1307-BK
1307-BK
    ANDERSON
    1307-BK
1307-BK 数据手册
SPEC Pak ® Sealed Power For Environmental Connections Marine | Machine Tool Wind Power | | Lighting Industrial Automation | | Transportation Motor | | Pumps Solar Power | | Ground Support Harsh Environments Rugged and Sealed (IP68) Plugs and Receptacles The SPEC Pak® Mid Power is rugged and environmentally sealed (IP68). It leverages APP’s core Powerpole® flat wiping contact technology, offering power handling capabilities up to 80 amps at 600 volts with signal. The SPEC Pak® Mid Power shells are highly configurable. They accept up to four Powerpole® 75 (PP75) contacts and housings. They also accept up to 8 pin and socket auxiliary contacts providing the user signal and/or sequencing options. Assembly is made easy though the use of colored Powerpole® housings which can be matched to wire colors. They will accept wire sizes ranging from 12 to 6 AWG [3.3 to 13.3 mm²]. SPEC Pak® Mid Power is highly configurable providing users with a multitude of flexible design solutions in a single interconnect. 1 2 3 8 7 Top of the latch is not visible from this view. 1 - Chemical & UV Resistant Ruggedized Shells • Wire to Wire Configurations • Wire to Panel Configurations 2 - Auxiliary Contacts for Signal and/or Sequencing (up to 8) 3 - Power Contacts (up to 4) 4 - Sealing Gland to Ensures (IP68) Environmental Seal - 2 - | www.andersonpower.com Auxiliary contacts are not visible in the cut-a-way view. 4 5 6 5 - Color Coded Powerpole® Housings to Match Wire Colors 6 - Stainless Steel Latches to Prevent Accidental Unmating 7 - IP68 Panel Mount Receptacle Gasket 8 - Sealing O-Ring Ensures (IP68) Environmental Seal .............................................. SPEC Pak® Shells Used With ............................................ SPEC Pak® Shell Powerpole® Power Contacts & Housings Auxiliary Contacts [1] (PowerMod® Series) Electrical Current Rating (Amperes) UL 1977 - 80 [2] 5 CSA (30° C Rise) - 50 [2] 5 Voltage Rating UL 1977 (AC/DC) - 600 600 Dielectric Withstanding (AC) - 3,000 - Contact Resistance Milliohms (average) - 0.200 [3] 2.000 [4] Hot Plug Amp Rating (UL 1977) 250 Cycles at 120V - 50 [5] Mechanical Environmental Seal IP rating IP68 - Submersion (UL 50E) Pass - Wire Size - 12 to 6 AWG 24 to 12 AWG - 3.3 to 13.3 mm² 0.50 to 2.5 mm² Operating Temperature -40° to 105° C -20° to 105° C -40° to 105° C -40° to 221° F -4° to 221° F -40° to 221° F Mating Cycles (no load) Silver Plated Contacts - 1,500 Gold Plated Contacts - - 1,500 Contact Retention Force - > 50 lbf / 222 N - Insertion Force - 28 lbf Touch Safe (IEC 60529) - IP10 Drop Test (UL50E) Pass - Panel Break Off (EIA 394-97) Pass - Crush Test (EIA 364-40B) Pass - Materials Shell / Housing PC/PBT PC PC/PBT Powerpole® Holder PC/PBT - Latch Stainless Steel - Flammability (UL 94) V0 V0 V0 Weatherability (UL 764C) F1 F1 F1 Contacts Base - Copper Alloy Copper Alloy Plating - Silver Gold over Nickel NOTES: 1. Integral signal holders that holds up to 8 pins and 8 sockets. 2. Based on 6 AWG. 3. Based on 6 AWG 1-1/4” distance between probes. 4. Based on 20 AWG. 5. Hot Plug testing completed using individual Powerpole® housings and contacts, not installed in SPEC Pak® shells. For other industry tests and/or agency approvals, contact customer service. www.andersonpower.com | -3- Product Selection Guide SPEC Pak® is a highly configurable environmentally sealed connector, that can be purchased as components in bulk for volume production, or pre-packaged as a kit. For convenience, follow the steps below to determine component or kit part numbers. | COMPONENT PART NUMBER GUIDE (FOR COMPONENT BULK PURCHASE) | Step 1: Select Shell Step 2: Select Wire Protection SK6-076C04 Plug SK1-076C04 Inline Receptacle * Select Shell Style, from page 6. SK2-076C04 Panel Mount Receptacle * Define: Number of Wires Wire OD Wires - Discrete ____________ _____________ - Bundled ____________ _____________ * Select wire protection that will accommodate the number of wires and outer diameter (OD) of the wire used in your application, from page 6. * Wire protection is required for use with inline receptacles and plugs to obtain IP68 seal. List Component Part Numbers Here: | KIT PART NUMBER GUIDE (FOR KITTED CONNECTOR PURCHASE) | Step 1 - (see page 6) ............................................................................................. Shell ........................................................................................ Shell Color Shell Style Shell Size Insert Arrangement SPEC Pak® Series (Select One) Dash S K 1 = Inline Receptacle - 2 = Panel Mount Receptacle 6 = Straight Plug 9 = Receptacle Cover 9P = Plug Cover 076 C04 List Kit Part Number Here: Receptacle Kit Part Number: S K ___________________________ - K ___________________________ - 076 C04 Plug Kit Part Number: S - 4 - | www.andersonpower.com 076 C04 Step 3: Select Housing Arrangement Step 4: Select Contacts Pin Auxiliary Contact Socket Auxiliary Contact Power Contact * Define: Number of Number of Wires Auxiliaries Housing Arrangement - AC Single Phase ___________ ____________ - AC 3 Phase ___________ ____________ - DC ___________ ____________ - Other ___________ ____________ * Define: Number of Circuits Wire Gauge Contacts - Power _____________ __________ - Auxiliary _____________ __________ - Other _____________ __________ Amps (continuous): ____ Max amps at ____ volts * Select housing arrangement colors appropriate for your AC or DC application, from page 7. * Select power and/or auxiliary contacts appropriate for your wire size (AWG or mm²), from page 7. List Component Part Numbers Here: Step 2 - (see page 6) Step 3 - (see page 7) Step 4 - (see page 7) Custom .................... Wire Protection .................... .. Housing Arrangement .. ........... Contacts ........... .... APP Content .... Number of Holes Cable Sealing Range (Select Two) Dash (Select One) (Select One) Dash 00 = None PS = Plastic Single-hole PM = Plastic Multi-hole 00 = None 01 - 99 = Various Gland Types 0 = Custom Configuration A = AC Single Phase B = AC 3 Phase, 3 Wire C = DC Circuit, 4 Wire Z = All Black (See Page 6) Contact the factory Custom Configuration 0 = Custom Configuration 70 = 1307 Contact for #6 AWG (13.3 mm²) 71 = Please inquire for #8 AWG (8.4 mm²) 72 = 5953 Contact for #10/12 AWG (3.3 to 5.3 mm²) NOTE: Panel Mount Receptacle is always “00 00”. - __________ __________ - __________ __________ __________ __________ - __________ __________ www.andersonpower.com | -5- Ordering Information PLUG SHELL KIT COVER KIT INLINE RECEPTACLE KIT PANEL MOUNT RECEPTACLE KIT Part Number & Description Part Number & Description Part Number & Description Part Number & Description SK6-076C04 - Plug shell - Powerpole® holder - plug - Powerpole® holder retaining screws M3.5 x 15mm SK2-076C04 - Panel mount receptacle shell - Powerpole® holder - receptacle - Panel mount receptacle gasket - Powerpole® holder retaining screws M3.5 x 15mm SK1-076C04 - Inline receptacle shell - Powerpole® holder - receptacle - Powerpole® holder retaining screws M3.5 x 15mm - Sealing Gland Nut SK9-076 Receptacle Cover Kit - Cover (IP68) with lanyard - Sealing Gland Nut (Sealing grommet sold separately) (Sealing grommet sold separately) Holder Retaining Screws Plug Shell Housing with Latches Holder Retaining Screws Plug Powerpole® Holder Receptacle Powerpole® Holder Panel Gasket Holder Retaining Screws Sealing Nut Inline Receptacle Shell Receptacle Powerpole® Holder SK9P-076 Plug Cover Kit - Cover (IP68) with lanyard Receptacle Cover Plug Cover with Interfacial seal Sealing Nut Panel Receptacle Shell Component Replacement Parts Part Number Description 115129P1 Panel Mount Receptacle Gasket H1120P53 Powerpole holder retaining screws M3.5 x 15mm NOTE: Mounting Hardware (4 each M4 or #8 screws) not included. Recommended torque for mounting hardware is 7-10 in-lbs. | WIRE PROTECTION - CABLE GLAND | Material Mechanical Shell PBT/PC Sealing Grommet EPDM Flammability (UL 94) V0 Weatherability (UL 764C) F1 Color Black IP Rating IP68 Operating Temperature (UL 1977) -40° to 105° C -40° to 221° F Thread Type Integrated into inline receptacle & plug shells Torque Requirements Hand tighten. Using a 44 mm wrench or strap wrench, tighten an additional 3/4 - 1 turn. Wire Protection Straight Plastic Single & Multi Hole Cable Gland Sealing Glands Number Cable Range Wire Wrench Size Protection Sealing Grommet Only (includes sealing grommet & wire protection nut) of Holes Outer Diameter mm (in) Sealing Nut Designation -------------------------------- Part Numbers -----------------------------------------------------For use with 10 ................................................................ Minimum Quantity ................................................................................................................ 10 SK1-076C04 & 1 18.0 - 24.0 mm (0.79” - 0.85”) 44 PS 01 B02130P7 PS1T40-24X For use with shell kit components SK6-076C04 2 3.8 - 5.0mm (0.15” - 0.20”) 44 PM 21 B02130P12 PS2T40-5X purchased in bulk. 2 6.0 - 7.2mm (0.24” - 0.28”) 44 PM 22 B02130P11 PS2T40-7X 2 7.0 - 9.0mm (0.28” - 0.35”) 44 PM 23 B02130P10 PS2T40-9X ....................................................................................................................................................................... ................... 3 6.0 - 7.2mm (0.24” - 0.28”) 44 PM 32 B02130P5 PS3T40-7X 3 7.0 - 9.0mm (0.28” - 0.35”) 44 PM 33 B02130P4 PS3T40-9X ....................................................................................................................................................................... ................... 4 3.8 - 5.0mm (0.15” - 0.20”) 44 PM 41 B02130P3 PS4T40-5X 4 6.0 - 7.2mm (0.24” - 0.28”) 44 PM 42 B02130P2 PS4T40-7X 4 7.0 - 9.0mm (0.28” - 0.35”) 44 PM 43 B02130P1 PS4T40-9X ................................................................................................................................................................................................................................................................................... - 6 - | www.andersonpower.com C04 Housing Arrangement Configured with up to 4 PP75 Contacts - Up to 80 Amps | TEMPERATURE CHART | | Standard Housing Arrangements | E = Empty Custom Configuration 60 AC Single Phase A 5916G4 5916G5 5916G6 E 50 Temperature (°C) 0 Mid Power SPEC Pak® Four Power Contacts / Eight Signal Contacts 5A AC 3 Phase, 3 Wire B 5916G4 5916G5 5916G7 E DC 2 Circuit, 4 Wire C 5916G4 5916G4 5916G7 5916G7 40 30 20 10 0 All Black Z 5916G4 5916G4 5916G4 5916G4 0 10 20 30 40 50 60 70 80 Amperes Applied 6 AWG 10 AWG 8 AWG 12 AWG Ordering Information PP75 Standard Power Contacts, Signal Contacts & Housings Spacer & Keying Accessory Description Description -------- Part Number -------- -------- Part Number -------- Minimum Quantity ..... Red, Short Red, Long Minimum Quantity .. 1000 100 ..... Red 5916G7-BK 5916G7 Green 5916G6-BK 5916G6 Black 5916G4-BK 5916G4 White 5916G5-BK 5916G5 Blue 5916-BK 5916 Yellow 5916G15-BK 5916G15 Orange 5916G14-BK 5916G14 Gray 5916G16-BK 5916G16 Short 1000 100 .... 1399G23-BK 1399G23 1399G21-BK 1399G21 Long PP75 Silver Plated Wire Contacts Pneumatic Mating Contact Code Hand Type AWG mm² Force -- Part Numbers -- Designation Tool Tool Die Locator Minimum Quantity ............................... 1000 100 Individual 6 13.3 Low 1307-BK 1307 Individual 8 8.4 Low Please inquire Individual 12 to 10 3.3 to 5.3 Low 5953-BK 5953 ........................ For use with 6 AWG 70 ................. 1309G4 1387G1 1388G6 1389G6 71 ................................................................................... 72 ................. For use with 12/10 AWG 1309G4 1387G1 1388G7 1389G6 Auxiliary Contacts (PowerMod® series) Type AWG mm² Minimum Quantity….................. ---- Part Number --- 500 50 ..... Standard Length 7.7mm Pin 24 to 20 0.50 to 0.75 PM16P2024S30 PM16P2024S30-50 Pin 20 to 18 0.75 to 1.00 PM16P1620S30 PM16P1620S30-50 Pin 16 to 14 1.00 to 1.5 PM16P1416S30 PM16P1416S30-50 Pin 12 2.50 PM16P12S30 PM16P12S30-50 Pre-Mate 9.3mm Pin 24 to 20 0.50 to 0.75 PM16P2024A30 PM16P2024A30-50 Pin 20 to 18 0.75 to 1.00 PM16P1620A30 PM16P1620A30-50 Pin 16 to 14 1.00 to 1.5 PM16P1416A30 PM16P1416A30-50 Pin 12 2.50 PM16P12A30 PM16P12A30-50 Post-Mate 6.4mm Pin 24 to 20 0.50 to 0.75 PM16P2024C30 PM16P2024C30-50 Pin 20 to 18 0.75 to 1.00 PM16P1620C30 PM16P1620C30-50 Pin 16 to 14 1.00 to 1.5 PM16P1416C30 PM16P1416C30-50 Pin 12 2.50 PM16P12C30 PM16P12C30-50 -----------------------------------------------------------------------------------------------------------Socket 24 to 20 0.25 to 0.50 PM16S2024S32 PM16S2024S32-50 Socket 20 to 16 0.50 to 1.30 PM16S1620S32 PM16S1620S32-50 Socket 16 to 14 1.30 to 2.10 PM16S1416S32 PM16S1416S32-50 Socket 12 2.5 PM16S12S32 PM16S12S32-50 Hand Tool For use with pins PM1000G1 Hand Tool Locator TM0001 Pnuematic Tool Locator TL0001 TP0001 TL0001 TL0002 TP0002 TL0002 For use with sockets PM1000G1 TM0001 www.andersonpower.com | -7- | PLUG MID POWER FOR PP75 HOUSINGS | Top View Front View [ 3.73 ] 94.7 Side View [ 2.97 ] 75.5 [ 3.09 ] 99.0 Mated View [ 4.4 ] 111.0 Mated Length to Panel Receptacle [ 2.47 ] 62.8 | PANEL MOUNT RECEPTACLE MID-POWER FOR PP75 | Panel Cut Out Front View Side View [ 3.19 ] 81.0 [ 2.36 ] 60.0 Mated View [ 4.4 ] 111.0 Mated Length to Panel Receptacle [ 1.31 ] 33.2 [ 3.19 ] 81.0 [ 2.36 ] 60.0 [ 0.98 ] 25.0 | INLINE RECEPTACLE MID-POWER FOR PP75 | Top View Front View Side View Mated View [ 2.83 ] [ 3.76 ] 71.8 95.5 [ 2.70 ] 68.6 [ 6.9 ] 175.0 Mated Length to Plug [ 3.9 ] 100.0 | PLUG COVER KIT | | RECEPTACLE COVER KIT | Front View Side View Front View Side View [ 3.03 ] 77.0 [ 2.79 ] 70.8 [ 2.52 ] 63.9 [ 1.10 ] 28.0 [ 2.47 ] 62.8 [ 1.40 ] 35.5 © 2017 Anderson Power Products, Inc. All rights reserved. APP®, Anderson Power Products®, A®, SPEC Pak®, Powerpole® and the APP Logo are registered trademarks of Anderson Power Products, Inc. • All Data Subject To Change Without Notice 2017-0005 DS-MPSPAK REV 3 HEADQUARTERS: Anderson Power Products®, 13 Pratts Junction Road, Sterling, MA 01564-2305 USA T:978-422-3600 F:978-422-0128 • EUROPE: Anderson Power Products® Ltd., Unit 3, Europa Court, Europa Boulevard, Westbrook, Warrington, Cheshire, WA5 7TN United Kingdom T: +44 (0) 1925 428390 F: +44 (0) 1925 520203 • ASIA / PACIFIC: IDEAL Anderson Asia Pacific Ltd., Unit 922-928 Topsail Plaza, 11 On Sum Street, Shatin N.T., Hong Kong T:+(852) 2636 0836 F:+(852) 2635 9036 • CHINA: IDEAL Anderson Technologies (Shenzhen) Ltd., Block A8 Tantou Western Industrial Park, Songgang Baoan District, Shenzhen, PR. China 518105 T: +(86) 755 2768 2118 F: +(86) 755 2768 2218 • TAIWAN: IDEAL Anderson Asia Pacific Ltd., Taiwan Branch, 4F.-2, No.116, Dadun 20th St., Situn District, Taichung City 407, Taiwan (R.O.C.) T: +(886) 4 2310 6451 F:+(886) 4 2310 6460 • www.andersonpower.com
1307-BK 价格&库存
很抱歉,暂时无法提供与“1307-BK”相匹配的价格&库存,您可以联系我们找货
1307-BK
    • 1+22.347811+2.87688
    • 100+13.23186100+1.70337
    库存:165
    1307-BK
      • 1+25.32596
      • 100+14.86004
