195202-234
195202-234
    JOHNSON
195202-234 数据手册
STA® Pull DC Tubular Solenoid Model 51 Size: – ½” OD X 1” L ALL PRODUCTS ARE RoHS COMPLIANT Solenoid shown energized with plunger fully seated Supplied with hex nut shipped loose Spring kits available (consult factory) Part No. 195202-231 195202-234 195202-234 195202-237 Duty Cycle Intermittent Continuous Intermittent Continuous Voltage 12 VDC 12 VDC 24 VDC 24 VDC Resistance (Ω) ± 5% 9.56 37.41 37.41 141.93 Max On Time 5 Secs ∞ 5 Secs ∞ Power (W) 15.1 3.9 15.4 4.1 Current (A) 1.26 0.32 0.64 0.17 Continuous Duty = 100% “On” Time Intermittent Duty = 25% “On” Time When ordering please refer to Part No. as listed above Please consult factory for custom configurations and other pole face angles Stroke (in.) Continuous Duty Intermittent Duty 0.050 6.4 14.0 Typical Pull Force (oz.) 0.100 0.150 0.200 0.250 3.4 1.9 1.0 0.6 9.4 6.6 4.9 3.7 Additional Specifications: Dielectric Strength: Recommended Heat Sink: Total Unit Weight: Plunger Weight: Ledex® Holding Force (oz.) 0.300 N/A 2.8 0.350 N/A 2.3 0.400 N/A 1.6 14.4 N/A 500 VRMS Maximum watts dissipated by solenoid are based on an unrestricted flow of air at 20°C, with solenoid mounted to the equivalent of an aluminum plate measuring 2” square by 1/8” thick. 0.87 oz. / 24.7 g 0.16 oz. / 4.5 g sales@johnsonelectric.com
195202-234 价格&库存
很抱歉,暂时无法提供与“195202-234”相匹配的价格&库存,您可以联系我们找货
  • 1+473.109451+56.74465
  • 10+421.3969810+50.54227
  • 25+402.3804525+48.26143
  • 50+388.5554450+46.60326
  • 100+375.19408100+45.00070
  • 250+358.22533250+42.96547
库存:2537
