MARC
Multi Axial Rotational Connector
The Multi Axial Rotational Connector “MARC” features 8
Powerpole® contacts integrated into a blindmate housing.
The connector is designed to blindmate from 2 rotating axis
or straight on. The two row, horizontally oriented connector
uses our industry leading flat wiping contacts. The MARC
is rated to 29 amps per circuit and can be configured with
8 standard length contacts or 6 standard length and 2 pre
mate, multi-purpose contacts, which can function as ground,
power or signal. The rugged connector is UL listed and rated
up to 10,000 mating cycles. The dielectric is a chemically
resistant PBT plastic. APP connectors are manufactured
using the finest materials and world-class manufacturing
processes. They embody the highest quality in the industry
and meet all applicable industry standards.
• Rotational Blindmate Error Correction
• Rugged and Durable
• Sequential Mating
• Interchangeable Genderless Design
Enables blindmating from 2 independently rotating axes
with .100” of error correction
Can be configured with up to 8 power and signal or 6
power and signal circuits and 2 pre mate contacts
- The connector is rated up to 10,000 mating cycles
- Constructed of chemically resistant PBT plastic
Makes assembly quick and easy and reduces number
of parts stocked
| ORDERING INFORMATION |
45A Premate Ground Wire Contacts
Housings
Description
Minimum Quantity ......................
Housing with springs
Housing with float mount kit
Housing with fixed mount kit
- Part Numbers 25 ......
602G00
602G01
602G02
PP15-45 Tin Plated Power Contacts
Offer cost effective performance up to 1,500 mating cycles. See specifications and
temperature charts for amperage ratings by wire size.
Mating Loose Piece
Reeled
Barrel AWG
mm²
Force -------- Part Numbers -------
Minimum Quantity ......................................
200
5,000
Open 14 to 10 K*
2.1 to 5.3 High 269G3-LPBK 269G3
Open 14 to 10 K*
2.1 to 5.3 Low 261G2-LPBK 261G2
Open 14 to 10 SF* 2.1 to 6.0 High 201G1H-LPBK 201G1H
Open 14 to 10 SF* 2.1 to 6.0 Low 200G1L-LPBK 200G1L
Open 16 to 12
1.3 to 3.3 High 269G1-LPBK 269G1
Open 16 to 12
1.3 to 3.3 Low 261G1-LPBK 261G1
Open 20 to 16
0.52 to 1.3 High 269G2-LPBK 269G2
Open 20 to 16
0.52 to 1.3 Low 262G1-LPBK 262G1
Open 20 to 16 SF* 0.52 to 1.5 Low 200G2L-LPBK 200G2L
Tin or silver plated contacts are rated for ground or power. Hand crimp tools are
available for loose piece contacts. Reeled contacts can be used with high volume
press and applicator crimp tooling. Tin contacts are rated for up to 1,500 mating
cycles. Silver contacts are rated up to 10,000 mating cycles.
Reeled
Mating
Loose Piece
Part
Type
AWG
mm²
Force - Part Numbers - - Numbers Minimum Quantity .............................................
200
5,000 .....
Open, Tin
14 to 10 2.1 to 6.0 Low
1830G1-LPBK
1830G1
Open, Silver 14 to 10 2.1 to 6.0 Low
1830G2-LPBK
1830G2
PP15-45 Silver Plated Power Contacts
Maximize performance by offering up to 10,000 mating cycles and are recommended
for circuit interrupt or hot plug applications. See specifications and temperature charts
for amperage ratings by wire size. Only closed barrel contacts are suitable for soldering.
Mating
Loose Piece
Reeled
Barrel AWG
mm²
Force ------------- Part Numbers -------------Minimum Quantity ....................................... 5,000
200
5,000 ..
Open 14 to 10 K* 2.1 to 5.3 Low
261G3-LPBK 261G3
201G3H
200G3L-LPBK 200G3L
Open 16 to 12
1.3 to 3.3 Low
261G4-LPBK 261G4
Open 20 to 16
0.52 to 1.3 Low
262G2-LPBK 262G2
200G4L
Closed 16 to 12
1.3 to 3.3 Low 1331-BK 1331
Closed 20 to 16
0.52 to 1.3 Low 1332-BK 1332
Accessories
Description
- Part Numbers Minimum Quantity ...
25
Float Mount Kit
110G69
Fixed Mount Kit
103G40
K* - For #10 AWG class K stranded wire or smaller. For larger wires use
superflex contacts.
SF*- Indicates wires with high stranding such as Super Flex.
| SPECIFICATIONS |
Current Rating (Amperes)
#10 AWG = 29A @ 30º rise
#12 AWG = 24A @ 30º rise
#18 AWG = 14A @ 30º rise
Voltage Rating (AC/DC)
600V AC/DC per UL1977
150V DC per EN1175-1
35
Contact Barrel Wire Size (AWG) 10 to 20
(mm²) 4 to 0.5
Average Contact Resistance
MARC Connector
Temperature Rise at Constant Current
40
Temperature (°C)
Electrical
| TEMPERATURE CHART |
15A contact = 875 x 106 ohms
30A contact = 600 x 106 ohms
45A contact = 525 x 106 ohms
30
25
10
5
Mechanical
Contact Retention Force (lbf) 25
(N) 111
18 AWG
Maximum Wire Insulation Diameter (inches)
0.175
(mm) 4.45
No Load (mating cycles)
Up to 10,000
Average Disconnect Force -Fully Loaded (lbf)
18
(N) 80
Operating Temperature Range (°C)
(°F)
10
15
Amperes Applied
12 AWG
30
35
10 AWG
Materials
Flammability Rating of Housing Material PBT UL94 V-0
-40° to 125°
-40° to 257°
| TOOLING INFORMATION |
W ire Size
Loose Piece Part Numbers
Tin
Plating
AWG
mm²
16 / 20
12 / 16
16 / 20
16 / 20
16 / 20
12 / 16
10 / 14
12 / 16
10 / 14
10 / 14
10 / 14
10 / 14
1.3 / 0.52
L o o s e Pie c e Co n t act C rimp Tool
Pneumatic
Hand
Bench
Tool or
Tool
+ Die
Silver
Plating
Reeled Part Numbers
Number
+ Locator of Crimps
Tin
Plating
Silver
Plating
Reeled Contact Crimp Tools
ATS
Applicator
ATS
Press
Air Feed
Kit*
PP15 / 45 Flat Wiping Power & Ground
N/A
1332
N/A
3.3 / 1.3
1331
1.3 / 0.52 262G1-LPBK 262G2-LPBK
1.5 / 0.52 200G2L-LPBK 200G4L-LPBK
1.3 / 0.52 269G2-LPBK
N/A
3.3 / 1.3 261G1-LPBK 261G4-LPBK
5.3 / 2.1 261G2-LPBK 261G3-LPBK
3.3 / 1.3 269G1-LPBK
N/A
5.3 / 2.1 269G3-LPBK
N/A
6.0 / 2.1 200G1L-LPBK 200G3L-LPBK
6.0 / 2.1 201G1H-LPBK 201G3H-LPBK
6.0 / 2.1 1830G1-LPBK 1830G2-LPBK
1309G2
or
1309G8
1367G1
N/A
N/A
N/A
262G1
200G2L
269G2
261G1
261G2
269G1
269G3
200G1L
201G1H
1830G1
262G2
200G4L
N/A
261G4
261G3
N/A
N/A
200G3L
201G3H
1830G2
1309G3
or
1309G8
N/A
N/A
Single
1309G6
or
1309G8
N/A
N/A
N/A
1385519-1
TBD
1385519-1
1385520-1 1725900-2 1424266-1
1385458-1
or
or
1385520-1
[354500-1] [354578-1]
1385458-1
1385460-1
1385460-1
1385460-1
* All ATS applicators for APP® contacts are air feed style and require the press to have an air feed kit installed.
NOTE: See website for the most current information.
| DIMENSIONS |
Top View
Side View
LOCATION FOR
OPTIONAL FLAT-WIPING
GROUND CONTACTS
Mounted View
[ 27.2 ]
1.07
[ 26.9 ]
1.06
PANEL
FLAT
WASHERS (2)
[ 62.0 ]
2.44 [ 74.4 ]
2.93
Layout For
Panel Cut-Outs
PLASTIC SHOULDER WASHERS (2)
MACHINE SCREWS (4)
FLOAT-MOUNTED SIDE
PANEL
HEX NUTS (4)
[ 60.96 ]
2.400
A
B
[ 6.60 ]
Ø 0.260
All Data Subject To Change Without Notice
C
D
LOCK
WASHERS (4)
[ 19.3 ]
.76
RIGID-MOUNTED SIDE
[ 30.48 ]
1.200
Mounting
-AHardware mm
in.
-Bmm
in.
-Cmm
in.
-Dmm
in.
Float
Fixed
25.78
22.23
22.29
20.51
44.58 1.755
41.02 1.615
12.89
11.11
0.508
0.438
1.015
0.875
“APP & Anderson Power Products are registered trademarks of Anderson Power Products”
0.878
0.808
15406
DS-MARC REV 05
HEADQUARTERS: Anderson Power Products®, 13 Pratts Junction Road, Sterling, MA 01564-2305 USA T:978-422-3600 F:978-422-0128
EUROPE: Anderson Power Products® Ltd., Unit 3, Europa Court, Europa Boulevard, Westbrook, Warrington, Cheshire, WA5 7TN United Kingdom T: +44 (0) 1925 428390 F: +44 (0) 1925 520203
ASIA / PACIFIC: IDEAL Anderson Asia Pacific Ltd., Unit 922-928 Topsail Plaza, 11 On Sum Street, Shatin N.T., Hong Kong T:+(852) 2636 0836 F:+(852) 2635 9036
CHINA: IDEAL Anderson Technologies (Shenzhen) Ltd., Block A8 Tantou Western Industrial Park, Songgang Baoan District, Shenzhen, PR. China 518105 T: +(86) 755 2768 2118 F: +(86) 755 2768 2218
TAIWAN: IDEAL Anderson Asia Pacific Ltd., Taiwan Branch, 4F.-2, No.116, Dadun 20th St., Situn District, Taichung City 407, Taiwan (R.O.C.) T: +(886) 4 2310 6451 F:+(886) 4 2310 6460
www.andersonpower.com
很抱歉,暂时无法提供与“201G1H-LPBK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12.895891+1.65191
