Technical Data Sheet
RFB00035/12.20/6.4
Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG
N 50 Ω
Adaptor
N Plug – 7-16 50 Ω Plug
53S160-SIMN1
All dimensions are in mm; tolerances according to ISO 2768 m-H
Interface
According to
N side:
7-16 side:
IEC 61169-16, MIL-PRF-39012, CECC 22210
IEC 61169-4, EN 122190, DIN 47223
Documents
N/A
Material and plating
Connector parts
Center contact
Outer contact
Coupling nut
Dielectric
Gasket
Material
Brass
Brass
Brass
PTFE
Silicone
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.com
Plating
Silver, 3-6 µm
Flash white bronze over silver(e.g. Optargen®)
White bronze(e.g. Optalloy®)
Tel. : +49 8684 18-0
Email : info@rosenberger.com
Page
1/2
N 50 Ω
Adaptor
53S160-SIMN1
Electrical data
RFB00035/12.20/6.4
Impedance
Frequency
Return loss
Insertion loss
Insulation resistance
Center contact resistance
Outer contact resistance
Working voltage
Power handling (at 20 °C, sea level, VSWR 1.0)
RF-leakage
Intermodulation (3rd order)
50
DC to 7.5 GHz
40 dB, DC to 2.5 GHz
36 dB, 2.5 to 4 GHz
25 dB, 4 to 7.5 GHz
0.05 dB
5 x103 M
1 m, N side;
0.4 m, 7-16 side
0.25 m, N side;
1.5 m, 7-16 side
500 V rms
1000 W @ 1 GHz
700 W @ 2 GHz
128 dB up to 1 GHz
-130 dBm @ 2 x 20 W
Mechanical data
Mating cycles
Coupling nut retention
Center contact captivation: axial
radial
Coupling test torque
Recommended torque
N side
min. 500
450 N
200 N
3 Ncm
max. 1.7 Nm
0.7 Nm to 1.1 Nm
7-16 side
min. 500
1000 N
200 N
3 Ncm
max. 35 Nm
25 to 30 Nm
Environmental data
Temperature range
Rapid change of temperature
Corrosion salt mist
Vibration
Shock
Climatic class
Cold
Dry heat
Damp heat (steady state)
Degree of protection (mated pair)
RoHS
-45°C to +85°C
IEC 60068-2-14 Test Na
IEC 60068-2-11 Test Ka
IEC 60068-2-6 Test Fc
IEC 60068-2-27 Test Ea
IEC 60068-1 (45/85/56)
IEC 60068-2-1 Test A
IEC 60068-2-2 Test B
IEC 60068-2-3 Test Ca
IEC 60529, IP68
compliant
Tooling
N/A
Suitable cables
N/A
Weight
Weight
87.7 g/pce
While the information has been carefully compiled to the best of our knowledge, nothing is
intended as representation or warranty on our part and no statement herein shall be
construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
For the installation of the
electrotechnical equipment,
particular electrotechnical
expertise is required.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
Benjamin Kaindl
15.03.12
Chr. Janßen
27.01.21
c00
20-1927
S. Huber-Siegl
27.01.21
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.com
Page
2/2
很抱歉,暂时无法提供与“53S160-SIMN1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+466.9569525+60.68225
