COM-09426
COM-09426
    SPARKFUNELECTRONICS
    拇指滑动式操纵杆
COM-09426 数据手册
      Thumb Slide Joystick COM-09426 RoHS In Eagle Library Description: This is a resistive analog joystick, very similar to those found on the PSP1000. These compact joysticks are different in that they have a very interesting ‘slide’ feeling. For wiring this part, if you look at the device from the bottom the pin out goes     1) x-axis output 2) +5V 3) y-axis output 4) gnd Pin 4 is the pin closest to the 2 mounting tabs found on one side of the device. When connected to an Arduino, you can expect a range of about 128 to 775 on each axis. The rubber thumb pad is removable if you desire. The pads are spaced by 2mm, but it is possible to get our 2.54mm headers connected with a bit of bending.                                                             https://www.sparkfun.com/products/9426 8‐4‐17
COM-09426 价格&库存
很抱歉,暂时无法提供与“COM-09426”相匹配的价格&库存,您可以联系我们找货
