1382-BK
1382-BK
    ANDERSON
    1382-BK
1382-BK 数据手册
SPEC Pak ® Sealed Power For Environmental Connections Marine | Machine Tool Wind Power | | Lighting Industrial Automation | | Transportation Motor | | Pumps Solar Power | | Ground Support Harsh Environments ® Anderson Power Products ® Rugged and Sealed (IP68) Plugs and Receptacles For Use with APP® Powerpole® Signal, Power & Ground Contacts & Housings The SPEC Pak® High Power uses rugged and environmentally sealed (IP68) shells to protect APP® Powerpole® contacts and housings. Customer configured SPEC Pak® High Power Connectors are capable of up to 260 amps and may be used anywhere a rugged and/or waterproof high power, signal and ground interconnect solution is required. The SPEC Pak® High Power shell accepts 75 to 180 amp Powerpole® contacts and up to 8 auxiliary contacts. The wide range of Powerpole® housing colors and contact sizes, coupled with the available Powerpole® insert holders, offers the user a wide array of design options. Wire sizes which can accommodate a range from 24 to 3/0 AWG (0.25 to 85.0 mm²). SPEC Pak® High Power is highly configurable with thousands of design options in a single interconnect. 1 2 3 4 8 5 5 Powerpole® Insert Arrangement H02 H03 1 - Chemical & UV Resistant Ruggedized Shells • Wire to Wire Configurations • Wire to Panel Configurations 2 - Stainless Steel Latches (securing plug to receptacle) 3 - IP68 Interfacial Sealing O-Ring 4 - Auxiliary Contacts (up to 8) 5 - Powerpole® Insert Holders (user configurable) 6 7 • H02 Arrangement - up to two PP180 & 8 Auxiliaries • H03 Arrangement - up to three PP120 & 8 Auxiliaries • H06 Arrangement - up to six PP75 & 8 Auxiliaries - 2 - | www.andersonpower.com H06 6 - Power Contacts (up to 260 amps with 3/0 AWG) 7- Color Coded Powerpole® Housings Match Wire Colors 8 - Industry Standard Sealing (IP68) Components • PG Gland Compatible - Size 36 & 42 • Multi Hole Glands For Use With Discrete Wires • Single Hole Glands For Use With Jacketed Cable Specifications High Power SPEC Pak® Shell / Components Electrical UL Voltage Rating (AC/DC) Dielectric Withstanding Voltage (AC) Operating Temperature (°C ) [1] (°F ) Flammability Rating of SPEC Pak® Shells UV Rating (equivalent) 600 3000 -40 to 105 -40 to 221 UL94 V-0 UL746C F1 Inline Receptacle Latch Plug Mechanical Shell/Latch Mating Cycles 1,500 Min. Average Connect/Disconnect (lbf) 28 (N) 125 IP Rating IP68 UL50E Sealing Requirement Pass Crush Test per EIA-364-40B Pass Mated pair Drop Test per UL50E Pass High Power Plug To PG Gland Inline Receptacle Material SPEC Pak® - Receptacle, Plug & Holders Latch Latch Retainer Holder Mount Hardware PBT Stainless Steel Stainless Steel Nickel Plated Steel Powerpole® Contacts PP180 UL Current Rating (Amperes) [2] CSA (30C Rise) (Amperes) [2] Voltage Rating (AC/DC) Contact Barrel Wire Size (AWG) (mm²) Average Contact Resistance (milliohm) Contact Retention Force (lbf) (N) Operating Temperature (°C) [1] (°F) Flammability Rating Contact Materials Contact Plating 260 190 70 5 140 100 40 5 600 600 600 600 3/0 to 6 1/0 to 6 6 to 12 12 to 24 85 to 13.3 53.5 to 13.3 13.3 to 3.3 4.0 to 0.25 0.10 0.14 0.20 3.00 170 100 50 8 756 445 222 36 -20 to 105 -20 to 105 -20 to 105 -20 to 105 -4 to 221 -4 to 221 -4 to 221 -4 to 221 UL94 V-0 UL94 V-0 UL94 V-0 UL94 V-0 Copper Copper Copper Copper Alloy Silver Silver Silver Gold over Nickel PP120 PP75 PowerMod® Mechanical Mating Cycles - no load [3] 10,000 10,000 10,000 10,000 Average Connect/Disconnect (lbf) 20 8 5 (Low Detent) 10 oz. (3N) Average 7 (High Detent) Material Powerpole® Housing Material Polycarbonate Polycarbonate Polycarbonate PBT NOTE: [1] -40° to 105° C (-40° to 221° F) can be achieved by using APP Chemical Resistant Powerpole® housing. Contact factory for more information. [2] Based on Panel Mount Receptacle to Plug configuration. [3] Based on silver plated contacts. For other industry tests and/or agency approvals, contact customer service. www.andersonpower.com | -3- Product Selection Guide SPEC Pak® High Power Series is a highly configurable environmentally sealed connector, that can be purchased as components in bulk for volume production, or pre-packaged as a kit. For your convenience, follow the steps below to determine the component or kit part number. | COMPONENT PART NUMBER GUIDE (FOR COMPONENT BULK PURCHASE) | Step 1: Select Shell Step 2: Select Wire Protection Plug Inline Receptacle * Define: Number of Wires Wires - Discrete ______________ - Bundled ______________ Wire OD _____________ _____________ * Select PG Gland size PG36 ________ PG42 ________ * Select wire protection that will accommodate the number of wires and outer diameter (OD) of the wire used in your application, from page 7. Panel Mount Receptacle * Select shell kit for use with PG36 _____ or PG42 _____ from page 6. * Wire protection is required for use with Inline Receptacles and Plugs to obtain IP68 seal. List Component Part Numbers Here: | KIT PART NUMBER GUIDE (FOR KITTED CONNECTOR PURCHASE) | Step 1 - (see page 6) ............................................................................................. Shell ........................................................................................ SPEC Pak® Series Shell Color Shell Style Shell Size Insert Arrangement (Select One) Dash (Select One) (Select One) S K 1 = Inline Receptacle 2 = Panel Mount Receptacle 6 = Plug 9 = Receptacle Cover 9P = Plug Cover List Kit Part Number Here: - 4 - | www.andersonpower.com 095 = 095mm Panel Mount Receptacle Shell A95 = 095mm Inline Receptacle or Plug Shell, PG 36 B95 = 095mm Inline Receptacle or Plug Shell, PG 42 H02, PP180, 2 Pole H03, PP120, 3 Pole H06, PP75, 6 Pole Step 3: Select Housing Arrangement Step 4: Select Contacts Pin Auxiliary Contact Power Contact * Define: Number of Wires Housing Arrangement - AC ___________ - DC ___________ - Other ___________ Number of Auxiliaries ____________ ____________ ____________ * Select housing arrangement colors appropriate for your AC or DC application, from page 8, 9 or 10. Socket Auxiliary Contact * Define: Number of Wire Gauge Wire Gauge Contacts - Power ____________________ _______________ - Auxiliary ____________________ _______________ - Other ____________________ _______________ Amps (continuous): ____ Max amps at ____ volts * Select power and/or auxiliary contacts appropriate for your wire size (AWG or mm²), from page 8, 9 or 10. List Component Part Numbers Here: Step 3 - Select Housing Step 2 - Wire Protection Arrangement (Style) Step 4 - Select Contacts Custom .................... Wire Protection .................... .. Housing Arrangement .. ........... Contacts ........... .... APP Content .... Number of Holes Cable Sealing Range (Select Two) Dash (Select One) (Select One) Dash 00 = None PS = Plastic Single Hole PM = Plastic Multi Hole Contact Wire Size Code Contact AWG (mm²) Insert 00 = Custom Configuration Arrangement 11 = 5900 #6 13.3 H06 12 = 5952 #8 8.4 H06 13 = 5915 #10/12 5.3/3.3 H06 #6 #8 #10/12 13.3 8.4 5.3/3.3 0 = Custom Configuration A = AC Single Phase B = AC 3 Phase, 3 Wire E = AC 3 Phase, 4 wire F = AC 3 phase, 5 wire G = DC 2 Circuit, 6 wire R = DC 1 Circuit, 2 Wire Z = All Black 00 = None “01 to 99 = Various Gland Types From Page 7 With Auxiliary [1] 14 = 5900 15 = 5952 16 = 5915 H06 H06 H06 Contact Code Contact 20 = 1323G2 21 = 1323G1 22 = 1319 23 = 1319G4 24 = 1319G6 With Auxiliary [1] 25 = 1323G2 26 = 1323G1 27 = 1319 28 = 1319G4 29 = 1319G6 - Contact the factory Custom Configuration Insert Arrangement H03 H06 H06 H06 H06 Contact Wire Size Insert H02, H03 Code Contact AWG (mm²) Arrangement H02, H03, H06 80 = 1328G2 3/0 85.0 H02 81 = 1328G1 2/0 67.4 H02 Wire Size Insert 82 = 1382 1/0 53.5 H02 AWG (mm²) Arrangement 83 = 1347 #1 42.4 H02 1/0 53.5 H03 84 = 1383 #2 33.6 H02 #1 42.4 H03 85 = 1384 #4 21.2 H02 #2 33.6 H03 86 = 1348 #6 13.3 H02 #4 21.2 H03 #6 13.3 H03 With Auxiliary [1] 87 = 1328G2 3/0 85.0 H02 88 = 1328G1 2/0 67.4 H02 1/0 53.5 H03 89 = 1382 1/0 53.5 H02 #1 42.4 H03 90 = 1347 #1 42.4 H02 #2 33.6 H03 91 = 1383 #2 33.6 H02 #4 21.2 H03 92 = 1384 #4 21.2 H02 #6 13.3 H03 93 = 1348 #6 13.3 H02 NOTE: [1] Contact code designation #25 to 29 uses 4 each of PM16P12S30 (pins) & 4 each of part number PM16S12S32 (sockets) as signal. www.andersonpower.com | -5- | ORDERING INFORMATION | Step 1: Select Shell (Pick 1 Receptacle Shell Kit & Pick 1 Plug Shell Kit) Powerpole® Holder Set Panel Mount Receptacle Gasket Powerpole Holder Set ® Panel Mount Receptacle Shell With Latches Powerpole® Holder Set Inline Receptacle Shell With Latches Holder Retaining Screws Holder Retaining Screws Plug Shell Holder Retaining Screws Inline Receptacle Shell Kit (PG 36) Inline Receptacle Shell Kit (PG 42) Plug Shell Kit (PG 36) Plug Shell Kit (PG 42) Cover Kit PP75 Spacer & Key Component Replacement Parts Description - Part Numbers Minimum Quantity ..... 10 ..... Receptacle SK9-095 Plug SK9P-095 Description -------- Part Numbers -------Minimum Quantity ..... 1000 100 .... Red, short 1399G23-BK 1399G23 Red, long 1399G21-BK 1399G21 Description - Part Number Minimum Quantity ..... 1000 ....... #8 x 5/8 screws H1120P41 Panel Mount Receptacle Shell Kit Description -- Part Numbers -Minimum Quantity ....................... 10 ..... With 2 pole PP180 holders SK2-095H02 With 3 pole PP180 holders SK2-095H03 With 6 pole PP75 holders SK2-095H06 Description -- Part Numbers -Minimum Quantity ....................... 10 ..... PG 36, with 2 pole PP180 holder SK1-A95H02 PG 36, with 3 pole PP120 holder SK1-A95H03 PG 36, with 6 pole PP75 holder SK1-A95H06 Description -- Part Numbers -Minimum Quantity ....................... 10 ..... PG 36, with 2 pole PP180 holder SK6-A95H02 PG 36, with 3 pole PP120 holder SK6-A95H03 PG 36, with 6 pole PP75 holder SK6-A95H06 Description -- Part Numbers -Minimum Quantity ....................... 10 ..... PG 42, with 2 pole PP180 holder SK1-B95H02 PG 42, with 3 pole PP120 holder SK1-B95H03 PG 42, with 6 pole PP75 holder SK1-B95H06 Description -- Part Numbers -Minimum Quantity ....................... 10 ..... PG 42, with 2 pole PP180 holder SK6-B95H02 PG 42, with 3 pole PP120 holder SK6-B95H03 PG 42, with 6 pole PP75 holder SK6-B95H06 | ACCESSORIES | IP68 Sealing Plug Cover Lanyard IP68 Sealing Receptacle Cover - 6 - | www.andersonpower.com Short Long | SPECIFICATIONS | Material Shell Mechanical Nylon PA 66 (UL94 V-2) Gasket EPDM Color Black Torque Requirements Operating Temp -40°C to 105°C (-40°F to 221°F) Cable Gland Body to Plug Housing IP Rating IP68 - Hand tighten until snug, tighten additional 1/8 - 1/4 turn with wrench UV Rating Equivalent to UL746C F1 Thread Type PG Sealing Nut to Cable - Hand tighten until snug, tighten additional 1/2 - 3/4 turn with wrench | STRAIGHT PLASTIC SHORT THREAD TYPE - STD PACK 10 / UL LISTED | C1 Lock Nut Number of Holes Cable Range Wire Outer Dia. mm (in) PG Gland Size Thread O.D. C1 mm (in) Washer C1 Panel Mounting Hole mm (in) Body Thread Length C2 mm (in) Seal Wrench Size Lock Nut (mm) Sealing Nut Wrench Wire Protection Size Sealing Designation Nut (mm) (4 Characters) Minimum Quantity … -- Part Numbers -..... 10 1 26.5 - 21.0 (1.04 - 0.83) 36 47 (1.85) 47 - 47.4 (1.85 - 1.67) 15 (0.59) 57 52 PS04 PS1P36-26X 1 32.0 - 24.0 (1.26 - 0.94) 36 47 (1.85) 47 - 47.4 (1.85 - 1.67) 15 (0.59) 57 52 PS05 PS1P36-32X PL1P42-19X ..... 1 19.5 - 16.0 (0.77 - 0.63) 42 54 (2.13) 54 - 54.4 (2.13 - 2.14) 15.5 (0.61) 64 62 PS01 1 32.0 - 26.0 (1.26 - 0.79) 42 54 (2.13) 54 - 54.4 (2.13 - 2.14) 15.5 (0.61) 64 62 PS02 PS1P42-32X 1 41.0 - 31.0 (1.61 - 1.22) 42 54 (2.13) 54 - 54.4 (2.13 - 2.14) 15.5 (0.61) 64 62 PS03 PS1P42-41X | STRAIGHT PLASTIC MULTI-HOLE TYPE - STD PACK 10 / NOT UL LISTED | C1 Lock Nut Washer C1 Body Seal Claw Sealing Nut Number of Holes Cable Range Wire Outer Dia. mm (in) PG Gland Size Thread O.D. C1 mm (in) Panel Mounting Hole mm (in) Thread Length C2 mm (in) Wrench Size Lock Nut (mm) Wrench Wire Protection Size Sealing Designation Nut (mm) (4 Characters) 2 2 3 3 4 5 13.0 - 11.0 (0.51 - 0.43) 9.0 - 7.0 (0.35 - 0.28) 7.8 - 6.5 (0.31 - 0.26) 10 - 7.7 (0.39 - 0.30) 12.0 - 10.0 (0.48 - 0.39) 8.3 - 6.5 (0.33 - 0.26) 36 36 36 36 36 36 47 (1.85) 47 (1.85) 47 (1.85) 47 (1.85) 47 (1.85) 47 (1.85) 47 - 47.4 (1.85 - 1.67) 47 - 47.4 (1.85 - 1.67) 47 - 47.4 (1.85 - 1.67) 47 - 47.4 (1.85 - 1.67) 47 - 47.4 (1.85 - 1.67) 47 - 47.4 (1.85 - 1.67) 15 (0.59) 15 (0.59) 15 (0.59) 15 (0.59) 15 (0.59) 15 (0.59) 57 57 57 57 57 57 Minimum Quantity … 52 52 52 52 52 52 PM21 PM22 PM31 PM32 PM41 PM51 10 ..... PS2P36-13X PS2P36-9X PS3P36-7X PS3P36-10X PS4P36-12X PS5P36-8X 4 6 8 10.5 - 8.5 (0.41 - 0.33) 7.0 - 5.0 (0.28 - 0.20) 7.0 - 5.7 (0.28 - 0.22) 42 42 42 54 (2.13) 54 (2.13) 54 (2.13) 54 - 54.4 (2.13 - 2.14) 54 - 54.4 (2.13 - 2.14) 54 - 54.4 (2.13 - 2.14) 15.5 (0.61) 15.5 (0.61) 15.5 (0.61) 64 64 64 62 62 62 PM46 PM66 PM86 PL4P42-10X PL6P42-7X PL8P42-7X -- Part Numbers -..... NOTE: 1. Other PG Gland configurations and specifications are available, please contact the factory. 2. Only UL listed cable glands are UL recognized components when used with SPEC Pak® connector(s). 3. Shading indicates stock item. www.andersonpower.com | -7- H02 Housing Arrangement Configured with up to 2 PP180 Contacts - Up to 260 Amps - Standard & Custom Configuration Options | HOUSING ARRANGEMENTS | 0 | POWERPOLE® INSERT HOLDER | Custom Configuration DC 1 Circuit, 2 Wire R 1381G1 1381G3 All Black Z 1381G1 1381G1 H02 NOTE: 1. For custom configuration, contact the factory. 2. Arrangement represents front view of the receptacle. | POWERPOLE® CONTACTS & HOUSINGS FOR H02 INSERT ARRANGEMENT | PP180 Contacts Mating AWG mm² Force ---------- Loose Piece Part Numbers ----------- Minimum Quantity ........ 500 300 250 50 .... 3/0 85 Low - - 1328G2-BK 1328G2 2/0 67.4 Low - 1328G1-BK - 1328G1 1/0 53.5 High 1382-BK - - 1382 1 42.4 High 1347-BK - - 1347 2 33.6 High 1383-BK - - 1383 4 21.1 High 1384-BK - - 1384 6 13.3 High 1348-BK - - 1348 Contact Code Designation ....................... 80 81 82 83 84 85 86 PP180 Housings Description ------- Part Numbers ------Minimum Quantity ... 250 50 ....... Red 1381G3-BK 1381G3 Green 1381G4-BK 1381G4 Black 1381G1-BK 1381G1 White 1381G2-BK 1381G2 Blue 1381-BK 1381 Auxiliary Contacts (PowerMod® series) Contact Code Type AWG mm² Minimum Quantity….................. ---------------- Part Numbers --------------- 500 50 ..... Standard Length 7.7mm Pin 24 to 20 0.50 to 0.75 PM16P2024S30 PM16P2024S30-50 Pin 20 to 18 0.75 to 1.00 PM16P1620S30 PM16P1620S30-50 Pin 16 to 14 1.00 to 1.5 PM16P1416S30 PM16P1416S30-50 Pin 12 2.50 PM16P12S30 PM16P12S30-50 Pre-Mate 9.3mm Pin 24 to 20 0.50 to 0.75 PM16P2024A30 PM16P2024A30-50 Pin 20 to 18 0.75 to 1.00 PM16P1620A30 PM16P1620A30-50 Pin 16 to 14 1.00 to 1.5 PM16P1416A30 PM16P1416A30-50 Pin 12 2.50 PM16P12A30 PM16P12A30-50 Post-Mate 6.4mm Pin 24 to 20 0.50 to 0.75 PM16P2024C30 PM16P2024C30-50 Pin 20 to 18 0.75 to 1.00 PM16P1620C30 PM16P1620C30-50 Pin 16 to 14 1.00 to 1.5 PM16P1416C30 PM16P1416C30-50 Pin 12 2.50 PM16P12C30 PM16P12C30-50 --------------------------------------------------------------------------------------------------------Socket 24 to 20 0.25 to 0.50 PM16S2024S32 PM16S2024S32-50 Socket 20 to 16 0.50 to 1.30 PM16S1620S32 PM16S1620S32-50 Socket 16 to 14 1.30 to 2.10 PM16S1416S32 PM16S1416S32-50 Socket 12 2.5 PM16S12S32 PM16S12S32-50 Designation ..................... 87 thru 93 87 thru 93 NOTE: 1. Contact code designation #87 to 93 is 4 each of PM16P12S30 (pins) & 4 each of part number PM16S12S32 (sockets) as signal. 2. See Powerpole® & Multipole Power Connectors Catalog for additional contacts and/or housings options. 3. Application tooling information is available on page 11. - 8 - | www.andersonpower.com H03 Housing Arrangement Configured with up to 3 PP120 Contacts - Up to 190 Amps - Standard & Custom Configuration Options | HOUSING ARRANGEMENTS | 0 | POWERPOLE® INSERT HOLDER | Custom Configuration AC Single Phase A 1321G1 1321G2 1321G4 DC 1 Circuit, 2 Wire R E 1321G3 1321G1 H03 All Black Z 1321G1 1321G1 1321G1 NOTE: 1. E = Empty 2. For custom configuration, contact the factory. 3. Arrangement represents front view of the receptacle. | POWERPOLE® CONTACTS & HOUSINGS FOR H03 INSERT ARRANGEMENT | PP120 Silver Plated Wire Contacts PP120 Housings Mating Contact Code AWG mm² Force -------- Loose Piece Part Numbers -------- Designation Description ------- Part Numbers ------Minimum Quantity ... 500 50 ....... Red 1321G3-BK 1321G3 Green 1321G4-BK 1321G4 Black 1321G1-BK 1321G1 White 1321G2-BK 1321G2 Blue 1321-BK 1321 Minimum Quantity ....... 600 500 1/0 53.5 Low 1323G2-BK - 1 42.4 Low 1323G1-BK - 2 33.6 High - 1319-BK 4 21.1 High - 1319G4-BK 6 13.3 Low - 6811G4-BK 50 ....... 1323G2 1323G1 1319 1319G4 6811G4 ....................... 20 21 22 23 24 Auxiliary Contacts (PowerMod® series) Contact Code Type AWG mm² Minimum Quantity….................. ---------------- Part Numbers --------------- 500 50 ..... Standard Length 7.7mm Pin 24 to 20 0.50 to 0.75 PM16P2024S30 PM16P2024S30-50 Pin 20 to 18 0.75 to 1.00 PM16P1620S30 PM16P1620S30-50 Pin 16 to 14 1.00 to 1.5 PM16P1416S30 PM16P1416S30-50 Pin 12 2.50 PM16P12S30 PM16P12S30-50 Pre-Mate 9.3mm Pin 24 to 20 0.50 to 0.75 PM16P2024A30 PM16P2024A30-50 Pin 20 to 18 0.75 to 1.00 PM16P1620A30 PM16P1620A30-50 Pin 16 to 14 1.00 to 1.5 PM16P1416A30 PM16P1416A30-50 Pin 12 2.50 PM16P12A30 PM16P12A30-50 Post-Mate 6.4mm Pin 24 to 20 0.50 to 0.75 PM16P2024C30 PM16P2024C30-50 Pin 20 to 18 0.75 to 1.00 PM16P1620C30 PM16P1620C30-5 Pin 16 to 14 1.00 to 1.5 PM16P1416C30 PM16P1416C30-50 Pin 12 2.50 PM16P12C30 PM16P12C30-50 --------------------------------------------------------------------------------------------------------Socket 24 to 20 0.25 to 0.50 PM16S2024S32 PM16S2024S32-50 Socket 20 to 16 0.50 to 1.30 PM16S1620S32 PM16S1620S32-50 Socket 16 to 14 1.30 to 2.10 PM16S1416S32 PM16S1416S32-50 Socket 12 2.5 PM16S12S32 PM16S12S32-50 Designation .................... 25 thru 29 25 thru 29 NOTE: 1. Contact code designation #25 to 29 uses 4 each of PM16P12S30 (pins) & 4 each of part number PM16S12S32 (sockets) as signal. 2. See Powerpole® & Multipole Power Connectors Catalog for additional contacts and/or housings options. 3. Application tooling information is available on page 11. www.andersonpower.com | -9- H06 Housing Arrangement Configured with up to 6 PP75 Contacts - Up to 75 Amps - Standard & Custom Configuration Options | HOUSING ARRANGEMENTS | | POWERPOLE® INSERT HOLDER | 0 Custom Configuration B AC 3 Phase, 3 Wire 5916G4 5916G5 5916G7 E 5916G6 E AC 3 Phase, 4 Wire E F 5916G4 5916 5916G5 5916G6 5916G7 E H06 AC3 Phase, 5 Wire 5916G4 5916G5 5916G7 5916 5916G6 5916 DC 2 Circuit, 6 Wire G 5916G4 5916G4 5916G4 5916G7 5916G7 5916G7 All Black 5916G4 5916G4 Z 5916G4 5916G4 5916G4 5916G4 NOTE: 1. E = Empty 2. For custom configuration, contact the factory. 3. Arrangement represents front view of the receptacle. | POWERPOLE® CONTACTS & HOUSINGS FOR H06 INSERT ARRANGEMENT | PP75 Contacts AWG mm² PP75 Standard Housings Mating Force Minimum Quantity ........................ 6 13.3 High 8 8.4 High 12 to 10 3.3 to 5.3 High Loose Piece -- Part Numbers -- Contact Code Designation 1,000 100 5900-BK 5900 5952-BK 5952 5915-BK 5915 ...................... 11 12 13 Description ------- Part Numbers -------Minimum Quantity ... 1,000 100 ..... Red 5916G7-BK 5916G7 Green 5916G6-BK 5916G6 Black 5916G4-BK 5916G4 White 5916G5-BK 5916G5 Blue 5916-BK 5916 Auxiliary Contacts (PowerMod® series) Type AWG mm² ----------------- Part Number ---------------- Contact Code Designation Minimum Quantity….................. .................... 500 50 ..... Standard Length 7.7mm Pin 24 to 20 0.50 to 0.75 PM16P2024S30 PM16P2024S30-50 - Pin 20 to 18 0.75 to 1.00 PM16P1620S30 PM16P1620S30-50 Pin 16 to 14 1.00 to 1.5 PM16P1416S30 PM16P1416S30-50 Pin 12 2.50 PM16P12S30 PM16P12S30-50 14 thru 16 Pre-Mate 9.3mm Pin 24 to 20 0.50 to 0.75 PM16P2024A30 PM16P2024A30-50 Pin 20 to 18 0.75 to 1.00 PM16P1620A30 PM16P1620A30-50 Pin 16 to 14 1.00 to 1.5 PM16P1416A30 PM16P1416A30-50 Pin 12 2.50 PM16P12A30 PM16P12A30-50 Post-Mate 6.4mm Pin 24 to 20 0.50 to 0.75 PM16P2024C30 PM16P2024C30-50 Pin 20 to 18 0.75 to 1.00 PM16P1620C30 PM16P1620C30-50 Pin 16 to 14 1.00 to 1.5 PM16P1416C30 PM16P1416C30-50 Pin 12 2.50 PM16P12C30 PM16P12C30-50 --------------------------------------------------------------------------------------------------------Socket 24 to 20 0.25 to 0.50 PM16S2024S32 PM16S2024S32-50 Socket 20 to 16 0.50 to 1.30 PM16S1620S32 PM16S1620S32-50 Socket 16 to 14 1.30 to 2.10 PM16S1416S32 PM16S1416S32-50 Socket 12 2.5 PM16S12S32 PM16S12S32-50 14 thru 16 NOTE: 1. Contact code designation #14 to 16 uses 4 each of PM16P12S30 (pins) & 4 each of part number PM16S12S32 (sockets) as signal. 2. See Powerpole® & Multipole Power Connectors Catalog for additional contacts and/or housings options. 3. Application tooling information is available on page 11. - 10 - | www.andersonpower.com Tooling W ire Size AWG Loose Piece Part Numbers Tin Plating mm² Silver Plating L o o s e P iece C ontact C rimp Tool Pneumatic Hand Bench Tool or Tool + Die Reeled Part Numbers Number + Locator of Crimps Tin Plating Silver Plating Reeled Contact Crimp Tools ATS Applicator ATS Press Air Feed Kit * PP75 #6 1307 13.3 #8 N/A 8.4 5952 1309G4 1389G6 1387G1 5953 #10 / 12 5.3 / 3.3 265G5 1388G6 5900 N/A Single 1388G7 5915 1385523-1 2-565435-2 692655-1 265G6 1385522-1 1725900-2 1424266-1 or or [3-54500-1] [354578-1] PP120 1/0 53.5 1323G2 #1 42.4 1323G1 #2 33.6 N/A 1319 #4 21.2 1319G4 #6 13.3 1319G6 3/0 85 1328G2 2/0 53.5 1328G1 1388G3 1368 1387G1 1389G4 Single N/A N/A N/A N/A 1388G4 PP180 1/0 53.5 #1 42.4 #2 33.6 1387G2 1347 1383 #4 21.1 1384 #6 13.3 1348 1304G32 Double 1389G3 Single 1303G13 1382 N/A 1303G12 1368 1387G1 1388G3 1387G2 1303G13 1304G32 Double 1387G1 Single 1388G3 1389G3 1387G2 1303G13 1304G32 Double 1387G1 Single 1388G4 1389G3 * All ATS applicators for APP® contacts are air feed style, (except 1385870) and require the press to have an air feed kit installed. NOTE: See website for the most current information. W ire Size AWG mm² Loose Piece Part Numbers Contacts Loose Piece C ontact C rimp Tool Pneumatic Bench Tool + Die + Locator Number of Crimps or Hand Tool PowerMod Auxiliary Contacts #12 / 24 2.5 / .25 All Crimp Pins All Crimp Sockets TP0001* N/A TL0001 TL0002 Single TM0001* PM1000G1 NOTE: See website for the most current information. * TP0001 and TM0001 tools require locators to properly position contacts. 1309 PM1000G1 TM0001 1387G2 1387G1 1368 TP0001 Die Locator www.andersonpower.com | - 11 - Dimensions | INLINE RECEPTACLE | Top View Side View Latch Range [ 0.55 ] 14.0 [ 155.2 ] 6.11 APPROXIMATE OVERALL LENGTH W/ GLAND X MM IN [ 3.57 ] 90.7 [ 127.0 ] 5.00 [ 6.11 ] 155.2 Shell with PG 36 200 Shell with PG 42 208 X 7.9 8.2 | PANEL MOUNT RECEPTACLE | Panel Cutout [ 2.94 ] 74.7 [ 0.22 ] Ø 5.6 TYP (8) C L [ 3.84 ] 97.5 Top View C L [ 1.7 ] 43.1 MAX PP180 [ 1.23 ] R31.2 TYP (2) Latch Range [ 0.55 ] 14.0 [ 2.94 ] 74.6 [ 4.49 ] 114.0 [ 3.50 ] 88.8 [ 1.80 ] 45.7 [ 0.71 ] 18.0 [ 3.30 ] 83.8 [ 1.50 ] 38.1 Side View [ 5.0 ] 127.0 [ 1.80 ] 45.7 | PLUG | Top View Side View [ 3.24 ] 82.3 [ 5.85 ] 148.6 APPROXIMATE OVERALL LENGTH W/ GLAND X MM IN [ 5.85 ] 148.6 Shell with PG 36 193 Shell with PG 42 201 X [ 3.95 ] 100.3 7.6 7.9 | MATED SIDE VIEW | Plug to Panel Mount receptacle Plug to Inline Receptacle [ 4.47 ] 114.0 [ 3.57 ] 90.7 X [ 1.7 ] 43.1 MAX PP180 X PANEL PLUG TO PANEL MOUNT RECEPTACLE X MM IN MM IN Shell with PG 36 114.0 Shell with PG 36 114.0 4.7 4.7 200.7 207.3 PLUG TO INLINE RECEPTACLE MM 7.90 8.16 Shell with PG 36 Shell with PG 36 | RECEPTACLE COVER | Front View [ 1.09 ] 27.6 REF [ 3.96 ] 100.7 MM X IN 3.57 354.1 13.94 3.57 370.3 14.58 | PLUG COVER | Side View [ 2.25 ] 57.15 90.7 90.7 IN [ 1.09 ] 27.6 REF [ 2.25 ] 57.15 Front View Side View [ 1.003 ] 24.48 [ 3.65 ] 92.7 [ 3.015 ] 76.58 [ 0.150 ] 3.81 [ 4.798 ] 121.88 [ 4.80 ] 121.88 All Data Subject To Change Without Notice “SPEC Pak, PowerMod, Powerpole, A, APP & Anderson Power Products are registered trademarks of Anderson Power Products”. 15411 DS-HPSPAK REV 01 HEADQUARTERS: Anderson Power Products®, 13 Pratts Junction Road, Sterling, MA 01564-2305 USA T:978-422-3600 F:978-422-0128 EUROPE: Anderson Power Products® Ltd., Unit 3, Europa Court, Europa Boulevard, Westbrook, Warrington, Cheshire, WA5 7TN United Kingdom T: +44 (0) 1925 428390 F: +44 (0) 1925 520203 ASIA / PACIFIC: IDEAL Anderson Asia Pacific Ltd., Unit 922-928 Topsail Plaza, 11 On Sum Street, Shatin N.T., Hong Kong T:+(852) 2636 0836 F:+(852) 2635 9036 CHINA: IDEAL Anderson Technologies (Shenzhen) Ltd., Block A8 Tantou Western Industrial Park, Songgang Baoan District, Shenzhen, PR. China 518105 T: +(86) 755 2768 2118 F: +(86) 755 2768 2218 TAIWAN: IDEAL Anderson Asia Pacific Ltd., Taiwan Branch, 4F.-2, No.116, Dadun 20th St., Situn District, Taichung City 407, Taiwan (R.O.C.) T: +(886) 4 2310 6451 F:+(886) 4 2310 6460 www.andersonpower.com
1382-BK 价格&库存
很抱歉,暂时无法提供与“1382-BK”相匹配的价格&库存,您可以联系我们找货
1382-BK
    库存:5157
