2GL51-73
2GL51-73
    CARLING
    插件
    钮子开关 双刀双掷 直插 125V 0℃~+85℃
2GL51-73 数据手册
Carling Technologies G-Series Toggle Switches ™ G-Series Toggle Switches General purpose workhorses with options tailored to meet most any need. Ratings to 20A 277VAC, international approvals, various actuator, bushing, termination, and circuit choices allow this toggle switch to easily integrate into a variety of different applications. The G-Series has a storied history in the Marine, Food Service, Generator, Industrial Control, and Office Automation markets and is appropriate for usage in low voltage DC applications as well. .687[17.44] Dielectric Strength UL/CSA: 1000V - live to dead metal parts & opposite polarity VDE: 4000V - live to dead metal parts; 1250V - opposite polarity & across open contacts Electrical Life 50,000 cycles- maintained 25,000 cycles- momentary Mechanical Life 100,000 cycles Operating Temperature 32°F to 185°F (0° to 85°C) .075[1.91] DIA .125[3.18] DIA .055[1.40] DIA 15/32-32UNS-2A THREAD .330[8.38] .187[4.74] .465[11.81] .437[11.09] .394[10.00] .250[6.35] .187[4.74] SOLDER LUG .778[19.76] .250 TAB (Q.C.) .187 TAB (Q.C.) TERMINAL TYPE .422[10.72] .778[19.76] 1.308[33.22] .750[19.05] KEYWAY .072[1.82] X .038[.965] DP #6-32NC-2 THREAD 6.000[152.40] .370[9.39] .500[12.70] .286[7.26] SCREW (ASSEMBLED) WIRE LEAD .062[1.57] .500[12.70] DIA .038[9.65] MOUNTING HOLE WITH KEYWAY 2GM51 - 73 1 Base Part Number 2 Actuator Style 1 BASE PART NUMBER: SERIES/POLES/CIRCUITRY/RATING/TERMINATION3 Single Pole in Double Pole base Double Pole 10A 250VAC, 15A 125VAC, 3/4 HP 125-250VAC solder lug .250 tab screw term. solder lug .250 tab screw term. 2GA50 2GA51 2GA54 ON-NONE-OFF 2GK50 2GK51 2GK54 6GA5A 6GA5B 6GA5E (ON)-NONE-OFF 6GK5A 6GK5B 6GK5E 6GA5L 6GA5M 6GA5S ON-NONE-(OFF) 6GK5L 6GK5M 6GK5S 2GB50 2GB51 2GB54 ON-NONE-ON 2GL50 2GL51 2GL54 6GB5A 6GB5B 6GB5E ON-NONE-(ON) 6GL5A 6GL5B 6GL5E 2GC50 2GC51 2GC54 ON-OFF-ON 2GM50 2GM51 2GM54 6GC5A 6GC5B 6GC5E ON-OFF-(ON) 6GM5A 6GM5B 6GM5E 6GC5L 6GC5M 6GC5S (ON-OFF-(ON) 6GM5L 6GM5M 6GM5S 10A 250VAC, 15A 125VAC, 12 (6)A 250VAC T85/55 ENEC/VDE Approved1 2GA90 2GA91 ON-NONE-OFF 2GK90 2GK91 2GB90 2GB91 ON-NONE-ON 2GL90 2GL91 2GC90 2GC91 ON-OFF-ON 2GM90 2GM91 Additional ratings up to 20A 125-277VAC, 1 1/2 HP 125VAC, 2HP 250 VAC and special circuits available. Consult factory for specifics. 2 ACTUATOR STYLE4 unsealed 73 BAT 5 PADDLE NBL3 2 D-3B-B BAT 2 PADDLE NOTES 1 2 3 4 5 () 26 sealed 78 NBL8 D-4B-B toggle length 0.687 0.687 0.687 0.687 PRINTED CIRCUIT .376[9.55] .500[12.70] DIA .750[19.05] IEC APPROVED CONSTRUCTION .187[4.75] .350[8.89] .490[22.86] .075[1.905] .187[4.75] .141[3.58] bushing length 0.465 0.465 0.379 0.379 Not available with 73 or NBL3 style toggles, T55 with 78 and NBL8 style toggles. All nylon bushing and toggle. Consult factory for .187 tab, wire lead and combination screw/tab/solder lug termination callouts. Additional actuator options available. Consult factory. Nylon toggle with black ebanol plated bushing. Indicates momentary function. www.carlingtech.com .500[12.70] DIA .125[3.17] DIA WITH LOCKING RING
2GL51-73 价格&库存
很抱歉,暂时无法提供与“2GL51-73”相匹配的价格&库存,您可以联系我们找货
