R E V I S I O N
NOTES: UNLESS OTHERWISE SPECIFIED
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
REV.
DRAWN BY
DATE
APPR.
A
M BOYER
PRELIMINARY RELEASE
2014-May-02
D.C.
B
M BOYER
REDUCE HEIGHT OF HATCH LIP
2014-May-16
D.C.
C
M BOYER
INCREASE HEIGHT OF COVER .102
2014-Oct-07
D.C.
D
M BOYER
ADD .039" BOARD OPTION
2014-Oct-21
D.C.
E
M BOYER
CLOSE UP BEAUTY RING AND ADD DRAWING DETAILS
2014-Dec-01
D.C.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH,
EQUIVELANT TO MT-11010. APPEARANCE AND DEPTH OF TEXTURE
VARIES OVER TIME DUE TO WEAR.
3. INTERIOR SURFACE TEXTURE TO BE: AS MOLDED.
4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE
LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED
BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS
ECO No
DESCRIPTION
1.0
R CRUZ
0469
UPDATE TO AS-BUILT AND RELEASE
2015-Sep-03
D.C.
2.0
M BOYER
02016
INCLUDE WALL CRADLE
2016-Mar-21
D.C.
3.0
R CRUZ
05416
UPDATE NOTES 2 AND 3
2016-Dec-20
D.C.
4.0
M BOYER
01417
INCREASE LEAD-IN ON HATCH LATCH
2017-May-11
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
2
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION
OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER.
9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED.
5
10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
11. ALLOWABLE FLASH: 0.005 MAX.
SHOWN WITH BOTH PCB
CHOOSE ONE
12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH,
PROTRUDING OR BELOW FLUSH.
6
13. TRIM GATE WITHIN 0.015" OF FLUSH.
1
9
10
361413(x) CONFIGURATIONS
-[BLANK]
361413 COVER
1
361413 BASE
1
361413 BASE w/ WALL NOTCHES
361413 BATTERY HATCH
1
361413 WALL CRADLE
#4 HiLo SCREW .375"
4
-K
1
1
1
1
4
11
-W
7
3
1
12
AA-SINGL-CONTACT-POS
ACC-AAPOS-5223
SPRING STEEL
SOLD SEPARATELY
1
11
AA-SINGL-CONTACT-NEG
ACC-AANEG-5201
SPRING STEEL
SOLD SEPARATELY
1
10
AA-DBL-CONTACT
ACC-AADBL-5212
SPRING STEEL
SOLD SEPARATELY
1
9
SCREW_HILO-NO4X375
#4 HiLo x .375" SCREW
ZINK PLATED
INCLUDED
4
8
SCREW-DRYWALLX750
DRYWALL SCREW
REFERENCE ONLY
CUSTOMER SUPPLIED
2
7
BATTERY_AA
"AA" SIZE BATTERY
REFERENCE
CUSTOMER SUPPLIED
2
6
361413-PCB_039
361413 .039" PCB - REFERENCE
1 MM THICK
CUSTOMER SUPPLIED
1
5
361413-PCB_062
361413 .062" PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
4
361413-WALL
361413 WALL CRADLE - STANDARD
ABS
BLACK or WHITE
1
3
361413-HATCH
361413 HATCH - STANDARD
ABS
BLACK or WHITE
1
2
361413-COVER
361413 COVER - STANDARD
ABS
BLACK or WHITE
1
1
361413-BASE
361413 BASE - STANDARD
ABS
BLACK or WHITE
1
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
12
BILL OF MATERIALS
361413 EXPLODED VIEW
SCALE 0.750
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
4
8
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2017
Customer's Part No:
APPROVAL
BY
361413
2240 South Thornburg Street
ph. (805) 595-1310
COMPACT AA - STANDARD
SXX-361413X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2014-May-02
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
361413_R4_0
SHEET
1 OF 8
REV.DOC
4.0
361413 ASSEMBLY
.350 CLEAR
.867
(.020)
1.317
.430
.555
1.440
SECTION D-D
D
3.600
R.200
SCALE 1.000
D
SECTION P-P
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
361413
ph. (805) 595-1310
SXX-361413X-XXX
DATE
CHECK
ENG.
3.0°
R.200
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2014-May-02
fax (805) 595-1024
A
DRAWING NAME
361413_R4_0
SHEET
2 OF 8
REV.DOC
4.0
361413 COVER
.035 CHAMFER
.070 NOMINAL
THICKNESS
.070 CHAMFER
x 45° BOTH ENDS
.880
3.0°
L
.150
.040
.100 CENTER
THICKNESS
3.600
2.760
3.531
W
W
.050
.082
.035 CHAMFER
x 43.5° BOTH ENDS
R.200
L
.219
SECTION L-L
SCALE 1.000
.495
.034
1.371
1.440
X.XXX = .010
X.X° = 1°
.065
DETAIL A
SCALE 4.000
SECTION W-W
SEE DETAIL A
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
5.0°
BY
361413
ph. (805) 595-1310
SXX-361413X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2014-May-02
fax (805) 595-1024
A
DRAWING NAME
361413_R4_0
SHEET
3 OF 8
REV.DOC
4.0
.006
.033
DETAIL E
SCALE 3.000
.867
.190
.022
.239
SEE DETAIL D
R.200
X
SEE DETAIL G
P
P
SEE DETAIL E
.065
3.600
SCALE 1.000
.000
.700
.625
DETAIL G
SCALE 2.000
.017
361413 BASE
1.440
WALL MOUNTING HOLES
NOT PRESENT UNLESS
WALL CRADLE IS ORDERED.
SECTION X-X
.880
2.026
2.760
SECTION P-P
X
.409
.045
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
361413
ph. (805) 595-1310
SXX-361413X-XXX
DATE
CHECK
ENG.
.467
DETAIL D
SCALE 2.000
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2014-May-02
fax (805) 595-1024
A
DRAWING NAME
361413_R4_0
SHEET
4 OF 8
REV.DOC
4.0
361413 HATCH
.332
.010
SEE DETAIL F
.015
DETAIL F
SCALE 6.000
SEE DETAIL B
X
BEAUTY RING
.338
.400
.035
Y
.050
Y
.150
R.050
SCALE 1.000
X
.048
SEE DETAIL C
SECTION X-X
1.386
.141
.020
.070
5.0°
R.200
.370
.100
X.XXX = .010
X.X° = 1°
.0670
.090
NEW AGE ENCLOSURES
.070
Customer's Part No:
APPROVAL
BY
361413
ph. (805) 595-1310
SXX-361413X-XXX
DATE
CHECK
DETAIL B
SCALE 2.000
SECTION Y-Y
.055
DETAIL C
SCALE 3.000
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2014-May-02
fax (805) 595-1024
A
DRAWING NAME
361413_R4_0
SHEET
5 OF 8
REV.DOC
4.0
361413 PCB - CUSTOMER SUPPLIED
SIZES AND VERIFICATION OF ITS FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
.630
.290 2x
.440 2x
.000
.440 2x
.290 2x
.630
1.260
.039
.062
1.710
1.380 2x
.062
1.091 2x
.200
.650 2x
.055
3.420
.000
.030
R.125
.650 2x
.194 4x
.244 4x
1.0910 2x
1.380 2x
1.710
SCALE 1.000
.050 CHAMFER x 45° 4x
SCALE 1.000
.320 x 4 PLACES
KEEP OUT ZONES
.320 x 4 PLACES
KEEP OUT ZONES
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
THIS ENCLOSURE CAN ACCOMODATE
EITHER PCB THICKNESS
Customer's Part No:
APPROVAL
BY
361413
ph. (805) 595-1310
SXX-361413X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2014-May-02
fax (805) 595-1024
A
DRAWING NAME
361413_R4_0
SHEET
6 OF 8
REV.DOC
4.0
361413 - 2nd OPERATION DETAILS - 1 of 2
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
1.398
X
.627
.625
STEP 2
3.851
2.500
361413 BASE
W/ WALL NOTCHES
SCALE 1.000
.627
STEP 1
.70
(.242)
.27
SECTION X-X
X
.625
.085
361413 WALL CRADLE
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
SXX-361413K-XXX
BASE
STEP NO
DESCRIPTION
CUTTER
1-C-C1
2-C-C2
WALL NOTCHES
WALL NOTCHES
T2 = .062" EM
T2 = .062" EM
ABS, BLACK
Customer's Part No:
APPROVAL
FIXTURE
ORIENTATION
PROGRAM
332
332
SINGLE
SINGLE
o1401
o1401
BY
361413
ph. (805) 595-1310
SXX-361413X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2014-May-02
fax (805) 595-1024
A
DRAWING NAME
361413_R4_0
SHEET
7 OF 8
REV.DOC
4.0
361413 - 2nd OPERATION DETAILS - 2 OF 2
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
SXX-361413-XXX
COVER
ABS, BLACK
Customer's Part No:
APPROVAL
STEP NO
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
PROGRAM
1-C-C1
2-C-C2
T2 = .062" EM
T2 = .062" EM
349
349
SINGLE
BY
361413
ph. (805) 595-1310
SXX-361413X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2014-May-02
fax (805) 595-1024
A
DRAWING NAME
361413_R4_0
SHEET
8 OF 8
REV.DOC
4.0
很抱歉,暂时无法提供与“S3A-361413”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+81.830811+10.59371
- 5+69.984385+9.06009
- 10+65.4262610+8.47000
- 25+59.8362125+7.74632
- 50+55.9262950+7.24015
- 100+52.27307100+6.76720
- 250+47.80660250+6.18898
- 500+46.20482500+5.98162
