PC5934T-BK
PC5934T-BK
    ANDERSON
    PC5934T-BK
PC5934T-BK 数据手册
SB® 50 Connectors Up to 120 amps Based off the design pioneered by Anderson™ in 1953, the two pole SB® connectors set the standard for DC power distribution and battery connections. SB® 50 connectors feature a one piece plastic housing using stainless steel springs to hold low resistance contacts in place. Wires sizes from 16 to 6 AWG (1.5 to 13.3 mm²) are held in the smallest of the SB® series housings. • Low Resistance Silver or Tin Plated Copper Contacts Allows UL rated currents up to 120 amps • UL Rated for Hot Plugging up to 50 Amps Great for battery or other applications where the ability to interrupt circuits is required • Wire, PCB, and Busbar Contacts SB® 50 Allows one connection system to meet multiple needs SB® 50 ORDERING INFORMATION SB® 50 Standard Housings The smallest SB® housings work with wire contacts up to 6 AWG (10 mm²) as well as PCB, and busbar contacts. Genderless design mates with itself. Mechanical keys are color-coded. Description Minimum Quantity Yellow Orange Red Gray Blue Green Black Part Numbers 500 100 992G5-BK 992G5 992G7-BK 992G7 992G1-BK 992G1 992-BK 992 992G4-BK 992G4 992G6-BK 992G6 992G2-BK 992G2 NOTE: SB® 50 Black and Gray housings have the same keying features and can be intermated. Bottom View [ 35.1 ] 1.38 [ 3.7 ] Ø 0.14 (2) PLC’S Material ID P = Chemical Resistant [ 22.5 ] 0.89 [ 19.1 ] 0.75 [ 6.4 ] 0.25 [ 81.3 ] 3.20 SB® 50 Chemical Resistant Housings Same features as the Standard SB® 50 but molded in a chemical resistant PBT/PC blend. Suitable for use to -40°C. Description Part Numbers Minimum Quantity 500 100 Red P992G1-BK P992G1 Gray P992-BK P992 Black P992G2-BK P992G2 [ 15.9 ] 0.63 Mated Length NOTE: SB® 50 Black and Gray housings have the same keying features and can be intermated. - 78 - www.andersonpower.com All Data Subject To Change Without Notice SB® 50 Silver Plated Wire Contacts Use two silver plated contacts per housing for the best electrical performance and durability up to 10,000 mating cycles. See reducing bushings in accessory section for smaller wires. Dimensions Mating Loose Piece -AAWG mm² Force Part Numbers inches mm 1,000 100 Minimum Quantity 6 13.3 Low 1307-BK 1307 0.22 5.59 13.3 High 5900-BK 5900 0.22 5.59 6 8 8.4 High 5952-BK 5952 0.19 4.83 12 to 10 3.3 to 5.3 Low 5953-BK 5953 0.14 3.56 5915-BK 5915 0.14 3.56 12 to 10 3.3 to 5.3 High [ 11.1 ] 0.44 [ 30.0 ] 1.18 A [ 7.2 ] 0.28 SB® 50 Silver Plated Busbar Contacts [ 7.1 ] 0.28 See Busbar contact drawing on website for further detail. Use 2 busbar contacts per housing to provide a quick disconnect input or output busbar connection. Busbar contacts are for mating with wire contacts only. Part number 75BBS includes lock nuts. Locknuts must be ordered separately for B01915P1. Mating Type Thread Force Loose Piece Part Numbers 1,000 20 Minimum Quantity Busbar 10 to 24 High B01915P1 75BBS Lock Nut 10 to 24 - H1216P8 110G54 [ 17.1 ] 0.68 SB® 50 [ 2.0 ] 0.08 [ 69.1 ] 2.72 NOTE: Has not been tested by UL. 55A Right Angle Standard Powerclaw PCB Contacts Standard Powerclaw contacts are for use inside a SB® 50 housing and provide a color-coded right angle connection to the PCB. Description Minimum Quantity Tin Plated Silver Plated Loose Piece Part Numbers 500 100 PC5930T-BK PC5930T PC5930S-BK PC5930S Top View [ 8.0 ] 0.32 [ 21.6 ] [ 19.05 ] 0.750 0.85 [ 22.6 ] 0.89 [ 23.7 ] 0.93 [x] x [ 15.6 ] 0.62 [ 35.0 ] 1.380 [ 27.4 ] 1.08 [ 11.4 ] 0.45 Side View [ 63.6 ] 2.51 [ 3.7 ] Ø 0.14 (2) See PCB contact drawing on website for further detail. 55A Right Angle Mini Powerclaw PCB Contacts Right angle Mini Powerclaw contacts can be used on the PCB edge without a SB® 50 housing on the PCB side. A self polarizing design only allow SB® 50 wire housings to mate to PCB contacts one way. Description Minimum Quantity Tin Plated Silver Plated Loose Piece Part Numbers 1,000 100 PC5934T-BK PC5934T PC5934S-BK PC5934S [ 8.1 ] 0.32 [ 7.6 ] 0.30 [ 12.19 ] 0.480 [ 24.6 ] 0.97 [ 2.42 ] 0.095 [ 6.10 ] 0.240 [ 25.4 ] 1.00 [ 17.5 ] 0.69 [ 1.27 ] 0.050 55A Vertical Mini Powerclaw PCB Contacts Vertical Mini Powerclaw contacts save space by not requiring a SB® 50 housing on the PCB side. The guide housing is required for to provide a polarized connection. (See SB® 50 accessories). Description Loose Piece Part Numbers Minimum Quantity 1,500 100 Tin Plated PC5933T-BK PC5933T Silver Plated PC5933S-BK PC5933S [ 12.2 ] 0.48 [ 24.3 ] 0.96 [ 9.7 ] 0.38 [2.32] 0.091 [ 10.29 ] 0.405 All Data Subject To Change Without Notice [ 6.25 ] 0.246 [ 1.27 ] 0.050 [ 4.98 ] 0.196 www.andersonpower.com - 79 - SB® 50 CONNECTOR TEMPERATURE CHARTS - Temperature rise charts are based on a 25°C ambient temperature. Current - Temperature Derating per IEC 60512-5-2 Test 5B SB® 50 Temperature Rise at Constant Current 50 Temperature Rise Above Ambient (°C) Temperature Rise Above Ambient (°C) 60 40 30 20 50 40 30 20 10 10 0 0 10 20 30 40 50 60 70 80 0 90 Amperes Applied 6 AWG 10 AWG SB®50 Derating vs. Ambient Temperature 100 75 50 25 0 10 20 30 40 50 60 70 80 90 100 Amperes Applied 6 AWG 10 AWG 8 AWG 12 AWG 0 10 20 30 40 50 60 70 80 90 Amperes Applied SB®50 8 AWG 12 AWG 125 Ambient Temperature (°C) SB® 50 Ambient Temperature (°C) 125 Mini Powerclaw Temperature Rise at Constant Current 60 Mini Powerclaw Derating vs. Ambient Temperature 100 75 50 25 0 10 20 30 40 50 60 70 80 90 100110 Amperes Applied SB® 50 NOTE: Powerclaw charts are based on 8 AWG equivalent copper foil on board side, mated to 6 AWG conductor on wire side. - 80 - www.andersonpower.com All Data Subject To Change Without Notice SB® 50 CONNECTOR SPECIFICATIONS MECHANICAL ELECTRICAL Current Rating Amperes ¹ Wire Size Range UL 1977 CSA Wire-to-Wire UL 1977 (6 AWG) 120 50 Wire-to-PCB UL 1977 (6 AWG) 50 Max. Wire Insulation Diameter 600 Operating Temperature ² Wire Contacts with Bushings PCB Connector Recommended Voltage per IEC 60950-1 Table 2L Pollution Degree 2 Mini Vert. Contact 522 Mini Horiz. Contact 504 Standard Contact 950 16 to 6 1.3 to 13.3 mm 0.440 11.200 °F °C Standard -4° to 221° -20° to 105° Chemical Resistant* -40 to 221° -40° to 105° 1,500 Lbf. N Wire to Wire Low Force Contacts 10 44 0.200 Wire to Wire High Force Contacts 15 67 0.500 Standard Powerclaw to Wire 15 66 Mini Powerclaw to Wire 8 36 Avg. Mated Contact Resistance Milliohms ¹ PCB Contact to Wire UL Hot Plug Current Rating Amperes - 250 Cycles at 120V DC Wire to Wire 50A PCB to Wire (Vertical Mini Powerclaw) 40A Mating Cycles No Load by Plating Wire and PCB Contacts Avg. Mating / Unmating Force PCB Specifications Mounting Style Plated Through Hole Max PCB Thickness- in. (mm) Standard: 0.15 (0.381) Mini: 0.25 (0.635) Recommended Traces 8 AWG Cross Section Min. Contact / Spring Retention Force MATERIALS Housing Standard Plastic Resin Polycarbonate Chem. Resistant Resin Polycarbonate / PBT blend Contact Retention Spring Stainless Steel Housing Flammability Rating UL94 V-0 Glow Wire 960°C (GWFI) / 800°C (GWIT) Contact Lbf. N 50 222 in. mm Standard Powerclaw 0.374 9.5 Mini Vert. Powerclaw 0.213 5.4 Mini Horz. Powerclaw 0.205 5.2 213 Condition A 50g’s 204 Condition A 10g’s Wire Housing Min. Creepage / Clearance Distance Mechanical Shock 4 MIL-STD-202 Base Copper Alloy Wire Plating Silver PCB Plating Sn or Ag over Ni SB® 50 Tin (Sn) 10,000 2,200 1 1/4” of 6 AWG wire *Chemical resistant material not available for PCB guide housings Silver (Ag) Dielectric Withstanding Voltage Volts AC mm² in. Voltage Rating AC/DC UL 1977 AWG Vibration High Frequency MIL-STD-202 4 Contact Termination Methods Crimp ³ Wire Contacts Hand Solder Wire and PCB Contacts Solder Dip PCB Contacts Wave Solder PCB Contacts Wrench / Socket Busbar Contacts NOTE 1: See IEC 60664-1 for working voltage. NOTE 2: Amp ratings are stated per position and based on all positions being fully loaded. 1 - Based on: 105°C rated or better cable of the largest size. Properly calibrated APP® recommended tooling, and a 25°C ambient temperature. UL rating not to exceed the maximum operating temperature. CSA rating below a 30°C temperature rise. 2 - Limited by the thermal properties of the connector plastic housing. 3 - Use APP® recommended tooling only. Alternate tools may adversely affect the performance of our connectors along with UL and CSA recognition. 4 - Tested with contact part number 5900. * UL Rated for 65°C largest wire or cable size. All Data Subject To Change Without Notice www.andersonpower.com - 81 - IEC INFORMATION ATTRIBUTES SB® 50 AMP Rating AC/DC 50 Voltage Rating AC/DC (Steady State) 250 Breaking Capacity AMP Rating / Cycles 50 / 10 Cycles Voltage Rating (Breaking Capacity) 220 VDC Finger Safety - Mated Only IEC 60529 - IP20 Wire Size Tested 16 mm² Contact Series Tested 5900/1307 Climatic Testing (Cold, Heat & MFG) IEC 60512 Test -11j, 11i & 11g Cycle Life IEC 60512 Test 9a - 5,000 Cycles Mechanical Strength Impact IEC 60512-5 @ 29.5 Inches - Dropped 8 times Temperature Range -20°C to 105°C Connector Series SB® 50 Creepage / Clearance Material Configurations per IEC Group 60950-1 Unmated 2.99 mm Mated 2.99 mm IIIa PROTECTION Touch Safety with Wire Contacts & PCB Mating Interface IEC 60529 IP10 unmated Environmental Sealing with Boots IEC 60529 IP64 -4°F to 221°F SB® Accessories SB® 50 “T” Handle * The “T” handle makes mating and unmating the connector easier. The non-conductive red plastic material is strong and safe. (2) Self tapping screws are used to secure the handle to the connector housing. Description Minimum Quantity Red “T” Handle + Hardware Bag Hardware Bag (2 Screws) Red “T” Handle Only #8 x 5/8” Screw (Order 2 Per Handle) (2) Self-tapping Screws Handle Part Numbers 1,000 50 - SB50-HDL-RED - 104G17 113899P1 H1120P55 - Connector Housing * Torque value 12 (in - lbs) / 1.4 (Nm) “A” frame handle for SB® 50 * Handle makes mating and unmating the connector easier. The non-conductive gray plastic material is strong and safe. Machine screws and locknuts included. Description Part Number Minimum Quantity Gray “A” Handle & Hardware 200 997G1 * Torque value 12 (in - lbs) / 1.4 (Nm) Screws Handle Locknuts Connector Housing not Included Dust Cover Prevents dust and dirt from entering the mating interface of the connector when unmated. NOTE: Not a Hermetic Seal. Description Minimum Quantity Dust Cover with Lanyard Strap, Red - 82 - Part Numbers 500 50 113890P1 134G1 www.andersonpower.com Slide cover over mating end. Housing not included. All Data Subject To Change Without Notice SB® Environmental Boots SB® Environmental Boots provide water, dirt, chemical and UV protection for SB® 50 connectors. The durable boots shield the connectors from water and dirt to IP64 in both the mated and unmated condition. Description Part Numbers Minimum Quantity SB® 50 Environmental Boot (with cover), Load SB® 50 Environmental Boot (with cover), Source SB® 50 Environmental Boot (no cover), Load SB® 50 Environmental Boot (no cover), Source 250 3-6054P2-BK 3-6055P2-BK 3-6054P1-BK 3-6055P1-BK 25 3-6054P2 3-6055P2 3-6054P1 3-6055P1 A Dimensions -A- -B- -C- in. mm in. mm in. mm 5.9 151.4 1.8 45.1 6.3 160 C B SB® 50 Connector Guide Housings for Vertical Mini Powerclaw Contacts Part Numbers Description Minimum Quantity 1,000 50 Black Guide Housing PC-HSG-SB-BK PC-HSG-SB SB® 50 Mini-vertical Powerclaw Contacts Prevents polarity being reversed when a SB® 50 is mated to vertical mini Powerclaw contacts. Guide Housing PCB Cable Clamps Durable metal cable clamps securely hold cables to prevent accidental strain or pulls from dislodging wire or contacts from the housing. Cable clamps are recommended for solder terminated wires. Cable Size AWG or mm² or Description (Inches O.D.) (mm O.D.) Part Numbers Minimum Quantity 500 50 Self Attaching for Discrete Conductor 8 to 6 10 990-BK 990 Self Attaching for Discrete Conductor 12 to 10 4 to 6 990G2-BK 990G2 Bolt on for Discrete Conductor 12 to 6 4 to 10 990G1-BK 990G1 Bolt on for Bundled Conductor 0.320 to 0.450 4.27 to 11.43 5905-BK 5905 * Torque value 12 (in - lbs) / 1.4 (Nm) NOTE: For assembly of cable clamp to housing only The given wire O.D. information is an estimate. Cable clamps should be evaluated for performance with the actual wire to be used. 990 990G1 Self attaching discrete conductor 5905 Bolt on discrete conductor Bolt on bundled conductors Reducing Bushings Use with contact part number 5900-BK or 1307-BK to allow a smaller wire to be used with the connector. Electrical capability is derated with smaller wire. Dimensions Contact Barrel Size Wire Size - ID - - Length AWG mm² AWG Minimum Quantity 6 13.3 8 12 to 0 6 13.3 6 13.3 16 to 14 mm² 8.4 3.3 to 5.3 1.3 to 2.1 All Data Subject To Change Without Notice Part Numbers 3,000 - 5910-BK 5913-BK 1,000 5912-BK - - 100 5912 5910 5913 inches mm inches mm 0.18 0.14 0.09 4.57 0.45 3.56 0.47 2.29 0.47 11.43 11.94 11.94 Length ID Wire Entrance www.andersonpower.com - 83 - SB® Tooling Information Wire Size AWG mm² Loose Piece Part Number Silver Plating Loose Piece Contact Crimp Tools Hand Tool OR Pneumatic Tool + Die + Locator Number of Crimps SB® 50 6 13.3 8 8.4 1307 5900 5952 1388G6 1309G4 1387G1 Single 5953 10 to 12 5.3 to 3.3 1 42.4 1323G1 2 33.6 1319 4 21.2 1319G4 6 13.3 1319G6 1389G6 1388G7 5915 1389G7 SB® 120 1388G3 1368 Series 1387G1 1388G4 1389G4 Single SB® TOOLING SB® 175 1/0 53.5 1382 1 42.4 1347 2 33.6 1383 4 21.1 1384 6 13.3 1348 1368 Series 1387G2 1303G13 1304G32 Double 1387G1 1388G4 1389G3 Single SB® 350 350 mcm 185 910 300 mcm 152 910 4/0 107.2 908 3/0 85 916 2/0 67.4 907 1/0 53.5 917 N/A 1303G3 1368 Series 1387G2 Double 1304G31 1303G12 NOTE: See website for the most current information. SB® 2/0 Tooling Information Wire Size Loose Piece Part Number Loose Piece Contact Crimp Tools AWG mm² Silver Plating Hand Tool 2/0 53.5 1328G1 1368 OR Pneumatic Tool 1387G2 + Die 1303G12 + Locator Number of Crimps 1304G32 Double NOTE: See website for the most current information. Your Best Connection™ 2020-0055 DS-SB50 REV C7 Anderson™ will use reasonable efforts to include accurate and up-to-date content in the data sheet. All product information contained in the data sheet including ordering information, illustrations, specifications, and dimensions, are believed to be reliable as of the date of publishing, but is subject to change without notice. Anderson™ makes no warranty or representation as to its accuracy. Content in the data sheet may contain technical inaccuracies, typographical errors and may be changed or updated without notice. Anderson™ may also make improvements and/or changes to the products and/or to the programs described in the content at any time without notice. Current sales drawings and specifications are available upon request. ©2020 Anderson Power Products, Inc. All rights reserved. APP®, A®, Anderson Power Products®, SB® and the APP Logo are registered trademarks of Anderson Power Products, Inc. Anderson™ and Your Best Connection™ are trademarks of Anderson Power Products, Inc. All Data Subject To Change Without Notice www.andersonpower.com - 101 -
PC5934T-BK 价格&库存
很抱歉,暂时无法提供与“PC5934T-BK”相匹配的价格&库存,您可以联系我们找货
PC5934T-BK
    • 1+67.936891+6.98640
    库存:31
