MBRB20200CT
MBRB20200CT
    SMCDIODESOLUTIONS(桑德斯)
    D2PAK
MBRB20200CT 数据手册
MBR20200CT MBRB20200CT MBR20200CT-1 Technical Data Data Sheet N0763, Rev. A MBR20200CT/MBRB20200CT/MBR20200CT-1 SCHOTTKY RECTIFIER Features              Applications 175 C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request     Switching power supply Converters Free-Wheeling diodes Reverse battery protection MBR20200CT MBRB20200CT MBR20200CT-1 TO-220AB D2PAK TO-262 Maximum Ratings: Characteristics Symbol Condition Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR - Average Rectified Forward Current IF (AV) Peak Repetitive Surge current (Rated VR , Square Wave,20KHz) Peak One Cycle Non-Repetitive Surge Current(Per Leg) IRRM IFSM 50% duty cycle @Tc=125°C, rectangular wave form Max. Units 200 V 10(Per Leg) 20(Per Device) A 0.5 A 180 A 8.3ms, Half Sine pulse  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR20200CT MBRB20200CT MBR20200CT-1 Technical Data Data Sheet N0763, Rev. A Electrical Characteristics: Characteristics Symbol Forward Voltage Drop (Per Leg)* VF1 Reverse Current (Per Leg)* Junction Capacitance(Per Leg) Condition Typ. Max. Units @ 10A, Pulse, TJ = 25 C @ 10A, Pulse, TJ = 125 C 0.85 0.90 V VF2 0.73 0.80 V IR1 @VR = rated VR, TJ = 25 C 0.002 1.00 mA IR2 @VR = rated VR, TJ = 125 C 0.9 50 mA CT @VR = 5V, TC = 25 C, fSIG = 1MHz 174 500 pF * Pulse width < 300 µs, duty cycle < 2% Thermal-Mechanical Specifications: Characteristics Junction Temperature Storage Temperature Typical Thermal Resistance Junction to Case Case Style Symbol Condition Specification Units TJ Tstg - -55 to +175 -55 to +175 C C 1.5 C/W RJC DC operation TO-220AB D PAK TO-262 2 Tube Specification Tube Specification(TO-220AB/TO-262) Device Package Weight Shipping MBR20200CT TO-220AB 1.8g 50pcs / tube MBRB20200CT D²PAK 1.85g 800pcs / reel MBR20200CT-1 TO-262 1.85g 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. Ratings and Characteristics Curves Forward current derating curve  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR20200CT MBRB20200CT MBR20200CT-1 Technical Data Data Sheet N0763, Rev. A Marking Diagram Where XXXXX is YYWWL MBR B 20 200 CT -1 SSG YY WW L = Device Type = Package type = Forward Current (20A) = Reverse Voltage (200V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR20200CT MBRB20200CT MBR20200CT-1 Technical Data Data Sheet N0763, Rev. A Carrier Tape Specification D2PAK Millimeters Min. Max. Symbol A 10.70 10.90 B 16.03 16.23 C 5.11 5.31 d 1.45 1.65 E 1.65 1.85 F 11.40 11.60 P0 3.90 4.10 P 15.90 16.10 P1 1.90 2.10 W 23.90 24.30 Mechanical Dimensions TO-220AB Symbol A A1 A2 b b1 c D D1 E e e1 H1 L L1 ΦP Q Θ1 Θ2 Θ3 Millimeters Min. 4.42 1.17 2.52 0.71 1.17 0.31 14.94 8.85 10.01 4.98 6.04 12.7 3.56 3.74 2.54  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Typical 4.57 1.27 2.69 0.81 1.27 0.38 15.24 9.00 10.16 2.54 5.06 6.24 13.56 3.5 3.84 2.74 7° 3° 4° Max. 4.72 1.37 2.89 0.96 1.37 0.61 15.54 9.15 10.31 5.18 6.44 13.80 3.96 4.04 2.94 MBR20200CT MBRB20200CT MBR20200CT-1 Technical Data Data Sheet N0763, Rev. A Mechanical Dimensions D2PAK Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 Millimeters Min. 4.47 0 2.59 0.71 1.17 0.31 1.17 8.50 6.40 10.01 7.6 9.98 Typical Max. 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.31 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 14.6 2.00 1.12 1.30 0.25BSC 5° 4° 0 e3 4.85 0.25 2.89 0.96 1.37 0.61 1.37 8.90 15.6 2.74 1.42 2.20 8° 4° Mechanical Dimensions TO-262 Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Millimeters Min. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Typical 4.70 0.10 2.69 0.81 1.27 0.38 1.27 Max. 4.85 0.25 2.89 0.96 0.61 1.37 8.70 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 15.6 2.70 1.40 2.20 8° Technical Data Data Sheet N0763, Rev. A MBR20200CT MBRB20200CT MBR20200CT-1 DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
MBRB20200CT 价格&库存
很抱歉,暂时无法提供与“MBRB20200CT”相匹配的价格&库存,您可以联系我们找货
