ABX00020
ABX00020
    ARDUINO
    ABX00020
ABX00020 数据手册
ARDUINO YÚN REV 2 Code: ABX00020 The Yún Rev 2, Linux powered board with the Arduino simplicity, is the perfect board for your IoT projects! The Yún rev. 2 with the power of a Linux based system that enables advanced network connections and applications. Connection to your WiFi or wired network is simple thanks to the Yún Web Panel and the dedicated ''YunFirstConfig'' sketch. The Web panel allows you to manage your shield preferences and upload your sketch. The Yún rev. 2 uses the Bridge library and so extends the board capabilities by using the Linux processor. As always, every element of the platform – hardware, software and documentation – is freely available and opensource. This means that you can learn exactly how it's made and use its design as the starting point for your own projects. AVR Arduino microcontroller Microcontroller Operating Voltage Input Voltage Digital I/O Pins PWM Output Analog I/O Pins DC Current per I/O Pin Flash Memory SRAM EEPROM Clock Speed ATmega32U4 5V 5V 20 7 12 40 mA on I/O Pins; 50 mA on 3,3 Pin 32 KB (of which 4 KB used by bootloader) 2.5 KB 1 KB 16 MHz Linux Microprocessor Processor Architecture Operating Voltage Ethernet WiFi USB Type Card Reader RAM Flash Memory Clock Speed Atheros AR9331 MIPS 3.3V 802.3 10/100Mbit/s 802.11b/g/n 2.4 GHz 2.0 Host Micro-SD 64 MB DDR2 16 MB 400 MHz Compatibility The Yún Rev. 2 board allows you to connect to the internet using the onboard WiFi or Ethernet connection. Furthermore thanks to the Bridge library it able to extend the functionalities of the Microprocessor by using the computational power of the Linux processor on the shield. Using the Yún Web Panel it is also possible to configure all the shield-related features and remotely upload sketches on the board connected to the shield. On-board Indicators The shield contains a number of signalling LEDs :  ON (green): indicates that the shield is properly powered  WLAN (blue): indicates a connection to a wireless network  WAN (red): indicates connection to ethernet  USB (white) : indicates system activity and/or if a USB key is mounted
ABX00020
物料型号:ARDUINO YÚN REV 2,代码:ABX00020。
器件简介: - Arduino Yún Rev 2是一款集成了Linux系统的开发板,非常适合物联网项目。 - 它通过Yún Web Panel和专用的"YunFirstConfig"草图简化了WiFi或有线网络的连接。 - 使用Bridge库,可以扩展开发板的功能,利用Linux处理器的能力。
引脚分配: - 微控制器:ATmega32U4。 - 数字I/O引脚:20个。 - PWM输出:7个。 - 模拟I/O引脚:12个。 - I/O引脚的直流电流:I/O引脚40 mA;3.3V引脚50 mA。
参数特性: - 工作电压:5V。 - 输入电压:5V。 - 闪存:32 KB(其中4 KB由引导程序使用)。 - SRAM:2.5 KB。 - EEPROM:1KB。 - 时钟速度:16 MHz。
Linux微处理器: - 处理器:Atheros AR9331。 - 架构:MIPS。 - 工作电压:3.3V。 - 以太网:802.3 10/100Mbit/s。 - WiFi:802.11b/g/n 2.4 GHz。 - USB类型:2.0主机。 - 卡读卡器:Micro-SD。 - RAM:64 MB DDR2。 - 闪存:16 MB 400 MHz。 - 时钟速度:未提供。
功能详解: - Yún Rev. 2板可以通过板载WiFi或以太网连接到互联网。 - 通过Bridge库,可以扩展微处理器的功能,使用Linux处理器的计算能力。 - 使用Yún Web Panel可以配置所有与盾牌相关的功能,并远程上传草图到连接到盾牌的板上。
应用信息: - 该开发板适合需要高级网络连接和应用程序的项目。
封装信息: - 板上包含多个信号指示灯,包括: - ON(绿色):表示盾牌正确供电。 - WLAN(蓝色):表示连接到无线网络。 - WAN(红色):表示连接到以太网。 - USB(白色):表示系统活动和/或如果插入了USB键。
ABX00020 价格&库存
很抱歉,暂时无法提供与“ABX00020”相匹配的价格&库存,您可以联系我们找货
