pcs/reel IC NAME IQS263B = IQS263B CONFIGURATION z = Sub Address Configuration (hexadecimal) 0 = 44H 1 = 45H 2 = 46H 3 = 47H PACKAGE TYPE DN = DFN10 (3x3) BULK PACKAGING R = Reel DNF10 (3x3) – 3000pcs/reel 14.2 DFN Package Copyright © Azoteq (Pty) Ltd 2019 All rights reserved. IQS263B Datasheet V1.05 Page 52 of 53 January 2021 IQ Switch® ProxSense® Series Azoteq USA Asia South Africa Physical Address 11940 Jollyville Suite 120-S Austin TX 78750 USA Room 501A, Block A, T-Share International Centre, Taoyuan Road, Nanshan District, Shenzhen, Guangdong, PRC 1 Bergsig Avenue Paarl 7646 South Africa Postal Address 11940 Jollyville Suite 120-S Austin TX 78750 USA Room 501A, Block A, T-Share International Centre, Taoyuan Road, Nanshan District, Shenzhen, Guangdong, PRC PO Box 3534 Paarl 7620 South Africa Tel +1 512 538 1995 +86 755 8303 5294 ext 808 +27 21 863 0033 Email info@azoteq.com info@azoteq.com info@azoteq.com Visit www.azoteq.com for a list of distributors and worldwide representation. Patents as listed on www.azoteq.com/patents-trademarks/ may relate to the device or usage of the device. Azoteq®, Crystal Driver , IQ Switch®, ProxSense®, ProxFusion®, LightSense™, SwipeSwitch™, and the logo are trademarks of Azoteq. The information in this Datasheet is believed to be accurate at the time of publication. Azoteq uses reasonable effort to maintain the information up-to-date and accurate, but does not warrant the accuracy, completeness or reliability of the information contained herein. All content and information are provided on an “as is” basis only, without any representations or warranties, express or implied, of any kind, including representations about the suitability of these products or informat ion for any purpose. Azoteq disclaims all warranties and conditions with regard to these products and information, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property rights. Azoteq assumes no liability for any damages or injury arising from any use of the information or the product o r caused by, without limitation, failure of performance, error, omission, interruption, defect, delay in operation or transmiss ion, even if Azoteq has been advised of the possibility of such damages. The applications mentioned herein are used solely for the purpose of illustration and Azoteq makes no warranty or representation that such applications will be suitable without further modification, nor recommends the use of its products for application that may present a risk to human life due to malfunction o r otherwise. Azoteq products are not authorized for use as critical components in life support devices or systems. No licenses to patents are granted, implicitly, express or implied, by estoppel or otherwise, under any intellectual property rights. In the event that any of the abovementioned limitations or exclusions does not apply , it is agreed that Azoteq’s total liability for all losses, damages and causes of action (in contract, tort (including without limitation, negligence) or otherwise) will not exceed the amount already paid by the customer for the products. Azoteq reserves the right to alter its products, to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and information, its products, programs and services at any time or to move or discontinue any contents, products, programs or services without pr ior notification. For the most up-to-date information and binding Terms and Conditions please refer to www.azoteq.com. Copyright © Azoteq (Pty) Ltd 2019. All Rights Reserved. info@azoteq.com IQS5xx-B000 Datasheet Revision 2.1 Page 1 of 1 March 2021
IQS263B-0-DNR 价格&库存
很抱歉,暂时无法提供与“IQS263B-0-DNR”相匹配的价格&库存,您可以联系我们找货
