EASSM2310S
EASSM2310S
    CARLOGAVAZZI
    EASSM2310S
EASSM2310S 数据手册
Timers Delay on Operate Type EAS • • • • • • • Fail-safe two-wire connection Low-cost Multi-voltage: 24-230 VAC/DC Delay on operate Time range: 0.5 s - 10 m Knob-adjustable time setting Output: SCR 10-500 mA (screws) and SCR 10-700mA (Fast-ON) • For mounting on DIN-rail in accordance with DIN/EN 50 022 • 22.5 mm small Euronorm housing SCREW FAST-ON Product Description Ordering Key Small, low-cost mono function timer with adjustable time setting. Only 2-wire connection for easy and fail-safe use (see diagram). For mounting on DIN-rail or directly on surface by screws. The timer is used e.g. to delay small industrial relays or 3-phase contactors. Housing Function Small E-line Output Power supply Time range Fast-ON connection EAS S M23 10S F Type Selection Mounting Output Time range Connection Supply: 24 - 230 VAC/DC For DIN-rail or for screw SCR SCR SCR 0.5 - 10 s 0.1 -1 m 1 - 10 m Screws Screws Screws EAS S M23 10S EAS S M23 1M EAS S M23 10M For DIN-rail or for screw SCR SCR SCR 0.5 - 10 s 0.1 -1 m 1 - 10 m Fast-ON Fast-ON Fast-ON EAS S M23 10S F EAS S M23 1M F EAS S M23 10M F Time Specifications Time ranges 10 s 1m 10 m Time range accuracy Repeat accuracy Time variation Within rated power supply and ambient temperature Reset Time and output Output Specifications 0.5 - 10 s 0.1 - 1 m 1 - 10 m max. setting: actual time ≥ max. set time min. setting: actual time ≤ min. set time ≤ 0.2% ≤ 0.1%/V ≤ 0.2%/°C Output Output current Maximum load current (screw terminals) (Fast-ON connection) Maximum current for 100 ms (screw terminals) (Fast-ON connection) Minimum load current Leakage current Voltage drop SCR 500 mA 700 mA 5.5 A 7A 10 mA ≤ 3.5 mA @ 230 V typ.: 2 m ≤ 8 VAC/DC typ.: 5 VAC/DC @ 50 mA Power supply interruption ≥ 200 ms Supply Specifications Power supply Rated operational voltage Rated insulation voltage Specifications are subject to change without notice (29.07.14) Overvoltage cat. III (IEC 60664) (IEC 60038) 24-230 VAC/DC, -10/+15% None 1 EAS General Specifications ≤ 100 ms ≥ 200 ms Power ON delay Power OFF delay Environment Degree of protection Pollution degree Operating temperature Storage temperature Weight Housing Dimensions (screw connection) IP 20 3 -20° to +50°C (-4° to +122°F) -30° to +80°C (-22° to +176°F) 50 g Max. screws tightening torque Dimensions (Fast-ON connection) Material Approvals CE Marking EMC Immunity 22.5 x 56 x 49 mm 0.5 Nm 22.5 x 56 x 49 mm ABS UL, CSA Yes Electromagnetic compatibility Acc. to IEC 60801-4 Acc. to IEC 60801-5 Wiring Diagram L N Operation Diagram Power supply EAS Dimensions SCREW FAST-ON 4x f3.4 2 15 49 44 20 22.5 15 56 47.4 49 56 22.5 42 49 4x f3.4 Specifications are subject to change without notice (29.07.14)
EASSM2310S 价格&库存
很抱歉,暂时无法提供与“EASSM2310S”相匹配的价格&库存,您可以联系我们找货
EASSM2310S
  • 1+374.948171+42.70270
  • 5+349.845795+39.84380
  • 10+328.9106010+37.45950
EASSM2310S
    • 1+449.84577
    库存:2
    EASSM2310S
    • 1+922.262501+105.03612
    • 10+751.8466910+85.62753
    库存:5
