HANDHELD DIGITAL MANOMETER
PG-100N
■ FEATURES
Zero point adjustment button
● Excellent stability
H i g h p re c i s i o n s e m i c o n d u c to r c h i p c o m b i n e d w i t h
temperature
compensation circuit guarantee excellent stability.
● Long battery life
Lasts more than 1000hrs with two AAA dry batteries.
● Automatic power off function
● Easy, one-handed operation
● Easy-to-read large LCD display
● Pressure unit selectable type also available
Pressure port
3 1/2 digit LCD display
(PG-100N-****-W).
Power button
Hold button
Unit of display
OUTLINE DIMENSIONS
W55mm × H110 × D16.9mm
■ MODEL NUMBER DESIGNATION
P G - 1 0 0 N - 1 0 2 R - M X2 T
Traceability system chart
Series name
Blank: Not attached
T: Traceability system chart
Rated pressure range
101:− 10 ~ 10 kPa
102:− 100 ~ 100 kPa
103:− 100 ~ 1000 kPa
Inspection report / Calibration Certificate
Blank: Not attached
X1:Inspection report
X2:Inspection report and Calibration certificate
Pressure reference
R:Gauge(Compound)
Unit of display
Blank:kPa
M:MPa
H :mmHg ※
W:Selectable(bar, psi, inch Hg, mmHg, mmAg, kPa, MPa
according to the pressure range) ※
※:103R range products do not correspond to Unit mmHg of Pressure unit selectable W type.
(Refer to the Pressure unit selectable W type below.)
■ Pressure unit selectable W type
Pressure range
kPa
101R
102R
103R
※ " ー " is not supported as a display unit.
Mpa
ー
mmHg
Unit selectable W type
in.Hg
mmAg
ー
ー
ー
psi
bar
PG-100N
■ LIST OF MODEL NUMBERS 〈For non-corrosive gas〉
Pressure reference
-10 ~ 10
Gauge(Compound)
-100 ~ 100
-100 ~ 1000
Product only
PG-100N-101R
PG-100N-102R
PG-100N-103R
Inspection report
PG-100N-101R-X1
PG-100N-102R-X1
PG-100N-103R-X1
Inspection report and Traceability system chart
PG-100N-101R-X1T
PG-100N-102R-X1T
PG-100N-103R-X1T
PG-100N-101R-X2
PG-100N-102R-X2
PG-100N-103R-X2
PG-100N-101R-T
PG-100N-102R-T
PG-100N-103R-T
Inspection report,Calibration certificate and
PG-100N-101R-X2T
PG-100N-102R-X2T
PG-100N-103R-X2T
Rated pressure range (kPa)
kPa
Product only
PG-100N-103R-M
Inspection report
PG-100N-103R-M-X1
PG-100N-103R-M-X1T
PG-100N-103R-M-X2
PG-100N-103R-M-T
PG-100N-103R-M-X2T
MPa
Product only
PG-100N-102R-H
Inspection report
PG-100N-102R-H-X1
PG-100N-102R-H-X1T
PG-100N-102R-H-X2
PG-100N-102R-H-T
PG-100N-102R-H-X2T
mmHg
Product only
PG-100N-101R-W
PG-100N-102R-W
PG-100N-103R-W
Inspection report
PG-100N-101R-W-X1
PG-100N-102R-W-X1
PG-100N-103R-W-X1
PG-100N-101R-W-X1T
PG-100N-102R-W-X1T
PG-100N-103R-W-X1T
PG-100N-101R-W-X2
PG-100N-102R-W-X2
PG-100N-103R-W-X2
PG-100N-101R-W-T
PG-100N-102R-W-T
PG-100N-103R-W-T
PG-100N-101R-W-X2T
PG-100N-102R-W-X2T
PG-100N-103R-W-X2T
Selectable
PG-100N
■ STANDARD SPECIFICATIONS
〈kPa version〉
● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5°C.
Item
PG-100N
Gauge
Pressure reference
General specifications
Model number
101R
102R
103R
− 10 ~ 10
− 100 ~ 100
− 100 ~ 1000
kPa
Maximum pressure
kPa 20
200
1500
Break-down pressure
kPa 50
500
2000
Operating temp. range
°C
0 ~ 50
Compensated temp. range
°C
0 ~ 50
Operating humidity
Storage temp.
15 ~ 85(No condensation)
% RH
− 20 ~ 70(Atmospheric pressure, humidity 65 %RH maximum)
°C
Pressure medium
Non-corrosive gases
M5 female
Pressure port
Net weight
g
Approx. 100
Display
Power
No. of digits
3 1/2
Display element
LCD
Rated display range
− 10.00 ~ 10.00
Display cycle
− 100.0 ~ 100.0
− 100 ~ 1000
−. 100 ~ 1.000(MPa)
Approx. 4 times/s
± 0.5 %F.S. ± 2 digits (at 25 °C ± 5 °C)
Integrated accuracy
Resolution
Power supply (External supply)
Analog output
AAA dry battery DC 1.5 V × 2 Battery life 1000 h minimum
Output voltage
± 1.5 %F.S. ± 2 digits
(at 25 °C ± 25 °C)
± 1.0 %F.S. ± 2 digits (at 25 °C ± 25 °C)
1 digit
5 ± 0.5 V DC 5 mA maximum
0 ~ ± 1.000 V ※ Proportionate to display value
Output accuracy / Resolution
± 10 mV / 1mV
Output resistance
Approx. 10 kΩ
Response
Approx. 10 ms
Additional function
Accessories
Option (Sold seperately)
Auto power off, Display hold, Battery replacement display, (LOBAT), Zero point adjustment
2 fittings (half union for 6mm OD tube, barb fitting for 4mm OD tube), 2 AAA batteries, strap
PG-100N soft carrying case
PG-100N
〈Non SI unit version〉
PG-100N
Item
Pressure reference
Gauge
Model number(mmHg display : compound)
102R-H
Maximum pressure
Break-down pressure
kPa
(mmHg)
kPa
(mmHg)
kPa
(mmHg)
°C
0 ~ 50
°C
0 ~ 50
Operating humidity
Storage temp.
% RH
°C
Pressure medium
Net weight
Power
35 ~ 85(No condensation)
Non-corrosive gases
M5 female
Pressure port
Display
− 100 ~ 100
(− 750 ~ 750)
200
(1500)
500
(3750)
g
Approx. 100
No. of digits
3 1/2
Display element
LCD
Rated display range(mmHg display)
Display cycle
− 750 ~ 750
Approx. 4 times/s
Integrated accuracy
Resolution
Analog output
Output voltage
1 digit
Output accuracy / Pesolution
± 10 mV / 1 mV
Output resistance
Approx. 10 kΩ
Response
Approx. 10 ms
Additional function
Accessories
Auto power off , Display hold, Battery replacement display(LOBAT), Zero point adjustment
PG-100N
■ ENVIRONMENTAL CHARACTERISTICS
Test conditions(At 25 ± 5 °C)
Test item
Permissible change
Amplitude 1.5 mm P-P, 10 ~ 55 Hz,
3 directions for 2 hours each (packed)
Vibration
Shock
98.1 m/s2, 3 directions for 3 times each (packed)
Pressure cycling
0 ~ Rated pressure, 106 cycles
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 hrs.
■ OUTLINE DIMENSIONS
Indicating accuracy: ± 1 %F.S. maximum
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
1
Pressure Port M5 female
Pressure medium
Strap
Power button
Display
Nameplate
Zero adjust button
Hold button
Battery case
■ OPTION
The soft carrying case for PG-100N ‒ Order item: PG-100 soft carrying case
(Useful for when carrying out and keeping.)
很抱歉,暂时无法提供与“PG-100N-101R-W”相匹配的价格&库存,您可以联系我们找货
