1.5 Watt BY-H Series
RoHS
High Isolated
Compliance
1500 V
AC1500V High Isolated Type DC-DC Converter
Input: 5V Output: 5V, ±12V
- Additional capacitors are the
same as those of
BY-SL, BY-WL series.
Input V
Output V
Output I
Vdc
Vdc
5
±12
mA
0-200
±0-65
4.75-6
% (typ.)
0.3
BY-SH
2.54
1
2.54
10
24
15
22.86
12
Φ0.6
Isolated
space
Units: mm
Weight: 17g typ.
13
5.08
5typ.
1.4
9.8
N.P
2.33
2.33
32.6
- Note!
Line Reg Load Reg Ripple/Noise Efficiency
% (typ.) mVpp(typ.) % (typ.)
0.3
100
60
Note 1: Derating required for input voltage 5.25V or higher.
15.24
(Derating required for 50°C or higher)
Models
BY-H Series
BY05-05S20H
BY05-12W06H
11.2
- Isolation Voltage AC1500V
- Long-Life with TCT Patent
Circuit
- 24pin-DIP IC Size
- Over-Heat Protection
- No Electrolytic Capacitor,
No Tantalum Capacitor
- Floating Type between Input
and Output
- 5-Side Metallic shield structure
- EMI Line Filter
- Over-Current Protection
- RoHS Compliance
- Operating Temp Range:
-20°C to +70°C
20.42
C
e
-I
l
u
d
d
C
C
I
I
Mo
Mo
M
M
p
p
i
i
C
C
M
C
h
M
ti
l
l
Mu
C
C
D
D
C
C
D
C
-D
C
D
D
型
型
a
te
d
a
te
d
l
l
縁
縁
s
o
s
o
I
I
絶
絶
e
s
e
s
i
i
l
l
p
p
p
p
C
C
Su
Su
D
D
e
r
e
r
C
C
w
w
D
D
Po
Po
圧
圧
e
e
高
高
ta
g
ta
g
l
l
中
中
Vo
Vo
h
h
g
g
H
i
H
i
C
C
D
D
A
C
D
C
A
C
D
C
C
C
A
A
ズ
ズ
N
o
i
s
e
N
o
i
s
e
イ
イ
L
o
w
L
o
w
ノ
ノ
低
低
U
l
t
r
a
U
l
t
r
a
A
C
D
C
A
C
D
C
C
C
D
D
O
u
t
p
u
t
O
u
t
p
u
t
C
C
A
A
力
力
M
u
l
t
i
p
l
e
M
u
l
t
i
p
l
e
出
出
多
多
S
e
m
i
C
u
s
t
o
m
S
e
m
i
C
u
s
t
o
m
e
r
e
r
器
器
fi
fi
流
流
R
e
c
ti
R
e
c
ti
整
整
D
C
-D
C
N
o
n
-I
s
o
l
a
te
d
D
C
-D
C
Mu
ti
C
h
u
l
e
-I
C
Bellnix High Isolated Type, Small Size DC-DC Converter
This catalogue is an outline of the product. When designing, be sure to refer to the datasheet.
Pin
1
10
12
13
15
24
Function
-Vin
-Vout
+Vin
-Vout
+Vout
+Vout
+Vin
BY-WH
Pin
1
10
12
13
15
24
Function
-Vin
-Vout
Common +Vin
Common
+Vout
+Vin
+Vin
C1
-Vin
+Vin
24
15
13
BY-SH Series
1
12
10
24
15
+Vout
C2
Load
-Vout
+Vout
Load
C2
C1
-Vin
BY-WH Series 13
12
1
10
Com
C3
-Vout
Load
很抱歉,暂时无法提供与“BY05-05S20H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+365.099971+45.91575
- 40+344.9295040+43.37907
- 120+341.59194120+42.95933
- 200+339.41527200+42.68558
- 400+333.75593400+41.97385
- 800+323.74325800+40.71464
